Interrupt gate in x86
Fered a_Fered at yahoo.com
Mon Jul 2 04:28:00 UTC 2012
Hi;
My question is about Interrupt Descriptor Table (IDT) initialization. RTEMS
initializes all descriptors as "Interrupt Gate". If you are familiar with x86
architecture, it have 3 gates for execution of handlers:
Interrupt gate, trap gate and task gate.
If we use "interrupt gate", processor clears IF flag, then all maskable
interrupts masked. If interrupts masked, then we have no interrupt at the
middle of execution of the handler. Then nested interrupting is disabled.
I saw "irq_asm.S" and as I said, "_ISR_Nest_level" increases before
dispatching of Interrupt handler. But I think if we use "Interrupt Gate" then
"_ISR_Nest_level" doesn't exceed one.
My question is "Is it true what I said about the variable?".
Thanks
you wrote:
> Have a look here wherever you've installed RTEMS --
> c/src/lib/libbsp/i386/shared/irq/irq_asm.S
> -- dc
> On Sun, Jul 1, 2012 at 7:26 AM, Fered <a_Fered at yahoo.com> wrote:
> > Nobody can help me?!
> > Fered wrote:
> >> Hi;
> >> In the following file:
> >> c/src/lib/libbsp/i386/shared/irq/idt.c
> >> in the following function:
> >> create_interrupt_gate_descriptor ()
> >> interrupt descriptor type, set to 0xe. It mean "Interrupt Gate" has been
> >> used. Interrupt gate clears IF flag then prevents nested interrupts. But
> >> I
> >> think nested interrupt handling implemented in RTEMS, according to usage
> >> of
> >> "_ISR_Nest_level" variable.
> >> Can anyone tell me how nesting implemented in interrupt handler of RTEMS?
> >> Thanks.
> >> _______________________________________________
> >> rtems-devel mailing list
> >> rtems-devel at rtems.org
> >> http://www.rtems.org/mailman/listinfo/rtems-devel
