the problem about qemu run i386 rtems bsp
yangwei weiyang wei.a.yang at gmail.com
Mon Jul 2 16:07:00 UTC 2012
2012/7/2 Joel Sherrill <joel.sherrill at oarcorp.com>:
> On 07/02/2012 10:48 AM, yangwei weiyang wrote:
>> Hi all,
>> When i use rtems-testing repository sim-scripts/pc386 to run pcp4 bsp,
>> it show the blow result:
>> ./sim-scripts/pc386 -i
>> ../rtems-build/i386-rtems4.11/c/pcp4/testsuites/samples/hello/hello.exe
>> qemu is /sdb1/gsoc2012/github/qemu-install/bin/qemu
>> Could not open option rom 'sgabios.bin': No such file or directory
> Looks like qemu didn't get completely built and installed correctly.
> It is installed under ${prefix}/share/qemu. See for my local install:
> $ find . -name *.bin
> ./share/qemu/vgabios-cirrus.bin
> ./share/qemu/sgabios.bin
> ./share/qemu/multiboot.bin
> ./share/qemu/ppc_rom.bin
> ./share/qemu/slof.bin
> ./share/qemu/bios.bin
> ./share/qemu/vgabios.bin
> ./share/qemu/vgabios-stdvga.bin
> ./share/qemu/pxe-virtio.bin
> ./share/qemu/spapr-rtas.bin
> ./share/qemu/linuxboot.bin
> ./share/qemu/pxe-ne2k_pci.bin
> ./share/qemu/vgabios-vmware.bin
> ./share/qemu/pxe-pcnet.bin
> ./share/qemu/pxe-rtl8139.bin
> ./share/qemu/vgabios-qxl.bin
> ./share/qemu/pxe-e1000.bin
In my local computer is :
It seems that i lack of lot of *.bin. Joel, could you tell me the
command of what you build qemu?
>> And then there is not any output. Anyone know this issue?
>> The follow step is what i do:
>> 1. git clone rtems-testing.git
>> 2. build rtems with the configuration:
>>      ../rtems/configure --target=i386-rtems4.11
>> --prefix=/sdb1/gsoc2012/github/rtems-install --enable-smp
>> --enable-tests=yes --enable-rtemsbsp=pcp4 USE_COM1_AS_CONSOLE=1
>> BSP_PRESS_KEY_FOR_RESET=0
>> 3. ./sim-scripts/pc386 -i
>> ../rtems-build/i386-rtems4.11/c/pcp4/testsuites/samples/hello/hello.exe.
>> And then it shows: CANNOT FIND qemu or qemu-system-i386.
> qemu is not in your PATH.
> $ type qemu
> qemu is /home/joel/qemu/git/install/bin/qemu
>> 4 And then i build qemu for i386. Then run the command step 3 then it
>> shows the log in the head of mail.
> Joel Sherrill, Ph.D.             Director of Research&   Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>     Support Available             (256) 722-9985
Wei Yang
Best Regards
