the problem about qemu run i386 rtems bsp
Mon Jul 2 15:55:56 UTC 2012
On 07/02/2012 10:48 AM, yangwei weiyang wrote:
> Hi all,
> When i use rtems-testing repository sim-scripts/pc386 to run pcp4 bsp,
> it show the blow result:
> ./sim-scripts/pc386 -i
> ../rtems-build/i386-rtems4.11/c/pcp4/testsuites/samples/hello/hello.exe
> qemu is /sdb1/gsoc2012/github/qemu-install/bin/qemu
> Could not open option rom 'sgabios.bin': No such file or directory
Looks like qemu didn't get completely built and installed correctly.
It is installed under ${prefix}/share/qemu. See for my local install:
$ find . -name *.bin
./share/qemu/vgabios-cirrus.bin
./share/qemu/sgabios.bin
./share/qemu/multiboot.bin
./share/qemu/ppc_rom.bin
./share/qemu/slof.bin
./share/qemu/bios.bin
./share/qemu/vgabios.bin
./share/qemu/vgabios-stdvga.bin
./share/qemu/pxe-virtio.bin
./share/qemu/spapr-rtas.bin
./share/qemu/linuxboot.bin
./share/qemu/pxe-ne2k_pci.bin
./share/qemu/vgabios-vmware.bin
./share/qemu/pxe-pcnet.bin
./share/qemu/pxe-rtl8139.bin
./share/qemu/vgabios-qxl.bin
./share/qemu/pxe-e1000.bin
> And then there is not any output. Anyone know this issue?
> The follow step is what i do:
> 1. git clone rtems-testing.git
> 2. build rtems with the configuration:
>      ../rtems/configure --target=i386-rtems4.11
> --prefix=/sdb1/gsoc2012/github/rtems-install --enable-smp
> --enable-tests=yes --enable-rtemsbsp=pcp4 USE_COM1_AS_CONSOLE=1
> BSP_PRESS_KEY_FOR_RESET=0
> 3. ./sim-scripts/pc386 -i
> ../rtems-build/i386-rtems4.11/c/pcp4/testsuites/samples/hello/hello.exe.
> And then it shows: CANNOT FIND qemu or qemu-system-i386.
qemu is not in your PATH.
$ type qemu
qemu is /home/joel/qemu/git/install/bin/qemu
> 4 And then i build qemu for i386. Then run the command step 3 then it
> shows the log in the head of mail.
Joel Sherrill, Ph.D.             Director of Research&   Development
