[Bug 2030] New: Export more shell functions
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 27 06:07:36 UTC 2012
I thought this use case involved passing a string to a shell method and it running the command after scanning the list of configured commands. I had no idea someone was using make args and calling a method directly.
If this is a valid use case, then we need to make all shell methods' main method public and make sure this is covered in the shell docs.
--joel
Chris Johns <chrisj at rtems.org> wrote:
>On 26/02/12 5:46 AM, Joel Sherrill wrote:
>> On my phone without code access but I think all shell command entry points can be static but the structure that is used by shellconfig.h must not be static.
>Why do they need to be static ?
>I can see cases where a user might dup stdout run the command and
>capture the output. I know Alan does this in the MMS project.
>I think we should keep the shell helper functions available and public.
>If we are missing decls for the functions we should add them.
>> Shell helper methods like make args and others to invoke a script or initialize the shell must be public.
>> The exception would be a case where you might invoke a shell commands main method directly and I don't know of these.
>> Or where one command wraps or uses another.
>> --joel
>> Gedare Bloom<gedare at rtems.org> wrote:
>>> Ralf,
>>> On Fri, Feb 24, 2012 at 4:36 PM,<bugzilla-daemon at rtems.org> wrote:
>>>> https://www.rtems.org/bugzilla/show_bug.cgi?id=2030
>>>> Bug #: 2030
>>>> Summary: Export more shell functions
>>>> Classification: Unclassified
>>>> Product: RTEMS
>>>> Version: HEAD
>>>> Platform: All
>>>> OS/Version: RTEMS
>>>> Status: NEW
>>>> Severity: normal
>>>> Priority: P3
>>>> Component: cpukit
>>>> AssignedTo: joel.sherrill at oarcorp.com
>>>> ReportedBy: sebastien at milkymist.org
>>>> Created attachment 1445
>>>> --> https://www.rtems.org/bugzilla/attachment.cgi?id=1445
>>>> patch
>>>> Export rtems_shell_init_env, rtems_shell_env_free, rtems_shell_main_mv,
>>>> rtems_shell_main_cp and rtems_shell_main_rm
>>> I think you changed these (at least the mv one) to be static recently.
>>> Is this change acceptable?
>>>> Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
>>>> ------- You are receiving this mail because: -------
>>>> You are watching all bug changes.
>>>> _______________________________________________
>>>> rtems-bugs mailing list
>>>> rtems-bugs at rtems.org
>>>> http://rtems.org/mailman/listinfo/rtems-bugs
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
