[PATCH 1/6] mghttpd: Update Mongoose
sebastian.huber at embedded-brains.de sebastian.huber at embedded-brains.de
Tue Jul 3 08:45:36 UTC 2012
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
Update to Mongoose Mercurial revision 268:38a02c8a6744 available at:
https://code.google.com/p/mongoose/
 cpukit/mghttpd/Makefile.am |    2 +-
 cpukit/mghttpd/mongoose.1  |  233 +-
 cpukit/mghttpd/mongoose.c  | 8409 +++++++++++++++++++++-----------------------
 cpukit/mghttpd/mongoose.h  |  445 ++--
 4 files changed, 4292 insertions(+), 4797 deletions(-)
diff --git a/cpukit/mghttpd/Makefile.am b/cpukit/mghttpd/Makefile.am
index 2c2a918..e4ed9fd 100644
--- a/cpukit/mghttpd/Makefile.am
+++ b/cpukit/mghttpd/Makefile.am
@@ -6,7 +6,7 @@ include_mghttpddir = $(includedir)/mghttpd
 project_lib_LIBRARIES = libmghttpd.a
 libmghttpd_a_CPPFLAGS = $(AM_CPPFLAGS)
 # libmghttpd_a_CPPFLAGS += -DHAVE_MD5
-libmghttpd_a_CPPFLAGS += -DNO_SSI -DNO_SSL -DNO_CGI
+libmghttpd_a_CPPFLAGS += -DNO_SSL -DNO_POPEN -DNO_CGI
 libmghttpd_a_SOURCES = mongoose.c mongoose.h
 include_mghttpd_HEADERS = mongoose.h
diff --git a/cpukit/mghttpd/mongoose.1 b/cpukit/mghttpd/mongoose.1
index a83a44f..e02b186 100644
--- a/cpukit/mghttpd/mongoose.1
+++ b/cpukit/mghttpd/mongoose.1
@@ -1,176 +1,167 @@
 .\" Process this file with
 .\" groff -man -Tascii mongoose.1
-.Dd Dec 1, 2008
+.\" $Id: mongoose.1,v 1.12 2008/11/29 15:32:42 drozd Exp $
+.Dd Aug 31, 2010
 .Dt mongoose 1
 .Sh NAME
 .Nm mongoose
 .Nd lightweight web server
 .Sh SYNOPSIS
 .Nm
-.Op Ar options
 .Op Ar config_file
+.Op Ar OPTIONS
 .Nm
 .Fl A Ar htpasswd_file domain_name user_name password
 .Sh DESCRIPTION
 .Nm
-is small, fast and easy to use web server with CGI, SSL, Digest Authorization
-support.
+is small, fast and easy to use web server with CGI, SSL, MD5 authorization,
+and basic SSI support.
 .Pp
 .Nm
 does not detach from terminal, and uses current working directory
 as the web root, unless
-.Fl root
+.Fl r
 option is specified.
-.Pp
-It is possible to specify multiple ports to listen on. For example, to
-make
+It is possible to specify multiple ports to listen on. For example, to make
+mongoose listen on HTTP port 80 and HTTPS port 443, one should start it as:
 .Nm
-listen on HTTP port 80 and HTTPS port 443, one should start it as
-.Dq mongoose -ssl_cert cert.pem -ports 80,443s .
-.Pp
-Options may be specified in any order, with one exception: if SSL listening
-port is specified in the -ports option, then -ssl_cert option must be set
-before -ports option.
+.Fl s Ar cert.pem Fl p Ar 80,443s
 .Pp
 Unlike other web servers,
 .Nm
-does not expect CGI scripts to be put in a special directory. CGI scripts may
-be anywhere. CGI files are recognized by the file extension.
-.Pp
-SSI files are also recognized by extension. Unknown SSI directives are silently
-ignored. Currently, two SSI directives supported, "include" and "exec". For the
-"include" directive, included file name can be specified in three different
-ways. Below is the summary of supported SSI directives:
-.Bl -bullet
-.It
-<!--#exec "shell command"--> Execute shell command.
-.It
-<!--#include "path"--> File path must be relative to the current document.
-.It
-<!--#include virtual="path"--> File path must be relative to the document root.
-.It
-<!--#include file="path"--> File path must be the absolute path.
+does not require CGI scripts be put in a special directory. CGI scripts can
+be anywhere. CGI (and SSI) files are recognized by the file name pattern.
+.Nm
+uses shell-like glob patterns with the following syntax:
+.Bl -tag -compact -width indent
+.It **
+Matches everything
+.It *
+Matches everything but slash character, '/'
+.It ?
+Matches any character
+.It $
+Matches the end of the string
+.It |
+Matches if pattern on the left side or the right side matches. Pattern on the
+left side is matched first
 .El
+All other characters in the pattern match themselves.
 .Pp
+If no arguments are given,
 .Nm
-can use the configuration file. By default, it is "mongoose.conf", and if it
-is present in the same directory where
-.Nm
-lives, the command line options are read from it. Alternatively, the
-configuration file may be specified as a last argument. The format of the
-configuration file is exactly the same as for the command line options, the
-only difference is that the command line options must be specified on
-separate lines, and leading dashes for option names must be omitted.
-Lines beginning with '#' are regarded as comments and ignored.
+searches for a configuration file called "mongoose.conf" in the same directory
+where mongoose binary is located. Alternatively, a file name could be
+specified in the command line. Format of the configuration file is the same
+as for the command line options except that each option must be specified
+on a separate line, leading dashes for option names must be omitted.
+Lines beginning with '#' and empty lines are ignored.
 .Pp
 .Sh OPTIONS
 .Bl -tag -width indent
 .It Fl A Ar htpasswd_file domain_name user_name password
 Add/edit user's password in the passwords file. Deleting users can be done
-with any text editor. Functionality similar to Apache's
+with any text editor. Functionality is similar to Apache's
 .Ic htdigest
 utility.
-.It Fl access_log Ar file
-Access log file. Default: not set, no logging is done.
-.It Fl acl Ar (+|-)x.x.x.x[/x],...
+.It Fl C Ar cgi_pattern
+All files that fully match cgi_pattern are treated as CGI.
+Default pattern allows CGI files be
+anywhere. To restrict CGIs to certain directory, use e.g. "-C /cgi-bin/**.cgi".
+Default: "**.cgi$|**.pl$|**.php$"
+.It Fl E Ar cgi_environment
+Extra environment variables to be passed to the CGI script in addition to
+standard ones. The list must be comma-separated list of X=Y pairs, like this:
+"VARIABLE1=VALUE1,VARIABLE2=VALUE2". Default: ""
+.It Fl G Ar put_delete_passwords_file
+PUT and DELETE passwords file. This must be specified if PUT or
+DELETE methods are used. Default: ""
+.It Fl I Ar cgi_interpreter
+Use
+.Ar cgi_interpreter
+as a CGI interpreter for all CGI scripts regardless script extension.
+Mongoose decides which interpreter to use by looking at
+the first line of a CGI script.  Default: "".
+.It Fl M Ar max_request_size
+Maximum HTTP request size in bytes. Default: "16384"
+.It Fl P Ar protect_uri
+Comma separated list of URI=PATH pairs, specifying that given URIs
+must be protected with respected password files. Default: ""
+.It Fl R Ar authentication_domain
+Authorization realm. Default: "mydomain.com"
+.It Fl S Ar ssi_pattern
+All files that fully match ssi_pattern are treated as SSI.
+Unknown SSI directives are silently ignored. Currently, two SSI directives
+are supported, "include" and "exec".  Default: "**.shtml$|**.shtm$"
+.It Fl a Ar access_log_file
+Access log file. Default: "", no logging is done.
+.It Fl d Ar enable_directory_listing
+Enable/disable directory listing. Default: "yes"
+.It Fl e Ar error_log_file
+Error log file. Default: "", no errors are logged.
+.It Fl g Ar global_passwords_file
+Location of a global passwords file. If set, per-directory .htpasswd files are
+ignored, and all requests must be authorised against that file.  Default: ""
+.It Fl i Ar index_files
+Comma-separated list of files to be treated as directory index files.
+Default: "index.html,index.htm,index.cgi"
+.It Fl l Ar access_control_list
 Specify access control list (ACL). ACL is a comma separated list
 of IP subnets, each subnet is prepended by '-' or '+' sign. Plus means allow,
 minus means deny. If subnet mask is
 omitted, like "-1.2.3.4", then it means single IP address. Mask may vary
 from 0 to 32 inclusive. On each request, full list is traversed, and
-last match wins. Default: not set, allow all.
-.It Fl admin_uri Ar uri
-If set,
-.Nm
-creates special administrative URI where options may be changed at runtime.
-This URI probably wants to be password-protected, look at
-.Fl protect
-option, and in the EXAMPLES section on how to do it. Default: not set.
-.It Fl aliases Ar list
-This options gives an ability to serve the directories outside web root
-by sort of symbolic linking to certain URI. The
-.Ar list
-must be comma-separated list of URI=PATH pairs, like this:
-"/etc/=/my_etc,/tmp=/my_tmp". Default: not set.
-.It Fl auth_PUT Ar file
-PUT and DELETE passwords file. This must be specified if PUT or
-DELETE methods are used. Default: not set.
-.It Fl auth_gpass Ar file
-Location of global passwords file. When set, per-directory .htpasswd files are
-ignored, and all accessed must be authorised against global passwords file.
-Default: not set.
-.It Fl auth_realm Ar domain_name
-Authorization realm. Default: "mydomain.com".
-.It Fl cgi_env Ar list
-Pass environment variables to the CGI script in addition to standard ones.
-The list must be comma-separated list of X=Y pairs, like this:
-"VARIABLE1=VALUE1,VARIABLE2=VALUE2".  Default: not set.
-.It Fl cgi_ext Ar list
-Comma-separated list of CGI extensions.  All files having these extensions
-are treated as CGI scripts. Default: "cgi,pl,php"
-.It Fl cgi_interp Ar file
-Force
-.Ar file
-to be a CGI interpreter for all CGI scripts. By default this option is not
-set, and
-.Nm
-decides which interpreter to use by looking at the first line of CGI script.
-.It Fl dir_list Ar yes|no
-Enable/disable directory listing. Default: "1" (enabled).
-.It Fl error_log Ar file
-Error log file. Default: not set, no errors are logged.
-.It Fl idle_time Ar num_seconds
-Number of seconds worker thread waits for some work before exit. Default: 10
-.It Fl max_threads Ar number
-Maximum number of worker threads to start. Default: 100
-.It Fl mime_types Ar list
-Additional to builtin mime types, in form
+last match wins. Default setting is to allow all. For example, to allow only
+192.168/16 subnet to connect, run "mongoose -0.0.0.0/0,+192.168/16".
+Default: ""
+.It Fl m Ar extra_mime_types
+Extra mime types to recognize, in form
 "extension1=type1,extension2=type2,...". Extension must include dot.
-.It Fl ports Ar port_list
+Example: "mongoose -m .cpp=plain/text,.java=plain/text". Default: ""
+.It Fl p Ar listening_ports
 Comma-separated list of ports to listen on. If the port is SSL, a letter 's'
-must be appeneded, for example, "-ports 80,443s" will open port 80 and port 443,
+must be appeneded, for example, "-p 80,443s" will open port 80 and port 443,
 and connections on port 443 will be SSL-ed. It is possible to specify an
 IP address to bind to. In this case, an IP address and a colon must be
-prepended to the port number, for example, "-ports 127.0.0.1:8080". Note that
-if SSL listening port is requested, then
-.Fl ssl_cert
-option must specified BEFORE
-.Fl ports
-option. Default: 8080
-.It Fl protect Ar list
-Comma separated list of URI=PATH pairs, specifying that given URIs
-must the protected with respected password files. Default: not set.
-.It Fl root Ar directory
-Location of the WWW root directory. Default: working directory from which
-.Nm
-has been started.
-.It Fl ssi_ext Ar list
-Comma separated list of SSI extensions. Default: "shtml,shtm".
-.It Fl ssl_cert Ar pem_file
-Location of SSL certificate file. Default: not set.
-.It Fl uid Ar login
-Switch to given user after startup. Default: not set.
+prepended to the port number. For example, to bind to a loopback interface
+on port 80 and to all interfaces on HTTPS port 443, use
+"mongoose -p 127.0.0.1:80,443s". Default: "8080"
+.It Fl r Ar document_root
+Location of the WWW root directory. Default: "."
+.It Fl s Ar ssl_certificate
+Location of SSL certificate file. Default: ""
+.It Fl t Ar num_threads
+Number of worker threads to start. Default: "10"
+.It Fl u Ar run_as_user
+Switch to given user's credentials after startup. Default: ""
+.It Fl w Ar url_rewrite_patterns
+Comma-separated list of URL rewrites in the form of
+"pattern=substitution,..." If the "pattern" matches some prefix
+of the requested URL, then matched prefix gets substituted with "substitution".
+For example, "-w /config=/etc,**.doc|**.rtf=/path/to/cgi-bin/handle_doc.cgi"
+will serve all URLs that start with "/config" from the "/etc" directory, and
+call handle_doc.cgi script for .doc and .rtf file requests. If some pattern
+matches, no further matching/substitution is performed
+(first matching pattern wins). Use full paths in substitutions. Default: ""
 .El
 .Pp
 .Sh EMBEDDING
 .Nm
 was designed to be embeddable into C/C++ applications. Since the
-source code is contained in single C file, it is fairly easy to embed it,
-and to follow the updates. Please refer to http://code.google.com/p/mongoose
+source code is contained in single C file, it is fairly easy to embed it
+and follow the updates. Please refer to http://code.google.com/p/mongoose
 for details.
 .Pp
 .Sh EXAMPLES
-.It Nm Fl root Ar /var/www Fl ssl_cert Ar /etc/cert.pem Fl ports Ar 8080,8043s Fl aliases Ar /aa=/tmp,/bb=/etc
-Start listening on port 8080 for HTTP, and 8043 for HTTPS connections.
-Use /etc/cert.pem as SSL certificate file. Web root is /var/www. In addition,
-map directory /tmp to URI /aa, directory /etc to URI /bb.
-.It Nm Fl acl Ar -0.0.0.0/0,+10.0.0.0/8,+1.2.3.4
+.It Nm Fl r Ar /var/www Fl s Ar /etc/cert.pem Fl p Ar 8080,8043s
+Start serving files from /var/www. Listen on port 8080 for HTTP, and 8043
+for HTTPS connections.  Use /etc/cert.pem as SSL certificate file.
+.It Nm Fl l Ar -0.0.0.0/0,+10.0.0.0/8,+1.2.3.4
 Deny connections from everywhere, allow only IP address 1.2.3.4 and
 all IP addresses from 10.0.0.0/8 subnet to connect.
-.It Nm Fl admin_uri Ar /ctl Fl protect Ar /ctl=/tmp/passwords.txt
-Create an administrative URI "/ctl" where
-options may be changed at runtime, and protect that URI with authorization.
+.It Nm Fl w Ar **=/usr/bin/script.cgi
+Invoke /usr/bin/script.cgi for every incoming request, regardless of the URL.
 .El
 .Pp
 .Sh COPYRIGHT
diff --git a/cpukit/mghttpd/mongoose.c b/cpukit/mghttpd/mongoose.c
index 24ce2ca..31c5275 100644
--- a/cpukit/mghttpd/mongoose.c
+++ b/cpukit/mghttpd/mongoose.c
@@ -1,41 +1,45 @@
- * Copyright (c) 2004-2009 Sergey Lyubka
- * Portions Copyright (c) 2009 Gilbert Wellisch
- * Permission is hereby granted, free of charge, to any person obtaining a copy
- * of this software and associated documentation files (the "Software"), to deal
- * in the Software without restriction, including without limitation the rights
- * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
- * copies of the Software, and to permit persons to whom the Software is
- * furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in
- * all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
- * THE SOFTWARE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
+// Copyright (c) 2004-2011 Sergey Lyubka
+// Permission is hereby granted, free of charge, to any person obtaining a copy
+// of this software and associated documentation files (the "Software"), to deal
+// in the Software without restriction, including without limitation the rights
+// to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
+// copies of the Software, and to permit persons to whom the Software is
+// furnished to do so, subject to the following conditions:
+// The above copyright notice and this permission notice shall be included in
+// all copies or substantial portions of the Software.
+// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+// IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+// FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+// AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+// LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+// OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
+// THE SOFTWARE.
 #if defined(_WIN32)
-#define _CRT_SECURE_NO_WARNINGS	/* Disable deprecation warning in VS2005 */
-#endif /* _WIN32 */
+#define _CRT_SECURE_NO_WARNINGS // Disable deprecation warning in VS2005
+#else
+#define _XOPEN_SOURCE 600     // For flockfile() on Linux
+#define _LARGEFILE_SOURCE     // Enable 64-bit file offsets
+#define __STDC_FORMAT_MACROS  // <inttypes.h> wants this for C++
+#define __STDC_LIMIT_MACROS   // C++ wants that for INT64_MAX
+#endif
+#if defined(__SYMBIAN32__)
+#define NO_SSL // SSL is not supported
+#define NO_CGI // CGI is not supported
+#define PATH_MAX FILENAME_MAX
+#endif // __SYMBIAN32__
-#ifndef _WIN32_WCE /* Some ANSI #includes are not available on Windows CE */
+#ifndef _WIN32_WCE // Some ANSI #includes are not available on Windows CE
 #include <sys/types.h>
 #include <sys/stat.h>
 #include <signal.h>
 #include <fcntl.h>
-#endif /* !_WIN32_WCE */
+#endif // !_WIN32_WCE
 #include <time.h>
@@ -47,4691 +51,4204 @@
 #include <stddef.h>
-#if defined(_WIN32)		/* Windows specific #includes and #defines */
-#define	_WIN32_WINNT	0x0400	/* To make it link in VS2005 */
+#if defined(_WIN32) && !defined(__SYMBIAN32__) // Windows specific
+#define _WIN32_WINNT 0x0400 // To make it link in VS2005
 #include <windows.h>
+#ifndef PATH_MAX
+#define PATH_MAX MAX_PATH
+#endif
 #ifndef _WIN32_WCE
 #include <process.h>
 #include <direct.h>
 #include <io.h>
-#else /* _WIN32_WCE */
-/* Windows CE-specific definitions */
+#else // _WIN32_WCE
 #include <winsock2.h>
-#define NO_CGI	/* WinCE has no pipes */
-#define NO_SSI	/* WinCE has no pipes */
+#include <ws2tcpip.h>
+#define NO_CGI // WinCE has no pipes
-#define FILENAME_MAX	MAX_PATH
-#define BUFSIZ		4096
 typedef long off_t;
-#define errno			GetLastError()
-#define strerror(x)		_ultoa(x, (char *) _alloca(sizeof(x) *3 ), 10)
-#endif /* _WIN32_WCE */
-#define EPOCH_DIFF	0x019DB1DED53E8000 /* 116444736000000000 nsecs */
-#define RATE_DIFF	10000000 /* 100 nsecs */
-#define MAKEUQUAD(lo, hi)	((uint64_t)(((uint32_t)(lo)) | \
-				((uint64_t)((uint32_t)(hi))) << 32))
-#define	SYS2UNIX_TIME(lo, hi) \
-	(time_t) ((MAKEUQUAD((lo), (hi)) - EPOCH_DIFF) / RATE_DIFF)
- * Visual Studio 6 does not know __func__ or __FUNCTION__
- * The rest of MS compilers use __FUNCTION__, not C99 __func__
- * Also use _strtoui64 on modern M$ compilers
+#define BUFSIZ  4096
+#define errno   GetLastError()
+#define strerror(x)  _ultoa(x, (char *) _alloca(sizeof(x) *3 ), 10)
+#endif // _WIN32_WCE
+#define MAKEUQUAD(lo, hi) ((uint64_t)(((uint32_t)(lo)) | \
+      ((uint64_t)((uint32_t)(hi))) << 32))
+#define RATE_DIFF 10000000 // 100 nsecs
+#define EPOCH_DIFF MAKEUQUAD(0xd53e8000, 0x019db1de)
+#define SYS2UNIX_TIME(lo, hi) \
+  (time_t) ((MAKEUQUAD((lo), (hi)) - EPOCH_DIFF) / RATE_DIFF)
+// Visual Studio 6 does not know __func__ or __FUNCTION__
+// The rest of MS compilers use __FUNCTION__, not C99 __func__
+// Also use _strtoui64 on modern M$ compilers
 #if defined(_MSC_VER) && _MSC_VER < 1300
-#define	STRX(x)			#x
-#define	STR(x)			STRX(x)
-#define	__func__		"line " STR(__LINE__)
-#define	strtoull(x, y, z)	strtoul(x, y, z)
+#define STRX(x) #x
+#define STR(x) STRX(x)
+#define __func__ "line " STR(__LINE__)
+#define strtoull(x, y, z) strtoul(x, y, z)
+#define strtoll(x, y, z) strtol(x, y, z)
 #else
-#define	__func__		__FUNCTION__
-#define	strtoull(x, y, z)	_strtoui64(x, y, z)
-#endif /* _MSC_VER */
-#define	ERRNO			GetLastError()
-#define	NO_SOCKLEN_T
-#define	SSL_LIB			"ssleay32.dll"
-#define	CRYPTO_LIB		"libeay32.dll"
-#define	DIRSEP			'\\'
-#define	IS_DIRSEP_CHAR(c)	((c) == '/' || (c) == '\\')
-#define	O_NONBLOCK		0
-#define	EWOULDBLOCK		WSAEWOULDBLOCK
-#define	_POSIX_
-#define INT64_FMT		"I64"
-#define	SHUT_WR			1
-#define	snprintf		_snprintf
-#define	vsnprintf		_vsnprintf
-#define	sleep(x)		Sleep((x) * 1000)
-#define	popen(x, y)		_popen(x, y)
-#define	pclose(x)		_pclose(x)
-#define	close(x)		_close(x)
-#define	dlsym(x,y)		GetProcAddress((HINSTANCE) (x), (y))
-#define	RTLD_LAZY		0
-#define	fseeko(x, y, z)		fseek((x), (y), (z))
-#define	fdopen(x, y)		_fdopen((x), (y))
-#define	write(x, y, z)		_write((x), (y), (unsigned) z)
-#define	read(x, y, z)		_read((x), (y), (unsigned) z)
-#define	flockfile(x)		(void) 0
-#define	funlockfile(x)		(void) 0
+#define __func__  __FUNCTION__
+#define strtoull(x, y, z) _strtoui64(x, y, z)
+#define strtoll(x, y, z) _strtoi64(x, y, z)
+#endif // _MSC_VER
+#define ERRNO   GetLastError()
+#define NO_SOCKLEN_T
+#define SSL_LIB   "ssleay32.dll"
+#define CRYPTO_LIB  "libeay32.dll"
+#define DIRSEP '\\'
+#define IS_DIRSEP_CHAR(c) ((c) == '/' || (c) == '\\')
+#define O_NONBLOCK  0
+#if !defined(EWOULDBLOCK)
+#define EWOULDBLOCK  WSAEWOULDBLOCK
+#endif // !EWOULDBLOCK
+#define _POSIX_
+#define INT64_FMT  "I64d"
+#define WINCDECL __cdecl
+#define SHUT_WR 1
+#define snprintf _snprintf
+#define vsnprintf _vsnprintf
+#define mg_sleep(x) Sleep(x)
+#define pipe(x) _pipe(x, BUFSIZ, _O_BINARY)
+#define popen(x, y) _popen(x, y)
+#define pclose(x) _pclose(x)
+#define close(x) _close(x)
+#define dlsym(x,y) GetProcAddress((HINSTANCE) (x), (y))
+#define RTLD_LAZY  0
+#define fseeko(x, y, z) fseek((x), (y), (z))
+#define fdopen(x, y) _fdopen((x), (y))
+#define write(x, y, z) _write((x), (y), (unsigned) z)
+#define read(x, y, z) _read((x), (y), (unsigned) z)
+#define flockfile(x) EnterCriticalSection(&global_log_file_lock)
+#define funlockfile(x) LeaveCriticalSection(&global_log_file_lock)
 #if !defined(fileno)
-#define	fileno(x)		_fileno(x)
-#endif /* !fileno MINGW #defines fileno */
+#define fileno(x) _fileno(x)
+#endif // !fileno MINGW #defines fileno
 typedef HANDLE pthread_mutex_t;
-typedef HANDLE pthread_cond_t;
+typedef struct {HANDLE signal, broadcast;} pthread_cond_t;
 typedef DWORD pthread_t;
-#define pid_t HANDLE	/* MINGW typedefs pid_t to int. Using #define here. */
+#define pid_t HANDLE // MINGW typedefs pid_t to int. Using #define here.
 struct timespec {
-	long tv_nsec;
-	long tv_sec;
+  long tv_nsec;
+  long tv_sec;
 static int pthread_mutex_lock(pthread_mutex_t *);
 static int pthread_mutex_unlock(pthread_mutex_t *);
+static FILE *mg_fopen(const char *path, const char *mode);
 #if defined(HAVE_STDINT)
 #include <stdint.h>
 #else
-typedef unsigned int		uint32_t;
-typedef unsigned short		uint16_t;
-typedef unsigned __int64	uint64_t;
-typedef __int64			int64_t;
-#define	INT64_MAX		9223372036854775807
-#endif /* HAVE_STDINT */
- * POSIX dirent interface
+typedef unsigned int  uint32_t;
+typedef unsigned short  uint16_t;
+typedef unsigned __int64 uint64_t;
+typedef __int64   int64_t;
+#define INT64_MAX  9223372036854775807
+#endif // HAVE_STDINT
+// POSIX dirent interface
 struct dirent {
-	char	d_name[FILENAME_MAX];
+  char d_name[PATH_MAX];
 typedef struct DIR {
-	HANDLE			handle;
-	WIN32_FIND_DATAW	info;
-	struct dirent		result;
+  HANDLE   handle;
+  WIN32_FIND_DATAW info;
+  struct dirent  result;
 } DIR;
-#else				/* UNIX  specific	*/
+#else    // UNIX  specific
 #include <sys/wait.h>
 #include <sys/socket.h>
 #include <sys/select.h>
-#if HAVE_SYS_MMAN_H
-#include <sys/mman.h>
-#endif
-#if defined(__rtems__)
-#endif
 #include <netinet/in.h>
 #include <arpa/inet.h>
 #include <sys/time.h>
 #include <stdint.h>
 #include <inttypes.h>
+#include <netdb.h>
 #include <pwd.h>
 #include <unistd.h>
 #include <dirent.h>
-#if HAVE_DLFCN_H
+#if !defined(NO_SSL_DL) && !defined(NO_SSL)
 #include <dlfcn.h>
 #endif
 #include <pthread.h>
-#define	SSL_LIB			"libssl.so"
-#define	CRYPTO_LIB		"libcrypto.so"
-#define	DIRSEP			'/'
-#define	IS_DIRSEP_CHAR(c)	((c) == '/')
-#define	O_BINARY		0
-#define	closesocket(a)		close(a)
-#define	mg_fopen(x, y)		fopen(x, y)
-#define	mg_mkdir(x, y)		mkdir(x, y)
-#define	mg_remove(x)		remove(x)
-#define	mg_rename(x, y)		rename(x, y)
-#define	ERRNO			errno
-#define	INVALID_SOCKET		(-1)
-#define INT64_FMT		PRId64
+#if defined(__MACH__)
+#define SSL_LIB   "libssl.dylib"
+#define CRYPTO_LIB  "libcrypto.dylib"
+#else
+#if !defined(SSL_LIB)
+#define SSL_LIB   "libssl.so"
+#endif
+#if !defined(CRYPTO_LIB)
+#define CRYPTO_LIB  "libcrypto.so"
+#endif
+#endif
+#define DIRSEP   '/'
+#define IS_DIRSEP_CHAR(c) ((c) == '/')
+#ifndef O_BINARY
+#define O_BINARY  0
+#endif // O_BINARY
+#define closesocket(a) close(a)
+#define mg_fopen(x, y) fopen(x, y)
+#define mg_mkdir(x, y) mkdir(x, y)
+#define mg_remove(x) remove(x)
+#define mg_rename(x, y) rename(x, y)
+#define mg_sleep(x) usleep((x) * 1000)
+#define ERRNO errno
+#define INVALID_SOCKET (-1)
+#define INT64_FMT PRId64
 typedef int SOCKET;
+#define WINCDECL
-#endif /* End of Windows and UNIX specific includes */
+#endif // End of Windows and UNIX specific includes
 #include "mongoose.h"
-#define	MONGOOSE_VERSION	"2.9"
-#define	PASSWORDS_FILE_NAME	".htpasswd"
-#define	CGI_ENVIRONMENT_SIZE	4096
-#define	MAX_CGI_ENVIR_VARS	64
-#define	MAX_REQUEST_SIZE	8192
-#define	MAX_LISTENING_SOCKETS	10
-#define	MAX_CALLBACKS		20
-#define	ARRAY_SIZE(array)	(sizeof(array) / sizeof(array[0]))
-#define	DEBUG_MGS_PREFIX	"*** Mongoose debug *** "
+#define MONGOOSE_VERSION "3.2"
+#define PASSWORDS_FILE_NAME ".htpasswd"
+#define CGI_ENVIRONMENT_SIZE 4096
+#define MAX_CGI_ENVIR_VARS 64
+#define ARRAY_SIZE(array) (sizeof(array) / sizeof(array[0]))
+#ifdef _WIN32
+static CRITICAL_SECTION global_log_file_lock;
+static pthread_t pthread_self(void) {
+  return GetCurrentThreadId();
+#endif // _WIN32
 #if defined(DEBUG)
-#define	DEBUG_TRACE(x) do {printf x; putchar('\n'); fflush(stdout);} while (0)
+#define DEBUG_TRACE(x) do { \
+  flockfile(stdout); \
+  printf("*** %lu.%p.%s.%d: ", \
+         (unsigned long) time(NULL), (void *) pthread_self(), \
+         __func__, __LINE__); \
+  printf x; \
+  putchar('\n'); \
+  fflush(stdout); \
+  funlockfile(stdout); \
+} while (0)
 #else
-#endif /* DEBUG */
+#endif // DEBUG
- * Darwin prior to 7.0 and Win32 do not have socklen_t
+// Darwin prior to 7.0 and Win32 do not have socklen_t
 #ifdef NO_SOCKLEN_T
 typedef int socklen_t;
-#endif /* NO_SOCKLEN_T */
+#endif // NO_SOCKLEN_T
-#if !defined(FALSE)
-enum {FALSE, TRUE};
-#endif /* !FALSE */
+#if !defined(MSG_NOSIGNAL)
+#define MSG_NOSIGNAL 0
+#endif
-typedef int bool_t;
 typedef void * (*mg_thread_func_t)(void *);
 static const char *http_500_error = "Internal Server Error";
- * Snatched from OpenSSL includes. I put the prototypes here to be independent
- * from the OpenSSL source installation. Having this, mongoose + SSL can be
- * built on any system with binary SSL libraries installed.
+// Snatched from OpenSSL includes. I put the prototypes here to be independent
+// from the OpenSSL source installation. Having this, mongoose + SSL can be
+// built on any system with binary SSL libraries installed.
 typedef struct ssl_st SSL;
 typedef struct ssl_method_st SSL_METHOD;
 typedef struct ssl_ctx_st SSL_CTX;
-#define	SSL_ERROR_WANT_READ	2
-#define	SSL_ERROR_WANT_WRITE	3
-#define SSL_FILETYPE_PEM	1
-#define	CRYPTO_LOCK		1
- * Dynamically loaded SSL functionality
+#define SSL_ERROR_WANT_READ 2
+#define SSL_ERROR_WANT_WRITE 3
+#define SSL_FILETYPE_PEM 1
+#define CRYPTO_LOCK  1
+#if defined(NO_SSL_DL)
+extern void SSL_free(SSL *);
+extern int SSL_accept(SSL *);
+extern int SSL_connect(SSL *);
+extern int SSL_read(SSL *, void *, int);
+extern int SSL_write(SSL *, const void *, int);
+extern int SSL_get_error(const SSL *, int);
+extern int SSL_set_fd(SSL *, int);
+extern SSL *SSL_new(SSL_CTX *);
+extern SSL_CTX *SSL_CTX_new(SSL_METHOD *);
+extern SSL_METHOD *SSLv23_server_method(void);
+extern int SSL_library_init(void);
+extern void SSL_load_error_strings(void);
+extern int SSL_CTX_use_PrivateKey_file(SSL_CTX *, const char *, int);
+extern int SSL_CTX_use_certificate_file(SSL_CTX *, const char *, int);
+extern int SSL_CTX_use_certificate_chain_file(SSL_CTX *, const char *);
+extern void SSL_CTX_set_default_passwd_cb(SSL_CTX *, mg_callback_t);
+extern void SSL_CTX_free(SSL_CTX *);
+extern unsigned long ERR_get_error(void);
+extern char *ERR_error_string(unsigned long, char *);
+extern int CRYPTO_num_locks(void);
+extern void CRYPTO_set_locking_callback(void (*)(int, int, const char *, int));
+extern void CRYPTO_set_id_callback(unsigned long (*)(void));
+#else
+// Dynamically loaded SSL functionality
 struct ssl_func {
-	const char	*name;		/* SSL function name	*/
-	void		(*ptr)(void);	/* Function pointer	*/
+  const char *name;   // SSL function name
+  void  (*ptr)(void); // Function pointer
-#define	SSL_free(x)	(* (void (*)(SSL *)) ssl_sw[0].ptr)(x)
-#define	SSL_accept(x)	(* (int (*)(SSL *)) ssl_sw[1].ptr)(x)
-#define	SSL_connect(x)	(* (int (*)(SSL *)) ssl_sw[2].ptr)(x)
-#define	SSL_read(x,y,z)	(* (int (*)(SSL *, void *, int)) 		\
-				ssl_sw[3].ptr)((x),(y),(z))
-#define	SSL_write(x,y,z) (* (int (*)(SSL *, const void *,int))		\
-				ssl_sw[4].ptr)((x), (y), (z))
-#define	SSL_get_error(x,y)(* (int (*)(SSL *, int)) ssl_sw[5])((x), (y))
-#define	SSL_set_fd(x,y)	(* (int (*)(SSL *, SOCKET)) ssl_sw[6].ptr)((x), (y))
-#define	SSL_new(x)	(* (SSL * (*)(SSL_CTX *)) ssl_sw[7].ptr)(x)
-#define	SSL_CTX_new(x)	(* (SSL_CTX * (*)(SSL_METHOD *)) ssl_sw[8].ptr)(x)
-#define	SSLv23_server_method()	(* (SSL_METHOD * (*)(void)) ssl_sw[9].ptr)()
-#define	SSL_library_init() (* (int (*)(void)) ssl_sw[10].ptr)()
-#define	SSL_CTX_use_PrivateKey_file(x,y,z)	(* (int (*)(SSL_CTX *, \
-		const char *, int)) ssl_sw[11].ptr)((x), (y), (z))
-#define	SSL_CTX_use_certificate_file(x,y,z)	(* (int (*)(SSL_CTX *, \
-		const char *, int)) ssl_sw[12].ptr)((x), (y), (z))
-#define SSL_CTX_set_default_passwd_cb(x,y) \
-	(* (void (*)(SSL_CTX *, mg_spcb_t)) ssl_sw[13].ptr)((x),(y))
-#define SSL_CTX_free(x) (* (void (*)(SSL_CTX *)) ssl_sw[14].ptr)(x)
-#define CRYPTO_num_locks() (* (int (*)(void)) crypto_sw[0].ptr)()
-#define CRYPTO_set_locking_callback(x)					\
-		(* (void (*)(void (*)(int, int, const char *, int)))	\
-	 	crypto_sw[1].ptr)(x)
-#define CRYPTO_set_id_callback(x)					\
-	(* (void (*)(unsigned long (*)(void))) crypto_sw[2].ptr)(x)
- * set_ssl_option() function when called, updates this array.
- * It loads SSL library dynamically and changes NULLs to the actual addresses
- * of respective functions. The macros above (like SSL_connect()) are really
- * just calling these functions indirectly via the pointer.
-static struct ssl_func	ssl_sw[] = {
-	{"SSL_free",			NULL},
-	{"SSL_accept",			NULL},
-	{"SSL_connect",			NULL},
-	{"SSL_read",			NULL},
-	{"SSL_write",			NULL},
-	{"SSL_get_error",		NULL},
-	{"SSL_set_fd",			NULL},
-	{"SSL_new",			NULL},
-	{"SSL_CTX_new",			NULL},
-	{"SSLv23_server_method",	NULL},
-	{"SSL_library_init",		NULL},
-	{"SSL_CTX_use_PrivateKey_file",	NULL},
-	{"SSL_CTX_use_certificate_file",NULL},
-	{"SSL_CTX_set_default_passwd_cb",NULL},
-	{"SSL_CTX_free",		NULL},
-	{NULL,				NULL}
+#define SSL_free (* (void (*)(SSL *)) ssl_sw[0].ptr)
+#define SSL_accept (* (int (*)(SSL *)) ssl_sw[1].ptr)
+#define SSL_connect (* (int (*)(SSL *)) ssl_sw[2].ptr)
+#define SSL_read (* (int (*)(SSL *, void *, int)) ssl_sw[3].ptr)
+#define SSL_write (* (int (*)(SSL *, const void *,int)) ssl_sw[4].ptr)
+#define SSL_get_error (* (int (*)(SSL *, int)) ssl_sw[5].ptr)
+#define SSL_set_fd (* (int (*)(SSL *, SOCKET)) ssl_sw[6].ptr)
+#define SSL_new (* (SSL * (*)(SSL_CTX *)) ssl_sw[7].ptr)
+#define SSL_CTX_new (* (SSL_CTX * (*)(SSL_METHOD *)) ssl_sw[8].ptr)
+#define SSLv23_server_method (* (SSL_METHOD * (*)(void)) ssl_sw[9].ptr)
+#define SSL_library_init (* (int (*)(void)) ssl_sw[10].ptr)
+#define SSL_CTX_use_PrivateKey_file (* (int (*)(SSL_CTX *, \
+        const char *, int)) ssl_sw[11].ptr)
+#define SSL_CTX_use_certificate_file (* (int (*)(SSL_CTX *, \
+        const char *, int)) ssl_sw[12].ptr)
+#define SSL_CTX_set_default_passwd_cb \
+  (* (void (*)(SSL_CTX *, mg_callback_t)) ssl_sw[13].ptr)
+#define SSL_CTX_free (* (void (*)(SSL_CTX *)) ssl_sw[14].ptr)
+#define SSL_load_error_strings (* (void (*)(void)) ssl_sw[15].ptr)
+#define SSL_CTX_use_certificate_chain_file \
+  (* (int (*)(SSL_CTX *, const char *)) ssl_sw[16].ptr)
+#define CRYPTO_num_locks (* (int (*)(void)) crypto_sw[0].ptr)
+#define CRYPTO_set_locking_callback \
+  (* (void (*)(void (*)(int, int, const char *, int))) crypto_sw[1].ptr)
+#define CRYPTO_set_id_callback \
+  (* (void (*)(unsigned long (*)(void))) crypto_sw[2].ptr)
+#define ERR_get_error (* (unsigned long (*)(void)) crypto_sw[3].ptr)
+#define ERR_error_string (* (char * (*)(unsigned long,char *)) crypto_sw[4].ptr)
+// set_ssl_option() function updates this array.
+// It loads SSL library dynamically and changes NULLs to the actual addresses
+// of respective functions. The macros above (like SSL_connect()) are really
+// just calling these functions indirectly via the pointer.
+static struct ssl_func ssl_sw[] = {
+  {"SSL_free",   NULL},
+  {"SSL_accept",   NULL},
+  {"SSL_connect",   NULL},
+  {"SSL_read",   NULL},
+  {"SSL_write",   NULL},
+  {"SSL_get_error",  NULL},
+  {"SSL_set_fd",   NULL},
+  {"SSL_new",   NULL},
+  {"SSL_CTX_new",   NULL},
+  {"SSLv23_server_method", NULL},
+  {"SSL_library_init",  NULL},
+  {"SSL_CTX_use_PrivateKey_file", NULL},
+  {"SSL_CTX_use_certificate_file",NULL},
+  {"SSL_CTX_set_default_passwd_cb",NULL},
+  {"SSL_CTX_free",  NULL},
+  {"SSL_load_error_strings", NULL},
+  {"SSL_CTX_use_certificate_chain_file", NULL},
+  {NULL,    NULL}
+// Similar array as ssl_sw. These functions could be located in different lib.
 #if !defined(NO_SSL)
- * Similar array as ssl_sw. These functions are located in different lib.
-static struct ssl_func	crypto_sw[] = {
-	{"CRYPTO_num_locks",		NULL},
-	{"CRYPTO_set_locking_callback",	NULL},
-	{"CRYPTO_set_id_callback",	NULL},
-	{NULL,				NULL}
+static struct ssl_func crypto_sw[] = {
+  {"CRYPTO_num_locks",  NULL},
+  {"CRYPTO_set_locking_callback", NULL},
+  {"CRYPTO_set_id_callback", NULL},
+  {"ERR_get_error",  NULL},
+  {"ERR_error_string", NULL},
+  {NULL,    NULL}
-#endif
+#endif // NO_SSL
+#endif // NO_SSL_DL
- * Month names
 static const char *month_names[] = {
-	"Jan", "Feb", "Mar", "Apr", "May", "Jun",
-	"Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
+  "Jan", "Feb", "Mar", "Apr", "May", "Jun",
+  "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
- * Unified socket address. For IPv6 support, add IPv6 address structure
- * in the union u.
-struct usa {
-	socklen_t len;
-	union {
-		struct sockaddr	sa;
-		struct sockaddr_in sin;
-	} u;
+// Unified socket address. For IPv6 support, add IPv6 address structure
+// in the union u.
+union usa {
+  struct sockaddr sa;
+  struct sockaddr_in sin;
+#if defined(USE_IPV6)
+  struct sockaddr_in6 sin6;
+#endif
- * Specifies a string (chunk of memory).
- * Used to traverse comma separated lists of options.
+// Describes a string (chunk of memory).
 struct vec {
-	const char	*ptr;
-	size_t		len;
+  const char *ptr;
+  size_t len;
- * Structure used by mg_stat() function. Uses 64 bit file length.
+// Structure used by mg_stat() function. Uses 64 bit file length.
 struct mgstat {
-	bool_t		is_directory;	/* Directory marker		*/
-	int64_t		size;		/* File size			*/
-	time_t		mtime;		/* Modification time		*/
+  int is_directory;  // Directory marker
+  int64_t size;      // File size
+  time_t mtime;      // Modification time
-struct mg_option {
-	const char	*name;
-	const char	*description;
-	const char	*default_value;
-	int		index;
-	bool_t (*setter)(struct mg_context *, const char *);
- * Numeric indexes for the option values in context, ctx->options
-enum mg_option_index {
-	OPT_ROOT, OPT_INDEX_FILES, OPT_PORTS, OPT_DIR_LIST, OPT_CGI_EXTENSIONS,
-	OPT_CGI_INTERPRETER, OPT_CGI_ENV, OPT_SSI_EXTENSIONS, OPT_AUTH_DOMAIN,
-	OPT_AUTH_GPASSWD, OPT_AUTH_PUT, OPT_ACCESS_LOG, OPT_ERROR_LOG,
-	OPT_SSL_CERTIFICATE, OPT_ALIASES, OPT_ACL, OPT_UID, OPT_PROTECT,
-	OPT_SERVICE, OPT_HIDE, OPT_ADMIN_URI, OPT_MAX_THREADS, OPT_IDLE_TIME,
-	OPT_MIME_TYPES,
-	NUM_OPTIONS
+// Describes listening socket, or socket which was accept()-ed by the master
+// thread and queued for future handling by the worker thread.
+struct socket {
+  struct socket *next;  // Linkage
+  SOCKET sock;          // Listening socket
+  union usa lsa;        // Local socket address
+  union usa rsa;        // Remote socket address
+  int is_ssl;           // Is socket SSL-ed
- * Structure used to describe listening socket, or socket which was
- * accept()-ed by the master thread and queued for future handling
- * by the worker thread.
-struct socket {
-	SOCKET		sock;		/* Listening socket		*/
-	struct usa	lsa;		/* Local socket address		*/
-	struct usa	rsa;		/* Remote socket address	*/
-	bool_t		is_ssl;		/* Is socket SSL-ed		*/
+enum {
+  CGI_EXTENSIONS, CGI_ENVIRONMENT, PUT_DELETE_PASSWORDS_FILE, CGI_INTERPRETER,
+  PROTECT_URI, AUTHENTICATION_DOMAIN, SSI_EXTENSIONS, ACCESS_LOG_FILE,
+  SSL_CHAIN_FILE, ENABLE_DIRECTORY_LISTING, ERROR_LOG_FILE,
+  GLOBAL_PASSWORDS_FILE, INDEX_FILES,
+  ENABLE_KEEP_ALIVE, ACCESS_CONTROL_LIST, MAX_REQUEST_SIZE,
+  EXTRA_MIME_TYPES, LISTENING_PORTS,
+  DOCUMENT_ROOT, SSL_CERTIFICATE, NUM_THREADS, RUN_AS_USER, REWRITE,
+  NUM_OPTIONS
- * Callback function, and where it is bound to
-struct callback {
-	char		*uri_regex;	/* URI regex to handle		*/
-	mg_callback_t	func;		/* user callback		*/
-	bool_t		is_auth;	/* func is auth checker		*/
-	int		status_code;	/* error code to handle		*/
-	void		*user_data;	/* opaque user data		*/
+static const char *config_options[] = {
+  "C", "cgi_pattern", "**.cgi$|**.pl$|**.php$",
+  "E", "cgi_environment", NULL,
+  "G", "put_delete_passwords_file", NULL,
+  "I", "cgi_interpreter", NULL,
+  "P", "protect_uri", NULL,
+  "R", "authentication_domain", "mydomain.com",
+  "S", "ssi_pattern", "**.shtml$|**.shtm$",
+  "a", "access_log_file", NULL,
+  "c", "ssl_chain_file", NULL,
+  "d", "enable_directory_listing", "yes",
+  "e", "error_log_file", NULL,
+  "g", "global_passwords_file", NULL,
+  "i", "index_files", "index.html,index.htm,index.cgi,index.shtml,index.php",
+  "k", "enable_keep_alive", "no",
+  "l", "access_control_list", NULL,
+  "M", "max_request_size", "16384",
+  "m", "extra_mime_types", NULL,
+  "p", "listening_ports", "8080",
+  "r", "document_root",  ".",
+  "s", "ssl_certificate", NULL,
+  "t", "num_threads", "10",
+  "u", "run_as_user", NULL,
+  "w", "url_rewrite_patterns", NULL,
+  NULL
+#define ENTRIES_PER_CONFIG_OPTION 3
- * Mongoose context
 struct mg_context {
-	int		stop_flag;	/* Should we stop event loop	*/
-	SSL_CTX		*ssl_ctx;	/* SSL context			*/
+  volatile int stop_flag;       // Should we stop event loop
+  SSL_CTX *ssl_ctx;             // SSL context
+  char *config[NUM_OPTIONS];    // Mongoose configuration parameters
+  mg_callback_t user_callback;  // User-defined callback function
+  void *user_data;              // User-defined data
+  struct socket *listening_sockets;
+  volatile int num_threads;  // Number of threads
+  pthread_mutex_t mutex;     // Protects (max|num)_threads
+  pthread_cond_t  cond;      // Condvar for tracking workers terminations
+  struct socket queue[20];   // Accepted sockets
+  volatile int sq_head;      // Head of the socket queue
+  volatile int sq_tail;      // Tail of the socket queue
+  pthread_cond_t sq_full;    // Singaled when socket is produced
+  pthread_cond_t sq_empty;   // Signaled when socket is consumed
-	FILE		*access_log;	/* Opened access log		*/
-	FILE		*error_log;	/* Opened error log		*/
+struct mg_connection {
+  struct mg_request_info request_info;
+  struct mg_context *ctx;
+  SSL *ssl;                   // SSL descriptor
+  struct socket client;       // Connected client
+  time_t birth_time;          // Time connection was accepted
+  int64_t num_bytes_sent;     // Total bytes sent to client
+  int64_t content_len;        // Content-Length header value
+  int64_t consumed_content;   // How many bytes of content is already read
+  char *buf;                  // Buffer for received data
+  char *path_info;            // PATH_INFO part of the URL
+  int must_close;             // 1 if connection must be closed
+  int buf_size;               // Buffer size
+  int request_len;            // Size of the request + headers in a buffer
+  int data_len;               // Total size of data in a buffer
-	struct socket	listeners[MAX_LISTENING_SOCKETS];
-	int		num_listeners;
+const char **mg_get_valid_option_names(void) {
+  return config_options;
+static void *call_user(struct mg_connection *conn, enum mg_event event) {
+  conn->request_info.user_data = conn->ctx->user_data;
+  return conn->ctx->user_callback == NULL ? NULL :
+    conn->ctx->user_callback(event, conn, &conn->request_info);
+static int get_option_index(const char *name) {
+  int i;
+  for (i = 0; config_options[i] != NULL; i += ENTRIES_PER_CONFIG_OPTION) {
+    if (strcmp(config_options[i], name) == 0 ||
+        strcmp(config_options[i + 1], name) == 0) {
+      return i / ENTRIES_PER_CONFIG_OPTION;
+  return -1;
+const char *mg_get_option(const struct mg_context *ctx, const char *name) {
+  int i;
+  if ((i = get_option_index(name)) == -1) {
+    return NULL;
+  } else if (ctx->config[i] == NULL) {
+    return "";
+  } else {
+    return ctx->config[i];
+static void sockaddr_to_string(char *buf, size_t len,
+                                     const union usa *usa) {
+  buf[0] = '\0';
+  inet_ntop(usa->sa.sa_family, usa->sa.sa_family == AF_INET ?
+            (void *) &usa->sin.sin_addr :
+            (void *) &usa->sin6.sin6_addr, buf, len);
+#elif defined(_WIN32)
+  // Only Windoze Vista (and newer) have inet_ntop()
+  strncpy(buf, inet_ntoa(usa->sin.sin_addr), len);
+#else
+  inet_ntop(usa->sa.sa_family, (void *) &usa->sin.sin_addr, buf, len);
+#endif
-	struct callback	callbacks[MAX_CALLBACKS];
-	int		num_callbacks;
+// Print error message to the opened error log stream.
+static void cry(struct mg_connection *conn, const char *fmt, ...) {
+  char buf[BUFSIZ], src_addr[20];
+  va_list ap;
+  FILE *fp;
+  time_t timestamp;
-	char		*options[NUM_OPTIONS];	/* Configured opions	*/
-	pthread_mutex_t	opt_mutex[NUM_OPTIONS];	/* Option protector	*/
+  va_start(ap, fmt);
+  (void) vsnprintf(buf, sizeof(buf), fmt, ap);
+  va_end(ap);
-	int		max_threads;	/* Maximum number of threads	*/
-	int		num_threads;	/* Number of threads		*/
-	int		num_idle;	/* Number of idle threads	*/
-	pthread_mutex_t	thr_mutex;	/* Protects (max|num)_threads	*/
-	pthread_cond_t	thr_cond;
-	pthread_mutex_t	bind_mutex;	/* Protects bind operations	*/
+  // Do not lock when getting the callback value, here and below.
+  // I suppose this is fine, since function cannot disappear in the
+  // same way string option can.
+  conn->request_info.log_message = buf;
+  if (call_user(conn, MG_EVENT_LOG) == NULL) {
+    fp = conn->ctx->config[ERROR_LOG_FILE] == NULL ? NULL :
+      mg_fopen(conn->ctx->config[ERROR_LOG_FILE], "a+");
-	struct socket	queue[20];	/* Accepted sockets		*/
-	int		sq_head;	/* Head of the socket queue	*/
-	int		sq_tail;	/* Tail of the socket queue	*/
-	pthread_cond_t	empty_cond;	/* Socket queue empty condvar	*/
-	pthread_cond_t	full_cond;	/* Socket queue full condvar	*/
+    if (fp != NULL) {
+      flockfile(fp);
+      timestamp = time(NULL);
-	mg_spcb_t	ssl_password_callback;
-	mg_callback_t	log_callback;
+      sockaddr_to_string(src_addr, sizeof(src_addr), &conn->client.rsa);
+      fprintf(fp, "[%010lu] [error] [client %s] ", (unsigned long) timestamp,
+              src_addr);
- * Client connection.
-struct mg_connection {
-	struct mg_request_info	request_info;
-	struct mg_context *ctx;		/* Mongoose context we belong to*/
-	SSL		*ssl;		/* SSL descriptor		*/
-	struct socket	client;		/* Connected client		*/
-	time_t		birth_time;	/* Time connection was accepted	*/
-	bool_t		free_post_data;	/* post_data was malloc-ed	*/
-	bool_t		embedded_auth;	/* Used for authorization	*/
-	int64_t		num_bytes_sent;	/* Total bytes sent to client	*/
+      if (conn->request_info.request_method != NULL) {
+        fprintf(fp, "%s %s: ", conn->request_info.request_method,
+                conn->request_info.uri);
- * Print error message to the opened error log stream.
-static void
-cry(struct mg_connection *conn, const char *fmt, ...)
-	char	buf[BUFSIZ];
-	va_list	ap;
+      (void) fprintf(fp, "%s", buf);
+      fputc('\n', fp);
+      funlockfile(fp);
+      if (fp != stderr) {
+        fclose(fp);
+  conn->request_info.log_message = NULL;
-	va_start(ap, fmt);
-	(void) vsnprintf(buf, sizeof(buf), fmt, ap);
-	conn->ctx->log_callback(conn, &conn->request_info, buf);
-	va_end(ap);
+// Return fake connection structure. Used for logging, if connection
+// is not applicable at the moment of logging.
+static struct mg_connection *fc(struct mg_context *ctx) {
+  static struct mg_connection fake_connection;
+  fake_connection.ctx = ctx;
+  return &fake_connection;
- * Return fake connection structure. Used for logging, if connection
- * is not applicable at the moment of logging.
-static struct mg_connection *
-fc(struct mg_context *ctx)
-	static struct mg_connection fake_connection;
-	fake_connection.ctx = ctx;
-	return (&fake_connection);
+const char *mg_version(void) {
+  return MONGOOSE_VERSION;
- * If an embedded code does not intercept logging by calling
- * mg_set_log_callback(), this function is used for logging. It prints
- * stuff to the conn->error_log, which is stderr unless "error_log"
- * option was set.
-static void
-builtin_error_log(struct mg_connection *conn,
-		const struct mg_request_info *request_info, void *message)
-	FILE	*fp;
-	time_t	timestamp;
+static void mg_strlcpy(register char *dst, register const char *src, size_t n) {
+  for (; *src != '\0' && n > 1; n--) {
+    *dst++ = *src++;
+  *dst = '\0';
-	fp = conn->ctx->error_log;
-	flockfile(fp);
+static int lowercase(const char *s) {
+  return tolower(* (const unsigned char *) s);
-	timestamp = time(NULL);
+static int mg_strncasecmp(const char *s1, const char *s2, size_t len) {
+  int diff = 0;
-	(void) fprintf(fp,
-	    "[%010lu] [error] [client %s] ",
-	    (unsigned long) timestamp,
-	    inet_ntoa(conn->client.rsa.u.sin.sin_addr));
+  if (len > 0)
+    do {
+      diff = lowercase(s1++) - lowercase(s2++);
+    } while (diff == 0 && s1[-1] != '\0' && --len > 0);
-	if (request_info->request_method != NULL)
-		(void) fprintf(fp, "%s %s: ",
-		    request_info->request_method,
-		    request_info->uri);
+  return diff;
-	(void) fprintf(fp, "%s", (char *) message);
+static int mg_strcasecmp(const char *s1, const char *s2) {
+  int diff;
-	fputc('\n', fp);
+  do {
+  } while (diff == 0 && s1[-1] != '\0');
-	funlockfile(fp);
+  return diff;
-const char *
-mg_version(void)
-	return (MONGOOSE_VERSION);
+static char * mg_strndup(const char *ptr, size_t len) {
+  char *p;
+  if ((p = (char *) malloc(len + 1)) != NULL) {
+    mg_strlcpy(p, ptr, len + 1);
-static void
-mg_strlcpy(register char *dst, register const char *src, size_t n)
-	for (; *src != '\0' && n > 1; n--)
-		*dst++ = *src++;
-	*dst = '\0';
+  return p;
-static int
-lowercase(const char *s)
-	return (tolower(* (unsigned char *) s));
+static char * mg_strdup(const char *str) {
+  return mg_strndup(str, strlen(str));
-static int
-mg_strncasecmp(const char *s1, const char *s2, size_t len)
-	int	diff = 0;
+// Like snprintf(), but never returns negative value, or the value
+// that is larger than a supplied buffer.
+// Thanks to Adam Zeldis to pointing snprintf()-caused vulnerability
+// in his audit report.
+static int mg_vsnprintf(struct mg_connection *conn, char *buf, size_t buflen,
+                        const char *fmt, va_list ap) {
+  int n;
-	if (len > 0)
-		do {
-			diff = lowercase(s1++) - lowercase(s2++);
-		} while (diff == 0 && s1[-1] != '\0' && --len > 0);
+  if (buflen == 0)
+    return 0;
-	return (diff);
+  n = vsnprintf(buf, buflen, fmt, ap);
+  if (n < 0) {
+    cry(conn, "vsnprintf error");
+    n = 0;
+  } else if (n >= (int) buflen) {
+    cry(conn, "truncating vsnprintf buffer: [%.*s]",
+        n > 200 ? 200 : n, buf);
+    n = (int) buflen - 1;
+  buf[n] = '\0';
+  return n;
-static int
-mg_strcasecmp(const char *s1, const char *s2)
-	int	diff;
+static int mg_snprintf(struct mg_connection *conn, char *buf, size_t buflen,
+                       const char *fmt, ...) {
+  va_list ap;
+  int n;
-	do {
-	} while (diff == 0 && s1[-1] != '\0');
+  n = mg_vsnprintf(conn, buf, buflen, fmt, ap);
+  va_end(ap);
-	return (diff);
+  return n;
-static char *
-mg_strndup(const char *ptr, size_t len)
-	char	*p;
+// Skip the characters until one of the delimiters characters found.
+// 0-terminate resulting word. Skip the delimiter and following whitespaces if any.
+// Advance pointer to buffer to the next word. Return found 0-terminated word.
+// Delimiters can be quoted with quotechar.
+static char *skip_quoted(char **buf, const char *delimiters, const char *whitespace, char quotechar) {
+  char *p, *begin_word, *end_word, *end_whitespace;
-	if ((p = (char *) malloc(len + 1)) != NULL)
-		mg_strlcpy(p, ptr, len + 1);
-	return (p);
+  begin_word = *buf;
+  end_word = begin_word + strcspn(begin_word, delimiters);
+  // Check for quotechar
+  if (end_word > begin_word) {
+    p = end_word - 1;
+    while (*p == quotechar) {
+      // If there is anything beyond end_word, copy it
+      if (*end_word == '\0') {
+        *p = '\0';
+        break;
+      } else {
+        size_t end_off = strcspn(end_word + 1, delimiters);
+        memmove (p, end_word, end_off + 1);
+        p += end_off; // p must correspond to end_word - 1
+        end_word += end_off + 1;
+    for (p++; p < end_word; p++) {
+      *p = '\0';
+    *buf = end_word;
+  } else {
+    end_whitespace = end_word + 1 + strspn(end_word + 1, whitespace);
+    for (p = end_word; p < end_whitespace; p++) {
+      *p = '\0';
+    *buf = end_whitespace;
+  return begin_word;
+// Simplified version of skip_quoted without quote char
+// and whitespace == delimiters
+static char *skip(char **buf, const char *delimiters) {
+  return skip_quoted(buf, delimiters, delimiters, 0);
+// Return HTTP header value, or NULL if not found.
+static const char *get_header(const struct mg_request_info *ri,
+                              const char *name) {
+  int i;
+  for (i = 0; i < ri->num_headers; i++)
+    if (!mg_strcasecmp(name, ri->http_headers[i].name))
+      return ri->http_headers[i].value;
+  return NULL;
+const char *mg_get_header(const struct mg_connection *conn, const char *name) {
+  return get_header(&conn->request_info, name);
+// A helper function for traversing comma separated list of values.
+// It returns a list pointer shifted to the next value, of NULL if the end
+// of the list found.
+// Value is stored in val vector. If value has form "x=y", then eq_val
+// vector is initialized to point to the "y" part, and val vector length
+// is adjusted to point only to "x".
+static const char *next_option(const char *list, struct vec *val,
+                               struct vec *eq_val) {
+  if (list == NULL || *list == '\0') {
+    // End of the list
+    list = NULL;
+  } else {
+    val->ptr = list;
+    if ((list = strchr(val->ptr, ',')) != NULL) {
+      // Comma found. Store length and shift the list ptr
+      val->len = list - val->ptr;
+      list++;
+    } else {
+      // This value is the last one
+      list = val->ptr + strlen(val->ptr);
+    if (eq_val != NULL) {
+      // Value has form "x=y", adjust pointers and lengths
+      // so that val points to "x", and eq_val points to "y".
+      eq_val->len = 0;
+      eq_val->ptr = (const char *) memchr(val->ptr, '=', val->len);
+      if (eq_val->ptr != NULL) {
+        eq_val->ptr++;  // Skip over '=' character
+        eq_val->len = val->ptr + val->len - eq_val->ptr;
+        val->len = (eq_val->ptr - val->ptr) - 1;
+  return list;
+static int match_prefix(const char *pattern, int pattern_len, const char *str) {
+  const char *or_str;
+  int i, j, len, res;
+  if ((or_str = (const char *) memchr(pattern, '|', pattern_len)) != NULL) {
+    res = match_prefix(pattern, or_str - pattern, str);
+    return res > 0 ? res :
+        match_prefix(or_str + 1, (pattern + pattern_len) - (or_str + 1), str);
+  i = j = 0;
+  res = -1;
+  for (; i < pattern_len; i++, j++) {
+    if (pattern[i] == '?' && str[j] != '\0') {
+      continue;
+    } else if (pattern[i] == '$') {
+      return str[j] == '\0' ? j : -1;
+    } else if (pattern[i] == '*') {
+      i++;
+      if (pattern[i] == '*') {
+        i++;
+        len = strlen(str + j);
+      } else {
+        len = strcspn(str + j, "/");
+      if (i == pattern_len) {
+        return j + len;
+      do {
+        res = match_prefix(pattern + i, pattern_len - i, str + j + len);
+      } while (res == -1 && len-- > 0);
+      return res == -1 ? -1 : j + res + len;
+    } else if (pattern[i] != str[j]) {
+      return -1;
+  return j;
+// HTTP 1.1 assumes keep alive if "Connection:" header is not set
+// This function must tolerate situations when connection info is not
+// set up, for example if request parsing failed.
+static int should_keep_alive(const struct mg_connection *conn) {
+  const char *http_version = conn->request_info.http_version;
+  const char *header = mg_get_header(conn, "Connection");
+  if (conn->must_close ||
+      conn->request_info.status_code == 401 ||
+      mg_strcasecmp(conn->ctx->config[ENABLE_KEEP_ALIVE], "yes") != 0 ||
+      (header != NULL && mg_strcasecmp(header, "keep-alive") != 0) ||
+      (header == NULL && http_version && strcmp(http_version, "1.1"))) {
+    return 0;
+  return 1;
+static const char *suggest_connection_header(const struct mg_connection *conn) {
+  return should_keep_alive(conn) ? "keep-alive" : "close";
+static void send_http_error(struct mg_connection *conn, int status,
+                            const char *reason, const char *fmt, ...) {
+  char buf[BUFSIZ];
+  va_list ap;
+  int len;
+  conn->request_info.status_code = status;
+  if (call_user(conn, MG_HTTP_ERROR) == NULL) {
+    buf[0] = '\0';
+    len = 0;
+    // Errors 1xx, 204 and 304 MUST NOT send a body
+    if (status > 199 && status != 204 && status != 304) {
+      len = mg_snprintf(conn, buf, sizeof(buf), "Error %d: %s", status, reason);
+      cry(conn, "%s", buf);
+      buf[len++] = '\n';
+      len += mg_vsnprintf(conn, buf + len, sizeof(buf) - len, fmt, ap);
+      va_end(ap);
+    DEBUG_TRACE(("[%s]", buf));
+    mg_printf(conn, "HTTP/1.1 %d %s\r\n"
+              "Content-Type: text/plain\r\n"
+              "Content-Length: %d\r\n"
+              "Connection: %s\r\n\r\n", status, reason, len,
+              suggest_connection_header(conn));
+    conn->num_bytes_sent += mg_printf(conn, "%s", buf);
+static int pthread_mutex_init(pthread_mutex_t *mutex, void *unused) {
+  unused = NULL;
+  *mutex = CreateMutex(NULL, FALSE, NULL);
+  return *mutex == NULL ? -1 : 0;
+static int pthread_mutex_destroy(pthread_mutex_t *mutex) {
+  return CloseHandle(*mutex) == 0 ? -1 : 0;
+static int pthread_mutex_lock(pthread_mutex_t *mutex) {
+  return WaitForSingleObject(*mutex, INFINITE) == WAIT_OBJECT_0? 0 : -1;
+static int pthread_mutex_unlock(pthread_mutex_t *mutex) {
+  return ReleaseMutex(*mutex) == 0 ? -1 : 0;
+static int pthread_cond_init(pthread_cond_t *cv, const void *unused) {
+  unused = NULL;
+  cv->signal = CreateEvent(NULL, FALSE, FALSE, NULL);
+  cv->broadcast = CreateEvent(NULL, TRUE, FALSE, NULL);
+  return cv->signal != NULL && cv->broadcast != NULL ? 0 : -1;
+static int pthread_cond_wait(pthread_cond_t *cv, pthread_mutex_t *mutex) {
+  HANDLE handles[] = {cv->signal, cv->broadcast};
+  ReleaseMutex(*mutex);
+  WaitForMultipleObjects(2, handles, FALSE, INFINITE);
+static int pthread_cond_signal(pthread_cond_t *cv) {
+  return SetEvent(cv->signal) == 0 ? -1 : 0;
+static int pthread_cond_broadcast(pthread_cond_t *cv) {
+  // Implementation with PulseEvent() has race condition, see
+  // http://www.cs.wustl.edu/~schmidt/win32-cv-1.html
+  return PulseEvent(cv->broadcast) == 0 ? -1 : 0;
-static char *
-mg_strdup(const char *str)
-	return (mg_strndup(str, strlen(str)));
+static int pthread_cond_destroy(pthread_cond_t *cv) {
+  return CloseHandle(cv->signal) && CloseHandle(cv->broadcast) ? 0 : -1;
- * Like snprintf(), but never returns negative value, or the value
- * that is larger than a supplied buffer.
- * Thanks to Adam Zeldis to pointing snprintf()-caused vulnerability
- * in his audit report.
-static int
-mg_vsnprintf(struct mg_connection *conn,
-		char *buf, size_t buflen, const char *fmt, va_list ap)
-	int	n;
+// For Windows, change all slashes to backslashes in path names.
+static void change_slashes_to_backslashes(char *path) {
+  int i;
-	if (buflen == 0)
-		return (0);
+  for (i = 0; path[i] != '\0'; i++) {
+    if (path[i] == '/')
+      path[i] = '\\';
+    // i > 0 check is to preserve UNC paths, like \\server\file.txt
+    if (path[i] == '\\' && i > 0)
+      while (path[i + 1] == '\\' || path[i + 1] == '/')
+        (void) memmove(path + i + 1,
+            path + i + 2, strlen(path + i + 1));
-	n = vsnprintf(buf, buflen, fmt, ap);
+// Encode 'path' which is assumed UTF-8 string, into UNICODE string.
+// wbuf and wbuf_len is a target buffer and its length.
+static void to_unicode(const char *path, wchar_t *wbuf, size_t wbuf_len) {
+  char buf[PATH_MAX], buf2[PATH_MAX], *p;
-	if (n < 0) {
-		cry(conn, "vsnprintf error");
-		n = 0;
-	} else if (n >= (int) buflen) {
-		cry(conn, "truncating vsnprintf buffer: [%.*s]",
-		    n > 200 ? 200 : n, buf);
-		n = (int) buflen - 1;
-	buf[n] = '\0';
+  mg_strlcpy(buf, path, sizeof(buf));
+  change_slashes_to_backslashes(buf);
-	return (n);
+  // Point p to the end of the file name
+  p = buf + strlen(buf) - 1;
-static int
-mg_snprintf(struct mg_connection *conn,
-		char *buf, size_t buflen, const char *fmt, ...)
-	va_list	ap;
-	int	n;
-	n = mg_vsnprintf(conn, buf, buflen, fmt, ap);
-	va_end(ap);
-	return (n);
- * Convert string representing a boolean value to a boolean value
-static bool_t
-is_true(const char *str)
-	static const char	*trues[] = {"1", "yes", "true", "ja", NULL};
-	int			i;
-	for (i = 0; trues[i] != NULL; i++)
-		if (str != NULL && mg_strcasecmp(str, trues[i]) == 0)
-			return (TRUE);
-	return (FALSE);
- * Skip the characters until one of the delimiters characters found.
- * 0-terminate resulting word. Skip the rest of the delimiters if any.
- * Advance pointer to buffer to the next word. Return found 0-terminated word.
-static char *
-skip(char **buf, const char *delimiters)
-	char	*p, *begin_word, *end_word, *end_delimiters;
-	begin_word = *buf;
-	end_word = begin_word + strcspn(begin_word, delimiters);
-	end_delimiters = end_word + strspn(end_word, delimiters);
-	for (p = end_word; p < end_delimiters; p++)
-		*p = '\0';
-	*buf = end_delimiters;
-	return (begin_word);
- * Return HTTP header value, or NULL if not found.
-static const char *
-get_header(const struct mg_request_info *ri, const char *name)
-	int	i;
-	for (i = 0; i < ri->num_headers; i++)
-		if (!mg_strcasecmp(name, ri->http_headers[i].name))
-			return (ri->http_headers[i].value);
-	return (NULL);
-const char *
-mg_get_header(const struct mg_connection *conn, const char *name)
-	return (get_header(&conn->request_info, name));
- * A helper function for traversing comma separated list of values.
- * It returns a list pointer shifted to the next value, of NULL if the end
- * of the list found.
- * Value is stored in val vector. If value has form "x=y", then eq_val
- * vector is initialized to point to the "y" part, and val vector length
- * is adjusted to point only to "x".
-next_option(const char *list, struct vec *val, struct vec *eq_val)
-	if (list == NULL || *list == '\0') {
-		/* End of the list */
-		list = NULL;
-	} else {
-		val->ptr = list;
-		if ((list = strchr(val->ptr, ',')) != NULL) {
-			/* Comma found. Store length and shift the list ptr */
-			val->len = list - val->ptr;
-			list++;
-		} else {
-			/* This value is the last one */
-			list = val->ptr + strlen(val->ptr);
-		if (eq_val != NULL) {
-			 * Value has form "x=y", adjust pointers and lengths
-			 * so that val points to "x", and eq_val points to "y".
-			eq_val->len = 0;
-			eq_val->ptr = memchr(val->ptr, '=', val->len);
-			if (eq_val->ptr != NULL) {
-				eq_val->ptr++;  /* Skip over '=' character */
-				eq_val->len = val->ptr + val->len - eq_val->ptr;
-				val->len = (eq_val->ptr - val->ptr) - 1;
-	return (list);
-#if !(defined(NO_CGI) && defined(NO_SSI))
- * Verify that given file has certain extension
-static bool_t
-match_extension(const char *path, const char *ext_list)
-	struct vec	ext_vec;
-	size_t		path_len;
-	path_len = strlen(path);
-	while ((ext_list = next_option(ext_list, &ext_vec, NULL)) != NULL)
-		if (ext_vec.len < path_len &&
-		    mg_strncasecmp(path + path_len - ext_vec.len,
-			    ext_vec.ptr, ext_vec.len) == 0)
-			return (TRUE);
-	return (FALSE);
-#endif /* !(NO_CGI && NO_SSI) */
- * Return TRUE if "uri" matches "regexp".
- * '*' in the regexp means zero or more characters.
-static bool_t
-match_regex(const char *uri, const char *regexp)
-	if (*regexp == '\0')
-		return (*uri == '\0');
-	if (*regexp == '*')
-		do {
-			if (match_regex(uri, regexp + 1))
-				return (TRUE);
-		} while (*uri++ != '\0');
-	if (*uri != '\0' && *regexp == *uri)
-		return (match_regex(uri + 1, regexp + 1));
-	return (FALSE);
-static const struct callback *
-find_callback(struct mg_context *ctx, bool_t is_auth,
-		const char *uri, int status_code)
-	const struct callback	*cb, *found;
-	int			i;
-	found = NULL;
-	pthread_mutex_lock(&ctx->bind_mutex);
-	for (i = 0; i < ctx->num_callbacks; i++) {
-		cb = ctx->callbacks + i;
-		if ((uri != NULL && cb->uri_regex != NULL &&
-		    ((is_auth && cb->is_auth) || (!is_auth && !cb->is_auth)) &&
-		    match_regex(uri, cb->uri_regex)) || (uri == NULL &&
-		     (cb->status_code == 0 ||
-		      cb->status_code == status_code))) {
-			found = cb;
-			break;
-	pthread_mutex_unlock(&ctx->bind_mutex);
-	return (found);
- * For use by external application. This sets custom logging function.
-void
-mg_set_log_callback(struct mg_context *ctx, mg_callback_t log_callback)
-	/* If NULL is specified as a callback, revert back to the default */
-	if (log_callback == NULL)
-		ctx->log_callback = &builtin_error_log;
-	else
-		ctx->log_callback = log_callback;
- * Send error message back to the client.
-static void
-send_error(struct mg_connection *conn, int status, const char *reason,
-		const char *fmt, ...)
-	const struct callback	*cb;
-	char		buf[BUFSIZ];
-	va_list		ap;
-	int		len;
-	conn->request_info.status_code = status;
-	/* If error handler is set, call it. Otherwise, send error message */
-	if ((cb = find_callback(conn->ctx, FALSE, NULL, status)) != NULL) {
-		cb->func(conn, &conn->request_info, cb->user_data);
-	} else {
-		buf[0] = '\0';
-		len = 0;
-		/* Errors 1xx, 204 and 304 MUST NOT send a body */
-		if (status > 199 && status != 204 && status != 304) {
-			len = mg_snprintf(conn, buf, sizeof(buf),
-			    "Error %d: %s\n", status, reason);
-			cry(conn, "%s", buf);
-			len += mg_vsnprintf(conn, buf + len, sizeof(buf) - len,
-			    fmt, ap);
-			va_end(ap);
-			conn->num_bytes_sent = len;
-		(void) mg_printf(conn,
-		    "HTTP/1.1 %d %s\r\n"
-		    "Content-Type: text/plain\r\n"
-		    "Content-Length: %d\r\n"
-		    "Connection: close\r\n"
-		    "\r\n%s", status, reason, len, buf);
+  // Trim trailing backslash character
+  while (p > buf && *p == '\\' && p[-1] != ':') {
+    *p-- = '\0';
-#ifdef _WIN32
-static int
-pthread_mutex_init(pthread_mutex_t *mutex, void *unused)
-	unused = NULL;
-	*mutex = CreateMutex(NULL, FALSE, NULL);
-	return (*mutex == NULL ? -1 : 0);
-static int
-pthread_mutex_destroy(pthread_mutex_t *mutex)
-	return (CloseHandle(*mutex) == 0 ? -1 : 0);
-static int
-pthread_mutex_lock(pthread_mutex_t *mutex)
-	return (WaitForSingleObject(*mutex, INFINITE) == WAIT_OBJECT_0? 0 : -1);
-static int
-pthread_mutex_unlock(pthread_mutex_t *mutex)
-	return (ReleaseMutex(*mutex) == 0 ? -1 : 0);
-static int
-pthread_cond_init(pthread_cond_t *cv, const void *unused)
-	unused = NULL;
-	*cv = CreateEvent(NULL, FALSE, FALSE, NULL);
-	return (*cv == NULL ? -1 : 0);
-static int
-pthread_cond_timedwait(pthread_cond_t *cv, pthread_mutex_t *mutex,
-	const struct timespec *ts)
-	DWORD	status;
-	DWORD	msec = INFINITE;
-	time_t	now;
-	if (ts != NULL) {
-		now = time(NULL);
-		msec = 1000 * (now > ts->tv_sec ? 0 : ts->tv_sec - now);
-	(void) ReleaseMutex(*mutex);
-	status = WaitForSingleObject(*cv, msec);
-	(void) WaitForSingleObject(*mutex, INFINITE);
-	return (status == WAIT_OBJECT_0 ? 0 : -1);
-static int
-pthread_cond_wait(pthread_cond_t *cv, pthread_mutex_t *mutex)
-	return (pthread_cond_timedwait(cv, mutex, NULL));
-static int
-pthread_cond_signal(pthread_cond_t *cv)
-	return (SetEvent(*cv) == 0 ? -1 : 0);
-static int
-pthread_cond_destroy(pthread_cond_t *cv)
-	return (CloseHandle(*cv) == 0 ? -1 : 0);
-static pthread_t
-pthread_self(void)
-	return (GetCurrentThreadId());
- * Change all slashes to backslashes. It is Windows.
-static void
-fix_directory_separators(char *path)
-	int	i;
-	for (i = 0; path[i] != '\0'; i++) {
-		if (path[i] == '/')
-			path[i] = '\\';
-		/* i > 0 check is to preserve UNC paths, \\server\file.txt */
-		if (path[i] == '\\' && i > 0)
-			while (path[i + 1] == '\\' || path[i + 1] == '/')
-				(void) memmove(path + i + 1,
-				    path + i + 2, strlen(path + i + 1));
- * Encode 'path' which is assumed UTF-8 string, into UNICODE string.
- * wbuf and wbuf_len is a target buffer and its length.
-static void
-to_unicode(const char *path, wchar_t *wbuf, size_t wbuf_len)
-	char	buf[FILENAME_MAX], *p;
-	mg_strlcpy(buf, path, sizeof(buf));
-	fix_directory_separators(buf);
-	/* Point p to the end of the file name */
-	p = buf + strlen(buf) - 1;
-	/* Trim trailing backslash character */
-	while (p > buf && *p == '\\' && p[-1] != ':')
-		*p-- = '\0';
-	 * Protect from CGI code disclosure.
-	 * This is very nasty hole. Windows happily opens files with
-	 * some garbage in the end of file name. So fopen("a.cgi    ", "r")
-	 * actually opens "a.cgi", and does not return an error!
-	if (*p == 0x20 ||               /* No space at the end */
-	    (*p == 0x2e && p > buf) ||  /* No '.' but allow '.' as full path */
-	    *p == 0x2b ||               /* No '+' */
-	    (*p & ~0x7f)) {             /* And generally no non-ascii chars */
-		(void) fprintf(stderr, "Rejecting suspicious path: [%s]", buf);
-		buf[0] = '\0';
-	(void) MultiByteToWideChar(CP_UTF8, 0, buf, -1, wbuf, (int) wbuf_len);
+   // Protect from CGI code disclosure.
+   // This is very nasty hole. Windows happily opens files with
+   // some garbage in the end of file name. So fopen("a.cgi    ", "r")
+   // actually opens "a.cgi", and does not return an error!
+  if (*p == 0x20 ||               // No space at the end
+      (*p == 0x2e && p > buf) ||  // No '.' but allow '.' as full path
+      *p == 0x2b ||               // No '+'
+      (*p & ~0x7f)) {             // And generally no non-ascii chars
+    (void) fprintf(stderr, "Rejecting suspicious path: [%s]", buf);
+    wbuf[0] = L'\0';
+  } else {
+    // Convert to Unicode and back. If doubly-converted string does not
+    // match the original, something is fishy, reject.
+    memset(wbuf, 0, wbuf_len * sizeof(wchar_t));
+    MultiByteToWideChar(CP_UTF8, 0, buf, -1, wbuf, (int) wbuf_len);
+    WideCharToMultiByte(CP_UTF8, 0, wbuf, (int) wbuf_len, buf2, sizeof(buf2),
+                        NULL, NULL);
+    if (strcmp(buf, buf2) != 0) {
+      wbuf[0] = L'\0';
 #if defined(_WIN32_WCE)
+static time_t time(time_t *ptime) {
+  time_t t;
+  SYSTEMTIME st;
+  FILETIME ft;
-static time_t
-time(time_t *ptime)
-	time_t		t;
-	SYSTEMTIME	st;
-	FILETIME	ft;
-	GetSystemTime(&st);
-	SystemTimeToFileTime(&st, &ft);
-	t = SYS2UNIX_TIME(ft.dwLowDateTime, ft.dwHighDateTime);
-	if (ptime != NULL)
-		*ptime = t;
-	return (t);
-static time_t
-mktime(struct tm *ptm)
-	SYSTEMTIME	st;
-	FILETIME	ft, lft;
-	st.wYear = ptm->tm_year + 1900;
-	st.wMonth = ptm->tm_mon + 1;
-	st.wDay = ptm->tm_mday;
-	st.wHour = ptm->tm_hour;
-	st.wMinute = ptm->tm_min;
-	st.wSecond = ptm->tm_sec;
-	st.wMilliseconds = 0;
-	LocalFileTimeToFileTime(&ft, &lft);
-	return (time_t)((MAKEUQUAD(lft.dwLowDateTime, lft.dwHighDateTime) -
-	    EPOCH_DIFF) / RATE_DIFF);
-static struct tm *
-localtime(const time_t *ptime, struct tm *ptm)
-	int64_t	t = ((int64_t)*ptime) * RATE_DIFF + EPOCH_DIFF;
-	FILETIME	ft, lft;
-	SYSTEMTIME	st;
-	TIME_ZONE_INFORMATION	tzinfo;
-	if (ptm == NULL)
-		return NULL;
-	* (int64_t *) &ft = t;
-	FileTimeToLocalFileTime(&ft, &lft);
-	FileTimeToSystemTime(&lft, &st);
-	ptm->tm_year = st.wYear - 1900;
-	ptm->tm_mon = st.wMonth - 1;
-	ptm->tm_wday = st.wDayOfWeek;
-	ptm->tm_mday = st.wDay;
-	ptm->tm_hour = st.wHour;
-	ptm->tm_min = st.wMinute;
-	ptm->tm_sec = st.wSecond;
-	ptm->tm_yday = 0; // hope nobody uses this
-	ptm->tm_isdst = ((GetTimeZoneInformation(&tzinfo) ==
-	    TIME_ZONE_ID_DAYLIGHT) ? 1 : 0);
-	return ptm;
-static size_t
-strftime(char *dst, size_t dst_size, const char *fmt, const struct tm *tm)
-	(void) snprintf(dst, dst_size, "implement strftime() for WinCE");
-	return (0);
-#endif
-static int
-mg_rename(const char* oldname, const char* newname)
-	wchar_t	woldbuf[FILENAME_MAX];
-	wchar_t	wnewbuf[FILENAME_MAX];
+  GetSystemTime(&st);
+  SystemTimeToFileTime(&st, &ft);
+  t = SYS2UNIX_TIME(ft.dwLowDateTime, ft.dwHighDateTime);
-	to_unicode(oldname, woldbuf, ARRAY_SIZE(woldbuf));
-	to_unicode(newname, wnewbuf, ARRAY_SIZE(wnewbuf));
+  if (ptime != NULL) {
+    *ptime = t;
-	return (MoveFileW(woldbuf, wnewbuf) ? 0 : -1);
+  return t;
+static struct tm *localtime(const time_t *ptime, struct tm *ptm) {
+  int64_t t = ((int64_t) *ptime) * RATE_DIFF + EPOCH_DIFF;
+  FILETIME ft, lft;
+  SYSTEMTIME st;
+  TIME_ZONE_INFORMATION tzinfo;
-static FILE *
-mg_fopen(const char *path, const char *mode)
-	wchar_t	wbuf[FILENAME_MAX], wmode[20];
+  if (ptm == NULL) {
+    return NULL;
-	to_unicode(path, wbuf, ARRAY_SIZE(wbuf));
-	MultiByteToWideChar(CP_UTF8, 0, mode, -1, wmode, ARRAY_SIZE(wmode));
+  * (int64_t *) &ft = t;
+  FileTimeToLocalFileTime(&ft, &lft);
+  FileTimeToSystemTime(&lft, &st);
+  ptm->tm_year = st.wYear - 1900;
+  ptm->tm_mon = st.wMonth - 1;
+  ptm->tm_wday = st.wDayOfWeek;
+  ptm->tm_mday = st.wDay;
+  ptm->tm_hour = st.wHour;
+  ptm->tm_min = st.wMinute;
+  ptm->tm_sec = st.wSecond;
+  ptm->tm_yday = 0; // hope nobody uses this
+  ptm->tm_isdst =
+    GetTimeZoneInformation(&tzinfo) == TIME_ZONE_ID_DAYLIGHT ? 1 : 0;
-	return (_wfopen(wbuf, wmode));
+  return ptm;
-static int
-mg_stat(const char *path, struct mgstat *stp)
-	int				ok = -1; /* Error */
-	wchar_t				wbuf[FILENAME_MAX];
-	WIN32_FILE_ATTRIBUTE_DATA	info;
-	if (GetFileAttributesExW(wbuf, GetFileExInfoStandard, &info) != 0) {
-		stp->size = MAKEUQUAD(info.nFileSizeLow, info.nFileSizeHigh);
-		stp->mtime = SYS2UNIX_TIME(info.ftLastWriteTime.dwLowDateTime,
-		    info.ftLastWriteTime.dwHighDateTime);
-		stp->is_directory =
-		    info.dwFileAttributes & FILE_ATTRIBUTE_DIRECTORY;
-		ok = 0;  /* Success */
+static struct tm *gmtime(const time_t *ptime, struct tm *ptm) {
+  // FIXME(lsm): fix this.
+  return localtime(ptime, ptm);
-	return (ok);
+static size_t strftime(char *dst, size_t dst_size, const char *fmt,
+                       const struct tm *tm) {
+  (void) snprintf(dst, dst_size, "implement strftime() for WinCE");
+  return 0;
+#endif
-static int
-mg_remove(const char *path)
+static int mg_rename(const char* oldname, const char* newname) {
+  wchar_t woldbuf[PATH_MAX];
+  wchar_t wnewbuf[PATH_MAX];
+  to_unicode(oldname, woldbuf, ARRAY_SIZE(woldbuf));
+  to_unicode(newname, wnewbuf, ARRAY_SIZE(wnewbuf));
-	return (DeleteFileW(wbuf) ? 0 : -1);
+  return MoveFileW(woldbuf, wnewbuf) ? 0 : -1;
-static int
-mg_mkdir(const char *path, int mode)
-	char	buf[FILENAME_MAX];
-	mode = 0; /* Unused */
+static FILE *mg_fopen(const char *path, const char *mode) {
+  wchar_t wbuf[PATH_MAX], wmode[20];
-	(void) MultiByteToWideChar(CP_UTF8, 0, buf, -1, wbuf, sizeof(wbuf));
+  to_unicode(path, wbuf, ARRAY_SIZE(wbuf));
+  MultiByteToWideChar(CP_UTF8, 0, mode, -1, wmode, ARRAY_SIZE(wmode));
-	return (CreateDirectoryW(wbuf, NULL) ? 0 : -1);
+  return _wfopen(wbuf, wmode);
- * Implementation of POSIX opendir/closedir/readdir for Windows.
-static DIR *
-opendir(const char *name)
-	DIR	*dir = NULL;
-	wchar_t	wpath[FILENAME_MAX];
-	DWORD attrs;
+static int mg_stat(const char *path, struct mgstat *stp) {
+  int ok = -1; // Error
+  wchar_t wbuf[PATH_MAX];
+  WIN32_FILE_ATTRIBUTE_DATA info;
-	if (name == NULL) {
-		SetLastError(ERROR_BAD_ARGUMENTS);
-	} else if ((dir = (DIR *) malloc(sizeof(*dir))) == NULL) {
-		SetLastError(ERROR_NOT_ENOUGH_MEMORY);
-	} else {
-		to_unicode(name, wpath, ARRAY_SIZE(wpath));
-		attrs = GetFileAttributesW(wpath);
-		if (attrs != 0xFFFFFFFF &&
-		    ((attrs & FILE_ATTRIBUTE_DIRECTORY) == FILE_ATTRIBUTE_DIRECTORY)) {
-			(void) wcscat(wpath, L"\\*");
-			dir->handle = FindFirstFileW(wpath, &dir->info);
-			dir->result.d_name[0] = '\0';
-		} else {
-			free(dir);
-			dir = NULL;
-	return (dir);
+  if (GetFileAttributesExW(wbuf, GetFileExInfoStandard, &info) != 0) {
+    stp->size = MAKEUQUAD(info.nFileSizeLow, info.nFileSizeHigh);
+    stp->mtime = SYS2UNIX_TIME(info.ftLastWriteTime.dwLowDateTime,
+                               info.ftLastWriteTime.dwHighDateTime);
+    stp->is_directory =
+      info.dwFileAttributes & FILE_ATTRIBUTE_DIRECTORY;
+    ok = 0;  // Success
+  return ok;
+static int mg_remove(const char *path) {
+  return DeleteFileW(wbuf) ? 0 : -1;
-static int
-closedir(DIR *dir)
-	int result = 0;
+static int mg_mkdir(const char *path, int mode) {
+  char buf[PATH_MAX];
-	if (dir != NULL) {
-		if (dir->handle != INVALID_HANDLE_VALUE)
-			result = FindClose(dir->handle) ? 0 : -1;
+  mode = 0; // Unused
-		free(dir);
-	} else {
-		result = -1;
+  (void) MultiByteToWideChar(CP_UTF8, 0, buf, -1, wbuf, sizeof(wbuf));
-	return (result);
+  return CreateDirectoryW(wbuf, NULL) ? 0 : -1;
-struct dirent *
-readdir(DIR *dir)
-	struct dirent *result = 0;
+// Implementation of POSIX opendir/closedir/readdir for Windows.
+static DIR * opendir(const char *name) {
+  DIR *dir = NULL;
+  wchar_t wpath[PATH_MAX];
+  DWORD attrs;
-	if (dir) {
-		if (dir->handle != INVALID_HANDLE_VALUE) {
-			result = &dir->result;
-			(void) WideCharToMultiByte(CP_UTF8, 0,
-			    dir->info.cFileName, -1, result->d_name,
-			    sizeof(result->d_name), NULL, NULL);
+  if (name == NULL) {
+    SetLastError(ERROR_BAD_ARGUMENTS);
+  } else if ((dir = (DIR *) malloc(sizeof(*dir))) == NULL) {
+    SetLastError(ERROR_NOT_ENOUGH_MEMORY);
+  } else {
+    to_unicode(name, wpath, ARRAY_SIZE(wpath));
+    attrs = GetFileAttributesW(wpath);
+    if (attrs != 0xFFFFFFFF &&
+        ((attrs & FILE_ATTRIBUTE_DIRECTORY) == FILE_ATTRIBUTE_DIRECTORY)) {
+      (void) wcscat(wpath, L"\\*");
+      dir->handle = FindFirstFileW(wpath, &dir->info);
+      dir->result.d_name[0] = '\0';
+    } else {
+      free(dir);
+      dir = NULL;
-			if (!FindNextFileW(dir->handle, &dir->info)) {
-				(void) FindClose(dir->handle);
-				dir->handle = INVALID_HANDLE_VALUE;
+  return dir;
-		} else {
-			SetLastError(ERROR_FILE_NOT_FOUND);
-	} else {
+static int closedir(DIR *dir) {
+  int result = 0;
-	return (result);
+  if (dir != NULL) {
+    if (dir->handle != INVALID_HANDLE_VALUE)
+      result = FindClose(dir->handle) ? 0 : -1;
+    free(dir);
+  } else {
+    result = -1;
+  return result;
-#define	set_close_on_exec(fd)	/* No FD_CLOEXEC on Windows */
+static struct dirent *readdir(DIR *dir) {
+  struct dirent *result = 0;
-static int
-start_thread(struct mg_context *ctx, mg_thread_func_t func, void *param)
-	HANDLE	hThread;
+  if (dir) {
+    if (dir->handle != INVALID_HANDLE_VALUE) {
+      result = &dir->result;
+      (void) WideCharToMultiByte(CP_UTF8, 0,
+          dir->info.cFileName, -1, result->d_name,
+          sizeof(result->d_name), NULL, NULL);
-	ctx = NULL;	/* Unused */
-	hThread = CreateThread(NULL, 0,
-	    (LPTHREAD_START_ROUTINE) func, param, 0, NULL);
+      if (!FindNextFileW(dir->handle, &dir->info)) {
+        (void) FindClose(dir->handle);
+        dir->handle = INVALID_HANDLE_VALUE;
-	if (hThread != NULL)
-		(void) CloseHandle(hThread);
+    } else {
+      SetLastError(ERROR_FILE_NOT_FOUND);
+  } else {
-	return (hThread == NULL ? -1 : 0);
+  return result;
-static HANDLE
-dlopen(const char *dll_name, int flags)
+#define set_close_on_exec(fd) // No FD_CLOEXEC on Windows
-	flags = 0; /* Unused */
-	to_unicode(dll_name, wbuf, ARRAY_SIZE(wbuf));
-	return (LoadLibraryW(wbuf));
+static int start_thread(struct mg_context *ctx, mg_thread_func_t f, void *p) {
+  return _beginthread((void (__cdecl *)(void *)) f, 0, p) == -1L ? -1 : 0;
+static HANDLE dlopen(const char *dll_name, int flags) {
+  flags = 0; // Unused
+  to_unicode(dll_name, wbuf, ARRAY_SIZE(wbuf));
+  return LoadLibraryW(wbuf);
 #if !defined(NO_CGI)
-static int
-kill(pid_t pid, int sig_num)
-	(void) TerminateProcess(pid, sig_num);
-	(void) CloseHandle(pid);
-	return (0);
-static pid_t
-spawn_process(struct mg_connection *conn, const char *prog, char *envblk,
-		char *envp[], int fd_stdin, int fd_stdout, const char *dir)
-	HANDLE	me;
-	char	*p, *interp, cmdline[FILENAME_MAX], line[FILENAME_MAX];
-	FILE	*fp;
-	STARTUPINFOA		si;
-	PROCESS_INFORMATION	pi;
-	envp = NULL; /* Unused */
-	(void) memset(&si, 0, sizeof(si));
-	(void) memset(&pi, 0, sizeof(pi));
-	/* XXX redirect CGI errors to the error log file */
-	si.cb		= sizeof(si);
-	si.dwFlags	= STARTF_USESTDHANDLES | STARTF_USESHOWWINDOW;
-	si.wShowWindow	= SW_HIDE;
-	me = GetCurrentProcess();
-	(void) DuplicateHandle(me, (HANDLE) _get_osfhandle(fd_stdin), me,
-	    &si.hStdInput, 0, TRUE, DUPLICATE_SAME_ACCESS);
-	(void) DuplicateHandle(me, (HANDLE) _get_osfhandle(fd_stdout), me,
-	    &si.hStdOutput, 0, TRUE, DUPLICATE_SAME_ACCESS);
-	/* If CGI file is a script, try to read the interpreter line */
-	interp = conn->ctx->options[OPT_CGI_INTERPRETER];
-	if (interp == NULL) {
-		line[2] = '\0';
-		(void) mg_snprintf(conn, cmdline, sizeof(cmdline), "%s%c%s",
-		    dir, DIRSEP, prog);
-		if ((fp = fopen(cmdline, "r")) != NULL) {
-			(void) fgets(line, sizeof(line), fp);
-			if (memcmp(line, "#!", 2) != 0)
-				line[2] = '\0';
-			/* Trim whitespaces from interpreter name */
-			for (p = &line[strlen(line) - 1]; p > line &&
-			    isspace(*p); p--)
-				*p = '\0';
-			(void) fclose(fp);
-		interp = line + 2;
-	if ((p = (char *) strrchr(prog, '/')) != NULL)
-		prog = p + 1;
-	(void) mg_snprintf(conn, cmdline, sizeof(cmdline), "%s%s%s",
-	    interp, interp[0] == '\0' ? "" : " ", prog);
-	(void) mg_snprintf(conn, line, sizeof(line), "%s", dir);
-	fix_directory_separators(line);
-	DEBUG_TRACE((DEBUG_MGS_PREFIX "%s: Running [%s]", __func__, cmdline));
-	if (CreateProcessA(NULL, cmdline, NULL, NULL, TRUE,
-	    CREATE_NEW_PROCESS_GROUP, envblk, line, &si, &pi) == 0) {
-		cry(conn, "%s: CreateProcess(%s): %d",
-		    __func__, cmdline, ERRNO);
-		pi.hProcess = (pid_t) -1;
-	} else {
-		(void) close(fd_stdin);
-		(void) close(fd_stdout);
-	(void) CloseHandle(si.hStdOutput);
-	(void) CloseHandle(si.hStdInput);
-	(void) CloseHandle(pi.hThread);
-	return ((pid_t) pi.hProcess);
-static int
-pipe(int *fds)
-	return (_pipe(fds, BUFSIZ, _O_BINARY));
-#endif /* !NO_CGI */
-static int
-set_non_blocking_mode(struct mg_connection *conn, SOCKET sock)
-	unsigned long	on = 1;
-	conn = NULL; /* unused */
-	return (ioctlsocket(sock, FIONBIO, &on));
+#define SIGKILL 0
+static int kill(pid_t pid, int sig_num) {
+  (void) TerminateProcess(pid, sig_num);
+  (void) CloseHandle(pid);
+  return 0;
+static pid_t spawn_process(struct mg_connection *conn, const char *prog,
+                           char *envblk, char *envp[], int fd_stdin,
+                           int fd_stdout, const char *dir) {
+  HANDLE me;
+  char *p, *interp, cmdline[PATH_MAX], buf[PATH_MAX];
+  FILE *fp;
+  STARTUPINFOA si = { sizeof(si) };
+  PROCESS_INFORMATION pi = { 0 };
+  envp = NULL; // Unused
+  // TODO(lsm): redirect CGI errors to the error log file
+  si.dwFlags = STARTF_USESTDHANDLES | STARTF_USESHOWWINDOW;
+  si.wShowWindow = SW_HIDE;
+  me = GetCurrentProcess();
+  (void) DuplicateHandle(me, (HANDLE) _get_osfhandle(fd_stdin), me,
+      &si.hStdInput, 0, TRUE, DUPLICATE_SAME_ACCESS);
+  (void) DuplicateHandle(me, (HANDLE) _get_osfhandle(fd_stdout), me,
+      &si.hStdOutput, 0, TRUE, DUPLICATE_SAME_ACCESS);
+  // If CGI file is a script, try to read the interpreter line
+  interp = conn->ctx->config[CGI_INTERPRETER];
+  if (interp == NULL) {
+    buf[2] = '\0';
+    mg_snprintf(conn, cmdline, sizeof(cmdline), "%s%c%s", dir, DIRSEP, prog);
+    if ((fp = fopen(cmdline, "r")) != NULL) {
+      (void) fgets(buf, sizeof(buf), fp);
+      if (buf[0] != '#' || buf[1] != '!') {
+        // First line does not start with "#!". Do not set interpreter.
+        buf[2] = '\0';
+      } else {
+        // Trim whitespaces in interpreter name
+        for (p = &buf[strlen(buf) - 1]; p > buf && isspace(*p); p--) {
+          *p = '\0';
+      (void) fclose(fp);
+    interp = buf + 2;
+  (void) mg_snprintf(conn, cmdline, sizeof(cmdline), "%s%s%s%c%s",
+                     interp, interp[0] == '\0' ? "" : " ", dir, DIRSEP, prog);
+  DEBUG_TRACE(("Running [%s]", cmdline));
+  if (CreateProcessA(NULL, cmdline, NULL, NULL, TRUE,
+        CREATE_NEW_PROCESS_GROUP, envblk, dir, &si, &pi) == 0) {
+    cry(conn, "%s: CreateProcess(%s): %d",
+        __func__, cmdline, ERRNO);
+    pi.hProcess = (pid_t) -1;
+  } else {
+    (void) close(fd_stdin);
+    (void) close(fd_stdout);
+  (void) CloseHandle(si.hStdOutput);
+  (void) CloseHandle(si.hStdInput);
+  (void) CloseHandle(pi.hThread);
+  return (pid_t) pi.hProcess;
+#endif // !NO_CGI
+static int set_non_blocking_mode(SOCKET sock) {
+  unsigned long on = 1;
+  return ioctlsocket(sock, FIONBIO, &on);
 #else
+  struct stat st;
+  int ok;
-static int
-	struct stat	st;
-	int		ok;
-	if (stat(path, &st) == 0) {
-		ok = 0;
-		stp->size = st.st_size;
-		stp->mtime = st.st_mtime;
-		stp->is_directory = S_ISDIR(st.st_mode);
-	} else {
-		ok = -1;
+  if (stat(path, &st) == 0) {
+    ok = 0;
+    stp->size = st.st_size;
+    stp->mtime = st.st_mtime;
+    stp->is_directory = S_ISDIR(st.st_mode);
+  } else {
+    ok = -1;
-	return (ok);
+  return ok;
-static void
-set_close_on_exec(int fd)
-	(void) fcntl(fd, F_SETFD, FD_CLOEXEC);
+static void set_close_on_exec(int fd) {
+  (void) fcntl(fd, F_SETFD, FD_CLOEXEC);
-static int
-	pthread_t	thread_id;
-	pthread_attr_t	attr;
-	int		retval;
+static int start_thread(struct mg_context *ctx, mg_thread_func_t func,
+                        void *param) {
+  pthread_t thread_id;
+  pthread_attr_t attr;
+  int retval;
-	(void) pthread_attr_init(&attr);
-	(void) pthread_attr_setdetachstate(&attr, PTHREAD_CREATE_DETACHED);
+  (void) pthread_attr_init(&attr);
+  (void) pthread_attr_setdetachstate(&attr, PTHREAD_CREATE_DETACHED);
+  // TODO(lsm): figure out why mongoose dies on Linux if next line is enabled
+  // (void) pthread_attr_setstacksize(&attr, sizeof(struct mg_connection) * 5);
-	if ((retval = pthread_create(&thread_id, &attr, func, param)) != 0)
-		cry(fc(ctx), "%s: %s", __func__, strerror(retval));
+  if ((retval = pthread_create(&thread_id, &attr, func, param)) != 0) {
+    cry(fc(ctx), "%s: %s", __func__, strerror(retval));
-	return (retval);
+  return retval;
 #ifndef NO_CGI
-static pid_t
-	pid_t		pid;
-	const char	*interp;
-	envblk = NULL;	/* unused */
-	if ((pid = fork()) == -1) {
-		/* Parent */
-		send_error(conn, 500, http_500_error,
-		    "fork(): %s", strerror(ERRNO));
-	} else if (pid == 0) {
-		/* Child */
-		if (chdir(dir) != 0) {
-			cry(conn, "%s: chdir(%s): %s",
-			    __func__, dir, strerror(ERRNO));
-		} else if (dup2(fd_stdin, 0) == -1) {
-			cry(conn, "%s: dup2(stdin, %d): %s",
-			    __func__, fd_stdin, strerror(ERRNO));
-		} else if (dup2(fd_stdout, 1) == -1) {
-			cry(conn, "%s: dup2(stdout, %d): %s",
-			    __func__, fd_stdout, strerror(ERRNO));
-		} else {
-			/* If error file is specified, send errors there */
-			if (conn->ctx->error_log != NULL)
-				(void) dup2(fileno(conn->ctx->error_log), 2);
-			/* Execute CGI program */
-				(void) execle(prog, prog, NULL, envp);
-				cry(conn, "%s: execle(%s): %s",
-				    __func__, prog, strerror(ERRNO));
-			} else {
-				(void) execle(interp, interp, prog, NULL, envp);
-				cry(conn, "%s: execle(%s %s): %s",
-				    __func__, interp, prog, strerror(ERRNO));
-		exit(EXIT_FAILURE);
-	} else {
-		/* Parent. Close stdio descriptors */
-	return (pid);
-static int
-	int	flags, ok = -1;
-	if ((flags = fcntl(sock, F_GETFL, 0)) == -1) {
-		cry(conn, "%s: fcntl(F_GETFL): %d", __func__, ERRNO);
-	} else if (fcntl(sock, F_SETFL, flags | O_NONBLOCK) != 0) {
-		cry(conn, "%s: fcntl(F_SETFL): %d", __func__, ERRNO);
-	} else {
-	return (ok);
-#endif /* _WIN32 */
-static void
-lock_option(struct mg_context *ctx, int opt_index)
-	if (pthread_mutex_lock(&ctx->opt_mutex[opt_index]) != 0)
-		cry(fc(ctx), "pthread_mutex_lock: %s", strerror(ERRNO));
-static void
-unlock_option(struct mg_context *ctx, int opt_index)
-	if (pthread_mutex_unlock(&ctx->opt_mutex[opt_index]) != 0)
-		cry(fc(ctx), "pthread_mutex_unlock: %s", strerror(ERRNO));
- * Write data to the IO channel - opened file descriptor, socket or SSL
- * descriptor. Return number of bytes written.
-static int64_t
-push(FILE *fp, SOCKET sock, SSL *ssl, const char *buf, int64_t len)
-	int64_t	sent;
-	int	n, k;
-	sent = 0;
-	while (sent < len) {
-		/* How many bytes we send in this iteration */
-		k = len - sent > INT_MAX ? INT_MAX : (int) (len - sent);
-		if (ssl != NULL) {
-			n = SSL_write(ssl, buf + sent, k);
-		} else if (fp != NULL) {
-			n = fwrite(buf + sent, 1, k, fp);
-			if (ferror(fp))
-				n = -1;
-		} else {
-			n = send(sock, buf + sent, k, 0);
-		if (n < 0)
-			break;
-		sent += n;
-	return (sent);
- * Read from IO channel - opened file descriptor, socket, or SSL descriptor.
- * Return number of bytes read.
-static int
-pull(FILE *fp, SOCKET sock, SSL *ssl, char *buf, int len)
-	int	nread;
-		nread = SSL_read(ssl, buf, len);
-		nread = fread(buf, 1, (size_t) len, fp);
-		if (ferror(fp))
-			nread = -1;
-	} else {
-		nread = recv(sock, buf, (size_t) len, 0);
-	return (nread);
-int
-mg_write(struct mg_connection *conn, const void *buf, int len)
-	assert(len >= 0);
-	return ((int) push(NULL, conn->client.sock, conn->ssl,
-				(const char *) buf, (int64_t) len));
-int
-mg_printf(struct mg_connection *conn, const char *fmt, ...)
-	char	buf[MAX_REQUEST_SIZE];
-	int	len;
-	va_list	ap;
-	len = mg_vsnprintf(conn, buf, sizeof(buf), fmt, ap);
-	va_end(ap);
-	return (mg_write(conn, buf, len));
- * Return content length of the request, or -1 constant if
- * Content-Length header is not set.
-static int64_t
-get_content_length(const struct mg_connection *conn)
-	const char *cl = mg_get_header(conn, "Content-Length");
-	return (cl == NULL ? -1 : strtoll(cl, NULL, 10));
- * URL-decode input buffer into destination buffer.
- * 0-terminate the destination buffer. Return the length of decoded data.
- * form-url-encoded data differs from URI encoding in a way that it
- * uses '+' as character for space, see RFC 1866 section 8.2.1
- * http://ftp.ics.uci.edu/pub/ietf/html/rfc1866.txt
-static size_t
-url_decode(const char *src, size_t src_len, char *dst, size_t dst_len,
-		bool_t is_form_url_encoded)
-	size_t	i, j;
-	int	a, b;
-#define	HEXTOI(x)	(isdigit(x) ? x - '0' : x - 'W')
-	for (i = j = 0; i < src_len && j < dst_len - 1; i++, j++) {
-		if (src[i] == '%' &&
-		    isxdigit(* (unsigned char *) (src + i + 1)) &&
-		    isxdigit(* (unsigned char *) (src + i + 2))) {
-			a = tolower(* (unsigned char *) (src + i + 1));
-			b = tolower(* (unsigned char *) (src + i + 2));
-			dst[j] = ((HEXTOI(a) << 4) | HEXTOI(b)) & 0xff;
-			i += 2;
-		} else if (is_form_url_encoded && src[i] == '+') {
-			dst[j] = ' ';
-		} else {
-			dst[j] = src[i];
-	dst[j] = '\0';	/* Null-terminate the destination */
-	return (j);
- * Search for a form variable in a given buffer.
- * Semantic is the same as for mg_get_var().
-static char *
-get_var(const char *name, const char *buf, size_t buf_len)
-	const char	*p, *e, *s;
-	char		*val;
-	size_t		var_len, len;
-	var_len = strlen(name);
-	e = buf + buf_len;
-	val = NULL;
-	/* buf is "var1=val1&var2=val2...". Find variable first */
-	for (p = buf; p + var_len < e; p++)
-		if ((p == buf || p[-1] == '&') && p[var_len] == '=' &&
-		    !mg_strncasecmp(name, p, var_len)) {
-			/* Point p to variable value */
-			p += var_len + 1;
-			/* Point s to the end of the value */
-			s = (const char *) memchr(p, '&', e - p);
-			if (s == NULL)
-				s = e;
-			/* Try to allocate the buffer */
-			len = s - p;
-			if ((val = (char *) malloc(len + 1)) != NULL)
-				(void) url_decode(p, len, val, len + 1, TRUE);
-			break;
-	return (val);
- * Free the pointer returned by mg_get_var(). This is needed for languages
- * like python, to have an ability to free allocated data without
- * loading C runtime library and calling free().
-void
-mg_free(char *data)
-	free(data);
- * Return form data variable.
- * It can be specified in query string, or in the POST data.
- * Return NULL if the variable not found, or allocated 0-terminated value.
- * It is caller's responsibility to free the returned value.
-char *
-mg_get_var(const struct mg_connection *conn, const char *name)
-	const struct mg_request_info	*ri = &conn->request_info;
-	char				*v1, *v2;
-	v1 = v2 = NULL;
-	/* Look in both query_string and POST data */
-	if (ri->query_string != NULL)
-		v1 = get_var(name, ri->query_string, strlen(ri->query_string));
-	if (ri->post_data_len > 0)
-		v2 = get_var(name, ri->post_data, ri->post_data_len);
-	/* If they both have queried variable, POST data wins */
-	if (v1 != NULL && v2 != NULL)
-		free(v1);
-	return (v2 == NULL ? v1 : v2);
- * Transform URI to the file name.
-static void
-convert_uri_to_file_name(struct mg_connection *conn, const char *uri,
-		char *buf, size_t buf_len)
-	struct mg_context	*ctx = conn->ctx;
-	struct vec		uri_vec, path_vec;
-	const char		*list;
-	lock_option(ctx, OPT_ROOT);
-	mg_snprintf(conn, buf, buf_len, "%s%s", ctx->options[OPT_ROOT], uri);
-	unlock_option(ctx, OPT_ROOT);
-	/* If requested URI has aliased prefix, use alternate root */
-	lock_option(ctx, OPT_ALIASES);
-	list = ctx->options[OPT_ALIASES];
-	while ((list = next_option(list, &uri_vec, &path_vec)) != NULL) {
-		if (memcmp(uri, uri_vec.ptr, uri_vec.len) == 0) {
-			(void) mg_snprintf(conn, buf, buf_len, "%.*s%s",
-			    path_vec.len, path_vec.ptr, uri + uri_vec.len);
-			break;
-	unlock_option(ctx, OPT_ALIASES);
+  pid_t pid;
+  const char *interp;
+  envblk = NULL; // Unused
+  if ((pid = fork()) == -1) {
+    // Parent
+    send_http_error(conn, 500, http_500_error, "fork(): %s", strerror(ERRNO));
+  } else if (pid == 0) {
+    // Child
+    if (chdir(dir) != 0) {
+      cry(conn, "%s: chdir(%s): %s", __func__, dir, strerror(ERRNO));
+    } else if (dup2(fd_stdin, 0) == -1) {
+      cry(conn, "%s: dup2(%d, 0): %s", __func__, fd_stdin, strerror(ERRNO));
+    } else if (dup2(fd_stdout, 1) == -1) {
+      cry(conn, "%s: dup2(%d, 1): %s", __func__, fd_stdout, strerror(ERRNO));
+    } else {
+      (void) dup2(fd_stdout, 2);
+      // Execute CGI program. No need to lock: new process
+        (void) execle(prog, prog, NULL, envp);
+        cry(conn, "%s: execle(%s): %s", __func__, prog, strerror(ERRNO));
+      } else {
+        (void) execle(interp, interp, prog, NULL, envp);
+        cry(conn, "%s: execle(%s %s): %s", __func__, interp, prog,
+            strerror(ERRNO));
+    exit(EXIT_FAILURE);
+  } else {
+    // Parent. Close stdio descriptors
+  return pid;
+#endif // !NO_CGI
+  int flags;
+  flags = fcntl(sock, F_GETFL, 0);
+  (void) fcntl(sock, F_SETFL, flags | O_NONBLOCK);
+  return 0;
+#endif // _WIN32
+// Write data to the IO channel - opened file descriptor, socket or SSL
+// descriptor. Return number of bytes written.
+static int64_t push(FILE *fp, SOCKET sock, SSL *ssl, const char *buf,
+                    int64_t len) {
+  int64_t sent;
+  int n, k;
+  sent = 0;
+  while (sent < len) {
+    // How many bytes we send in this iteration
+    k = len - sent > INT_MAX ? INT_MAX : (int) (len - sent);
+    if (ssl != NULL) {
+      n = SSL_write(ssl, buf + sent, k);
+    } else if (fp != NULL) {
+      n = fwrite(buf + sent, 1, (size_t) k, fp);
+      if (ferror(fp))
+        n = -1;
+    } else {
+      n = send(sock, buf + sent, (size_t) k, MSG_NOSIGNAL);
+    if (n < 0)
+      break;
+    sent += n;
+  return sent;
+// Read from IO channel - opened file descriptor, socket, or SSL descriptor.
+// Return number of bytes read.
+static int pull(FILE *fp, SOCKET sock, SSL *ssl, char *buf, int len) {
+  int nread;
+    nread = SSL_read(ssl, buf, len);
+    // Use read() instead of fread(), because if we're reading from the CGI
+    // pipe, fread() may block until IO buffer is filled up. We cannot afford
+    // to block and must pass all read bytes immediately to the client.
+    nread = read(fileno(fp), buf, (size_t) len);
+    if (ferror(fp))
+      nread = -1;
+  } else {
+    nread = recv(sock, buf, (size_t) len, 0);
+  return nread;
+int mg_read(struct mg_connection *conn, void *buf, size_t len) {
+  int n, buffered_len, nread;
+  const char *buffered;
+  assert((conn->content_len == -1 && conn->consumed_content == 0) ||
+         conn->consumed_content <= conn->content_len);
+  DEBUG_TRACE(("%p %zu %lld %lld", buf, len,
+               conn->content_len, conn->consumed_content));
+  nread = 0;
+  if (conn->consumed_content < conn->content_len) {
+    // Adjust number of bytes to read.
+    int64_t to_read = conn->content_len - conn->consumed_content;
+    if (to_read < (int64_t) len) {
+      len = (int) to_read;
+    // How many bytes of data we have buffered in the request buffer?
+    buffered = conn->buf + conn->request_len + conn->consumed_content;
+    buffered_len = conn->data_len - conn->request_len;
+    assert(buffered_len >= 0);
+    // Return buffered data back if we haven't done that yet.
+    if (conn->consumed_content < (int64_t) buffered_len) {
+      buffered_len -= (int) conn->consumed_content;
+      if (len < (size_t) buffered_len) {
+        buffered_len = len;
+      memcpy(buf, buffered, (size_t)buffered_len);
+      len -= buffered_len;
+      buf = (char *) buf + buffered_len;
+      conn->consumed_content += buffered_len;
+      nread = buffered_len;
+    // We have returned all buffered data. Read new data from the remote socket.
+    while (len > 0) {
+      n = pull(NULL, conn->client.sock, conn->ssl, (char *) buf, (int) len);
+      if (n <= 0) {
+        break;
+      buf = (char *) buf + n;
+      conn->consumed_content += n;
+      nread += n;
+      len -= n;
+  return nread;
+int mg_write(struct mg_connection *conn, const void *buf, size_t len) {
+  return (int) push(NULL, conn->client.sock, conn->ssl, (const char *) buf,
+                    (int64_t) len);
+int mg_printf(struct mg_connection *conn, const char *fmt, ...) {
+  char buf[BUFSIZ];
+  int len;
+  va_list ap;
+  len = mg_vsnprintf(conn, buf, sizeof(buf), fmt, ap);
+  va_end(ap);
+  return mg_write(conn, buf, (size_t)len);
+// URL-decode input buffer into destination buffer.
+// 0-terminate the destination buffer. Return the length of decoded data.
+// form-url-encoded data differs from URI encoding in a way that it
+// uses '+' as character for space, see RFC 1866 section 8.2.1
+// http://ftp.ics.uci.edu/pub/ietf/html/rfc1866.txt
+static size_t url_decode(const char *src, size_t src_len, char *dst,
+                         size_t dst_len, int is_form_url_encoded) {
+  size_t i, j;
+  int a, b;
+#define HEXTOI(x) (isdigit(x) ? x - '0' : x - 'W')
+  for (i = j = 0; i < src_len && j < dst_len - 1; i++, j++) {
+    if (src[i] == '%' &&
+        isxdigit(* (const unsigned char *) (src + i + 1)) &&
+        isxdigit(* (const unsigned char *) (src + i + 2))) {
+      a = tolower(* (const unsigned char *) (src + i + 1));
+      b = tolower(* (const unsigned char *) (src + i + 2));
+      dst[j] = (char) ((HEXTOI(a) << 4) | HEXTOI(b));
+      i += 2;
+    } else if (is_form_url_encoded && src[i] == '+') {
+      dst[j] = ' ';
+    } else {
+      dst[j] = src[i];
+  dst[j] = '\0'; // Null-terminate the destination
+  return j;
+// Scan given buffer and fetch the value of the given variable.
+// It can be specified in query string, or in the POST data.
+// Return NULL if the variable not found, or allocated 0-terminated value.
+// It is caller's responsibility to free the returned value.
+int mg_get_var(const char *buf, size_t buf_len, const char *name,
+               char *dst, size_t dst_len) {
+  const char *p, *e, *s;
+  size_t name_len, len;
+  name_len = strlen(name);
+  e = buf + buf_len;
+  len = -1;
+  dst[0] = '\0';
+  // buf is "var1=val1&var2=val2...". Find variable first
+  for (p = buf; p != NULL && p + name_len < e; p++) {
+    if ((p == buf || p[-1] == '&') && p[name_len] == '=' &&
+        !mg_strncasecmp(name, p, name_len)) {
+      // Point p to variable value
+      p += name_len + 1;
+      // Point s to the end of the value
+      s = (const char *) memchr(p, '&', (size_t)(e - p));
+      if (s == NULL) {
+        s = e;
+      assert(s >= p);
+      // Decode variable into destination buffer
+      if ((size_t) (s - p) < dst_len) {
+        len = url_decode(p, (size_t)(s - p), dst, dst_len, 1);
+      break;
+  return len;
+int mg_get_cookie(const struct mg_connection *conn, const char *cookie_name,
+                  char *dst, size_t dst_size) {
+  const char *s, *p, *end;
+  int name_len, len = -1;
+  dst[0] = '\0';
+  if ((s = mg_get_header(conn, "Cookie")) == NULL) {
+    return 0;
+  name_len = strlen(cookie_name);
+  end = s + strlen(s);
+  for (; (s = strstr(s, cookie_name)) != NULL; s += name_len)
+    if (s[name_len] == '=') {
+      s += name_len + 1;
+      if ((p = strchr(s, ' ')) == NULL)
+        p = end;
+      if (p[-1] == ';')
+        p--;
+      if (*s == '"' && p[-1] == '"' && p > s + 1) {
+        s++;
+        p--;
+      if ((size_t) (p - s) < dst_size) {
+        len = (p - s) + 1;
+        mg_strlcpy(dst, s, (size_t)len);
+      break;
+  return len;
+static int convert_uri_to_file_name(struct mg_connection *conn, char *buf,
+                                    size_t buf_len, struct mgstat *st) {
+  struct vec a, b;
+  const char *rewrite, *uri = conn->request_info.uri;
+  char *p;
+  int match_len, stat_result;
+  buf_len--;  // This is because memmove() for PATH_INFO may shift part
+              // of the path one byte on the right.
+  mg_snprintf(conn, buf, buf_len, "%s%s", conn->ctx->config[DOCUMENT_ROOT],
+              uri);
+  rewrite = conn->ctx->config[REWRITE];
+  while ((rewrite = next_option(rewrite, &a, &b)) != NULL) {
+    if ((match_len = match_prefix(a.ptr, a.len, uri)) > 0) {
+      mg_snprintf(conn, buf, buf_len, "%.*s%s", b.len, b.ptr, uri + match_len);
+      break;
+#if defined(_WIN32) && !defined(__SYMBIAN32__)
+  //change_slashes_to_backslashes(buf);
+#endif // _WIN32
+  if ((stat_result = mg_stat(buf, st)) != 0) {
+    // Support PATH_INFO for CGI scripts.
+    for (p = buf + strlen(buf); p > buf + 1; p--) {
+      if (*p == '/') {
+        *p = '\0';
+        if (match_prefix(conn->ctx->config[CGI_EXTENSIONS],
+                         strlen(conn->ctx->config[CGI_EXTENSIONS]), buf) > 0 &&
+            (stat_result = mg_stat(buf, st)) == 0) {
+          // Shift PATH_INFO block one character right, e.g.
+          //  "/x.cgi/foo/bar\x00" => "/x.cgi\x00/foo/bar\x00"
+          // conn->path_info is pointing to the local variable "path" declared
+          // in handle_request(), so PATH_INFO not valid after
+          // handle_request returns.
+          conn->path_info = p + 1;
+          memmove(p + 2, p + 1, strlen(p + 1) + 1);  // +1 is for trailing \0
+          p[1] = '/';
+          break;
+        } else {
+          *p = '/';
+          stat_result = -1;
+  return stat_result;
+static int sslize(struct mg_connection *conn, int (*func)(SSL *)) {
+  return (conn->ssl = SSL_new(conn->ctx->ssl_ctx)) != NULL &&
+    SSL_set_fd(conn->ssl, conn->client.sock) == 1 &&
+    func(conn->ssl) == 1;
+// Check whether full request is buffered. Return:
+//   -1  if request is malformed
+//    0  if request is not yet fully buffered
+//   >0  actual request length, including last \r\n\r\n
+static int get_request_len(const char *buf, int buflen) {
+  const char *s, *e;
+  int len = 0;
+  DEBUG_TRACE(("buf: %p, len: %d", buf, buflen));
+  for (s = buf, e = s + buflen - 1; len <= 0 && s < e; s++)
+    // Control characters are not allowed but >=128 is.
+    if (!isprint(* (const unsigned char *) s) && *s != '\r' &&
+        *s != '\n' && * (const unsigned char *) s < 128) {
+      len = -1;
+    } else if (s[0] == '\n' && s[1] == '\n') {
+      len = (int) (s - buf) + 2;
+    } else if (s[0] == '\n' && &s[1] < e &&
+        s[1] == '\r' && s[2] == '\n') {
+      len = (int) (s - buf) + 3;
+  return len;
+// Convert month to the month number. Return -1 on error, or month number
+static int get_month_index(const char *s) {
+  size_t i;
+  for (i = 0; i < ARRAY_SIZE(month_names); i++)
+    if (!strcmp(s, month_names[i]))
+      return (int) i;
+  return -1;
+// Parse UTC date-time string, and return the corresponding time_t value.
+static time_t parse_date_string(const char *datetime) {
+  static const unsigned short days_before_month[] = {
+    0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334
+  char month_str[32];
+  int second, minute, hour, day, month, year, leap_days, days;
+  time_t result = (time_t) 0;
+  if (((sscanf(datetime, "%d/%3s/%d %d:%d:%d",
+               &day, month_str, &year, &hour, &minute, &second) == 6) ||
+       (sscanf(datetime, "%d %3s %d %d:%d:%d",
+       (sscanf(datetime, "%*3s, %d %3s %d %d:%d:%d",
+       (sscanf(datetime, "%d-%3s-%d %d:%d:%d",
+               &day, month_str, &year, &hour, &minute, &second) == 6)) &&
+      year > 1970 &&
+      (month = get_month_index(month_str)) != -1) {
+    year -= 1970;
+    leap_days = year / 4 - year / 100 + year / 400;
+    days = year * 365 + days_before_month[month] + (day - 1) + leap_days;
+    result = days * 24 * 3600 + hour * 3600 + minute * 60 + second;
+  return result;
+// Protect against directory disclosure attack by removing '..',
+// excessive '/' and '\' characters
+static void remove_double_dots_and_double_slashes(char *s) {
+  char *p = s;
+  while (*s != '\0') {
+    *p++ = *s++;
+    if (IS_DIRSEP_CHAR(s[-1])) {
+      // Skip all following slashes and backslashes
+      while (IS_DIRSEP_CHAR(s[0])) {
+        s++;
+      // Skip all double-dots
+      while (*s == '.' && s[1] == '.') {
+        s += 2;
+  *p = '\0';
-#ifdef _WIN32
-	DEBUG_TRACE((DEBUG_MGS_PREFIX "%s: [%s] -> [%s]", __func__, uri, buf));
- * Setup listening socket on given address, return socket.
- * Address format: [local_ip_address:]port_number
-static SOCKET
-mg_open_listening_port(struct mg_context *ctx, const char *str, struct usa *usa)
-	SOCKET		sock;
-	int		on = 1, a, b, c, d, port;
-	/* MacOS needs that. If we do not zero it, bind() will fail. */
-	(void) memset(usa, 0, sizeof(*usa));
-	if (sscanf(str, "%d.%d.%d.%d:%d", &a, &b, &c, &d, &port) == 5) {
-		/* IP address to bind to is specified */
-		usa->u.sin.sin_addr.s_addr =
-		    htonl(((uint32_t)a << 24) | ((uint32_t)b << 16) | ((uint32_t)c << 8) | (uint32_t)d);
-	} else if (sscanf(str, "%d", &port) == 1) {
-		/* Only port number is specified. Bind to all addresses */
-		usa->u.sin.sin_addr.s_addr = htonl(INADDR_ANY);
-	} else {
-		return (INVALID_SOCKET);
-	usa->len			= sizeof(usa->u.sin);
-	usa->u.sin.sin_family		= AF_INET;
-	usa->u.sin.sin_port		= htons((uint16_t) port);
-	if ((sock = socket(PF_INET, SOCK_STREAM, 6)) != INVALID_SOCKET &&
-	    setsockopt(sock, SOL_SOCKET, SO_REUSEADDR,
-	    (char *) &on, sizeof(on)) == 0 &&
-	    bind(sock, &usa->u.sa, usa->len) == 0 &&
-	    listen(sock, 20) == 0) {
-		/* Success */
-		set_close_on_exec(sock);
-	} else {
-		/* Error */
-		cry(fc(ctx), "%s(%d): %s", __func__, port, strerror(ERRNO));
-		if (sock != INVALID_SOCKET)
-			(void) closesocket(sock);
-		sock = INVALID_SOCKET;
-	return (sock);
- * Check whether full request is buffered. Return:
- *   -1         if request is malformed
- *    0         if request is not yet fully buffered
- *   >0         actual request length, including last \r\n\r\n
-static int
-get_request_len(const char *buf, size_t buflen)
-	const char	*s, *e;
-	int		len = 0;
-	for (s = buf, e = s + buflen - 1; len <= 0 && s < e; s++)
-		/* Control characters are not allowed but >=128 is. */
-		if (!isprint(* (unsigned char *) s) && *s != '\r' &&
-		    *s != '\n' && * (unsigned char *) s < 128)
-			len = -1;
-		else if (s[0] == '\n' && s[1] == '\n')
-			len = (int) (s - buf) + 2;
-		else if (s[0] == '\n' && &s[1] < e &&
-		    s[1] == '\r' && s[2] == '\n')
-			len = (int) (s - buf) + 3;
-	return (len);
- * Convert month to the month number. Return -1 on error, or month number
-static int
-montoi(const char *s)
-	size_t	i;
-	for (i = 0; i < sizeof(month_names) / sizeof(month_names[0]); i++)
-		if (!strcmp(s, month_names[i]))
-			return ((int) i);
-	return (-1);
- * Parse date-time string, and return the corresponding time_t value
-static time_t
-date_to_epoch(const char *s)
-	time_t		current_time;
-	struct tm	tm, *tmp;
-	char		mon[32];
-	int		sec, min, hour, mday, month, year;
-	(void) memset(&tm, 0, sizeof(tm));
-	sec = min = hour = mday = month = year = 0;
-	if (((sscanf(s, "%d/%3s/%d %d:%d:%d",
-	    &mday, mon, &year, &hour, &min, &sec) == 6) ||
-	    (sscanf(s, "%d %3s %d %d:%d:%d",
-	    (sscanf(s, "%*3s, %d %3s %d %d:%d:%d",
-	    (sscanf(s, "%d-%3s-%d %d:%d:%d",
-	    &mday, mon, &year, &hour, &min, &sec) == 6)) &&
-	    (month = montoi(mon)) != -1) {
-		tm.tm_mday	= mday;
-		tm.tm_mon	= month;
-		tm.tm_year	= year;
-		tm.tm_hour	= hour;
-		tm.tm_min	= min;
-		tm.tm_sec	= sec;
-	if (tm.tm_year > 1900)
-		tm.tm_year -= 1900;
-	else if (tm.tm_year < 70)
-		tm.tm_year += 100;
-	/* Set Daylight Saving Time field */
-	current_time = time(NULL);
-	tmp = localtime(&current_time);
-	tm.tm_isdst = tmp->tm_isdst;
-	return (mktime(&tm));
- * Protect against directory disclosure attack by removing '..',
- * excessive '/' and '\' characters
-static void
-remove_double_dots_and_double_slashes(char *s)
-	char	*p = s;
-	while (*s != '\0') {
-		*p++ = *s++;
-		if (s[-1] == '/' || s[-1] == '\\') {
-			/* Skip all following slashes and backslashes */
-			while (*s == '/' || *s == '\\')
-				s++;
-			/* Skip all double-dots */
-			while (*s == '.' && s[1] == '.')
-				s += 2;
-	*p = '\0';
- * Built-in mime types
 static const struct {
-	const char	*extension;
-	size_t		ext_len;
-	const char	*mime_type;
-	size_t		mime_type_len;
-} mime_types[] = {
-	{".html",	5,	"text/html",			9},
-	{".htm",	4,	"text/html",			9},
-	{".shtm",	5,	"text/html",			9},
-	{".shtml",	6,	"text/html",			9},
-	{".css",	4,	"text/css",			8},
-	{".js",		3,	"application/x-javascript",	24},
-	{".ico",	4,	"image/x-icon",			12},
-	{".gif",	4,	"image/gif",			9},
-	{".jpg",	4,	"image/jpeg",			10},
-	{".jpeg",	5,	"image/jpeg",			10},
-	{".png",	4,	"image/png",			9},
-	{".svg",	4,	"image/svg+xml",		13},
-	{".torrent",	8,	"application/x-bittorrent",	24},
-	{".wav",	4,	"audio/x-wav",			11},
-	{".mp3",	4,	"audio/x-mp3",			11},
-	{".mid",	4,	"audio/mid",			9},
-	{".m3u",	4,	"audio/x-mpegurl",		15},
-	{".ram",	4,	"audio/x-pn-realaudio",		20},
-	{".xml",	4,	"text/xml",			8},
-	{".xslt",	5,	"application/xml",		15},
-	{".ra",		3,	"audio/x-pn-realaudio",		20},
-	{".doc",	4,	"application/msword",		19},
-	{".exe",	4,	"application/octet-stream",	24},
-	{".zip",	4,	"application/x-zip-compressed",	28},
-	{".xls",	4,	"application/excel",		17},
-	{".tgz",	4,	"application/x-tar-gz",		20},
-	{".tar",	4,	"application/x-tar",		17},
-	{".gz",		3,	"application/x-gunzip",		20},
-	{".arj",	4,	"application/x-arj-compressed",	28},
-	{".rar",	4,	"application/x-arj-compressed",	28},
-	{".rtf",	4,	"application/rtf",		15},
-	{".pdf",	4,	"application/pdf",		15},
-	{".swf",	4,	"application/x-shockwave-flash",29},
-	{".mpg",	4,	"video/mpeg",			10},
-	{".mpeg",	5,	"video/mpeg",			10},
-	{".asf",	4,	"video/x-ms-asf",		14},
-	{".avi",	4,	"video/x-msvideo",		15},
-	{".bmp",	4,	"image/bmp",			9},
-	{NULL,		0,	NULL,				0}
+  const char *extension;
+  size_t ext_len;
+  const char *mime_type;
+  size_t mime_type_len;
+} builtin_mime_types[] = {
+  {".html", 5, "text/html",   9},
+  {".htm", 4, "text/html",   9},
+  {".shtm", 5, "text/html",   9},
+  {".shtml", 6, "text/html",   9},
+  {".css", 4, "text/css",   8},
+  {".js",  3, "application/x-javascript", 24},
+  {".ico", 4, "image/x-icon",   12},
+  {".gif", 4, "image/gif",   9},
+  {".jpg", 4, "image/jpeg",   10},
+  {".jpeg", 5, "image/jpeg",   10},
+  {".png", 4, "image/png",   9},
+  {".svg", 4, "image/svg+xml",  13},
+  {".torrent", 8, "application/x-bittorrent", 24},
+  {".wav", 4, "audio/x-wav",   11},
+  {".mp3", 4, "audio/x-mp3",   11},
+  {".mid", 4, "audio/mid",   9},
+  {".m3u", 4, "audio/x-mpegurl",  15},
+  {".ram", 4, "audio/x-pn-realaudio",  20},
+  {".xml", 4, "text/xml",   8},
+  {".xslt", 5, "application/xml",  15},
+  {".ra",  3, "audio/x-pn-realaudio",  20},
+  {".doc", 4, "application/msword",  19},
+  {".exe", 4, "application/octet-stream", 24},
+  {".zip", 4, "application/x-zip-compressed", 28},
+  {".xls", 4, "application/excel",  17},
+  {".tgz", 4, "application/x-tar-gz",  20},
+  {".tar", 4, "application/x-tar",  17},
+  {".gz",  3, "application/x-gunzip",  20},
+  {".arj", 4, "application/x-arj-compressed", 28},
+  {".rar", 4, "application/x-arj-compressed", 28},
+  {".rtf", 4, "application/rtf",  15},
+  {".pdf", 4, "application/pdf",  15},
+  {".swf", 4, "application/x-shockwave-flash",29},
+  {".mpg", 4, "video/mpeg",   10},
+  {".mpeg", 5, "video/mpeg",   10},
+  {".mp4", 4, "video/mp4", 9},
+  {".m4v", 4, "video/x-m4v", 11},
+  {".asf", 4, "video/x-ms-asf",  14},
+  {".avi", 4, "video/x-msvideo",  15},
+  {".bmp", 4, "image/bmp",   9},
+  {NULL,  0, NULL,    0}
- * Look at the "path" extension and figure what mime type it has.
- * Store mime type in the vector.
-static void
-get_mime_type(struct mg_context *ctx, const char *path, struct vec *vec)
-	struct vec	ext_vec, mime_vec;
-	const char	*list, *ext;
-	size_t		i, path_len;
-	 * Scan user-defined mime types first, in case user wants to
-	 * override default mime types.
-	lock_option(ctx, OPT_MIME_TYPES);
-	list = ctx->options[OPT_MIME_TYPES];
-	while ((list = next_option(list, &ext_vec, &mime_vec)) != NULL) {
-		/* ext now points to the path suffix */
-		ext = path + path_len - ext_vec.len;
-		if (mg_strncasecmp(ext, ext_vec.ptr, ext_vec.len) == 0) {
-			*vec = mime_vec;
-			unlock_option(ctx, OPT_MIME_TYPES);
-			return;
-	/* Now scan built-in mime types */
-	for (i = 0; mime_types[i].extension != NULL; i++) {
-		ext = path + (path_len - mime_types[i].ext_len);
-		if (path_len > mime_types[i].ext_len &&
-		    mg_strcasecmp(ext, mime_types[i].extension) == 0) {
-			vec->ptr = mime_types[i].mime_type;
-			vec->len = mime_types[i].mime_type_len;
-			return;
-	/* Nothing found. Fall back to text/plain */
-	vec->ptr = "text/plain";
-	vec->len = 10;
+// Look at the "path" extension and figure what mime type it has.
+// Store mime type in the vector.
+static void get_mime_type(struct mg_context *ctx, const char *path,
+                          struct vec *vec) {
+  struct vec ext_vec, mime_vec;
+  const char *list, *ext;
+  size_t i, path_len;
+  path_len = strlen(path);
+  // Scan user-defined mime types first, in case user wants to
+  // override default mime types.
+  list = ctx->config[EXTRA_MIME_TYPES];
+  while ((list = next_option(list, &ext_vec, &mime_vec)) != NULL) {
+    // ext now points to the path suffix
+    ext = path + path_len - ext_vec.len;
+    if (mg_strncasecmp(ext, ext_vec.ptr, ext_vec.len) == 0) {
+      *vec = mime_vec;
+      return;
+  // Now scan built-in mime types
+  for (i = 0; builtin_mime_types[i].extension != NULL; i++) {
+    ext = path + (path_len - builtin_mime_types[i].ext_len);
+    if (path_len > builtin_mime_types[i].ext_len &&
+        mg_strcasecmp(ext, builtin_mime_types[i].extension) == 0) {
+      vec->ptr = builtin_mime_types[i].mime_type;
+      vec->len = builtin_mime_types[i].mime_type_len;
+      return;
+  // Nothing found. Fall back to "text/plain"
+  vec->ptr = "text/plain";
+  vec->len = 10;
 #ifndef HAVE_MD5
 typedef struct MD5Context {
-	uint32_t	buf[4];
-	uint32_t	bits[2];
-	unsigned char	in[64];
+  uint32_t buf[4];
+  uint32_t bits[2];
+  unsigned char in[64];
 } MD5_CTX;
-#if __BYTE_ORDER == 1234
-#define byteReverse(buf, len)	/* Nothing */
+#if defined(__BYTE_ORDER) && (__BYTE_ORDER == 1234)
+#define byteReverse(buf, len) // Do nothing
 #else
- * Note: this code is harmless on little-endian machines.
-static void
-byteReverse(unsigned char *buf, unsigned longs)
-	uint32_t t;
-	do {
-		t = (uint32_t) ((unsigned) buf[3] << 8 | buf[2]) << 16 |
-			((unsigned) buf[1] << 8 | buf[0]);
-		*(uint32_t *) buf = t;
-		buf += 4;
-	} while (--longs);
-#endif /* __BYTE_ORDER */
-/* The four core functions - F1 is optimized somewhat */
-/* #define F1(x, y, z) (x & y | ~x & z) */
+static void byteReverse(unsigned char *buf, unsigned longs) {
+  uint32_t t;
+  do {
+    t = (uint32_t) ((unsigned) buf[3] << 8 | buf[2]) << 16 |
+      ((unsigned) buf[1] << 8 | buf[0]);
+    *(uint32_t *) buf = t;
+    buf += 4;
+  } while (--longs);
+#endif
 #define F1(x, y, z) (z ^ (x & (y ^ z)))
 #define F2(x, y, z) F1(z, x, y)
 #define F3(x, y, z) (x ^ y ^ z)
 #define F4(x, y, z) (y ^ (x | ~z))
-/* This is the central step in the MD5 algorithm. */
 #define MD5STEP(f, w, x, y, z, data, s) \
-( w += f(x, y, z) + data,  w = w<<s | w>>(32-s),  w += x )
- * Start MD5 accumulation.  Set bit count to 0 and buffer to mysterious
- * initialization constants.
-static void
-MD5Init(MD5_CTX *ctx)
-	ctx->buf[0] = 0x67452301;
-	ctx->buf[1] = 0xefcdab89;
-	ctx->buf[2] = 0x98badcfe;
-	ctx->buf[3] = 0x10325476;
-	ctx->bits[0] = 0;
-	ctx->bits[1] = 0;
- * The core of the MD5 algorithm, this alters an existing MD5 hash to
- * reflect the addition of 16 longwords of new data.  MD5Update blocks
- * the data and converts bytes into longwords for this routine.
-static void
-MD5Transform(uint32_t buf[4], uint32_t const in[16])
-	register uint32_t a, b, c, d;
-	a = buf[0];
-	b = buf[1];
-	c = buf[2];
-	d = buf[3];
-	MD5STEP(F1, a, b, c, d, in[0] + 0xd76aa478, 7);
-	MD5STEP(F1, d, a, b, c, in[1] + 0xe8c7b756, 12);
-	MD5STEP(F1, c, d, a, b, in[2] + 0x242070db, 17);
-	MD5STEP(F1, b, c, d, a, in[3] + 0xc1bdceee, 22);
-	MD5STEP(F1, a, b, c, d, in[4] + 0xf57c0faf, 7);
-	MD5STEP(F1, d, a, b, c, in[5] + 0x4787c62a, 12);
-	MD5STEP(F1, c, d, a, b, in[6] + 0xa8304613, 17);
-	MD5STEP(F1, b, c, d, a, in[7] + 0xfd469501, 22);
-	MD5STEP(F1, a, b, c, d, in[8] + 0x698098d8, 7);
-	MD5STEP(F1, d, a, b, c, in[9] + 0x8b44f7af, 12);
-	MD5STEP(F1, c, d, a, b, in[10] + 0xffff5bb1, 17);
-	MD5STEP(F1, b, c, d, a, in[11] + 0x895cd7be, 22);
-	MD5STEP(F1, a, b, c, d, in[12] + 0x6b901122, 7);
-	MD5STEP(F1, d, a, b, c, in[13] + 0xfd987193, 12);
-	MD5STEP(F1, c, d, a, b, in[14] + 0xa679438e, 17);
-	MD5STEP(F1, b, c, d, a, in[15] + 0x49b40821, 22);
-	MD5STEP(F2, a, b, c, d, in[1] + 0xf61e2562, 5);
-	MD5STEP(F2, d, a, b, c, in[6] + 0xc040b340, 9);
-	MD5STEP(F2, c, d, a, b, in[11] + 0x265e5a51, 14);
-	MD5STEP(F2, b, c, d, a, in[0] + 0xe9b6c7aa, 20);
-	MD5STEP(F2, a, b, c, d, in[5] + 0xd62f105d, 5);
-	MD5STEP(F2, d, a, b, c, in[10] + 0x02441453, 9);
-	MD5STEP(F2, c, d, a, b, in[15] + 0xd8a1e681, 14);
-	MD5STEP(F2, b, c, d, a, in[4] + 0xe7d3fbc8, 20);
-	MD5STEP(F2, a, b, c, d, in[9] + 0x21e1cde6, 5);
-	MD5STEP(F2, d, a, b, c, in[14] + 0xc33707d6, 9);
-	MD5STEP(F2, c, d, a, b, in[3] + 0xf4d50d87, 14);
-	MD5STEP(F2, b, c, d, a, in[8] + 0x455a14ed, 20);
-	MD5STEP(F2, a, b, c, d, in[13] + 0xa9e3e905, 5);
-	MD5STEP(F2, d, a, b, c, in[2] + 0xfcefa3f8, 9);
-	MD5STEP(F2, c, d, a, b, in[7] + 0x676f02d9, 14);
-	MD5STEP(F2, b, c, d, a, in[12] + 0x8d2a4c8a, 20);
-	MD5STEP(F3, a, b, c, d, in[5] + 0xfffa3942, 4);
-	MD5STEP(F3, d, a, b, c, in[8] + 0x8771f681, 11);
-	MD5STEP(F3, c, d, a, b, in[11] + 0x6d9d6122, 16);
-	MD5STEP(F3, b, c, d, a, in[14] + 0xfde5380c, 23);
-	MD5STEP(F3, a, b, c, d, in[1] + 0xa4beea44, 4);
-	MD5STEP(F3, d, a, b, c, in[4] + 0x4bdecfa9, 11);
-	MD5STEP(F3, c, d, a, b, in[7] + 0xf6bb4b60, 16);
-	MD5STEP(F3, b, c, d, a, in[10] + 0xbebfbc70, 23);
-	MD5STEP(F3, a, b, c, d, in[13] + 0x289b7ec6, 4);
-	MD5STEP(F3, d, a, b, c, in[0] + 0xeaa127fa, 11);
-	MD5STEP(F3, c, d, a, b, in[3] + 0xd4ef3085, 16);
-	MD5STEP(F3, b, c, d, a, in[6] + 0x04881d05, 23);
-	MD5STEP(F3, a, b, c, d, in[9] + 0xd9d4d039, 4);
-	MD5STEP(F3, d, a, b, c, in[12] + 0xe6db99e5, 11);
-	MD5STEP(F3, c, d, a, b, in[15] + 0x1fa27cf8, 16);
-	MD5STEP(F3, b, c, d, a, in[2] + 0xc4ac5665, 23);
-	MD5STEP(F4, a, b, c, d, in[0] + 0xf4292244, 6);
-	MD5STEP(F4, d, a, b, c, in[7] + 0x432aff97, 10);
-	MD5STEP(F4, c, d, a, b, in[14] + 0xab9423a7, 15);
-	MD5STEP(F4, b, c, d, a, in[5] + 0xfc93a039, 21);
-	MD5STEP(F4, a, b, c, d, in[12] + 0x655b59c3, 6);
-	MD5STEP(F4, d, a, b, c, in[3] + 0x8f0ccc92, 10);
-	MD5STEP(F4, c, d, a, b, in[10] + 0xffeff47d, 15);
-	MD5STEP(F4, b, c, d, a, in[1] + 0x85845dd1, 21);
-	MD5STEP(F4, a, b, c, d, in[8] + 0x6fa87e4f, 6);
-	MD5STEP(F4, d, a, b, c, in[15] + 0xfe2ce6e0, 10);
-	MD5STEP(F4, c, d, a, b, in[6] + 0xa3014314, 15);
-	MD5STEP(F4, b, c, d, a, in[13] + 0x4e0811a1, 21);
-	MD5STEP(F4, a, b, c, d, in[4] + 0xf7537e82, 6);
-	MD5STEP(F4, d, a, b, c, in[11] + 0xbd3af235, 10);
-	MD5STEP(F4, c, d, a, b, in[2] + 0x2ad7d2bb, 15);
-	MD5STEP(F4, b, c, d, a, in[9] + 0xeb86d391, 21);
-	buf[0] += a;
-	buf[1] += b;
-	buf[2] += c;
-	buf[3] += d;
- * Update context to reflect the concatenation of another buffer full
- * of bytes.
-static void
-MD5Update(MD5_CTX *ctx, unsigned char const *buf, uint32_t len)
-	uint32_t t;
-	/* Update bitcount */
-	t = ctx->bits[0];
-	if ((ctx->bits[0] = t + (len << 3)) < t)
-		ctx->bits[1]++;		/* Carry from low to high */
-	ctx->bits[1] += len >> 29;
-	t = (t >> 3) & 0x3f;	/* Bytes already in shsInfo->data */
-	/* Handle any leading odd-sized chunks */
-	if (t) {
-		unsigned char *p = (unsigned char *) ctx->in + t;
-		t = 64 - t;
-		if (len < t) {
-			memcpy(p, buf, len);
-			return;
-		memcpy(p, buf, t);
-		byteReverse(ctx->in, 16);
-		MD5Transform(ctx->buf, (uint32_t *) ctx->in);
-		buf += t;
-		len -= t;
-	/* Process data in 64-byte chunks */
-	while (len >= 64) {
-		memcpy(ctx->in, buf, 64);
-		buf += 64;
-		len -= 64;
-	/* Handle any remaining bytes of data. */
-	memcpy(ctx->in, buf, len);
- * Final wrapup - pad to 64-byte boundary with the bit pattern
- * 1 0* (64-bit count of bits processed, MSB-first)
-static void
-MD5Final(unsigned char digest[16], MD5_CTX *ctx)
-	unsigned count;
-	unsigned char *p;
-	/* Compute number of bytes mod 64 */
-	count = (ctx->bits[0] >> 3) & 0x3F;
-	/* Set the first char of padding to 0x80.  This is safe since there is
-	   always at least one byte free */
-	p = ctx->in + count;
-	*p++ = 0x80;
-	/* Bytes of padding needed to make 64 bytes */
-	count = 64 - 1 - count;
-	/* Pad out to 56 mod 64 */
-	if (count < 8) {
-		/* Two lots of padding:  Pad the first block to 64 bytes */
-		memset(p, 0, count);
-		/* Now fill the next block with 56 bytes */
-		memset(ctx->in, 0, 56);
-	} else {
-		/* Pad block to 56 bytes */
-		memset(p, 0, count - 8);
-	byteReverse(ctx->in, 14);
-	/* Append length in bits and transform */
-	((uint32_t *) ctx->in)[14] = ctx->bits[0];
-	((uint32_t *) ctx->in)[15] = ctx->bits[1];
-	byteReverse((unsigned char *) ctx->buf, 4);
-	memcpy(digest, ctx->buf, 16);
-	memset((char *) ctx, 0, sizeof(ctx));	/* In case it's sensitive */
-#endif /* !HAVE_MD5 */
- * Stringify binary data. Output buffer must be twice as big as input,
- * because each byte takes 2 bytes in string representation
-static void
-bin2str(char *to, const unsigned char *p, size_t len)
-	static const char *hex = "0123456789abcdef";
-	for (; len--; p++) {
-		*to++ = hex[p[0] >> 4];
-		*to++ = hex[p[0] & 0x0f];
-	*to = '\0';
- * Return stringified MD5 hash for list of vectors.
- * buf must point to 33-bytes long buffer
-static void
-mg_md5(char *buf, ...)
-	unsigned char	hash[16];
-	const char	*p;
-	va_list		ap;
-	MD5_CTX		ctx;
-	MD5Init(&ctx);
-	va_start(ap, buf);
-	while ((p = va_arg(ap, const char *)) != NULL)
-		MD5Update(&ctx, (unsigned char *) p, strlen(p));
-	va_end(ap);
-	MD5Final(hash, &ctx);
-	bin2str(buf, hash, sizeof(hash));
- * Check the user's password, return 1 if OK
-static bool_t
-check_password(const char *method, const char *ha1, const char *uri,
-		const char *nonce, const char *nc, const char *cnonce,
-		const char *qop, const char *response)
-	char	ha2[32 + 1], expected_response[32 + 1];
-	/* XXX  Due to a bug in MSIE, we do not compare the URI	 */
-	/* Also, we do not check for authentication timeout */
-	if (/*strcmp(dig->uri, c->ouri) != 0 || */
-	    strlen(response) != 32 /*||
-	    now - strtoul(dig->nonce, NULL, 10) > 3600 */)
-		return (FALSE);
-	mg_md5(ha2, method, ":", uri, NULL);
-	mg_md5(expected_response, ha1, ":", nonce, ":", nc,
-	    ":", cnonce, ":", qop, ":", ha2, NULL);
-	return (!mg_strcasecmp(response, expected_response));
- * Use the global passwords file, if specified by auth_gpass option,
- * or search for .htpasswd in the requested directory.
-static FILE *
-open_auth_file(struct mg_connection *conn, const char *path)
-	char 			name[FILENAME_MAX];
-	const char		*p, *e;
-	struct mgstat		st;
-	FILE			*fp;
-	if (ctx->options[OPT_AUTH_GPASSWD] != NULL) {
-		/* Use global passwords file */
-		fp =  mg_fopen(ctx->options[OPT_AUTH_GPASSWD], "r");
-		if (fp == NULL)
-			cry(fc(ctx), "fopen(%s): %s",
-			    ctx->options[OPT_AUTH_GPASSWD], strerror(ERRNO));
-	} else if (!mg_stat(path, &st) && st.is_directory) {
-		(void) mg_snprintf(conn, name, sizeof(name), "%s%c%s",
-		    path, DIRSEP, PASSWORDS_FILE_NAME);
-		fp = mg_fopen(name, "r");
-	} else {
-		 * Try to find .htpasswd in requested directory.
-		 * Given the path, create the path to .htpasswd file
-		 * in the same directory. Find the right-most
-		 * directory separator character first. That would be the
-		 * directory name. If directory separator character is not
-		 * found, 'e' will point to 'p'.
-		for (p = path, e = p + strlen(p) - 1; e > p; e--)
-			if (IS_DIRSEP_CHAR(*e))
-				break;
-		 * Make up the path by concatenating directory name and
-		 * .htpasswd file name.
-		(void) mg_snprintf(conn, name, sizeof(name), "%.*s%c%s",
-		    (int) (e - p), p, DIRSEP, PASSWORDS_FILE_NAME);
-	return (fp);
- * Parsed Authorization: header
+  ( w += f(x, y, z) + data,  w = w<<s | w>>(32-s),  w += x )
+// Start MD5 accumulation.  Set bit count to 0 and buffer to mysterious
+// initialization constants.
+static void MD5Init(MD5_CTX *ctx) {
+  ctx->buf[0] = 0x67452301;
+  ctx->buf[1] = 0xefcdab89;
+  ctx->buf[2] = 0x98badcfe;
+  ctx->buf[3] = 0x10325476;
+  ctx->bits[0] = 0;
+  ctx->bits[1] = 0;
+static void MD5Transform(uint32_t buf[4], uint32_t const in[16]) {
+  register uint32_t a, b, c, d;
+  a = buf[0];
+  b = buf[1];
+  c = buf[2];
+  d = buf[3];
+  MD5STEP(F1, a, b, c, d, in[0] + 0xd76aa478, 7);
+  MD5STEP(F1, d, a, b, c, in[1] + 0xe8c7b756, 12);
+  MD5STEP(F1, c, d, a, b, in[2] + 0x242070db, 17);
+  MD5STEP(F1, b, c, d, a, in[3] + 0xc1bdceee, 22);
+  MD5STEP(F1, a, b, c, d, in[4] + 0xf57c0faf, 7);
+  MD5STEP(F1, d, a, b, c, in[5] + 0x4787c62a, 12);
+  MD5STEP(F1, c, d, a, b, in[6] + 0xa8304613, 17);
+  MD5STEP(F1, b, c, d, a, in[7] + 0xfd469501, 22);
+  MD5STEP(F1, a, b, c, d, in[8] + 0x698098d8, 7);
+  MD5STEP(F1, d, a, b, c, in[9] + 0x8b44f7af, 12);
+  MD5STEP(F1, c, d, a, b, in[10] + 0xffff5bb1, 17);
+  MD5STEP(F1, b, c, d, a, in[11] + 0x895cd7be, 22);
+  MD5STEP(F1, a, b, c, d, in[12] + 0x6b901122, 7);
+  MD5STEP(F1, d, a, b, c, in[13] + 0xfd987193, 12);
+  MD5STEP(F1, c, d, a, b, in[14] + 0xa679438e, 17);
+  MD5STEP(F1, b, c, d, a, in[15] + 0x49b40821, 22);
+  MD5STEP(F2, a, b, c, d, in[1] + 0xf61e2562, 5);
+  MD5STEP(F2, d, a, b, c, in[6] + 0xc040b340, 9);
+  MD5STEP(F2, c, d, a, b, in[11] + 0x265e5a51, 14);
+  MD5STEP(F2, b, c, d, a, in[0] + 0xe9b6c7aa, 20);
+  MD5STEP(F2, a, b, c, d, in[5] + 0xd62f105d, 5);
+  MD5STEP(F2, d, a, b, c, in[10] + 0x02441453, 9);
+  MD5STEP(F2, c, d, a, b, in[15] + 0xd8a1e681, 14);
+  MD5STEP(F2, b, c, d, a, in[4] + 0xe7d3fbc8, 20);
+  MD5STEP(F2, a, b, c, d, in[9] + 0x21e1cde6, 5);
+  MD5STEP(F2, d, a, b, c, in[14] + 0xc33707d6, 9);
+  MD5STEP(F2, c, d, a, b, in[3] + 0xf4d50d87, 14);
+  MD5STEP(F2, b, c, d, a, in[8] + 0x455a14ed, 20);
+  MD5STEP(F2, a, b, c, d, in[13] + 0xa9e3e905, 5);
+  MD5STEP(F2, d, a, b, c, in[2] + 0xfcefa3f8, 9);
+  MD5STEP(F2, c, d, a, b, in[7] + 0x676f02d9, 14);
+  MD5STEP(F2, b, c, d, a, in[12] + 0x8d2a4c8a, 20);
+  MD5STEP(F3, a, b, c, d, in[5] + 0xfffa3942, 4);
+  MD5STEP(F3, d, a, b, c, in[8] + 0x8771f681, 11);
+  MD5STEP(F3, c, d, a, b, in[11] + 0x6d9d6122, 16);
+  MD5STEP(F3, b, c, d, a, in[14] + 0xfde5380c, 23);
+  MD5STEP(F3, a, b, c, d, in[1] + 0xa4beea44, 4);
+  MD5STEP(F3, d, a, b, c, in[4] + 0x4bdecfa9, 11);
+  MD5STEP(F3, c, d, a, b, in[7] + 0xf6bb4b60, 16);
+  MD5STEP(F3, b, c, d, a, in[10] + 0xbebfbc70, 23);
+  MD5STEP(F3, a, b, c, d, in[13] + 0x289b7ec6, 4);
+  MD5STEP(F3, d, a, b, c, in[0] + 0xeaa127fa, 11);
+  MD5STEP(F3, c, d, a, b, in[3] + 0xd4ef3085, 16);
+  MD5STEP(F3, b, c, d, a, in[6] + 0x04881d05, 23);
+  MD5STEP(F3, a, b, c, d, in[9] + 0xd9d4d039, 4);
+  MD5STEP(F3, d, a, b, c, in[12] + 0xe6db99e5, 11);
+  MD5STEP(F3, c, d, a, b, in[15] + 0x1fa27cf8, 16);
+  MD5STEP(F3, b, c, d, a, in[2] + 0xc4ac5665, 23);
+  MD5STEP(F4, a, b, c, d, in[0] + 0xf4292244, 6);
+  MD5STEP(F4, d, a, b, c, in[7] + 0x432aff97, 10);
+  MD5STEP(F4, c, d, a, b, in[14] + 0xab9423a7, 15);
+  MD5STEP(F4, b, c, d, a, in[5] + 0xfc93a039, 21);
+  MD5STEP(F4, a, b, c, d, in[12] + 0x655b59c3, 6);
+  MD5STEP(F4, d, a, b, c, in[3] + 0x8f0ccc92, 10);
+  MD5STEP(F4, c, d, a, b, in[10] + 0xffeff47d, 15);
+  MD5STEP(F4, b, c, d, a, in[1] + 0x85845dd1, 21);
+  MD5STEP(F4, a, b, c, d, in[8] + 0x6fa87e4f, 6);
+  MD5STEP(F4, d, a, b, c, in[15] + 0xfe2ce6e0, 10);
+  MD5STEP(F4, c, d, a, b, in[6] + 0xa3014314, 15);
+  MD5STEP(F4, b, c, d, a, in[13] + 0x4e0811a1, 21);
+  MD5STEP(F4, a, b, c, d, in[4] + 0xf7537e82, 6);
+  MD5STEP(F4, d, a, b, c, in[11] + 0xbd3af235, 10);
+  MD5STEP(F4, c, d, a, b, in[2] + 0x2ad7d2bb, 15);
+  MD5STEP(F4, b, c, d, a, in[9] + 0xeb86d391, 21);
+  buf[0] += a;
+  buf[1] += b;
+  buf[2] += c;
+  buf[3] += d;
+static void MD5Update(MD5_CTX *ctx, unsigned char const *buf, unsigned len) {
+  uint32_t t;
+  t = ctx->bits[0];
+  if ((ctx->bits[0] = t + ((uint32_t) len << 3)) < t)
+    ctx->bits[1]++;
+  ctx->bits[1] += len >> 29;
+  t = (t >> 3) & 0x3f;
+  if (t) {
+    unsigned char *p = (unsigned char *) ctx->in + t;
+    t = 64 - t;
+    if (len < t) {
+      memcpy(p, buf, len);
+      return;
+    memcpy(p, buf, t);
+    byteReverse(ctx->in, 16);
+    MD5Transform(ctx->buf, (uint32_t *) ctx->in);
+    buf += t;
+    len -= t;
+  while (len >= 64) {
+    memcpy(ctx->in, buf, 64);
+    buf += 64;
+    len -= 64;
+  memcpy(ctx->in, buf, len);
+static void MD5Final(unsigned char digest[16], MD5_CTX *ctx) {
+  unsigned count;
+  unsigned char *p;
+  count = (ctx->bits[0] >> 3) & 0x3F;
+  p = ctx->in + count;
+  *p++ = 0x80;
+  count = 64 - 1 - count;
+  if (count < 8) {
+    memset(p, 0, count);
+    memset(ctx->in, 0, 56);
+  } else {
+    memset(p, 0, count - 8);
+  byteReverse(ctx->in, 14);
+  ((uint32_t *) ctx->in)[14] = ctx->bits[0];
+  ((uint32_t *) ctx->in)[15] = ctx->bits[1];
+  byteReverse((unsigned char *) ctx->buf, 4);
+  memcpy(digest, ctx->buf, 16);
+  memset((char *) ctx, 0, sizeof(*ctx));
+#endif // !HAVE_MD5
+// Stringify binary data. Output buffer must be twice as big as input,
+// because each byte takes 2 bytes in string representation
+static void bin2str(char *to, const unsigned char *p, size_t len) {
+  static const char *hex = "0123456789abcdef";
+  for (; len--; p++) {
+    *to++ = hex[p[0] >> 4];
+    *to++ = hex[p[0] & 0x0f];
+  *to = '\0';
+// Return stringified MD5 hash for list of vectors. Buffer must be 33 bytes.
+void mg_md5(char *buf, ...) {
+  unsigned char hash[16];
+  const char *p;
+  va_list ap;
+  MD5_CTX ctx;
+  MD5Init(&ctx);
+  va_start(ap, buf);
+  while ((p = va_arg(ap, const char *)) != NULL) {
+    MD5Update(&ctx, (const unsigned char *) p, (unsigned) strlen(p));
+  va_end(ap);
+  MD5Final(hash, &ctx);
+  bin2str(buf, hash, sizeof(hash));
+// Check the user's password, return 1 if OK
+static int check_password(const char *method, const char *ha1, const char *uri,
+                          const char *nonce, const char *nc, const char *cnonce,
+                          const char *qop, const char *response) {
+  char ha2[32 + 1], expected_response[32 + 1];
+  // Some of the parameters may be NULL
+  if (method == NULL || nonce == NULL || nc == NULL || cnonce == NULL ||
+      qop == NULL || response == NULL) {
+    return 0;
+  // NOTE(lsm): due to a bug in MSIE, we do not compare the URI
+  // TODO(lsm): check for authentication timeout
+  if (// strcmp(dig->uri, c->ouri) != 0 ||
+      strlen(response) != 32
+      // || now - strtoul(dig->nonce, NULL, 10) > 3600
+    return 0;
+  mg_md5(ha2, method, ":", uri, NULL);
+  mg_md5(expected_response, ha1, ":", nonce, ":", nc,
+      ":", cnonce, ":", qop, ":", ha2, NULL);
+  return mg_strcasecmp(response, expected_response) == 0;
+// Use the global passwords file, if specified by auth_gpass option,
+// or search for .htpasswd in the requested directory.
+static FILE *open_auth_file(struct mg_connection *conn, const char *path) {
+  struct mg_context *ctx = conn->ctx;
+  char name[PATH_MAX];
+  const char *p, *e;
+  struct mgstat st;
+  FILE *fp;
+  if (ctx->config[GLOBAL_PASSWORDS_FILE] != NULL) {
+    // Use global passwords file
+    fp =  mg_fopen(ctx->config[GLOBAL_PASSWORDS_FILE], "r");
+    if (fp == NULL)
+      cry(fc(ctx), "fopen(%s): %s",
+          ctx->config[GLOBAL_PASSWORDS_FILE], strerror(ERRNO));
+  } else if (!mg_stat(path, &st) && st.is_directory) {
+    (void) mg_snprintf(conn, name, sizeof(name), "%s%c%s",
+        path, DIRSEP, PASSWORDS_FILE_NAME);
+    fp = mg_fopen(name, "r");
+  } else {
+     // Try to find .htpasswd in requested directory.
+    for (p = path, e = p + strlen(p) - 1; e > p; e--)
+      if (IS_DIRSEP_CHAR(*e))
+        break;
+    (void) mg_snprintf(conn, name, sizeof(name), "%.*s%c%s",
+        (int) (e - p), p, DIRSEP, PASSWORDS_FILE_NAME);
+  return fp;
+// Parsed Authorization header
 struct ah {
-	char	*user, *uri, *cnonce, *response, *qop, *nc, *nonce;
+  char *user, *uri, *cnonce, *response, *qop, *nc, *nonce;
-static bool_t
-parse_auth_header(struct mg_connection *conn, char *buf, size_t buf_size,
-		struct ah *ah)
-	char		*name, *value, *s;
-	const char	*auth_header;
-	if ((auth_header = mg_get_header(conn, "Authorization")) == NULL ||
-	    mg_strncasecmp(auth_header, "Digest ", 7) != 0)
-		return (FALSE);
-	/* Make modifiable copy of the auth header */
-	(void) mg_strlcpy(buf, auth_header + 7, buf_size);
-	s = buf;
-	(void) memset(ah, 0, sizeof(*ah));
-	/* Gobble initial spaces */
-	while (isspace(* (unsigned char *) s))
-		s++;
-	/* Parse authorization header */
-	for (;;) {
-		name = skip(&s, "=");
-		value = skip(&s, ", ");
-		if (*value == '"') {
-			value++;
-			value[strlen(value) - 1] = '\0';
-		} else if (*value == '\0') {
-			break;
-		if (!strcmp(name, "username")) {
-			ah->user = value;
-		} else if (!strcmp(name, "cnonce")) {
-			ah->cnonce = value;
-		} else if (!strcmp(name, "response")) {
-			ah->response = value;
-		} else if (!strcmp(name, "uri")) {
-			ah->uri = value;
-		} else if (!strcmp(name, "qop")) {
-			ah->qop = value;
-		} else if (!strcmp(name, "nc")) {
-			ah->nc = value;
-		} else if (!strcmp(name, "nonce")) {
-			ah->nonce = value;
-	/* CGI needs it as REMOTE_USER */
-	if (ah->user != NULL)
-		conn->request_info.remote_user = mg_strdup(ah->user);
-	return (TRUE);
- * Authorize against the opened passwords file. Return 1 if authorized.
-static bool_t
-authorize(struct mg_connection *conn, FILE *fp)
-	struct ah	ah;
-	char		line[256], f_user[256], domain[256], ha1[256],
-			buf[MAX_REQUEST_SIZE];
-	if (!parse_auth_header(conn, buf, sizeof(buf), &ah))
-		return (FALSE);
-	/* Loop over passwords file */
-	while (fgets(line, sizeof(line), fp) != NULL) {
-		if (sscanf(line, "%[^:]:%[^:]:%s", f_user, domain, ha1) != 3)
-			continue;
-		if (!strcmp(ah.user, f_user) &&
-		    !strcmp(domain, conn->ctx->options[OPT_AUTH_DOMAIN]))
-			return (check_password(
-			    conn->request_info.request_method, ha1,
-			    ah.uri, ah.nonce, ah.nc, ah.cnonce,
-			    ah.qop, ah.response));
-	return (FALSE);
- * Return TRUE if request is authorised, FALSE otherwise.
-static bool_t
-check_authorization(struct mg_connection *conn, const char *path)
-	FILE		*fp;
-	char		fname[FILENAME_MAX];
-	struct vec	uri_vec, filename_vec;
-	const char	*list;
-	bool_t		authorized;
-	fp = NULL;
-	authorized = TRUE;
-	lock_option(conn->ctx, OPT_PROTECT);
-	list = conn->ctx->options[OPT_PROTECT];
-	while ((list = next_option(list, &uri_vec, &filename_vec)) != NULL) {
-		if (!memcmp(conn->request_info.uri, uri_vec.ptr, uri_vec.len)) {
-			(void) mg_snprintf(conn, fname, sizeof(fname), "%.*s",
-			    filename_vec.len, filename_vec.ptr);
-			if ((fp = mg_fopen(fname, "r")) == NULL)
-				cry(conn, "%s: cannot open %s: %s",
-				    __func__, fname, strerror(errno));
-			break;
-	unlock_option(conn->ctx, OPT_PROTECT);
-	if (fp == NULL)
-		fp = open_auth_file(conn, path);
-	if (fp != NULL) {
-		authorized = authorize(conn, fp);
-	return (authorized);
-static void
-send_authorization_request(struct mg_connection *conn)
-	conn->request_info.status_code = 401;
-	(void) mg_printf(conn,
-	    "HTTP/1.1 401 Unauthorized\r\n"
-	    "WWW-Authenticate: Digest qop=\"auth\", "
-	    "realm=\"%s\", nonce=\"%lu\"\r\n\r\n",
-	    conn->ctx->options[OPT_AUTH_DOMAIN], (unsigned long) time(NULL));
-static bool_t
-is_authorized_for_put(struct mg_connection *conn)
-	FILE	*fp;
-	int	ret = FALSE;
-	if ((fp = mg_fopen(conn->ctx->options[OPT_AUTH_PUT], "r")) != NULL) {
-		set_close_on_exec(fileno(fp));
-		ret = authorize(conn, fp);
-	return (ret);
-int
-mg_modify_passwords_file(struct mg_context *ctx, const char *fname,
-		const char *user, const char *pass)
-	int		found;
-	char		line[512], u[512], d[512], ha1[33], tmp[FILENAME_MAX];
-	const char	*domain;
-	FILE		*fp, *fp2;
-	found = 0;
-	fp = fp2 = NULL;
-	domain = ctx->options[OPT_AUTH_DOMAIN];
-	/* Regard empty password as no password - remove user record. */
-	if (pass[0] == '\0')
-		pass = NULL;
-	(void) snprintf(tmp, sizeof(tmp), "%s.tmp", fname);
-	/* Create the file if does not exist */
-	if ((fp = mg_fopen(fname, "a+")) != NULL)
-	/* Open the given file and temporary file */
-	if ((fp = mg_fopen(fname, "r")) == NULL) {
-		cry(fc(ctx), "Cannot open %s: %s", fname, strerror(errno));
-		return (0);
-	} else if ((fp2 = mg_fopen(tmp, "w+")) == NULL) {
-		cry(fc(ctx), "Cannot open %s: %s", tmp, strerror(errno));
-		return (0);
-	/* Copy the stuff to temporary file */
-		if (sscanf(line, "%[^:]:%[^:]:%*s", u, d) != 2)
-			continue;
-		if (!strcmp(u, user) && !strcmp(d, domain)) {
-			found++;
-			if (pass != NULL) {
-				mg_md5(ha1, user, ":", domain, ":", pass, NULL);
-				fprintf(fp2, "%s:%s:%s\n", user, domain, ha1);
-		} else {
-			(void) fprintf(fp2, "%s", line);
-	/* If new user, just add it */
-	if (!found && pass != NULL) {
-		(void) fprintf(fp2, "%s:%s:%s\n", user, domain, ha1);
-	/* Close files */
-	(void) fclose(fp2);
-	/* Put the temp file in place of real file */
-	(void) mg_remove(fname);
-	(void) mg_rename(tmp, fname);
-	return (0);
+static int parse_auth_header(struct mg_connection *conn, char *buf,
+                             size_t buf_size, struct ah *ah) {
+  char *name, *value, *s;
+  const char *auth_header;
+  if ((auth_header = mg_get_header(conn, "Authorization")) == NULL ||
+      mg_strncasecmp(auth_header, "Digest ", 7) != 0) {
+    return 0;
+  // Make modifiable copy of the auth header
+  (void) mg_strlcpy(buf, auth_header + 7, buf_size);
+  s = buf;
+  (void) memset(ah, 0, sizeof(*ah));
+  // Parse authorization header
+  for (;;) {
+    // Gobble initial spaces
+    while (isspace(* (unsigned char *) s)) {
+      s++;
+    name = skip_quoted(&s, "=", " ", 0);
+    // Value is either quote-delimited, or ends at first comma or space.
+    if (s[0] == '\"') {
+      s++;
+      value = skip_quoted(&s, "\"", " ", '\\');
+      if (s[0] == ',') {
+        s++;
+    } else {
+      value = skip_quoted(&s, ", ", " ", 0);  // IE uses commas, FF uses spaces
+    if (*name == '\0') {
+      break;
+    if (!strcmp(name, "username")) {
+      ah->user = value;
+    } else if (!strcmp(name, "cnonce")) {
+      ah->cnonce = value;
+    } else if (!strcmp(name, "response")) {
+      ah->response = value;
+    } else if (!strcmp(name, "uri")) {
+      ah->uri = value;
+    } else if (!strcmp(name, "qop")) {
+      ah->qop = value;
+    } else if (!strcmp(name, "nc")) {
+      ah->nc = value;
+    } else if (!strcmp(name, "nonce")) {
+      ah->nonce = value;
+  // CGI needs it as REMOTE_USER
+  if (ah->user != NULL) {
+    conn->request_info.remote_user = mg_strdup(ah->user);
+  } else {
+    return 0;
+  return 1;
+// Authorize against the opened passwords file. Return 1 if authorized.
+static int authorize(struct mg_connection *conn, FILE *fp) {
+  struct ah ah;
+  char line[256], f_user[256], ha1[256], f_domain[256], buf[BUFSIZ];
+  if (!parse_auth_header(conn, buf, sizeof(buf), &ah)) {
+    return 0;
+  // Loop over passwords file
+  while (fgets(line, sizeof(line), fp) != NULL) {
+    if (sscanf(line, "%[^:]:%[^:]:%s", f_user, f_domain, ha1) != 3) {
+      continue;
+    if (!strcmp(ah.user, f_user) &&
+        !strcmp(conn->ctx->config[AUTHENTICATION_DOMAIN], f_domain))
+      return check_password(
+            conn->request_info.request_method,
+            ha1, ah.uri, ah.nonce, ah.nc, ah.cnonce, ah.qop,
+            ah.response);
+  return 0;
+// Return 1 if request is authorised, 0 otherwise.
+static int check_authorization(struct mg_connection *conn, const char *path) {
+  FILE *fp;
+  char fname[PATH_MAX];
+  struct vec uri_vec, filename_vec;
+  const char *list;
+  int authorized;
+  fp = NULL;
+  authorized = 1;
+  list = conn->ctx->config[PROTECT_URI];
+  while ((list = next_option(list, &uri_vec, &filename_vec)) != NULL) {
+    if (!memcmp(conn->request_info.uri, uri_vec.ptr, uri_vec.len)) {
+      (void) mg_snprintf(conn, fname, sizeof(fname), "%.*s",
+          filename_vec.len, filename_vec.ptr);
+      if ((fp = mg_fopen(fname, "r")) == NULL) {
+        cry(conn, "%s: cannot open %s: %s", __func__, fname, strerror(errno));
+      break;
+  if (fp == NULL) {
+    fp = open_auth_file(conn, path);
+  if (fp != NULL) {
+    authorized = authorize(conn, fp);
+  return authorized;
+static void send_authorization_request(struct mg_connection *conn) {
+  conn->request_info.status_code = 401;
+  (void) mg_printf(conn,
+      "HTTP/1.1 401 Unauthorized\r\n"
+      "Content-Length: 0\r\n"
+      "WWW-Authenticate: Digest qop=\"auth\", "
+      "realm=\"%s\", nonce=\"%lu\"\r\n\r\n",
+      conn->ctx->config[AUTHENTICATION_DOMAIN],
+      (unsigned long) time(NULL));
+static int is_authorized_for_put(struct mg_connection *conn) {
+  FILE *fp;
+  int ret = 0;
+  fp = conn->ctx->config[PUT_DELETE_PASSWORDS_FILE] == NULL ? NULL :
+    mg_fopen(conn->ctx->config[PUT_DELETE_PASSWORDS_FILE], "r");
+  if (fp != NULL) {
+    ret = authorize(conn, fp);
+  return ret;
+int mg_modify_passwords_file(const char *fname, const char *domain,
+                             const char *user, const char *pass) {
+  int found;
+  char line[512], u[512], d[512], ha1[33], tmp[PATH_MAX];
+  FILE *fp, *fp2;
+  found = 0;
+  fp = fp2 = NULL;
+  // Regard empty password as no password - remove user record.
+  if (pass != NULL && pass[0] == '\0') {
+    pass = NULL;
+  (void) snprintf(tmp, sizeof(tmp), "%s.tmp", fname);
+  // Create the file if does not exist
+  if ((fp = mg_fopen(fname, "a+")) != NULL) {
+  // Open the given file and temporary file
+    return 0;
+  } else if ((fp2 = mg_fopen(tmp, "w+")) == NULL) {
+    fclose(fp);
+    return 0;
+  // Copy the stuff to temporary file
+    if (sscanf(line, "%[^:]:%[^:]:%*s", u, d) != 2) {
+      continue;
+    if (!strcmp(u, user) && !strcmp(d, domain)) {
+      found++;
+      if (pass != NULL) {
+        mg_md5(ha1, user, ":", domain, ":", pass, NULL);
+        fprintf(fp2, "%s:%s:%s\n", user, domain, ha1);
+    } else {
+      (void) fprintf(fp2, "%s", line);
+  // If new user, just add it
+  if (!found && pass != NULL) {
+    (void) fprintf(fp2, "%s:%s:%s\n", user, domain, ha1);
+  // Close files
+  (void) fclose(fp2);
+  // Put the temp file in place of real file
+  (void) mg_remove(fname);
+  (void) mg_rename(tmp, fname);
+  return 1;
 struct de {
-	struct mg_connection	*conn;
-	char			*file_name;
-	struct mgstat		st;
+  struct mg_connection *conn;
+  char *file_name;
+  struct mgstat st;
+static void url_encode(const char *src, char *dst, size_t dst_len) {
+  static const char *dont_escape = "._-$,;~()";
+  const char *end = dst + dst_len - 1;
+  for (; *src != '\0' && dst < end; src++, dst++) {
+    if (isalnum(*(const unsigned char *) src) ||
+        strchr(dont_escape, * (const unsigned char *) src) != NULL) {
+      *dst = *src;
+    } else if (dst + 2 < end) {
+      dst[0] = '%';
+      dst[1] = hex[(* (const unsigned char *) src) >> 4];
+      dst[2] = hex[(* (const unsigned char *) src) & 0xf];
+      dst += 2;
+  *dst = '\0';
+static void print_dir_entry(struct de *de) {
+  char size[64], mod[64], href[PATH_MAX];
+  if (de->st.is_directory) {
+    (void) mg_snprintf(de->conn, size, sizeof(size), "%s", "[DIRECTORY]");
+  } else {
+     // We use (signed) cast below because MSVC 6 compiler cannot
+     // convert unsigned __int64 to double. Sigh.
+    if (de->st.size < 1024) {
+          "%lu", (unsigned long) de->st.size);
+    } else if (de->st.size < 1024 * 1024) {
+          "%.1fk", (double) de->st.size / 1024.0);
+    } else if (de->st.size < 1024 * 1024 * 1024) {
+          "%.1fM", (double) de->st.size / 1048576);
+    } else {
+          "%.1fG", (double) de->st.size / 1073741824);
+  (void) strftime(mod, sizeof(mod), "%d-%b-%Y %H:%M", localtime(&de->st.mtime));
+  url_encode(de->file_name, href, sizeof(href));
+  de->conn->num_bytes_sent += mg_printf(de->conn,
+      "<tr><td><a href=\"%s%s%s\">%s%s</a></td>"
+      "<td> %s</td><td>  %s</td></tr>\n",
+      de->conn->request_info.uri, href, de->st.is_directory ? "/" : "",
+      de->file_name, de->st.is_directory ? "/" : "", mod, size);
+// This function is called from send_directory() and used for
+// sorting directory entries by size, or name, or modification time.
+// On windows, __cdecl specification is needed in case if project is built
+// with __stdcall convention. qsort always requires __cdels callback.
+static int WINCDECL compare_dir_entries(const void *p1, const void *p2) {
+  const struct de *a = (const struct de *) p1, *b = (const struct de *) p2;
+  const char *query_string = a->conn->request_info.query_string;
+  int cmp_result = 0;
+  if (query_string == NULL) {
+    query_string = "na";
+  if (a->st.is_directory && !b->st.is_directory) {
+    return -1;  // Always put directories on top
+  } else if (!a->st.is_directory && b->st.is_directory) {
+    return 1;   // Always put directories on top
+  } else if (*query_string == 'n') {
+    cmp_result = strcmp(a->file_name, b->file_name);
+  } else if (*query_string == 's') {
+    cmp_result = a->st.size == b->st.size ? 0 :
+      a->st.size > b->st.size ? 1 : -1;
+  } else if (*query_string == 'd') {
+    cmp_result = a->st.mtime == b->st.mtime ? 0 :
+      a->st.mtime > b->st.mtime ? 1 : -1;
+  return query_string[1] == 'd' ? -cmp_result : cmp_result;
+static int scan_directory(struct mg_connection *conn, const char *dir,
+                          void *data, void (*cb)(struct de *, void *)) {
+  char path[PATH_MAX];
+  struct dirent *dp;
+  DIR *dirp;
+  struct de de;
+  if ((dirp = opendir(dir)) == NULL) {
+    return 0;
+  } else {
+    de.conn = conn;
+    while ((dp = readdir(dirp)) != NULL) {
+      // Do not show current dir and passwords file
+      if (!strcmp(dp->d_name, ".") ||
+          !strcmp(dp->d_name, "..") ||
+          !strcmp(dp->d_name, PASSWORDS_FILE_NAME))
+        continue;
+      mg_snprintf(conn, path, sizeof(path), "%s%c%s", dir, DIRSEP, dp->d_name);
+      // If we don't memset stat structure to zero, mtime will have
+      // garbage and strftime() will segfault later on in
+      // print_dir_entry(). memset is required only if mg_stat()
+      // fails. For more details, see
+      // http://code.google.com/p/mongoose/issues/detail?id=79
+      if (mg_stat(path, &de.st) != 0) {
+        memset(&de.st, 0, sizeof(de.st));
+      de.file_name = dp->d_name;
+      cb(&de, data);
+    (void) closedir(dirp);
+  return 1;
+struct dir_scan_data {
+  struct de *entries;
+  int num_entries;
+  int arr_size;
-static void
-url_encode(const char *src, char *dst, size_t dst_len)
-	const char	*dont_escape = "._-$,;~()";
-	const char	*hex = "0123456789abcdef";
-	const char	*end = dst + dst_len - 1;
-	for (; *src != '\0' && dst < end; src++, dst++) {
-		if (isalnum(*(unsigned char *) src) ||
-		    strchr(dont_escape, * (unsigned char *) src) != NULL) {
-			*dst = *src;
-		} else if (dst + 2 < end) {
-			dst[0] = '%';
-			dst[1] = hex[(* (unsigned char *) src) >> 4];
-			dst[2] = hex[(* (unsigned char *) src) & 0xf];
-			dst += 2;
-	*dst = '\0';
- * This function is called from send_directory() and prints out
- * single directory entry.
-static void
-print_dir_entry(struct de *de)
-	char		size[64], mod[64], href[FILENAME_MAX];
-	if (de->st.is_directory) {
-		(void) mg_snprintf(de->conn,
-		    size, sizeof(size), "%s", "[DIRECTORY]");
-	} else {
-		 * We use (signed) cast below because MSVC 6 compiler cannot
-		 * convert unsigned __int64 to double. Sigh.
-		if (de->st.size < 1024)
-			(void) mg_snprintf(de->conn, size, sizeof(size),
-			    "%lu", (unsigned long) de->st.size);
-		else if (de->st.size < 0x100000 /* 1024 * 1024 */)
-			    "%.1fk", (double) de->st.size / 1024.0);
-		else if (de->st.size < 0x40000000 /* 1024 * 1024 * 1024 */)
-			    "%.1fM", (double) de->st.size / 1048576);
-		else
-			  "%.1fG", (double) de->st.size / 1073741824);
-	(void) strftime(mod, sizeof(mod), "%d-%b-%Y %H:%M",
-		localtime(&de->st.mtime));
-	url_encode(de->file_name, href, sizeof(href));
-	de->conn->num_bytes_sent += mg_printf(de->conn,
-	    "<tr><td><a href=\"%s%s%s\">%s%s</a></td>"
-	    "<td> %s</td><td>  %s</td></tr>\n",
-	    de->conn->request_info.uri, href, de->st.is_directory ? "/" : "",
-	    de->file_name, de->st.is_directory ? "/" : "", mod, size);
- * This function is called from send_directory() and used for
- * sorting direcotory entries by size, or name, or modification time.
-static int
-compare_dir_entries(const void *p1, const void *p2)
-	const struct de	*a = (struct de *) p1, *b = (struct de *) p2;
-	const char	*query_string = a->conn->request_info.query_string;
-	int		cmp_result = 0;
-	if (query_string == NULL)
-		query_string = "na";
-	if (a->st.is_directory && !b->st.is_directory) {
-		return (-1);  /* Always put directories on top */
-	} else if (!a->st.is_directory && b->st.is_directory) {
-		return (1);   /* Always put directories on top */
-	} else if (*query_string == 'n') {
-		cmp_result = strcmp(a->file_name, b->file_name);
-	} else if (*query_string == 's') {
-		cmp_result = a->st.size == b->st.size ? 0 :
-			a->st.size > b->st.size ? 1 : -1;
-	} else if (*query_string == 'd') {
-		cmp_result = a->st.mtime == b->st.mtime ? 0 :
-			a->st.mtime > b->st.mtime ? 1 : -1;
-	return (query_string[1] == 'd' ? -cmp_result : cmp_result);
- * Send directory contents.
-static void
-send_directory(struct mg_connection *conn, const char *dir)
-	struct dirent	*dp;
-	DIR		*dirp;
-	struct de	*entries = NULL;
-	char		path[FILENAME_MAX];
-	int		i, sort_direction, num_entries = 0, arr_size = 128;
-	if ((dirp = opendir(dir)) == NULL) {
-		send_error(conn, 500, "Cannot open directory",
-		    "Error: opendir(%s): %s", path, strerror(ERRNO));
-		return;
-	(void) mg_printf(conn, "%s",
-	    "HTTP/1.1 200 OK\r\n"
-	    "Connection: close\r\n"
-	    "Content-Type: text/html; charset=utf-8\r\n\r\n");
-	sort_direction = conn->request_info.query_string != NULL &&
-	    conn->request_info.query_string[1] == 'd' ? 'a' : 'd';
-	while ((dp = readdir(dirp)) != NULL) {
-		/* Do not show current dir and passwords file */
-		if (!strcmp(dp->d_name, ".") ||
-		    !strcmp(dp->d_name, "..") ||
-		    !strcmp(dp->d_name, PASSWORDS_FILE_NAME))
-			continue;
-		if (entries == NULL || num_entries >= arr_size) {
-			arr_size *= 2;
-			entries = (struct de *) realloc(entries,
-			    arr_size * sizeof(entries[0]));
-		if (entries == NULL) {
-			    "%s", "Error: cannot allocate memory");
-			return;
-		(void) mg_snprintf(conn, path, sizeof(path), "%s%c%s",
-		    dir, DIRSEP, dp->d_name);
-		 * If we don't memset stat structure to zero, mtime will have
-		 * garbage and strftime() will segfault later on in
-		 * print_dir_entry(). memset is required only if mg_stat()
-		 * fails. For more details, see
-		 * http://code.google.com/p/mongoose/issues/detail?id=79
-		if (mg_stat(path, &entries[num_entries].st) != 0)
-			(void) memset(&entries[num_entries].st, 0,
-			    sizeof(entries[num_entries].st));
-		entries[num_entries].conn = conn;
-		entries[num_entries].file_name = mg_strdup(dp->d_name);
-		num_entries++;
-	(void) closedir(dirp);
-	conn->num_bytes_sent += mg_printf(conn,
-	    "<html><head><title>Index of %s</title>"
-	    "<style>th {text-align: left;}</style></head>"
-	    "<body><h1>Index of %s</h1><pre><table cellpadding=\"0\">"
-	    "<tr><th><a href=\"?n%c\">Name</a></th>"
-	    "<th><a href=\"?d%c\">Modified</a></th>"
-	    "<th><a href=\"?s%c\">Size</a></th></tr>"
-	    "<tr><td colspan=\"3\"><hr></td></tr>",
-	    conn->request_info.uri, conn->request_info.uri,
-	    sort_direction, sort_direction, sort_direction);
-	/* Print first entry - link to a parent directory */
-	    "<tr><td><a href=\"%s%s\">%s</a></td>"
-	    conn->request_info.uri, "..", "Parent directory", "-", "-");
-	/* Sort and print directory entries */
-	qsort(entries, num_entries, sizeof(entries[0]), compare_dir_entries);
-	for (i = 0; i < num_entries; i++) {
-		print_dir_entry(&entries[i]);
-		free(entries[i].file_name);
-	free(entries);
-	conn->num_bytes_sent += mg_printf(conn, "%s", "</table></body></html>");
-	conn->request_info.status_code = 200;
- * Send len bytes from the opened file to the client.
-static void
-send_opened_file_stream(struct mg_connection *conn, FILE *fp, int64_t len)
-	char	buf[BUFSIZ];
-	int	to_read, num_read, num_written;
-	while (len > 0) {
-		/* Calculate how much to read from the file in the buffer */
-		to_read = sizeof(buf);
-		if ((int64_t) to_read > len)
-			to_read = (int) len;
-		/* Read from file, exit the loop on error */
-		if ((num_read = fread(buf, 1, to_read, fp)) == 0)
-			break;
-		/* Send read bytes to the client, exit the loop on error */
-		if ((num_written = mg_write(conn, buf, num_read)) != num_read)
-			break;
-		/* Both read and were successful, adjust counters */
-		conn->num_bytes_sent += num_written;
-		len -= num_written;
- * Send regular file contents.
-static void
-send_file(struct mg_connection *conn, const char *path, struct mgstat *stp)
-	char		date[64], lm[64], etag[64], range[64];
-	const char	*fmt = "%a, %d %b %Y %H:%M:%S %Z", *msg = "OK", *hdr;
-	time_t		curtime = time(NULL);
-	int64_t		cl, r1, r2;
-	struct vec	mime_vec;
-	FILE		*fp;
-	int		n;
-	get_mime_type(conn->ctx, path, &mime_vec);
-	cl = stp->size;
-	range[0] = '\0';
-	if ((fp = mg_fopen(path, "rb")) == NULL) {
-		send_error(conn, 500, http_500_error,
-		    "fopen(%s): %s", path, strerror(ERRNO));
-		return;
-	/* If Range: header specified, act accordingly */
-	r1 = r2 = 0;
-	hdr = mg_get_header(conn, "Range");
-	if (hdr != NULL && (n = sscanf(hdr,
-	    "bytes=%" INT64_FMT "-%" INT64_FMT, &r1, &r2)) > 0) {
-		conn->request_info.status_code = 206;
-		(void) fseeko(fp, (off_t) r1, SEEK_SET);
-		cl = n == 2 ? r2 - r1 + 1: cl - r1;
-		(void) mg_snprintf(conn, range, sizeof(range),
-		    "Content-Range: bytes "
-		    "%" INT64_FMT "-%"
-		    INT64_FMT "/%" INT64_FMT "\r\n",
-		    r1, r1 + cl - 1, stp->size);
-		msg = "Partial Content";
-	/* Prepare Etag, Date, Last-Modified headers */
-	(void) strftime(date, sizeof(date), fmt, localtime(&curtime));
-	(void) strftime(lm, sizeof(lm), fmt, localtime(&stp->mtime));
-	(void) mg_snprintf(conn, etag, sizeof(etag), "%lx.%lx",
-	    (unsigned long) stp->mtime, (unsigned long) stp->size);
-	    "HTTP/1.1 %d %s\r\n"
-	    "Date: %s\r\n"
-	    "Last-Modified: %s\r\n"
-	    "Etag: \"%s\"\r\n"
-	    "Content-Type: %.*s\r\n"
-	    "Content-Length: %" INT64_FMT "\r\n"
-	    "Accept-Ranges: bytes\r\n"
-	    "%s\r\n",
-	    conn->request_info.status_code, msg, date, lm, etag,
-	    mime_vec.len, mime_vec.ptr, cl, range);
-	if (strcmp(conn->request_info.request_method, "HEAD") != 0)
-		send_opened_file_stream(conn, fp, cl);
-	(void) fclose(fp);
- * Parse HTTP headers from the given buffer, advance buffer to the point
- * where parsing stopped.
-static void
-parse_http_headers(char **buf, struct mg_request_info *ri)
-	int	i;
-	for (i = 0; i < (int) ARRAY_SIZE(ri->http_headers); i++) {
-		ri->http_headers[i].name = skip(buf, ": ");
-		ri->http_headers[i].value = skip(buf, "\r\n");
-		if (ri->http_headers[i].name[0] == '\0')
-			break;
-		ri->num_headers = i + 1;
-static bool_t
-is_valid_http_method(const char *method)
-	return (!strcmp(method, "GET") ||
-	    !strcmp(method, "POST") ||
-	    !strcmp(method, "HEAD") ||
-	    !strcmp(method, "PUT") ||
-	    !strcmp(method, "DELETE"));
- * Parse HTTP request, fill in mg_request_info structure.
-static bool_t
-parse_http_request(char *buf, struct mg_request_info *ri, const struct usa *usa)
-	int	success_code = FALSE;
-	ri->request_method = skip(&buf, " ");
-	ri->uri = skip(&buf, " ");
-	ri->http_version = skip(&buf, "\r\n");
-	if (is_valid_http_method(ri->request_method) &&
-	    ri->uri[0] == '/' &&
-	    strncmp(ri->http_version, "HTTP/", 5) == 0) {
-		ri->http_version += 5;   /* Skip "HTTP/" */
-		parse_http_headers(&buf, ri);
-		ri->remote_port = ntohs(usa->u.sin.sin_port);
-		(void) memcpy(&ri->remote_ip, &usa->u.sin.sin_addr.s_addr, 4);
-		ri->remote_ip = ntohl(ri->remote_ip);
-		success_code = TRUE;
-	return (success_code);
- * Keep reading the input (either opened file descriptor fd, or socket sock,
- * or SSL descriptor ssl) into buffer buf, until \r\n\r\n appears in the
- * buffer (which marks the end of HTTP request). Buffer buf may already
- * have some data. The length of the data is stored in nread.
- * Upon every read operation, increase nread by the number of bytes read.
-static int
-read_request(FILE *fp, SOCKET sock, SSL *ssl, char *buf, int bufsiz, int *nread)
-	int	n, request_len;
-	request_len = 0;
-	while (*nread < bufsiz && request_len == 0) {
-		n = pull(fp, sock, ssl, buf + *nread, bufsiz - *nread);
-		if (n <= 0) {
-			break;
-		} else {
-			*nread += n;
-			request_len = get_request_len(buf, (size_t) *nread);
-	return (request_len);
- * For given directory path, substitute it to valid index file.
- * Return 0 if index file has been found, -1 if not found.
- * If the file is found, it's stats is returned in stp.
-static bool_t
-substitute_index_file(struct mg_connection *conn,
-		char *path, size_t path_len, struct mgstat *stp)
-	const char	*list;
-	struct mgstat	st;
-	struct vec	filename_vec;
-	size_t		n;
-	bool_t		found;
-	n = strlen(path);
-	 * The 'path' given to us points to the directory. Remove all trailing
-	 * directory separator characters from the end of the path, and
-	 * then append single directory separator character.
-	while (n > 0 && IS_DIRSEP_CHAR(path[n - 1]))
-		n--;
-	path[n] = DIRSEP;
-	 * Traverse index files list. For each entry, append it to the given
-	 * path and see if the file exists. If it exists, break the loop
-	lock_option(conn->ctx, OPT_INDEX_FILES);
-	list = conn->ctx->options[OPT_INDEX_FILES];
-	found = FALSE;
-	while ((list = next_option(list, &filename_vec, NULL)) != NULL) {
-		/* Ignore too long entries that may overflow path buffer */
-		if (filename_vec.len > path_len - n)
-			continue;
-		/* Prepare full path to the index file  */
-		(void) mg_strlcpy(path + n + 1,
-		    filename_vec.ptr, filename_vec.len + 1);
-		/* Does it exist ? */
-		if (mg_stat(path, &st) == 0) {
-			/* Yes it does, break the loop */
-			*stp = st;
-			found = TRUE;
-			break;
-	unlock_option(conn->ctx, OPT_INDEX_FILES);
-	/* If no index file exists, restore directory path */
-	if (found == FALSE)
-		path[n] = '\0';
-	return (found);
-static void
-remove_callback(struct mg_context *ctx,
-		const char *uri_regex, int status_code, bool_t is_auth)
-	struct callback	*cb;
-	int		i;
-	for (i = 0; i < ctx->num_callbacks; i++) {
-		cb = ctx->callbacks + i;
-		if ((uri_regex != NULL && cb->uri_regex != NULL &&
-		    ((is_auth && cb->is_auth) || (!is_auth && !cb->is_auth)) &&
-		    !strcmp(uri_regex, cb->uri_regex)) || (uri_regex == NULL &&
-		     (cb->status_code == 0 ||
-		      cb->status_code == status_code))) {
-			(void) memmove(cb, cb + 1,
-			    (char *) (ctx->callbacks + ctx->num_callbacks) -
-			    (char *) (cb + 1));
-			break;
-static void
-add_callback(struct mg_context *ctx, const char *uri_regex, int status_code,
-		mg_callback_t func, bool_t is_auth, void *user_data)
-	pthread_mutex_lock(&ctx->bind_mutex);
-	if (func == NULL) {
-		remove_callback(ctx, uri_regex, status_code, is_auth);
-	} else if (ctx->num_callbacks >= (int) ARRAY_SIZE(ctx->callbacks) - 1) {
-		cry(fc(ctx), "Too many callbacks! Increase MAX_CALLBACKS.");
-	} else {
-		cb = &ctx->callbacks[ctx->num_callbacks];
-		cb->uri_regex = uri_regex ? mg_strdup(uri_regex) : NULL;
-		cb->func = func;
-		cb->is_auth = is_auth;
-		cb->status_code = status_code;
-		cb->user_data = user_data;
-		ctx->num_callbacks++;
-		DEBUG_TRACE((DEBUG_MGS_PREFIX "%s: uri %s code %d",
-		    __func__, uri_regex ? uri_regex : "NULL", status_code));
-	pthread_mutex_unlock(&ctx->bind_mutex);
-void
-mg_set_uri_callback(struct mg_context *ctx, const char *uri_regex,
-		mg_callback_t func, void *user_data)
-	assert(uri_regex != NULL);
-	add_callback(ctx, uri_regex, -1, func, FALSE, user_data);
-void
-mg_set_error_callback(struct mg_context *ctx, int error_code,
-	assert(error_code >= 0 && error_code < 1000);
-	add_callback(ctx, NULL, error_code, func, FALSE, user_data);
-void
-mg_set_auth_callback(struct mg_context *ctx, const char *uri_regex,
-	add_callback(ctx, uri_regex, -1, func, TRUE, user_data);
- * Return True if we should reply 304 Not Modified.
-static bool_t
-is_not_modified(const struct mg_connection *conn, const struct mgstat *stp)
-	const char *ims = mg_get_header(conn, "If-Modified-Since");
-	return (ims != NULL && stp->mtime < date_to_epoch(ims));
-static bool_t
-append_chunk(struct mg_request_info *ri, FILE *fp, const char *buf, int len)
-	bool_t	ret_code = TRUE;
-	if (fp == NULL) {
-		/* TODO: check for NULL here */
-		ri->post_data = (char *) realloc(ri->post_data,
-		    ri->post_data_len + len);
-		(void) memcpy(ri->post_data + ri->post_data_len, buf, len);
-		ri->post_data_len += len;
-	} else if (push(fp, INVALID_SOCKET,
-	    NULL, buf, (int64_t) len) != (int64_t) len) {
-		ret_code = FALSE;
-	return (ret_code);
-static bool_t
-handle_request_body(struct mg_connection *conn, FILE *fp)
-	struct mg_request_info	*ri = &conn->request_info;
-	const char	*expect, *tmp;
-	int64_t		content_len;
-	char		buf[BUFSIZ];
-	int		to_read, nread, already_read;
-	bool_t		success_code = FALSE;
-	content_len = get_content_length(conn);
-	expect = mg_get_header(conn, "Expect");
-	if (content_len == -1) {
-		send_error(conn, 411, "Length Required", "");
-	} else if (expect != NULL && mg_strcasecmp(expect, "100-continue")) {
-		send_error(conn, 417, "Expectation Failed", "");
-	} else {
-		if (expect != NULL)
-			(void) mg_printf(conn, "HTTP/1.1 100 Continue\r\n\r\n");
-		already_read = ri->post_data_len;
-		assert(already_read >= 0);
-		if (content_len <= (int64_t) already_read) {
-			ri->post_data_len = (int) content_len;
-			 * If fp is NULL, this is embedded mode, and we do not
-			 * have to do anything: POST data is already there,
-			 * no need to allocate a buffer and copy it in.
-			 * If fp != NULL, we need to write the data.
-			success_code = fp == NULL || (push(fp, INVALID_SOCKET,
-			    NULL, ri->post_data, content_len) == content_len) ?
-			    TRUE : FALSE;
-		} else {
-			if (fp == NULL) {
-				conn->free_post_data = TRUE;
-				tmp = ri->post_data;
-				/* +1 in case if already_read == 0 */
-				ri->post_data = (char*)malloc(already_read + 1);
-				(void) memcpy(ri->post_data, tmp, already_read);
-			} else {
-				(void) push(fp, INVALID_SOCKET, NULL,
-				    ri->post_data, (int64_t) already_read);
-			content_len -= already_read;
-			while (content_len > 0) {
-				if ((int64_t) to_read > content_len)
-					to_read = (int) content_len;
-				nread = pull(NULL, conn->client.sock,
-				    conn->ssl, buf, to_read);
-				if (nread <= 0)
-					break;
-				if (!append_chunk(ri, fp, buf, nread))
-					break;
-				content_len -= nread;
-			success_code = content_len == 0 ? TRUE : FALSE;
-		/* Each error code path in this function must send an error */
-		if (success_code != TRUE)
-			send_error(conn, 577, http_500_error,
-			    "%s", "Error handling body data");
+static void dir_scan_callback(struct de *de, void *data) {
+  struct dir_scan_data *dsd = (struct dir_scan_data *) data;
+  if (dsd->entries == NULL || dsd->num_entries >= dsd->arr_size) {
+    dsd->arr_size *= 2;
+    dsd->entries = (struct de *) realloc(dsd->entries, dsd->arr_size *
+                                         sizeof(dsd->entries[0]));
+  if (dsd->entries == NULL) {
+    // TODO(lsm): propagate an error to the caller
+    dsd->num_entries = 0;
+  } else {
+    dsd->entries[dsd->num_entries].file_name = mg_strdup(de->file_name);
+    dsd->entries[dsd->num_entries].st = de->st;
+    dsd->entries[dsd->num_entries].conn = de->conn;
+    dsd->num_entries++;
+static void handle_directory_request(struct mg_connection *conn,
+                                     const char *dir) {
+  int i, sort_direction;
+  struct dir_scan_data data = { NULL, 0, 128 };
+  if (!scan_directory(conn, dir, &data, dir_scan_callback)) {
+    send_http_error(conn, 500, "Cannot open directory",
+                    "Error: opendir(%s): %s", dir, strerror(ERRNO));
+    return;
+  sort_direction = conn->request_info.query_string != NULL &&
+    conn->request_info.query_string[1] == 'd' ? 'a' : 'd';
+  conn->must_close = 1;
+  mg_printf(conn, "%s",
+            "HTTP/1.1 200 OK\r\n"
+            "Connection: close\r\n"
+            "Content-Type: text/html; charset=utf-8\r\n\r\n");
+  conn->num_bytes_sent += mg_printf(conn,
+      "<html><head><title>Index of %s</title>"
+      "<style>th {text-align: left;}</style></head>"
+      "<body><h1>Index of %s</h1><pre><table cellpadding=\"0\">"
+      "<tr><th><a href=\"?n%c\">Name</a></th>"
+      "<th><a href=\"?d%c\">Modified</a></th>"
+      "<th><a href=\"?s%c\">Size</a></th></tr>"
+      "<tr><td colspan=\"3\"><hr></td></tr>",
+      conn->request_info.uri, conn->request_info.uri,
+      sort_direction, sort_direction, sort_direction);
+  // Print first entry - link to a parent directory
+      "<tr><td><a href=\"%s%s\">%s</a></td>"
+      conn->request_info.uri, "..", "Parent directory", "-", "-");
+  // Sort and print directory entries
+  qsort(data.entries, (size_t) data.num_entries, sizeof(data.entries[0]),
+        compare_dir_entries);
+  for (i = 0; i < data.num_entries; i++) {
+    print_dir_entry(&data.entries[i]);
+    free(data.entries[i].file_name);
+  free(data.entries);
+  conn->num_bytes_sent += mg_printf(conn, "%s", "</table></body></html>");
+  conn->request_info.status_code = 200;
+// Send len bytes from the opened file to the client.
+static void send_file_data(struct mg_connection *conn, FILE *fp, int64_t len) {
+  char buf[BUFSIZ];
+  int to_read, num_read, num_written;
+  while (len > 0) {
+    // Calculate how much to read from the file in the buffer
+    to_read = sizeof(buf);
+    if ((int64_t) to_read > len)
+      to_read = (int) len;
+    // Read from file, exit the loop on error
+    if ((num_read = fread(buf, 1, (size_t)to_read, fp)) == 0)
+      break;
+    // Send read bytes to the client, exit the loop on error
+    if ((num_written = mg_write(conn, buf, (size_t)num_read)) != num_read)
+      break;
+    // Both read and were successful, adjust counters
+    conn->num_bytes_sent += num_written;
+    len -= num_written;
+static int parse_range_header(const char *header, int64_t *a, int64_t *b) {
+  return sscanf(header, "bytes=%" INT64_FMT "-%" INT64_FMT, a, b);
+static void gmt_time_string(char *buf, size_t buf_len, time_t *t) {
+  strftime(buf, buf_len, "%a, %d %b %Y %H:%M:%S GMT", gmtime(t));
+static void handle_file_request(struct mg_connection *conn, const char *path,
+                                struct mgstat *stp) {
+  char date[64], lm[64], etag[64], range[64];
+  const char *msg = "OK", *hdr;
+  time_t curtime = time(NULL);
+  int64_t cl, r1, r2;
+  struct vec mime_vec;
+  FILE *fp;
+  int n;
+  get_mime_type(conn->ctx, path, &mime_vec);
+  cl = stp->size;
+  range[0] = '\0';
+  if ((fp = mg_fopen(path, "rb")) == NULL) {
+    send_http_error(conn, 500, http_500_error,
+        "fopen(%s): %s", path, strerror(ERRNO));
+    return;
+  set_close_on_exec(fileno(fp));
+  // If Range: header specified, act accordingly
+  r1 = r2 = 0;
+  hdr = mg_get_header(conn, "Range");
+  if (hdr != NULL && (n = parse_range_header(hdr, &r1, &r2)) > 0) {
+    conn->request_info.status_code = 206;
+    (void) fseeko(fp, (off_t) r1, SEEK_SET);
+    cl = n == 2 ? r2 - r1 + 1: cl - r1;
+    (void) mg_snprintf(conn, range, sizeof(range),
+        "Content-Range: bytes "
+        "%" INT64_FMT "-%"
+        INT64_FMT "/%" INT64_FMT "\r\n",
+        r1, r1 + cl - 1, stp->size);
+    msg = "Partial Content";
+  // Prepare Etag, Date, Last-Modified headers. Must be in UTC, according to
+  // http://www.w3.org/Protocols/rfc2616/rfc2616-sec3.html#sec3.3
+  gmt_time_string(date, sizeof(date), &curtime);
+  gmt_time_string(lm, sizeof(lm), &stp->mtime);
+  (void) mg_snprintf(conn, etag, sizeof(etag), "%lx.%lx",
+      (unsigned long) stp->mtime, (unsigned long) stp->size);
+      "HTTP/1.1 %d %s\r\n"
+      "Date: %s\r\n"
+      "Last-Modified: %s\r\n"
+      "Etag: \"%s\"\r\n"
+      "Content-Type: %.*s\r\n"
+      "Content-Length: %" INT64_FMT "\r\n"
+      "Connection: %s\r\n"
+      "Accept-Ranges: bytes\r\n"
+      "%s\r\n",
+      conn->request_info.status_code, msg, date, lm, etag, (int) mime_vec.len,
+      mime_vec.ptr, cl, suggest_connection_header(conn), range);
+  if (strcmp(conn->request_info.request_method, "HEAD") != 0) {
+    send_file_data(conn, fp, cl);
+  (void) fclose(fp);
+void mg_send_file(struct mg_connection *conn, const char *path) {
+  struct mgstat st;
+  if (mg_stat(path, &st) == 0) {
+    handle_file_request(conn, path, &st);
+  } else {
+    send_http_error(conn, 404, "Not Found", "%s", "File not found");
+// Parse HTTP headers from the given buffer, advance buffer to the point
+// where parsing stopped.
+static void parse_http_headers(char **buf, struct mg_request_info *ri) {
+  int i;
+  for (i = 0; i < (int) ARRAY_SIZE(ri->http_headers); i++) {
+    ri->http_headers[i].name = skip_quoted(buf, ":", " ", 0);
+    ri->http_headers[i].value = skip(buf, "\r\n");
+    if (ri->http_headers[i].name[0] == '\0')
+      break;
+    ri->num_headers = i + 1;
+static int is_valid_http_method(const char *method) {
+  return !strcmp(method, "GET") || !strcmp(method, "POST") ||
+    !strcmp(method, "HEAD") || !strcmp(method, "CONNECT") ||
+    !strcmp(method, "PUT") || !strcmp(method, "DELETE") ||
+    !strcmp(method, "OPTIONS") || !strcmp(method, "PROPFIND");
+// Parse HTTP request, fill in mg_request_info structure.
+static int parse_http_request(char *buf, struct mg_request_info *ri) {
+  int status = 0;
+  // RFC says that all initial whitespaces should be ingored
+  while (*buf != '\0' && isspace(* (unsigned char *) buf)) {
+    buf++;
+  ri->request_method = skip(&buf, " ");
+  ri->uri = skip(&buf, " ");
+  ri->http_version = skip(&buf, "\r\n");
+  if (is_valid_http_method(ri->request_method) &&
+      strncmp(ri->http_version, "HTTP/", 5) == 0) {
+    ri->http_version += 5;   // Skip "HTTP/"
+    parse_http_headers(&buf, ri);
+    status = 1;
+  return status;
+// Keep reading the input (either opened file descriptor fd, or socket sock,
+// or SSL descriptor ssl) into buffer buf, until \r\n\r\n appears in the
+// buffer (which marks the end of HTTP request). Buffer buf may already
+// have some data. The length of the data is stored in nread.
+// Upon every read operation, increase nread by the number of bytes read.
+static int read_request(FILE *fp, SOCKET sock, SSL *ssl, char *buf, int bufsiz,
+                        int *nread) {
+  int request_len, n = 0;
+  do {
+    request_len = get_request_len(buf, *nread);
+    if (request_len == 0 &&
+        (n = pull(fp, sock, ssl, buf + *nread, bufsiz - *nread)) > 0) {
+      *nread += n;
+  } while (*nread < bufsiz && request_len == 0 && n > 0);
+  return request_len;
+// For given directory path, substitute it to valid index file.
+// Return 0 if index file has been found, -1 if not found.
+// If the file is found, it's stats is returned in stp.
+static int substitute_index_file(struct mg_connection *conn, char *path,
+                                 size_t path_len, struct mgstat *stp) {
+  const char *list = conn->ctx->config[INDEX_FILES];
+  struct mgstat st;
+  struct vec filename_vec;
+  size_t n = strlen(path);
+  int found = 0;
+  // The 'path' given to us points to the directory. Remove all trailing
+  // directory separator characters from the end of the path, and
+  // then append single directory separator character.
+  while (n > 0 && IS_DIRSEP_CHAR(path[n - 1])) {
+    n--;
+  path[n] = DIRSEP;
+  // Traverse index files list. For each entry, append it to the given
+  // path and see if the file exists. If it exists, break the loop
+  while ((list = next_option(list, &filename_vec, NULL)) != NULL) {
+    // Ignore too long entries that may overflow path buffer
+    if (filename_vec.len > path_len - (n + 2))
+      continue;
+    // Prepare full path to the index file
+    (void) mg_strlcpy(path + n + 1, filename_vec.ptr, filename_vec.len + 1);
+    // Does it exist?
+      // Yes it does, break the loop
+      *stp = st;
+      found = 1;
+      break;
+  // If no index file exists, restore directory path
+  if (!found) {
+    path[n] = '\0';
+  return found;
+// Return True if we should reply 304 Not Modified.
+static int is_not_modified(const struct mg_connection *conn,
+                           const struct mgstat *stp) {
+  const char *ims = mg_get_header(conn, "If-Modified-Since");
+  return ims != NULL && stp->mtime <= parse_date_string(ims);
+static int forward_body_data(struct mg_connection *conn, FILE *fp,
+                             SOCKET sock, SSL *ssl) {
+  const char *expect, *buffered;
+  char buf[BUFSIZ];
+  int to_read, nread, buffered_len, success = 0;
+  expect = mg_get_header(conn, "Expect");
+  assert(fp != NULL);
+  if (conn->content_len == -1) {
+    send_http_error(conn, 411, "Length Required", "");
+  } else if (expect != NULL && mg_strcasecmp(expect, "100-continue")) {
+    send_http_error(conn, 417, "Expectation Failed", "");
+  } else {
+    if (expect != NULL) {
+      (void) mg_printf(conn, "%s", "HTTP/1.1 100 Continue\r\n\r\n");
+    buffered = conn->buf + conn->request_len;
+    buffered_len = conn->data_len - conn->request_len;
+    assert(buffered_len >= 0);
+    assert(conn->consumed_content == 0);
+    if (buffered_len > 0) {
+      if ((int64_t) buffered_len > conn->content_len) {
+        buffered_len = (int) conn->content_len;
+      push(fp, sock, ssl, buffered, (int64_t) buffered_len);
+      conn->consumed_content += buffered_len;
+    while (conn->consumed_content < conn->content_len) {
+      if ((int64_t) to_read > conn->content_len - conn->consumed_content) {
+        to_read = (int) (conn->content_len - conn->consumed_content);
+      nread = pull(NULL, conn->client.sock, conn->ssl, buf, to_read);
+      if (nread <= 0 || push(fp, sock, ssl, buf, nread) != nread) {
+        break;
+      conn->consumed_content += nread;
+    if (conn->consumed_content == conn->content_len) {
+      success = 1;
+    // Each error code path in this function must send an error
+    if (!success) {
+      send_http_error(conn, 577, http_500_error, "");
+  return success;
 #if !defined(NO_CGI)
- * This structure helps to create an environment for the spawned CGI program.
- * Environment is an array of "VARIABLE=VALUE\0" ASCIIZ strings,
- * last element must be NULL.
- * However, on Windows there is a requirement that all these VARIABLE=VALUE\0
- * strings must reside in a contiguous buffer. The end of the buffer is
- * marked by two '\0' characters.
- * We satisfy both worlds: we create an envp array (which is vars), all
- * entries are actually pointers inside buf.
+// This structure helps to create an environment for the spawned CGI program.
+// Environment is an array of "VARIABLE=VALUE\0" ASCIIZ strings,
+// last element must be NULL.
+// However, on Windows there is a requirement that all these VARIABLE=VALUE\0
+// strings must reside in a contiguous buffer. The end of the buffer is
+// marked by two '\0' characters.
+// We satisfy both worlds: we create an envp array (which is vars), all
+// entries are actually pointers inside buf.
 struct cgi_env_block {
-	char	buf[CGI_ENVIRONMENT_SIZE];	/* Environment buffer	*/
-	int	len;				/* Space taken		*/
-	char	*vars[MAX_CGI_ENVIR_VARS];	/* char **envp		*/
-	int	nvars;				/* Number of variables	*/
+  char buf[CGI_ENVIRONMENT_SIZE]; // Environment buffer
+  int len; // Space taken
+  char *vars[MAX_CGI_ENVIR_VARS]; // char **envp
+  int nvars; // Number of variables
- * Append VARIABLE=VALUE\0 string to the buffer, and add a respective
- * pointer into the vars array.
-static char *
-addenv(struct cgi_env_block *block, const char *fmt, ...)
-	int	n, space;
-	char	*added;
-	va_list	ap;
-	/* Calculate how much space is left in the buffer */
-	space = sizeof(block->buf) - block->len - 2;
-	assert(space >= 0);
-	/* Make a pointer to the free space int the buffer */
-	added = block->buf + block->len;
-	/* Copy VARIABLE=VALUE\0 string into the free space */
-	va_start(ap, fmt);
-	n = mg_vsnprintf(block->conn, added, (size_t) space, fmt, ap);
-	va_end(ap);
-	/* Make sure we do not overflow buffer and the envp array */
-	if (n > 0 && n < space &&
-	    block->nvars < (int) ARRAY_SIZE(block->vars) - 2) {
-		/* Append a pointer to the added string into the envp array */
-		block->vars[block->nvars++] = block->buf + block->len;
-		/* Bump up used length counter. Include \0 terminator */
-		block->len += n + 1;
-	return (added);
-static void
-prepare_cgi_environment(struct mg_connection *conn, const char *prog,
-		struct cgi_env_block *blk)
-	const char	*s, *script_filename, *root, *slash;
-	struct vec	var_vec;
-	char		*p;
-	int		i;
-	blk->len = blk->nvars = 0;
-	blk->conn = conn;
-	/* SCRIPT_FILENAME */
-	script_filename = prog;
-	if ((s = strrchr(prog, '/')) != NULL)
-		script_filename = s + 1;
-	lock_option(conn->ctx, OPT_ROOT);
-	root = conn->ctx->options[OPT_ROOT];
-	addenv(blk, "SERVER_NAME=%s", conn->ctx->options[OPT_AUTH_DOMAIN]);
-	unlock_option(conn->ctx, OPT_ROOT);
-	/* Prepare the environment block */
-	addenv(blk, "%s", "GATEWAY_INTERFACE=CGI/1.1");
-	addenv(blk, "%s", "SERVER_PROTOCOL=HTTP/1.1");
-	addenv(blk, "%s", "REDIRECT_STATUS=200");	/* PHP */
-	addenv(blk, "SERVER_PORT=%d", ntohs(conn->client.lsa.u.sin.sin_port));
-	addenv(blk, "SERVER_ROOT=%s", root);
-	addenv(blk, "DOCUMENT_ROOT=%s", root);
-	addenv(blk, "REQUEST_METHOD=%s", conn->request_info.request_method);
-	addenv(blk, "REMOTE_ADDR=%s",
-	    inet_ntoa(conn->client.rsa.u.sin.sin_addr));
-	addenv(blk, "REMOTE_PORT=%d", conn->request_info.remote_port);
-	addenv(blk, "REQUEST_URI=%s", conn->request_info.uri);
-	slash = strrchr(conn->request_info.uri, '/');
-	addenv(blk, "SCRIPT_NAME=%.*s%s",
-	    (slash - conn->request_info.uri) + 1, conn->request_info.uri,
-	    script_filename);
-	addenv(blk, "SCRIPT_FILENAME=%s", script_filename);	/* PHP */
-	addenv(blk, "PATH_TRANSLATED=%s", prog);
-	addenv(blk, "HTTPS=%s", conn->ssl == NULL ? "off" : "on");
-	if ((s = mg_get_header(conn, "Content-Type")) != NULL)
-		addenv(blk, "CONTENT_TYPE=%s", s);
-	if (conn->request_info.query_string != NULL)
-		addenv(blk, "QUERY_STRING=%s", conn->request_info.query_string);
-	if ((s = mg_get_header(conn, "Content-Length")) != NULL)
-		addenv(blk, "CONTENT_LENGTH=%s", s);
-	if ((s = getenv("PATH")) != NULL)
-		addenv(blk, "PATH=%s", s);
+// Append VARIABLE=VALUE\0 string to the buffer, and add a respective
+// pointer into the vars array.
+static char *addenv(struct cgi_env_block *block, const char *fmt, ...) {
+  int n, space;
+  char *added;
+  va_list ap;
+  // Calculate how much space is left in the buffer
+  space = sizeof(block->buf) - block->len - 2;
+  assert(space >= 0);
+  // Make a pointer to the free space int the buffer
+  added = block->buf + block->len;
+  // Copy VARIABLE=VALUE\0 string into the free space
+  va_start(ap, fmt);
+  n = mg_vsnprintf(block->conn, added, (size_t) space, fmt, ap);
+  va_end(ap);
+  // Make sure we do not overflow buffer and the envp array
+  if (n > 0 && n < space &&
+      block->nvars < (int) ARRAY_SIZE(block->vars) - 2) {
+    // Append a pointer to the added string into the envp array
+    block->vars[block->nvars++] = block->buf + block->len;
+    // Bump up used length counter. Include \0 terminator
+    block->len += n + 1;
+  return added;
+static void prepare_cgi_environment(struct mg_connection *conn,
+                                    const char *prog,
+                                    struct cgi_env_block *blk) {
+  const char *s, *slash;
+  struct vec var_vec;
+  char *p, src_addr[20];
+  int  i;
+  blk->len = blk->nvars = 0;
+  blk->conn = conn;
+  sockaddr_to_string(src_addr, sizeof(src_addr), &conn->client.rsa);
+  addenv(blk, "SERVER_NAME=%s", conn->ctx->config[AUTHENTICATION_DOMAIN]);
+  addenv(blk, "SERVER_ROOT=%s", conn->ctx->config[DOCUMENT_ROOT]);
+  addenv(blk, "DOCUMENT_ROOT=%s", conn->ctx->config[DOCUMENT_ROOT]);
+  // Prepare the environment block
+  addenv(blk, "%s", "GATEWAY_INTERFACE=CGI/1.1");
+  addenv(blk, "%s", "SERVER_PROTOCOL=HTTP/1.1");
+  addenv(blk, "%s", "REDIRECT_STATUS=200"); // For PHP
+  // TODO(lsm): fix this for IPv6 case
+  addenv(blk, "SERVER_PORT=%d", ntohs(conn->client.lsa.sin.sin_port));
+  addenv(blk, "REQUEST_METHOD=%s", conn->request_info.request_method);
+  addenv(blk, "REMOTE_ADDR=%s", src_addr);
+  addenv(blk, "REMOTE_PORT=%d", conn->request_info.remote_port);
+  addenv(blk, "REQUEST_URI=%s", conn->request_info.uri);
+  // SCRIPT_NAME
+  assert(conn->request_info.uri[0] == '/');
+  slash = strrchr(conn->request_info.uri, '/');
+  if ((s = strrchr(prog, '/')) == NULL)
+    s = prog;
+  addenv(blk, "SCRIPT_NAME=%.*s%s", slash - conn->request_info.uri,
+         conn->request_info.uri, s);
+  addenv(blk, "SCRIPT_FILENAME=%s", prog);
+  addenv(blk, "PATH_TRANSLATED=%s", prog);
+  addenv(blk, "HTTPS=%s", conn->ssl == NULL ? "off" : "on");
+  if ((s = mg_get_header(conn, "Content-Type")) != NULL)
+    addenv(blk, "CONTENT_TYPE=%s", s);
+  if (conn->request_info.query_string != NULL)
+    addenv(blk, "QUERY_STRING=%s", conn->request_info.query_string);
+  if ((s = mg_get_header(conn, "Content-Length")) != NULL)
+    addenv(blk, "CONTENT_LENGTH=%s", s);
+  if ((s = getenv("PATH")) != NULL)
+    addenv(blk, "PATH=%s", s);
+  if (conn->path_info != NULL) {
+    addenv(blk, "PATH_INFO=%s", conn->path_info);
 #if defined(_WIN32)
-	if ((s = getenv("COMSPEC")) != NULL)
-		addenv(blk, "COMSPEC=%s", s);
-	if ((s = getenv("SYSTEMROOT")) != NULL)
-		addenv(blk, "SYSTEMROOT=%s", s);
+  if ((s = getenv("COMSPEC")) != NULL) {
+    addenv(blk, "COMSPEC=%s", s);
+  if ((s = getenv("SYSTEMROOT")) != NULL) {
+    addenv(blk, "SYSTEMROOT=%s", s);
+  if ((s = getenv("SystemDrive")) != NULL) {
+    addenv(blk, "SystemDrive=%s", s);
 #else
-	if ((s = getenv("LD_LIBRARY_PATH")) != NULL)
-		addenv(blk, "LD_LIBRARY_PATH=%s", s);
-#endif /* _WIN32 */
-	if ((s = getenv("PERLLIB")) != NULL)
-		addenv(blk, "PERLLIB=%s", s);
-	if (conn->request_info.remote_user != NULL) {
-		addenv(blk, "REMOTE_USER=%s", conn->request_info.remote_user);
-		addenv(blk, "%s", "AUTH_TYPE=Digest");
-	/* Add all headers as HTTP_* variables */
-	for (i = 0; i < conn->request_info.num_headers; i++) {
-		p = addenv(blk, "HTTP_%s=%s",
-		    conn->request_info.http_headers[i].name,
-		    conn->request_info.http_headers[i].value);
-		/* Convert variable name into uppercase, and change - to _ */
-		for (; *p != '=' && *p != '\0'; p++) {
-			if (*p == '-')
-				*p = '_';
-			*p = (char) toupper(* (unsigned char *) p);
-	/* Add user-specified variables */
-	lock_option(conn->ctx, OPT_CGI_ENV);
-	s = conn->ctx->options[OPT_CGI_ENV];
-	while ((s = next_option(s, &var_vec, NULL)) != NULL)
-		addenv(blk, "%.*s", var_vec.len, var_vec.ptr);
-	unlock_option(conn->ctx, OPT_CGI_ENV);
-	blk->vars[blk->nvars++] = NULL;
-	blk->buf[blk->len++] = '\0';
-	assert(blk->nvars < (int) ARRAY_SIZE(blk->vars));
-	assert(blk->len > 0);
-	assert(blk->len < (int) sizeof(blk->buf));
-static void
-send_cgi(struct mg_connection *conn, const char *prog)
-	int			headers_len, data_len, i;
-	const char		*status;
-	char			buf[MAX_REQUEST_SIZE], *pbuf;
-	struct mg_request_info	ri;
-	struct cgi_env_block	blk;
-	char			dir[FILENAME_MAX], *p;
-	int			fd_stdin[2], fd_stdout[2];
-	FILE			*in, *out;
-	pid_t			pid;
-	prepare_cgi_environment(conn, prog, &blk);
-	/* CGI must be executed in its own directory */
-	(void) mg_snprintf(conn, dir, sizeof(dir), "%s", prog);
-	if ((p = strrchr(dir, DIRSEP)) != NULL)
-		*p++ = '\0';
-	pid = (pid_t) -1;
-	fd_stdin[0] = fd_stdin[1] = fd_stdout[0] = fd_stdout[1] = -1;
-	in = out = NULL;
-	if (pipe(fd_stdin) != 0 || pipe(fd_stdout) != 0) {
-		    "Cannot create CGI pipe: %s", strerror(ERRNO));
-		goto done;
-	} else if ((pid = spawn_process(conn, p, blk.buf, blk.vars,
-	    fd_stdin[0], fd_stdout[1], dir)) == (pid_t) -1) {
-		goto done;
-	} else if ((in = fdopen(fd_stdin[1], "wb")) == NULL ||
-	    (out = fdopen(fd_stdout[0], "rb")) == NULL) {
-		    "fopen: %s", strerror(ERRNO));
-		goto done;
-	setbuf(in, NULL);
-	setbuf(out, NULL);
-	 * spawn_process() must close those!
-	 * If we don't mark them as closed, close() attempt before
-	 * return from this function throws an exception on Windows.
-	 * Windows does not like when closed descriptor is closed again.
-	fd_stdin[0] = fd_stdout[1] = -1;
-	/* Send POST data to the CGI process if needed */
-	if (!strcmp(conn->request_info.request_method, "POST") &&
-	    !handle_request_body(conn, in)) {
-		goto done;
-	 * Now read CGI reply into a buffer. We need to set correct
-	 * status code, thus we need to see all HTTP headers first.
-	 * Do not send anything back to client, until we buffer in all
-	 * HTTP headers.
-	data_len = 0;
-	headers_len = read_request(out, INVALID_SOCKET, NULL,
-	    buf, sizeof(buf), &data_len);
-	if (headers_len <= 0) {
-		    "CGI program sent malformed HTTP headers: [%.*s]",
-		    data_len, buf);
-		goto done;
-	pbuf = buf;
-	buf[headers_len - 1] = '\0';
-	parse_http_headers(&pbuf, &ri);
-	/* Make up and send the status line */
-	status = get_header(&ri, "Status");
-	conn->request_info.status_code = status == NULL ? 200 : atoi(status);
-	(void) mg_printf(conn, "HTTP/1.1 %d OK\r\n",
-	    conn->request_info.status_code);
-	/* Send headers */
-	for (i = 0; i < ri.num_headers; i++)
-		(void) mg_printf(conn, "%s: %s\r\n",
-		    ri.http_headers[i].name,
-		    ri.http_headers[i].value);
-	(void) mg_write(conn, "\r\n", 2);
-	/* Send chunk of data that may be read after the headers */
-	conn->num_bytes_sent += mg_write(conn,
-	    buf + headers_len, data_len - headers_len);
-	/* Read the rest of CGI output and send to the client */
-	send_opened_file_stream(conn, out, INT64_MAX);
+  if ((s = getenv("LD_LIBRARY_PATH")) != NULL)
+    addenv(blk, "LD_LIBRARY_PATH=%s", s);
+#endif // _WIN32
+  if ((s = getenv("PERLLIB")) != NULL)
+    addenv(blk, "PERLLIB=%s", s);
+  if (conn->request_info.remote_user != NULL) {
+    addenv(blk, "REMOTE_USER=%s", conn->request_info.remote_user);
+    addenv(blk, "%s", "AUTH_TYPE=Digest");
+  // Add all headers as HTTP_* variables
+  for (i = 0; i < conn->request_info.num_headers; i++) {
+    p = addenv(blk, "HTTP_%s=%s",
+        conn->request_info.http_headers[i].name,
+        conn->request_info.http_headers[i].value);
+    // Convert variable name into uppercase, and change - to _
+    for (; *p != '=' && *p != '\0'; p++) {
+      if (*p == '-')
+        *p = '_';
+      *p = (char) toupper(* (unsigned char *) p);
+  // Add user-specified variables
+  s = conn->ctx->config[CGI_ENVIRONMENT];
+  while ((s = next_option(s, &var_vec, NULL)) != NULL) {
+    addenv(blk, "%.*s", var_vec.len, var_vec.ptr);
+  blk->vars[blk->nvars++] = NULL;
+  blk->buf[blk->len++] = '\0';
+  assert(blk->nvars < (int) ARRAY_SIZE(blk->vars));
+  assert(blk->len > 0);
+  assert(blk->len < (int) sizeof(blk->buf));
+static void handle_cgi_request(struct mg_connection *conn, const char *prog) {
+  int headers_len, data_len, i, fd_stdin[2], fd_stdout[2];
+  const char *status, *status_text;
+  char buf[16384], *pbuf, dir[PATH_MAX], *p;
+  struct mg_request_info ri;
+  struct cgi_env_block blk;
+  FILE *in, *out;
+  pid_t pid;
+  prepare_cgi_environment(conn, prog, &blk);
+  // CGI must be executed in its own directory. 'dir' must point to the
+  // directory containing executable program, 'p' must point to the
+  // executable program name relative to 'dir'.
+  (void) mg_snprintf(conn, dir, sizeof(dir), "%s", prog);
+  if ((p = strrchr(dir, DIRSEP)) != NULL) {
+    *p++ = '\0';
+  } else {
+    dir[0] = '.', dir[1] = '\0';
+    p = (char *) prog;
+  pid = (pid_t) -1;
+  fd_stdin[0] = fd_stdin[1] = fd_stdout[0] = fd_stdout[1] = -1;
+  in = out = NULL;
+  if (pipe(fd_stdin) != 0 || pipe(fd_stdout) != 0) {
+        "Cannot create CGI pipe: %s", strerror(ERRNO));
+    goto done;
+  } else if ((pid = spawn_process(conn, p, blk.buf, blk.vars,
+          fd_stdin[0], fd_stdout[1], dir)) == (pid_t) -1) {
+    goto done;
+  } else if ((in = fdopen(fd_stdin[1], "wb")) == NULL ||
+      (out = fdopen(fd_stdout[0], "rb")) == NULL) {
+        "fopen: %s", strerror(ERRNO));
+    goto done;
+  setbuf(in, NULL);
+  setbuf(out, NULL);
+  // spawn_process() must close those!
+  // If we don't mark them as closed, close() attempt before
+  // return from this function throws an exception on Windows.
+  // Windows does not like when closed descriptor is closed again.
+  fd_stdin[0] = fd_stdout[1] = -1;
+  // Send POST data to the CGI process if needed
+  if (!strcmp(conn->request_info.request_method, "POST") &&
+      !forward_body_data(conn, in, INVALID_SOCKET, NULL)) {
+    goto done;
+  // Now read CGI reply into a buffer. We need to set correct
+  // status code, thus we need to see all HTTP headers first.
+  // Do not send anything back to client, until we buffer in all
+  // HTTP headers.
+  data_len = 0;
+  headers_len = read_request(out, INVALID_SOCKET, NULL,
+                             buf, sizeof(buf), &data_len);
+  if (headers_len <= 0) {
+                    "CGI program sent malformed HTTP headers: [%.*s]",
+                    data_len, buf);
+    goto done;
+  pbuf = buf;
+  buf[headers_len - 1] = '\0';
+  parse_http_headers(&pbuf, &ri);
+  // Make up and send the status line
+  status_text = "OK";
+  if ((status = get_header(&ri, "Status")) != NULL) {
+    conn->request_info.status_code = atoi(status);
+    status_text = status;
+    while (isdigit(* (unsigned char *) status_text) || *status_text == ' ') {
+      status_text++;
+  } else if (get_header(&ri, "Location") != NULL) {
+    conn->request_info.status_code = 302;
+  } else {
+  if (get_header(&ri, "Connection") != NULL &&
+      !mg_strcasecmp(get_header(&ri, "Connection"), "keep-alive")) {
+  (void) mg_printf(conn, "HTTP/1.1 %d %s\r\n", conn->request_info.status_code,
+                   status_text);
+  // Send headers
+  for (i = 0; i < ri.num_headers; i++) {
+    mg_printf(conn, "%s: %s\r\n",
+              ri.http_headers[i].name, ri.http_headers[i].value);
+  (void) mg_write(conn, "\r\n", 2);
+  // Send chunk of data that may be read after the headers
+  conn->num_bytes_sent += mg_write(conn, buf + headers_len,
+                                   (size_t)(data_len - headers_len));
+  // Read the rest of CGI output and send to the client
+  send_file_data(conn, out, INT64_MAX);
 done:
-	if (pid != (pid_t) -1)
-		kill(pid, SIGTERM);
-	if (fd_stdin[0] != -1)
-		(void) close(fd_stdin[0]);
-	if (fd_stdout[1] != -1)
-		(void) close(fd_stdout[1]);
-	if (in != NULL)
-		(void) fclose(in);
-	else if (fd_stdin[1] != -1)
-		(void) close(fd_stdin[1]);
-	if (out != NULL)
-		(void) fclose(out);
-	else if (fd_stdout[0] != -1)
-		(void) close(fd_stdout[0]);
-#endif /* !NO_CGI */
- * For a given PUT path, create all intermediate subdirectories
- * for given path. Return 0 if the path itself is a directory,
- * or -1 on error, 1 if OK.
-static int
-put_dir(const char *path)
-	char		buf[FILENAME_MAX];
-	const char	*s, *p;
-	struct mgstat	st;
-	size_t		len;
-	for (s = p = path + 2; (p = strchr(s, '/')) != NULL; s = ++p) {
-		len = p - path;
-		assert(len < sizeof(buf));
-		(void) memcpy(buf, path, len);
-		buf[len] = '\0';
-		/* Try to create intermediate directory */
-		if (mg_stat(buf, &st) == -1 && mg_mkdir(buf, 0755) != 0)
-			return (-1);
-		/* Is path itself a directory ? */
-		if (p[1] == '\0')
-			return (0);
-	return (1);
-static void
-put_file(struct mg_connection *conn, const char *path)
-	struct mgstat	st;
-	FILE		*fp;
-	int		rc;
-	conn->request_info.status_code = mg_stat(path, &st) == 0 ? 200 : 201;
-	if (mg_get_header(conn, "Range")) {
-		send_error(conn, 501, "Not Implemented",
-		    "%s", "Range support for PUT requests is not implemented");
-	} else if ((rc = put_dir(path)) == 0) {
-		(void) mg_printf(conn, "HTTP/1.1 %d OK\r\n\r\n",
-	} else if (rc == -1) {
-		    "put_dir(%s): %s", path, strerror(ERRNO));
-	} else if ((fp = mg_fopen(path, "wb+")) == NULL) {
-	} else {
-		if (handle_request_body(conn, fp))
-#if !defined(NO_SSI)
+  if (pid != (pid_t) -1) {
+    kill(pid, SIGKILL);
+  if (fd_stdin[0] != -1) {
+    (void) close(fd_stdin[0]);
+  if (fd_stdout[1] != -1) {
+    (void) close(fd_stdout[1]);
+  if (in != NULL) {
+    (void) fclose(in);
+  } else if (fd_stdin[1] != -1) {
+    (void) close(fd_stdin[1]);
+  if (out != NULL) {
+    (void) fclose(out);
+  } else if (fd_stdout[0] != -1) {
+    (void) close(fd_stdout[0]);
+#endif // !NO_CGI
+// For a given PUT path, create all intermediate subdirectories
+// for given path. Return 0 if the path itself is a directory,
+// or -1 on error, 1 if OK.
+static int put_dir(const char *path) {
+  char buf[PATH_MAX];
+  const char *s, *p;
+  struct mgstat st;
+  int len, res = 1;
+  for (s = p = path + 2; (p = strchr(s, DIRSEP)) != NULL; s = ++p) {
+    len = p - path;
+    if (len >= (int) sizeof(buf)) {
+      res = -1;
+      break;
+    memcpy(buf, path, len);
+    buf[len] = '\0';
+    // Try to create intermediate directory
+    DEBUG_TRACE(("mkdir(%s)", buf));
+    if (mg_stat(buf, &st) == -1 && mg_mkdir(buf, 0755) != 0) {
+      res = -1;
+      break;
+    // Is path itself a directory?
+    if (p[1] == '\0') {
+      res = 0;
+  return res;
+static void put_file(struct mg_connection *conn, const char *path) {
+  struct mgstat st;
+  const char *range;
+  int64_t r1, r2;
+  FILE *fp;
+  int rc;
+  conn->request_info.status_code = mg_stat(path, &st) == 0 ? 200 : 201;
+  if ((rc = put_dir(path)) == 0) {
+    mg_printf(conn, "HTTP/1.1 %d OK\r\n\r\n", conn->request_info.status_code);
+  } else if (rc == -1) {
+        "put_dir(%s): %s", path, strerror(ERRNO));
+  } else if ((fp = mg_fopen(path, "wb+")) == NULL) {
+  } else {
+    range = mg_get_header(conn, "Content-Range");
+    r1 = r2 = 0;
+    if (range != NULL && parse_range_header(range, &r1, &r2) > 0) {
+      // TODO(lsm): handle seek error
+    if (forward_body_data(conn, fp, INVALID_SOCKET, NULL))
+      (void) mg_printf(conn, "HTTP/1.1 %d OK\r\n\r\n",
+          conn->request_info.status_code);
 static void send_ssi_file(struct mg_connection *, const char *, FILE *, int);
-static void
-do_ssi_include(struct mg_connection *conn, const char *ssi, char *tag,
-		int include_level)
-	char	file_name[BUFSIZ], path[FILENAME_MAX], *p;
-	FILE	*fp;
-	 * sscanf() is safe here, since send_ssi_file() also uses buffer
-	 * of size BUFSIZ to get the tag. So strlen(tag) is always < BUFSIZ.
-	if (sscanf(tag, " virtual=\"%[^\"]\"", file_name) == 1) {
-		/* File name is relative to the webserver root */
-		    conn->ctx->options[OPT_ROOT], DIRSEP, file_name);
-	} else if (sscanf(tag, " file=\"%[^\"]\"", file_name) == 1) {
-		 * File name is relative to the webserver working directory
-		 * or it is absolute system path
-		(void) mg_snprintf(conn, path, sizeof(path), "%s", file_name);
-	} else if (sscanf(tag, " \"%[^\"]\"", file_name) == 1) {
-		/* File name is relative to the currect document */
-		(void) mg_snprintf(conn, path, sizeof(path), "%s", ssi);
-		if ((p = strrchr(path, DIRSEP)) != NULL)
-			p[1] = '\0';
-		(void) mg_snprintf(conn, path + strlen(path),
-		    sizeof(path) - strlen(path), "%s", file_name);
-	} else {
-		cry(conn, "Bad SSI #include: [%s]", tag);
-		return;
-		cry(conn, "Cannot open SSI #include: [%s]: fopen(%s): %s",
-		    tag, path, strerror(ERRNO));
-	} else {
-		if (match_extension(path,
-		    conn->ctx->options[OPT_SSI_EXTENSIONS])) {
-			send_ssi_file(conn, path, fp, include_level + 1);
-		} else {
-			send_opened_file_stream(conn, fp, INT64_MAX);
-static void
-do_ssi_exec(struct mg_connection *conn, char *tag)
-	char	cmd[BUFSIZ];
-	FILE	*fp;
-	if (sscanf(tag, " \"%[^\"]\"", cmd) != 1) {
-		cry(conn, "Bad SSI #exec: [%s]", tag);
-	} else if ((fp = popen(cmd, "r")) == NULL) {
-		cry(conn, "Cannot SSI #exec: [%s]: %s", cmd, strerror(ERRNO));
-	} else {
-		(void) pclose(fp);
-static void
-send_ssi_file(struct mg_connection *conn, const char *path, FILE *fp,
-	char	buf[BUFSIZ];
-	int	ch, len, in_ssi_tag;
-	if (include_level > 10) {
-		cry(conn, "SSI #include level is too deep (%s)", path);
-		return;
-	in_ssi_tag = FALSE;
-	len = 0;
-	while ((ch = fgetc(fp)) != EOF) {
-		if (in_ssi_tag && ch == '>') {
-			buf[len++] = ch & 0xff;
-			buf[len] = '\0';
-			assert(len <= (int) sizeof(buf));
-			if (len < 6 || memcmp(buf, "<!--#", 5) != 0) {
-				/* Not an SSI tag, pass it */
-				(void) mg_write(conn, buf, len);
-			} else {
-				if (!memcmp(buf + 5, "include", 7)) {
-					do_ssi_include(conn, path, buf + 12,
-					    include_level);
-				} else if (!memcmp(buf + 5, "exec", 4)) {
-					do_ssi_exec(conn, buf + 9);
-				} else {
-					cry(conn, "%s: unknown SSI "
-					    "command: \"%s\"", path, buf);
-			len = 0;
-		} else if (in_ssi_tag) {
-			if (len == 5 && memcmp(buf, "<!--#", 5) != 0) {
-				/* Not an SSI tag */
-			} else if (len == (int) sizeof(buf) - 2) {
-				cry(conn, "%s: SSI tag is too large", path);
-				len = 0;
-		} else if (ch == '<') {
-			in_ssi_tag = TRUE;
-			if (len > 0)
-			len = 0;
-		} else {
-			if (len == (int) sizeof(buf)) {
-				len = 0;
-	/* Send the rest of buffered data */
-	if (len > 0)
-static void
-send_ssi(struct mg_connection *conn, const char *path)
-	FILE	*fp;
-	} else {
-		(void) mg_printf(conn, "%s", "HTTP/1.1 200 OK\r\n"
-		    "Content-Type: text/html\r\nConnection: close\r\n\r\n");
-		send_ssi_file(conn, path, fp, 0);
-#endif /* !NO_SSI */
-void
-mg_authorize(struct mg_connection *conn)
-	conn->embedded_auth = TRUE;
-static bool_t
-check_embedded_authorization(struct mg_connection *conn)
-	const struct callback	*cb;
-	bool_t			authorized;
-	authorized = TRUE;
-	cb = find_callback(conn->ctx, TRUE, conn->request_info.uri, -1);
-	if (cb != NULL) {
-		cb->func(conn, &conn->request_info, cb->user_data);
-		authorized = conn->embedded_auth;
-	return (authorized);
- * This is the heart of the Mongoose's logic.
- * This function is called when the request is read, parsed and validated,
- * and Mongoose must decide what action to take: serve a file, or
- * a directory, or call embedded function, etcetera.
-static void
-analyze_request(struct mg_connection *conn)
-	char			path[FILENAME_MAX], *uri = ri->uri;
-	struct mgstat		st;
-	if ((conn->request_info.query_string = strchr(uri, '?')) != NULL)
-		* conn->request_info.query_string++ = '\0';
-	(void) url_decode(uri, (int) strlen(uri), uri, strlen(uri) + 1, FALSE);
-	remove_double_dots_and_double_slashes(uri);
-	convert_uri_to_file_name(conn, uri, path, sizeof(path));
-	if (!check_authorization(conn, path)) {
-		send_authorization_request(conn);
-	} else if (check_embedded_authorization(conn) == FALSE) {
-		 * Embedded code failed authorization. Do nothing here, since
-		 * an embedded code must handle this itself by either
-		 * showing proper error message, or redirecting to some
-		 * sort of login page, or something else.
-	} else if ((cb = find_callback(conn->ctx, FALSE, uri, -1)) != NULL) {
-		if ((strcmp(ri->request_method, "POST") != 0 &&
-		    strcmp(ri->request_method, "PUT") != 0) ||
-		    handle_request_body(conn, NULL))
-	} else if (strstr(path, PASSWORDS_FILE_NAME)) {
-		/* Do not allow to view passwords files */
-		send_error(conn, 403, "Forbidden", "Access Forbidden");
-	} else if ((!strcmp(ri->request_method, "PUT") ||
-	    !strcmp(ri->request_method, "DELETE")) &&
-	    (conn->ctx->options[OPT_AUTH_PUT] == NULL ||
-	     !is_authorized_for_put(conn))) {
-	} else if (!strcmp(ri->request_method, "PUT")) {
-		put_file(conn, path);
-	} else if (!strcmp(ri->request_method, "DELETE")) {
-		if (mg_remove(path) == 0)
-			send_error(conn, 200, "OK", "");
-		else
-			    "remove(%s): %s", path, strerror(ERRNO));
-	} else if (mg_stat(path, &st) != 0) {
-		send_error(conn, 404, "Not Found", "%s", "File not found");
-	} else if (st.is_directory && uri[strlen(uri) - 1] != '/') {
-		    "HTTP/1.1 301 Moved Permanently\r\n"
-		    "Location: %s/\r\n\r\n", uri);
-	    substitute_index_file(conn, path, sizeof(path), &st) == FALSE) {
-		if (is_true(conn->ctx->options[OPT_DIR_LIST])) {
-			send_directory(conn, path);
-		} else {
-			send_error(conn, 403, "Directory Listing Denied",
-			    "Directory listing denied");
+static void do_ssi_include(struct mg_connection *conn, const char *ssi,
+                           char *tag, int include_level) {
+  char file_name[BUFSIZ], path[PATH_MAX], *p;
+  FILE *fp;
+  // sscanf() is safe here, since send_ssi_file() also uses buffer
+  // of size BUFSIZ to get the tag. So strlen(tag) is always < BUFSIZ.
+  if (sscanf(tag, " virtual=\"%[^\"]\"", file_name) == 1) {
+    // File name is relative to the webserver root
+    (void) mg_snprintf(conn, path, sizeof(path), "%s%c%s",
+        conn->ctx->config[DOCUMENT_ROOT], DIRSEP, file_name);
+  } else if (sscanf(tag, " file=\"%[^\"]\"", file_name) == 1) {
+    // File name is relative to the webserver working directory
+    // or it is absolute system path
+    (void) mg_snprintf(conn, path, sizeof(path), "%s", file_name);
+  } else if (sscanf(tag, " \"%[^\"]\"", file_name) == 1) {
+    // File name is relative to the currect document
+    (void) mg_snprintf(conn, path, sizeof(path), "%s", ssi);
+    if ((p = strrchr(path, DIRSEP)) != NULL) {
+      p[1] = '\0';
+    (void) mg_snprintf(conn, path + strlen(path),
+        sizeof(path) - strlen(path), "%s", file_name);
+  } else {
+    cry(conn, "Bad SSI #include: [%s]", tag);
+    return;
+    cry(conn, "Cannot open SSI #include: [%s]: fopen(%s): %s",
+        tag, path, strerror(ERRNO));
+  } else {
+    if (match_prefix(conn->ctx->config[SSI_EXTENSIONS],
+                     strlen(conn->ctx->config[SSI_EXTENSIONS]), path) > 0) {
+      send_ssi_file(conn, path, fp, include_level + 1);
+    } else {
+      send_file_data(conn, fp, INT64_MAX);
+#if !defined(NO_POPEN)
+static void do_ssi_exec(struct mg_connection *conn, char *tag) {
+  char cmd[BUFSIZ];
+  FILE *fp;
+  if (sscanf(tag, " \"%[^\"]\"", cmd) != 1) {
+    cry(conn, "Bad SSI #exec: [%s]", tag);
+  } else if ((fp = popen(cmd, "r")) == NULL) {
+    cry(conn, "Cannot SSI #exec: [%s]: %s", cmd, strerror(ERRNO));
+  } else {
+    (void) pclose(fp);
+#endif // !NO_POPEN
+static void send_ssi_file(struct mg_connection *conn, const char *path,
+                          FILE *fp, int include_level) {
+  char buf[BUFSIZ];
+  int ch, len, in_ssi_tag;
+  if (include_level > 10) {
+    cry(conn, "SSI #include level is too deep (%s)", path);
+    return;
+  in_ssi_tag = 0;
+  len = 0;
+  while ((ch = fgetc(fp)) != EOF) {
+    if (in_ssi_tag && ch == '>') {
+      in_ssi_tag = 0;
+      buf[len++] = (char) ch;
+      buf[len] = '\0';
+      assert(len <= (int) sizeof(buf));
+      if (len < 6 || memcmp(buf, "<!--#", 5) != 0) {
+        // Not an SSI tag, pass it
+        (void) mg_write(conn, buf, (size_t)len);
+      } else {
+        if (!memcmp(buf + 5, "include", 7)) {
+          do_ssi_include(conn, path, buf + 12, include_level);
+        } else if (!memcmp(buf + 5, "exec", 4)) {
+          do_ssi_exec(conn, buf + 9);
+        } else {
+          cry(conn, "%s: unknown SSI " "command: \"%s\"", path, buf);
+      len = 0;
+    } else if (in_ssi_tag) {
+      if (len == 5 && memcmp(buf, "<!--#", 5) != 0) {
+        // Not an SSI tag
+        in_ssi_tag = 0;
+      } else if (len == (int) sizeof(buf) - 2) {
+        cry(conn, "%s: SSI tag is too large", path);
+        len = 0;
+      buf[len++] = ch & 0xff;
+    } else if (ch == '<') {
+      in_ssi_tag = 1;
+      if (len > 0) {
+      len = 0;
+    } else {
+      if (len == (int) sizeof(buf)) {
+        len = 0;
+  // Send the rest of buffered data
+  if (len > 0) {
+static void handle_ssi_file_request(struct mg_connection *conn,
+                                    const char *path) {
+  FILE *fp;
+    send_http_error(conn, 500, http_500_error, "fopen(%s): %s", path,
+                    strerror(ERRNO));
+  } else {
+    mg_printf(conn, "HTTP/1.1 200 OK\r\n"
+              "Content-Type: text/html\r\nConnection: %s\r\n\r\n",
+              suggest_connection_header(conn));
+    send_ssi_file(conn, path, fp, 0);
+static void send_options(struct mg_connection *conn) {
+      "Allow: GET, POST, HEAD, CONNECT, PUT, DELETE, OPTIONS\r\n"
+      "DAV: 1\r\n\r\n");
+// Writes PROPFIND properties for a collection element
+static void print_props(struct mg_connection *conn, const char* uri,
+                        struct mgstat* st) {
+  char mtime[64];
+  gmt_time_string(mtime, sizeof(mtime), &st->mtime);
+      "<d:response>"
+       "<d:href>%s</d:href>"
+       "<d:propstat>"
+        "<d:prop>"
+         "<d:resourcetype>%s</d:resourcetype>"
+         "<d:getcontentlength>%" INT64_FMT "</d:getcontentlength>"
+         "<d:getlastmodified>%s</d:getlastmodified>"
+        "</d:prop>"
+        "<d:status>HTTP/1.1 200 OK</d:status>"
+       "</d:propstat>"
+      "</d:response>\n",
+      uri,
+      st->is_directory ? "<d:collection/>" : "",
+      st->size,
+      mtime);
+static void print_dav_dir_entry(struct de *de, void *data) {
+  char href[PATH_MAX];
+  struct mg_connection *conn = (struct mg_connection *) data;
+  mg_snprintf(conn, href, sizeof(href), "%s%s",
+              conn->request_info.uri, de->file_name);
+  print_props(conn, href, &de->st);
+static void handle_propfind(struct mg_connection *conn, const char* path,
+  const char *depth = mg_get_header(conn, "Depth");
+  conn->request_info.status_code = 207;
+  mg_printf(conn, "HTTP/1.1 207 Multi-Status\r\n"
+            "Content-Type: text/xml; charset=utf-8\r\n\r\n");
+      "<?xml version=\"1.0\" encoding=\"utf-8\"?>"
+      "<d:multistatus xmlns:d='DAV:'>\n");
+  // Print properties for the requested resource itself
+  print_props(conn, conn->request_info.uri, st);
+  // If it is a directory, print directory entries too if Depth is not 0
+  if (st->is_directory &&
+      !mg_strcasecmp(conn->ctx->config[ENABLE_DIRECTORY_LISTING], "yes") &&
+      (depth == NULL || strcmp(depth, "0") != 0)) {
+    scan_directory(conn, path, conn, &print_dav_dir_entry);
+  conn->num_bytes_sent += mg_printf(conn, "%s\n", "</d:multistatus>");
+// This is the heart of the Mongoose's logic.
+// This function is called when the request is read, parsed and validated,
+// and Mongoose must decide what action to take: serve a file, or
+// a directory, or call embedded function, etcetera.
+static void handle_request(struct mg_connection *conn) {
+  struct mg_request_info *ri = &conn->request_info;
+  int stat_result, uri_len;
+  struct mgstat st;
+  if ((conn->request_info.query_string = strchr(ri->uri, '?')) != NULL) {
+    * conn->request_info.query_string++ = '\0';
+  uri_len = strlen(ri->uri);
+  url_decode(ri->uri, (size_t)uri_len, ri->uri, (size_t)(uri_len + 1), 0);
+  remove_double_dots_and_double_slashes(ri->uri);
+  stat_result = convert_uri_to_file_name(conn, path, sizeof(path), &st);
+  DEBUG_TRACE(("%s", ri->uri));
+  if (!check_authorization(conn, path)) {
+    send_authorization_request(conn);
+  } else if (call_user(conn, MG_NEW_REQUEST) != NULL) {
+    // Do nothing, callback has served the request
+  } else if (!strcmp(ri->request_method, "OPTIONS")) {
+    send_options(conn);
+  } else if (strstr(path, PASSWORDS_FILE_NAME)) {
+    // Do not allow to view passwords files
+    send_http_error(conn, 403, "Forbidden", "Access Forbidden");
+  } else if (conn->ctx->config[DOCUMENT_ROOT] == NULL) {
+    send_http_error(conn, 404, "Not Found", "Not Found");
+  } else if ((!strcmp(ri->request_method, "PUT") ||
+        !strcmp(ri->request_method, "DELETE")) &&
+      (conn->ctx->config[PUT_DELETE_PASSWORDS_FILE] == NULL ||
+       !is_authorized_for_put(conn))) {
+  } else if (!strcmp(ri->request_method, "PUT")) {
+    put_file(conn, path);
+  } else if (!strcmp(ri->request_method, "DELETE")) {
+    if (mg_remove(path) == 0) {
+      send_http_error(conn, 200, "OK", "");
+    } else {
+      send_http_error(conn, 500, http_500_error, "remove(%s): %s", path,
+                      strerror(ERRNO));
+  } else if (stat_result != 0) {
+  } else if (st.is_directory && ri->uri[uri_len - 1] != '/') {
+        "HTTP/1.1 301 Moved Permanently\r\n"
+        "Location: %s/\r\n\r\n", ri->uri);
+  } else if (!strcmp(ri->request_method, "PROPFIND")) {
+    handle_propfind(conn, path, &st);
+             !substitute_index_file(conn, path, sizeof(path), &st)) {
+    if (!mg_strcasecmp(conn->ctx->config[ENABLE_DIRECTORY_LISTING], "yes")) {
+      handle_directory_request(conn, path);
+    } else {
+      send_http_error(conn, 403, "Directory Listing Denied",
+          "Directory listing denied");
-	} else if (match_extension(path,
-	    conn->ctx->options[OPT_CGI_EXTENSIONS])) {
-		if (strcmp(ri->request_method, "POST") &&
-		    strcmp(ri->request_method, "GET")) {
-			    "Method %s is not implemented", ri->request_method);
-		} else {
-			send_cgi(conn, path);
-#endif /* NO_CGI */
-		send_ssi(conn, path);
-#endif /* NO_SSI */
-	} else if (is_not_modified(conn, &st)) {
-		send_error(conn, 304, "Not Modified", "");
-	} else {
-		send_file(conn, path, &st);
-static void
-close_all_listening_sockets(struct mg_context *ctx)
-	int	i;
-	for (i = 0; i < ctx->num_listeners; i++)
-		(void) closesocket(ctx->listeners[i].sock);
-	ctx->num_listeners = 0;
-static bool_t
-set_ports_option(struct mg_context *ctx, const char *list)
-	SOCKET		sock;
-	int		is_ssl;
-	struct vec	vec;
-	struct socket	*listener;
-	close_all_listening_sockets(ctx);
-	assert(ctx->num_listeners == 0);
-	while ((list = next_option(list, &vec, NULL)) != NULL) {
-		is_ssl	= vec.ptr[vec.len - 1] == 's' ? TRUE : FALSE;
-		listener = ctx->listeners + ctx->num_listeners;
-		if (ctx->num_listeners >=
-		    (int) (ARRAY_SIZE(ctx->listeners) - 1)) {
-			cry(fc(ctx), "%s", "Too many listeninig sockets");
-			return (FALSE);
-		} else if ((sock = mg_open_listening_port(ctx,
-		    vec.ptr, &listener->lsa)) == INVALID_SOCKET) {
-			cry(fc(ctx), "cannot bind to %.*s", vec.len, vec.ptr);
-			return (FALSE);
-		} else if (is_ssl == TRUE && ctx->ssl_ctx == NULL) {
-			(void) closesocket(sock);
-			cry(fc(ctx), "cannot add SSL socket, please specify "
-			    "-ssl_cert option BEFORE -ports option");
-			return (FALSE);
-		} else {
-			listener->sock = sock;
-			listener->is_ssl = is_ssl;
-			ctx->num_listeners++;
-	return (TRUE);
-static void
-log_header(const struct mg_connection *conn, const char *header, FILE *fp)
-	const char	*header_value;
-	if ((header_value = mg_get_header(conn, header)) == NULL) {
-		(void) fprintf(fp, "%s", " -");
-	} else {
-		(void) fprintf(fp, " \"%s\"", header_value);
-static void
-log_access(const struct mg_connection *conn)
-	const struct mg_request_info *ri;
-	char		date[64];
-	if (conn->ctx->access_log == NULL)
-		return;
-	(void) strftime(date, sizeof(date), "%d/%b/%Y:%H:%M:%S %z",
-	    localtime(&conn->birth_time));
-	ri = &conn->request_info;
-	flockfile(conn->ctx->access_log);
-	(void) fprintf(conn->ctx->access_log,
-	    "%s - %s [%s] \"%s %s HTTP/%s\" %d %" INT64_FMT,
-	    inet_ntoa(conn->client.rsa.u.sin.sin_addr),
-	    ri->remote_user == NULL ? "-" : ri->remote_user,
-	    date,
-	    ri->request_method ? ri->request_method : "-",
-	    ri->uri ? ri->uri : "-",
-	    ri->http_version,
-	    conn->request_info.status_code, conn->num_bytes_sent);
-	log_header(conn, "Referer", conn->ctx->access_log);
-	log_header(conn, "User-Agent", conn->ctx->access_log);
-	(void) fputc('\n', conn->ctx->access_log);
-	(void) fflush(conn->ctx->access_log);
-	funlockfile(conn->ctx->access_log);
-static bool_t
-isbyte(int n) {
-	return (n >= 0 && n <= 255);
- * Verify given socket address against the ACL.
- * Return -1 if ACL is malformed, 0 if address is disallowed, 1 if allowed.
-static int
-check_acl(struct mg_context *ctx, const char *list, const struct usa *usa)
-	int		a, b, c, d, n, mask, allowed;
-	char		flag;
-	uint32_t	acl_subnet, acl_mask, remote_ip;
-	struct vec	vec;
-	(void) memcpy(&remote_ip, &usa->u.sin.sin_addr, sizeof(remote_ip));
-	/* If any ACL is set, deny by default */
-	allowed = '-';
-		mask = 32;
-		if (sscanf(vec.ptr, "%c%d.%d.%d.%d%n",
-		    &flag, &a, &b, &c, &d, &n) != 5) {
-			cry(fc(ctx),
-			    "%s: subnet must be [+|-]x.x.x.x[/x]", __func__);
-			return (-1);
-		} else if (flag != '+' && flag != '-') {
-			cry(fc(ctx), "%s: flag must be + or -: [%s]",
-			    __func__, vec.ptr);
-			return (-1);
-		} else if (!isbyte(a)||!isbyte(b)||!isbyte(c)||!isbyte(d)) {
-			cry(fc(ctx),
-			    "%s: bad ip address: [%s]", __func__, vec.ptr);
-			return (-1);
-		} else if (sscanf(vec.ptr + n, "/%d", &mask) == 0) {
-			/* Do nothing, no mask specified */
-		} else if (mask < 0 || mask > 32) {
-			cry(fc(ctx), "%s: bad subnet mask: %d [%s]",
-			    __func__, n, vec.ptr);
-			return (-1);
-		acl_subnet = ((uint32_t)a << 24) | ((uint32_t)b << 16) | ((uint32_t)c << 8) | (uint32_t)d;
-		acl_mask = mask ? 0xffffffffU << (32 - mask) : 0;
-		if (acl_subnet == (ntohl(remote_ip) & acl_mask))
-			allowed = flag;
-	return (allowed == '+' ? 1 : 0);
-static void
-add_to_set(SOCKET fd, fd_set *set, int *max_fd)
-	FD_SET(fd, set);
-	if (fd > (SOCKET) *max_fd)
-		*max_fd = (int) fd;
- * Deallocate mongoose context, free up the resources
-static void
-mg_fini(struct mg_context *ctx)
-	int	i;
-	/* Wait until all threads finish */
-	(void) pthread_mutex_lock(&ctx->thr_mutex);
-	while (ctx->num_threads > 0)
-		(void) pthread_cond_wait(&ctx->thr_cond, &ctx->thr_mutex);
-	(void) pthread_mutex_unlock(&ctx->thr_mutex);
-	/* Deallocate all registered callbacks */
-		if (ctx->callbacks[i].uri_regex != NULL)
-			free(ctx->callbacks[i].uri_regex);
-	/* Deallocate all options */
-	for (i = 0; i < NUM_OPTIONS; i++)
-		if (ctx->options[i] != NULL)
-			free(ctx->options[i]);
-	/* Close log files */
-	if (ctx->access_log)
-		(void) fclose(ctx->access_log);
-	if (ctx->error_log)
-		(void) fclose(ctx->error_log);
-	/* Deallocate SSL context */
-	if (ctx->ssl_ctx)
-		SSL_CTX_free(ctx->ssl_ctx);
-	/* Deallocate mutexes and condvars */
-		(void) pthread_mutex_destroy(&ctx->opt_mutex[i]);
-	(void) pthread_mutex_destroy(&ctx->thr_mutex);
-	(void) pthread_mutex_destroy(&ctx->bind_mutex);
-	(void) pthread_cond_destroy(&ctx->thr_cond);
-	(void) pthread_cond_destroy(&ctx->empty_cond);
-	(void) pthread_cond_destroy(&ctx->full_cond);
-	/* Signal mg_stop() that we're done */
-	ctx->stop_flag = 2;
+  } else if (match_prefix(conn->ctx->config[CGI_EXTENSIONS],
+                          strlen(conn->ctx->config[CGI_EXTENSIONS]),
+                          path) > 0) {
+    if (strcmp(ri->request_method, "POST") &&
+        strcmp(ri->request_method, "GET")) {
+      send_http_error(conn, 501, "Not Implemented",
+                      "Method %s is not implemented", ri->request_method);
+    } else {
+      handle_cgi_request(conn, path);
+#endif // !NO_CGI
+  } else if (match_prefix(conn->ctx->config[SSI_EXTENSIONS],
+                          path) > 0) {
+    handle_ssi_file_request(conn, path);
+  } else if (is_not_modified(conn, &st)) {
+    send_http_error(conn, 304, "Not Modified", "");
+  } else {
+static void close_all_listening_sockets(struct mg_context *ctx) {
+  struct socket *sp, *tmp;
+  for (sp = ctx->listening_sockets; sp != NULL; sp = tmp) {
+    tmp = sp->next;
+    (void) closesocket(sp->sock);
+    free(sp);
+// Valid listening port specification is: [ip_address:]port[s]
+// Examples: 80, 443s, 127.0.0.1:3128,1.2.3.4:8080s
+// TODO(lsm): add parsing of the IPv6 address
+static int parse_port_string(const struct vec *vec, struct socket *so) {
+  int a, b, c, d, port, len;
+  // MacOS needs that. If we do not zero it, subsequent bind() will fail.
+  // Also, all-zeroes in the socket address means binding to all addresses
+  // for both IPv4 and IPv6 (INADDR_ANY and IN6ADDR_ANY_INIT).
+  memset(so, 0, sizeof(*so));
+  if (sscanf(vec->ptr, "%d.%d.%d.%d:%d%n", &a, &b, &c, &d, &port, &len) == 5) {
+    // Bind to a specific IPv4 address
+    so->lsa.sin.sin_addr.s_addr = htonl((a << 24) | (b << 16) | (c << 8) | d);
+  } else if (sscanf(vec->ptr, "%d%n", &port, &len) != 1 ||
+             len <= 0 ||
+             len > (int) vec->len ||
+             (vec->ptr[len] && vec->ptr[len] != 's' && vec->ptr[len] != ',')) {
+    return 0;
+  so->is_ssl = vec->ptr[len] == 's';
+#if defined(USE_IPV6)
+  so->lsa.sin6.sin6_family = AF_INET6;
+  so->lsa.sin6.sin6_port = htons((uint16_t) port);
+#else
+  so->lsa.sin.sin_family = AF_INET;
+  so->lsa.sin.sin_port = htons((uint16_t) port);
+#endif
+  return 1;
+static int set_ports_option(struct mg_context *ctx) {
+  const char *list = ctx->config[LISTENING_PORTS];
+  int on = 1, success = 1;
+  SOCKET sock;
+  struct vec vec;
+  struct socket so, *listener;
+  while (success && (list = next_option(list, &vec, NULL)) != NULL) {
+    if (!parse_port_string(&vec, &so)) {
+      cry(fc(ctx), "%s: %.*s: invalid port spec. Expecting list of: %s",
+          __func__, vec.len, vec.ptr, "[IP_ADDRESS:]PORT[s|p]");
+      success = 0;
+    } else if (so.is_ssl && ctx->ssl_ctx == NULL) {
+      cry(fc(ctx), "Cannot add SSL socket, is -ssl_certificate option set?");
+      success = 0;
+    } else if ((sock = socket(so.lsa.sa.sa_family, SOCK_STREAM, 6)) ==
+               INVALID_SOCKET ||
 #if !defined(_WIN32)
-static bool_t
-set_uid_option(struct mg_context *ctx, const char *uid)
-	struct passwd	*pw;
-	int		retval = FALSE;
-	if ((pw = getpwnam(uid)) == NULL)
-		cry(fc(ctx), "%s: unknown user [%s]", __func__, uid);
-	else if (setgid(pw->pw_gid) == -1)
-		cry(fc(ctx), "%s: setgid(%s): %s",
-		    __func__, uid, strerror(errno));
-	else if (setuid(pw->pw_uid) == -1)
-		cry(fc(ctx), "%s: setuid(%s): %s",
-	else
-		retval = TRUE;
-	return (retval);
-#endif /* !_WIN32 */
+               // On Windows, SO_REUSEADDR is recommended only for
+               // broadcast UDP sockets
+               setsockopt(sock, SOL_SOCKET, SO_REUSEADDR, &on,
+                          sizeof(on)) != 0 ||
+#endif // !_WIN32
+               // Set TCP keep-alive. This is needed because if HTTP-level
+               // keep-alive is enabled, and client resets the connection,
+               // server won't get TCP FIN or RST and will keep the connection
+               // open forever. With TCP keep-alive, next keep-alive
+               // handshake will figure out that the client is down and
+               // will close the server end.
+               // Thanks to Igor Klopov who suggested the patch.
+               setsockopt(sock, SOL_SOCKET, SO_KEEPALIVE, (void *) &on,
+               bind(sock, &so.lsa.sa, sizeof(so.lsa)) != 0 ||
+               listen(sock, 100) != 0) {
+      closesocket(sock);
+      cry(fc(ctx), "%s: cannot bind to %.*s: %s", __func__,
+          vec.len, vec.ptr, strerror(ERRNO));
+      success = 0;
+    } else if ((listener = (struct socket *)
+                calloc(1, sizeof(*listener))) == NULL) {
+      cry(fc(ctx), "%s: %s", __func__, strerror(ERRNO));
+      success = 0;
+    } else {
+      *listener = so;
+      listener->sock = sock;
+      set_close_on_exec(listener->sock);
+      listener->next = ctx->listening_sockets;
+      ctx->listening_sockets = listener;
+  if (!success) {
+    close_all_listening_sockets(ctx);
+  return success;
+static void log_header(const struct mg_connection *conn, const char *header,
+                       FILE *fp) {
+  const char *header_value;
+  if ((header_value = mg_get_header(conn, header)) == NULL) {
+    (void) fprintf(fp, "%s", " -");
+  } else {
+    (void) fprintf(fp, " \"%s\"", header_value);
+static void log_access(const struct mg_connection *conn) {
+  const struct mg_request_info *ri;
+  FILE *fp;
+  char date[64], src_addr[20];
+  fp = conn->ctx->config[ACCESS_LOG_FILE] == NULL ?  NULL :
+    mg_fopen(conn->ctx->config[ACCESS_LOG_FILE], "a+");
+  if (fp == NULL)
+    return;
+  strftime(date, sizeof(date), "%d/%b/%Y:%H:%M:%S %z",
+           localtime(&conn->birth_time));
+  ri = &conn->request_info;
+  flockfile(fp);
+  fprintf(fp, "%s - %s [%s] \"%s %s HTTP/%s\" %d %" INT64_FMT,
+          src_addr, ri->remote_user == NULL ? "-" : ri->remote_user, date,
+          ri->request_method ? ri->request_method : "-",
+          ri->uri ? ri->uri : "-", ri->http_version,
+          conn->request_info.status_code, conn->num_bytes_sent);
+  log_header(conn, "Referer", fp);
+  log_header(conn, "User-Agent", fp);
+  fputc('\n', fp);
+  fflush(fp);
+  funlockfile(fp);
+  fclose(fp);
+static int isbyte(int n) {
+  return n >= 0 && n <= 255;
+// Verify given socket address against the ACL.
+// Return -1 if ACL is malformed, 0 if address is disallowed, 1 if allowed.
+static int check_acl(struct mg_context *ctx, const union usa *usa) {
+  int a, b, c, d, n, mask, allowed;
+  char flag;
+  uint32_t acl_subnet, acl_mask, remote_ip;
+  struct vec vec;
+  const char *list = ctx->config[ACCESS_CONTROL_LIST];
+  if (list == NULL) {
+    return 1;
+  (void) memcpy(&remote_ip, &usa->sin.sin_addr, sizeof(remote_ip));
+  // If any ACL is set, deny by default
+  allowed = '-';
+  while ((list = next_option(list, &vec, NULL)) != NULL) {
+    mask = 32;
+    if (sscanf(vec.ptr, "%c%d.%d.%d.%d%n", &flag, &a, &b, &c, &d, &n) != 5) {
+      cry(fc(ctx), "%s: subnet must be [+|-]x.x.x.x[/x]", __func__);
+      return -1;
+    } else if (flag != '+' && flag != '-') {
+      cry(fc(ctx), "%s: flag must be + or -: [%s]", __func__, vec.ptr);
+      return -1;
+    } else if (!isbyte(a)||!isbyte(b)||!isbyte(c)||!isbyte(d)) {
+      cry(fc(ctx), "%s: bad ip address: [%s]", __func__, vec.ptr);
+      return -1;
+    } else if (sscanf(vec.ptr + n, "/%d", &mask) == 0) {
+      // Do nothing, no mask specified
+    } else if (mask < 0 || mask > 32) {
+      cry(fc(ctx), "%s: bad subnet mask: %d [%s]", __func__, n, vec.ptr);
+      return -1;
-#if !defined(NO_SSL)
-void
-mg_set_ssl_password_callback(struct mg_context *ctx, mg_spcb_t func)
-	ctx->ssl_password_callback = func;
+    acl_subnet = (a << 24) | (b << 16) | (c << 8) | d;
+    acl_mask = mask ? 0xffffffffU << (32 - mask) : 0;
+    if (acl_subnet == (ntohl(remote_ip) & acl_mask)) {
+      allowed = flag;
+  return allowed == '+';
+static void add_to_set(SOCKET fd, fd_set *set, int *max_fd) {
+  FD_SET(fd, set);
+  if (fd > (SOCKET) *max_fd) {
+    *max_fd = (int) fd;
+#if !defined(_WIN32)
+static int set_uid_option(struct mg_context *ctx) {
+  struct passwd *pw;
+  const char *uid = ctx->config[RUN_AS_USER];
+  int success = 0;
+  if (uid == NULL) {
+    success = 1;
+  } else {
+    if ((pw = getpwnam(uid)) == NULL) {
+      cry(fc(ctx), "%s: unknown user [%s]", __func__, uid);
+    } else if (setgid(pw->pw_gid) == -1) {
+      cry(fc(ctx), "%s: setgid(%s): %s", __func__, uid, strerror(errno));
+    } else if (setuid(pw->pw_uid) == -1) {
+      cry(fc(ctx), "%s: setuid(%s): %s", __func__, uid, strerror(errno));
+    } else {
+      success = 1;
+  return success;
+#endif // !_WIN32
+#if !defined(NO_SSL)
 static pthread_mutex_t *ssl_mutexes;
-static void
-ssl_locking_callback(int mode, int mutex_num, const char *file, int line)
-	line = 0;	/* Unused */
-	file = NULL;	/* Unused */
+// Return OpenSSL error message
+static const char *ssl_error(void) {
+  unsigned long err;
+  err = ERR_get_error();
+  return err == 0 ? "" : ERR_error_string(err, NULL);
+static void ssl_locking_callback(int mode, int mutex_num, const char *file,
+                                 int line) {
+  line = 0;    // Unused
+  file = NULL; // Unused
-	if (mode & CRYPTO_LOCK)
-		(void) pthread_mutex_lock(&ssl_mutexes[mutex_num]);
-	else
-		(void) pthread_mutex_unlock(&ssl_mutexes[mutex_num]);
+  if (mode & CRYPTO_LOCK) {
+    (void) pthread_mutex_lock(&ssl_mutexes[mutex_num]);
+  } else {
+    (void) pthread_mutex_unlock(&ssl_mutexes[mutex_num]);
-static unsigned long
-ssl_id_callback(void)
-	return ((unsigned long) pthread_self());
+static unsigned long ssl_id_callback(void) {
+  return (unsigned long) pthread_self();
-static bool_t
-load_dll(struct mg_context *ctx, const char *dll_name, struct ssl_func *sw)
-	union {void *p; void (*fp)(void);} u;
-	void		*dll_handle;
-	struct ssl_func	*fp;
+#if !defined(NO_SSL_DL)
+static int load_dll(struct mg_context *ctx, const char *dll_name,
+                    struct ssl_func *sw) {
+  union {void *p; void (*fp)(void);} u;
+  void  *dll_handle;
+  struct ssl_func *fp;
-	if ((dll_handle = dlopen(dll_name, RTLD_LAZY)) == NULL) {
-		cry(fc(ctx), "%s: cannot load %s", __func__, dll_name);
-		return (FALSE);
+  if ((dll_handle = dlopen(dll_name, RTLD_LAZY)) == NULL) {
+    cry(fc(ctx), "%s: cannot load %s", __func__, dll_name);
+    return 0;
-	for (fp = sw; fp->name != NULL; fp++) {
+  for (fp = sw; fp->name != NULL; fp++) {
 #ifdef _WIN32
-		/* GetProcAddress() returns pointer to function */
-		u.fp = (void (*)(void)) dlsym(dll_handle, fp->name);
+    // GetProcAddress() returns pointer to function
+    u.fp = (void (*)(void)) dlsym(dll_handle, fp->name);
 #else
-		 * dlsym() on UNIX returns void *.
-		 * ISO C forbids casts of data pointers to function
-		 * pointers. We need to use a union to make a cast.
-		u.p = dlsym(dll_handle, fp->name);
-		if (u.fp == NULL) {
-			cry(fc(ctx), "%s: cannot find %s", __func__, fp->name);
-			return (FALSE);
-		} else {
-			fp->ptr = u.fp;
-	return (TRUE);
- * Dynamically load SSL library. Set up ctx->ssl_ctx pointer.
-static bool_t
-set_ssl_option(struct mg_context *ctx, const char *pem)
-	SSL_CTX		*CTX;
-	int		i, size, retval = FALSE;
-	if (load_dll(ctx, SSL_LIB, ssl_sw) == FALSE ||
-	    load_dll(ctx, CRYPTO_LIB, crypto_sw) == FALSE)
-		return (FALSE);
-	/* Initialize SSL crap */
-	SSL_library_init();
-	if ((CTX = SSL_CTX_new(SSLv23_server_method())) == NULL)
-		cry(fc(ctx), "SSL_CTX_new error");
-	else if (ctx->ssl_password_callback != NULL)
-		SSL_CTX_set_default_passwd_cb(CTX, ctx->ssl_password_callback);
-	if (CTX != NULL && SSL_CTX_use_certificate_file(
-	    CTX, pem, SSL_FILETYPE_PEM) == 0)
-		cry(fc(ctx), "%s: cannot open %s", __func__, pem);
-	else if (CTX != NULL && SSL_CTX_use_PrivateKey_file(
-		cry(fc(ctx), "%s: cannot open %s", NULL, pem);
-	else
-		retval = TRUE;
-	 * Initialize locking callbacks, needed for thread safety.
-	 * http://www.openssl.org/support/faq.html#PROG1
-	size = sizeof(pthread_mutex_t) * CRYPTO_num_locks();
-	if ((ssl_mutexes = (pthread_mutex_t *) malloc(size)) == NULL) {
-		cry(fc(ctx), "%s: cannot allocate mutexes", __func__);
-		return (FALSE);
-	for (i = 0; i < CRYPTO_num_locks(); i++)
-		pthread_mutex_init(&ssl_mutexes[i], NULL);
-	CRYPTO_set_locking_callback(&ssl_locking_callback);
-	CRYPTO_set_id_callback(&ssl_id_callback);
-	/* Done with everything. Save the context. */
-	ctx->ssl_ctx = CTX;
-	return (retval);
-#endif /* !NO_SSL */
-static bool_t
-open_log_file(struct mg_context *ctx, FILE **fpp, const char *path)
-	bool_t	retval = TRUE;
-	if (*fpp != NULL)
-		(void) fclose(*fpp);
-	if (path == NULL) {
-		*fpp = NULL;
-	} else if ((*fpp = mg_fopen(path, "a")) == NULL) {
-		cry(fc(ctx), "%s(%s): %s", __func__, path, strerror(errno));
-		retval = FALSE;
-	} else {
-		set_close_on_exec(fileno(*fpp));
-	return (retval);
-static bool_t
-set_alog_option(struct mg_context *ctx, const char *path)
-	return (open_log_file(ctx, &ctx->access_log, path));
-static bool_t
-set_elog_option(struct mg_context *ctx, const char *path)
-	return (open_log_file(ctx, &ctx->error_log, path));
-static bool_t
-set_gpass_option(struct mg_context *ctx, const char *path)
-	struct mgstat	mgstat;
-	ctx = NULL;
-	return (mg_stat(path, &mgstat) == 0);
-static bool_t
-set_max_threads_option(struct mg_context *ctx, const char *str)
-	ctx->max_threads = atoi(str);
-	return (TRUE);
-static bool_t
-set_acl_option(struct mg_context *ctx, const char *acl)
-	struct usa	fake;
-	return (check_acl(ctx, acl, &fake) != -1);
-static void admin_page(struct mg_connection *,
-		const struct mg_request_info *, void *);
-static bool_t
-set_admin_uri_option(struct mg_context *ctx, const char *uri)
-	mg_set_uri_callback(ctx, uri, &admin_page, NULL);
-	return (TRUE);
- * Check if the comma-separated list of options has a format of key-value
- * pairs: "k1=v1,k2=v2". Return FALSE if any entry has invalid key or value.
-static bool_t
-set_kv_list_option(struct mg_context *ctx, const char *str)
-	const char	*list;
-	struct vec	key, value;
+    // dlsym() on UNIX returns void *. ISO C forbids casts of data pointers to
+    // function pointers. We need to use a union to make a cast.
+    u.p = dlsym(dll_handle, fp->name);
+#endif // _WIN32
+    if (u.fp == NULL) {
+      cry(fc(ctx), "%s: %s: cannot find %s", __func__, dll_name, fp->name);
+      return 0;
+    } else {
+      fp->ptr = u.fp;
+  return 1;
+#endif // NO_SSL_DL
+// Dynamically load SSL library. Set up ctx->ssl_ctx pointer.
+static int set_ssl_option(struct mg_context *ctx) {
+  struct mg_request_info request_info;
+  SSL_CTX *CTX;
+  int i, size;
+  const char *pem = ctx->config[SSL_CERTIFICATE];
+  const char *chain = ctx->config[SSL_CHAIN_FILE];
+  if (pem == NULL) {
+    return 1;
+  if (!load_dll(ctx, SSL_LIB, ssl_sw) ||
+      !load_dll(ctx, CRYPTO_LIB, crypto_sw)) {
+    return 0;
+  // Initialize SSL crap
+  SSL_library_init();
+  SSL_load_error_strings();
+  if ((CTX = SSL_CTX_new(SSLv23_server_method())) == NULL) {
+    cry(fc(ctx), "SSL_CTX_new error: %s", ssl_error());
+  } else if (ctx->user_callback != NULL) {
+    memset(&request_info, 0, sizeof(request_info));
+    request_info.user_data = ctx->user_data;
+    ctx->user_callback(MG_INIT_SSL, (struct mg_connection *) CTX,
+                       &request_info);
+  if (CTX != NULL && SSL_CTX_use_certificate_file(CTX, pem,
+        SSL_FILETYPE_PEM) == 0) {
+    cry(fc(ctx), "%s: cannot open %s: %s", __func__, pem, ssl_error());
+    return 0;
+  } else if (CTX != NULL && SSL_CTX_use_PrivateKey_file(CTX, pem,
+    cry(fc(ctx), "%s: cannot open %s: %s", NULL, pem, ssl_error());
+    return 0;
+  if (CTX != NULL && chain != NULL &&
+      SSL_CTX_use_certificate_chain_file(CTX, chain) == 0) {
+    cry(fc(ctx), "%s: cannot open %s: %s", NULL, chain, ssl_error());
+    return 0;
+  // Initialize locking callbacks, needed for thread safety.
+  // http://www.openssl.org/support/faq.html#PROG1
+  size = sizeof(pthread_mutex_t) * CRYPTO_num_locks();
+  if ((ssl_mutexes = (pthread_mutex_t *) malloc((size_t)size)) == NULL) {
+    cry(fc(ctx), "%s: cannot allocate mutexes: %s", __func__, ssl_error());
+    return 0;
+  for (i = 0; i < CRYPTO_num_locks(); i++) {
+    pthread_mutex_init(&ssl_mutexes[i], NULL);
+  CRYPTO_set_locking_callback(&ssl_locking_callback);
+  CRYPTO_set_id_callback(&ssl_id_callback);
+  // Done with everything. Save the context.
+  ctx->ssl_ctx = CTX;
+  return 1;
+static void uninitialize_ssl(struct mg_context *ctx) {
+  int i;
+  if (ctx->ssl_ctx != NULL) {
+    CRYPTO_set_locking_callback(NULL);
+      pthread_mutex_destroy(&ssl_mutexes[i]);
+    CRYPTO_set_id_callback(NULL);
+#endif // !NO_SSL
+static int set_gpass_option(struct mg_context *ctx) {
+  struct mgstat mgstat;
+  const char *path = ctx->config[GLOBAL_PASSWORDS_FILE];
+  return path == NULL || mg_stat(path, &mgstat) == 0;
+static int set_acl_option(struct mg_context *ctx) {
+  union usa fake;
+  return check_acl(ctx, &fake) != -1;
+static void reset_per_request_attributes(struct mg_connection *conn) {
+  // Reset request info attributes. DO NOT TOUCH is_ssl, remote_ip, remote_port
+  ri->remote_user = ri->request_method = ri->uri = ri->http_version =
+    conn->path_info = NULL;
+  ri->num_headers = 0;
+  ri->status_code = -1;
+  conn->num_bytes_sent = conn->consumed_content = 0;
+  conn->content_len = -1;
+  conn->request_len = conn->data_len = 0;
+  conn->must_close = 0;
+static void close_socket_gracefully(SOCKET sock) {
+  char buf[BUFSIZ];
+  struct linger linger;
+  int n;
+  // Set linger option to avoid socket hanging out after close. This prevent
+  // ephemeral port exhaust problem under high QPS.
+  linger.l_onoff = 1;
+  linger.l_linger = 1;
+  setsockopt(sock, SOL_SOCKET, SO_LINGER, (void *) &linger, sizeof(linger));
+  // Send FIN to the client
+  (void) shutdown(sock, SHUT_WR);
+  set_non_blocking_mode(sock);
+  // Read and discard pending data. If we do not do that and close the
+  // socket, the data in the send buffer may be discarded. This
+  // behaviour is seen on Windows, when client keeps sending data
+  // when server decide to close the connection; then when client
+  // does recv() it gets no data back.
+  do {
+    n = pull(NULL, sock, NULL, buf, sizeof(buf));
+  } while (n > 0);
+  // Now we know that our FIN is ACK-ed, safe to close
+  (void) closesocket(sock);
+static void close_connection(struct mg_connection *conn) {
+  if (conn->ssl) {
+    SSL_free(conn->ssl);
+    conn->ssl = NULL;
+  if (conn->client.sock != INVALID_SOCKET) {
+    close_socket_gracefully(conn->client.sock);
+static void discard_current_request_from_buffer(struct mg_connection *conn) {
+  char *buffered;
+  int buffered_len, body_len;
+  if (conn->content_len <= 0) {
+    // Protect from negative Content-Length, too
+    body_len = 0;
+  } else if (conn->content_len < (int64_t) buffered_len) {
+    body_len = (int) conn->content_len;
+  } else {
+    body_len = buffered_len;
+  conn->data_len -= conn->request_len + body_len;
+  memmove(conn->buf, conn->buf + conn->request_len + body_len,
+          (size_t) conn->data_len);
+static int is_valid_uri(const char *uri) {
+  // Conform to http://www.w3.org/Protocols/rfc2616/rfc2616-sec5.html#sec5.1.2
+  // URI can be an asterisk (*) or should start with slash.
+  return uri[0] == '/' || (uri[0] == '*' && uri[1] == '\0');
+static void process_new_connection(struct mg_connection *conn) {
+  int keep_alive_enabled;
+  const char *cl;
+  keep_alive_enabled = !strcmp(conn->ctx->config[ENABLE_KEEP_ALIVE], "yes");
+  do {
+    reset_per_request_attributes(conn);
+    conn->request_len = read_request(NULL, conn->client.sock, conn->ssl,
+                                     conn->buf, conn->buf_size,
+                                     &conn->data_len);
+    assert(conn->data_len >= conn->request_len);
+    if (conn->request_len == 0 && conn->data_len == conn->buf_size) {
+      send_http_error(conn, 413, "Request Too Large", "");
+      return;
+    } if (conn->request_len <= 0) {
+      return;  // Remote end closed the connection
+    // Nul-terminate the request cause parse_http_request() uses sscanf
+    conn->buf[conn->request_len - 1] = '\0';
+    if (!parse_http_request(conn->buf, ri) || !is_valid_uri(ri->uri)) {
+      // Do not put garbage in the access log, just send it back to the client
+      send_http_error(conn, 400, "Bad Request",
+          "Cannot parse HTTP request: [%.*s]", conn->data_len, conn->buf);
+    } else if (strcmp(ri->http_version, "1.0") &&
+               strcmp(ri->http_version, "1.1")) {
+      // Request seems valid, but HTTP version is strange
+      send_http_error(conn, 505, "HTTP version not supported", "");
+      log_access(conn);
+    } else {
+      // Request is valid, handle it
+      cl = get_header(ri, "Content-Length");
+      conn->content_len = cl == NULL ? -1 : strtoll(cl, NULL, 10);
+      conn->birth_time = time(NULL);
+      handle_request(conn);
+      call_user(conn, MG_REQUEST_COMPLETE);
+      log_access(conn);
+      discard_current_request_from_buffer(conn);
+    if (ri->remote_user != NULL) {
+      free((void *) ri->remote_user);
+  } while (conn->ctx->stop_flag == 0 &&
+           keep_alive_enabled &&
+           should_keep_alive(conn));
+// Worker threads take accepted socket from the queue
+static int consume_socket(struct mg_context *ctx, struct socket *sp) {
+  (void) pthread_mutex_lock(&ctx->mutex);
+  DEBUG_TRACE(("going idle"));
+  // If the queue is empty, wait. We're idle at this point.
+  while (ctx->sq_head == ctx->sq_tail && ctx->stop_flag == 0) {
+    pthread_cond_wait(&ctx->sq_full, &ctx->mutex);
+  // If we're stopping, sq_head may be equal to sq_tail.
+  if (ctx->sq_head > ctx->sq_tail) {
+    // Copy socket from the queue and increment tail
+    *sp = ctx->queue[ctx->sq_tail % ARRAY_SIZE(ctx->queue)];
+    ctx->sq_tail++;
+    DEBUG_TRACE(("grabbed socket %d, going busy", sp->sock));
+    // Wrap pointers if needed
+    while (ctx->sq_tail > (int) ARRAY_SIZE(ctx->queue)) {
+      ctx->sq_tail -= ARRAY_SIZE(ctx->queue);
+      ctx->sq_head -= ARRAY_SIZE(ctx->queue);
+  (void) pthread_cond_signal(&ctx->sq_empty);
+  (void) pthread_mutex_unlock(&ctx->mutex);
+  return !ctx->stop_flag;
+static void worker_thread(struct mg_context *ctx) {
+  struct mg_connection *conn;
+  int buf_size = atoi(ctx->config[MAX_REQUEST_SIZE]);
+  conn = (struct mg_connection *) calloc(1, sizeof(*conn) + buf_size);
+  if (conn == NULL) {
+    cry(fc(ctx), "%s", "Cannot create new connection struct, OOM");
+    return;
+  conn->buf_size = buf_size;
+  conn->buf = (char *) (conn + 1);
+  // Call consume_socket() even when ctx->stop_flag > 0, to let it signal
+  // sq_empty condvar to wake up the master waiting in produce_socket()
+  while (consume_socket(ctx, &conn->client)) {
+    conn->ctx = ctx;
+    // Fill in IP, port info early so even if SSL setup below fails,
+    // error handler would have the corresponding info.
+    // Thanks to Johannes Winkelmann for the patch.
+    // TODO(lsm): Fix IPv6 case
+    conn->request_info.remote_port = ntohs(conn->client.rsa.sin.sin_port);
+    memcpy(&conn->request_info.remote_ip,
+           &conn->client.rsa.sin.sin_addr.s_addr, 4);
+    conn->request_info.remote_ip = ntohl(conn->request_info.remote_ip);
+    conn->request_info.is_ssl = conn->client.is_ssl;
+    if (!conn->client.is_ssl ||
+        (conn->client.is_ssl && sslize(conn, SSL_accept))) {
+      process_new_connection(conn);
+    close_connection(conn);
+  free(conn);
+  // Signal master that we're done with connection and exiting
+  ctx->num_threads--;
+  (void) pthread_cond_signal(&ctx->cond);
+  assert(ctx->num_threads >= 0);
+  DEBUG_TRACE(("exiting"));
+// Master thread adds accepted socket to a queue
+static void produce_socket(struct mg_context *ctx, const struct socket *sp) {
+  // If the queue is full, wait
+  while (ctx->stop_flag == 0 &&
+         ctx->sq_head - ctx->sq_tail >= (int) ARRAY_SIZE(ctx->queue)) {
+    (void) pthread_cond_wait(&ctx->sq_empty, &ctx->mutex);
+  if (ctx->sq_head - ctx->sq_tail < (int) ARRAY_SIZE(ctx->queue)) {
+    // Copy socket to the queue and increment head
+    ctx->queue[ctx->sq_head % ARRAY_SIZE(ctx->queue)] = *sp;
+    ctx->sq_head++;
+    DEBUG_TRACE(("queued socket %d", sp->sock));
+  (void) pthread_cond_signal(&ctx->sq_full);
+static void accept_new_connection(const struct socket *listener,
+                                  struct mg_context *ctx) {
+  struct socket accepted;
+  char src_addr[20];
+  socklen_t len;
+  int allowed;
+  len = sizeof(accepted.rsa);
+  accepted.lsa = listener->lsa;
+  accepted.sock = accept(listener->sock, &accepted.rsa.sa, &len);
+  if (accepted.sock != INVALID_SOCKET) {
+    allowed = check_acl(ctx, &accepted.rsa);
+    if (allowed) {
+      // Put accepted socket structure into the queue
+      DEBUG_TRACE(("accepted socket %d", accepted.sock));
+      accepted.is_ssl = listener->is_ssl;
+      produce_socket(ctx, &accepted);
+    } else {
+      sockaddr_to_string(src_addr, sizeof(src_addr), &accepted.rsa);
+      cry(fc(ctx), "%s: %s is not allowed to connect", __func__, src_addr);
+      (void) closesocket(accepted.sock);
+static void master_thread(struct mg_context *ctx) {
+  fd_set read_set;
+  struct timeval tv;
+  struct socket *sp;
+  int max_fd;
+  // Increase priority of the master thread
+#if defined(_WIN32)
+  SetThreadPriority(GetCurrentThread(), THREAD_PRIORITY_ABOVE_NORMAL);
+#endif
+#if defined(ISSUE_317)
+  struct sched_param sched_param;
+  sched_param.sched_priority = sched_get_priority_max(SCHED_RR);
+  pthread_setschedparam(pthread_self(), SCHED_RR, &sched_param);
+#endif
-	list = str;
-	while ((list = next_option(list, &key, &value)) != NULL)
-		if (key.len == 0 || value.len == 0) {
-			cry(fc(ctx), "Invalid list specified: [%s], "
-			    "expecting key1=value1,key2=value2,...", str);
-			return (FALSE);
+  while (ctx->stop_flag == 0) {
+    FD_ZERO(&read_set);
+    max_fd = -1;
-	return (TRUE);
+    // Add listening sockets to the read set
+    for (sp = ctx->listening_sockets; sp != NULL; sp = sp->next) {
+      add_to_set(sp->sock, &read_set, &max_fd);
-static const struct mg_option known_options[] = {
-	{"root", "\tWeb root directory", ".", OPT_ROOT, NULL},
-	{"index_files",	"Index files", "index.html,index.htm,index.cgi",
-		OPT_INDEX_FILES, NULL},
-	{"ssl_cert", "SSL certificate file", NULL,
-		OPT_SSL_CERTIFICATE, &set_ssl_option},
-	{"ports", "Listening ports", NULL,
-		OPT_PORTS, &set_ports_option},
-	{"dir_list", "Directory listing", "yes",
-		OPT_DIR_LIST, NULL},
-	{"protect", "URI to htpasswd mapping", NULL,
-		OPT_PROTECT, &set_kv_list_option},
-#if !defined(NO_CGI)
-	{"cgi_ext", "CGI extensions", ".cgi,.pl,.php",
-		OPT_CGI_EXTENSIONS, NULL},
-	{"cgi_interp", "CGI interpreter to use with all CGI scripts", NULL,
-		OPT_CGI_INTERPRETER, NULL},
-	{"cgi_env", "Custom CGI enviroment variables", NULL,
-		OPT_CGI_ENV, &set_kv_list_option},
-	{"ssi_ext", "SSI extensions", ".shtml,.shtm",
-		OPT_SSI_EXTENSIONS, NULL},
-	{"auth_realm", "Authentication domain name", "mydomain.com",
-		OPT_AUTH_DOMAIN, NULL},
-	{"auth_gpass", "Global passwords file", NULL,
-		OPT_AUTH_GPASSWD, &set_gpass_option},
-	{"auth_PUT", "PUT,DELETE auth file", NULL,
-		OPT_AUTH_PUT, NULL},
-#if !defined(_WIN32)
-	{"uid", "\tRun as user", NULL, OPT_UID, &set_uid_option},
-	{"access_log", "Access log file", NULL,
-		OPT_ACCESS_LOG, &set_alog_option},
-	{"error_log", "Error log file", NULL,
-		OPT_ERROR_LOG, &set_elog_option},
-	{"aliases", "Path=URI mappings", NULL,
-		OPT_ALIASES, &set_kv_list_option},
-	{"admin_uri", "Administration page URI", NULL,
-		OPT_ADMIN_URI, &set_admin_uri_option},
-	{"acl", "\tAllow/deny IP addresses/subnets", NULL,
-		OPT_ACL, &set_acl_option},
-	{"max_threads", "Maximum simultaneous threads to spawn", "100",
-		OPT_MAX_THREADS, &set_max_threads_option},
-	{"idle_time", "Time in seconds connection stays idle", "10",
-		OPT_IDLE_TIME, NULL},
-	{"mime_types", "Comma separated list of ext=mime_type pairs", NULL,
-		OPT_MIME_TYPES, &set_kv_list_option},
-	{NULL, NULL, NULL, 0, NULL}
+    tv.tv_sec = 0;
+    tv.tv_usec = 200 * 1000;
-static const struct mg_option *
-find_opt(const char *opt_name)
-	int	i;
-	for (i = 0; known_options[i].name != NULL; i++)
-		if (!strcmp(opt_name, known_options[i].name))
-			return (known_options + i);
-	return (NULL);
-int
-mg_set_option(struct mg_context *ctx, const char *opt, const char *val)
-	const struct mg_option	*option;
-	int			i, retval;
-	DEBUG_TRACE((DEBUG_MGS_PREFIX "%s: [%s]->[%s]", __func__, opt, val));
-	if (opt != NULL && (option = find_opt(opt)) != NULL) {
-		i = (int) (option - known_options);
-		lock_option(ctx, i);
-		if (option->setter != NULL)
-			retval = option->setter(ctx, val);
-		else
-			retval = TRUE;
-		/* Free old value if any */
-		if (ctx->options[option->index] != NULL)
-			free(ctx->options[option->index]);
-		/* Set new option value */
-		ctx->options[option->index] = val ? mg_strdup(val) : NULL;
-		unlock_option(ctx, i);
-		if (retval == FALSE)
-			cry(fc(ctx), "%s(%s): failure", __func__, opt);
-	} else {
-		cry(fc(ctx), "%s: No such option: [%s]", __func__, opt);
-		retval = -1;
-	return (retval);
-void
-mg_show_usage_string(FILE *fp)
-	const struct mg_option	*o;
-	(void) fprintf(stderr,
-	    "Mongoose version %s (c) Sergey Lyubka\n"
-	    "usage: mongoose [options] [config_file]\n", mg_version());
-	fprintf(fp, "  -A <htpasswd_file> <realm> <user> <passwd>\n");
-	for (o = known_options; o->name != NULL; o++) {
-		(void) fprintf(fp, "  -%s\t%s", o->name, o->description);
-		if (o->default_value != NULL)
-			fprintf(fp, " (default: \"%s\")", o->default_value);
-		fputc('\n', fp);
-const char *
-mg_get_option(const struct mg_context *ctx, const char *option_name)
-	if ((option = find_opt(option_name)) != NULL)
-		return (ctx->options[option->index]);
-	else
-		return (NULL);
-static void
-admin_page(struct mg_connection *conn, const struct mg_request_info *ri,
-			   void *user_data)
-	const char		*option_name, *option_value;
-	user_data = NULL; /* Unused */
-	"HTTP/1.1 200 OK\r\n"
-			"Content-Type: text/html\r\n\r\n"
-			"<html><body><h1>Mongoose v. %s</h1>", mg_version());
-	if (!strcmp(ri->request_method, "POST")) {
-		option_name = mg_get_var(conn, "o");
-		option_value = mg_get_var(conn, "v");
-		if (mg_set_option(conn->ctx,
-		    option_name, option_value) == -1) {
-			    "<p style=\"background: red\">Error setting "
-			    "option \"%s\"</p>",
-			    option_name ? option_name : "(null)");
-		} else {
-			    "<p style=\"color: green\">Saved: %s=%s</p>",
-			    option_name, option_value ? option_value : "NULL");
-	/* Print table with all options */
-	(void) mg_printf(conn, "%s", "<table border=\"1\""
-			"<tr><th>Option</th><th>Description</th>"
-					"<th colspan=2>Value</th></tr>");
-	for (option = known_options; option->name != NULL; option++) {
-		option_value = mg_get_option(conn->ctx, option->name);
-		if (option_value == NULL)
-			option_value = "";
-		    "<form method=post><tr><td>%s</td><td>%s</td>"
-		    "<input type=hidden name=o value='%s'>"
-		    "<td><input type=text name=v value='%s'></td>"
-		    "<td><input type=submit value=save></td></form></tr>",
-		    option->name, option->description,
-		    option->name, option_value);
-	(void) mg_printf(conn, "%s", "</table></body></html>");
-static void
-reset_per_request_attributes(struct mg_connection *conn)
-	if (conn->request_info.remote_user != NULL) {
-		free((void *) conn->request_info.remote_user);
-		conn->request_info.remote_user = NULL;
-	if (conn->free_post_data && conn->request_info.post_data != NULL) {
-		free((void *) conn->request_info.post_data);
-		conn->request_info.post_data = NULL;
-static void
-close_socket_gracefully(struct mg_connection *conn, SOCKET sock)
-	char	buf[BUFSIZ];
-	int	n;
-	/* Send FIN to the client */
-	(void) shutdown(sock, SHUT_WR);
-	set_non_blocking_mode(conn, sock);
-	 * Read and discard pending data. If we do not do that and close the
-	 * socket, the data in the send buffer may be discarded. This
-	 * behaviour is seen on Windows, when client keeps sending data
-	 * when server decide to close the connection; then when client
-	 * does recv() it gets no data back.
-	do {
-		n = pull(NULL, sock, NULL, buf, sizeof(buf));
-	} while (n > 0);
-	/* Now we know that our FIN is ACK-ed, safe to close */
-static void
-close_connection(struct mg_connection *conn)
-	reset_per_request_attributes(conn);
-	if (conn->ssl)
-		SSL_free(conn->ssl);
-	if (conn->client.sock != INVALID_SOCKET)
-		close_socket_gracefully(conn, conn->client.sock);
-static void
-reset_connection_attributes(struct mg_connection *conn)
-	conn->free_post_data = FALSE;
-	conn->request_info.status_code = -1;
-	conn->num_bytes_sent = 0;
-	(void) memset(&conn->request_info, 0, sizeof(conn->request_info));
-static void
-shift_to_next(struct mg_connection *conn, char *buf, int req_len, int *nread)
-	int64_t	cl;
-	int	over_len, body_len;
-	cl = get_content_length(conn);
-	over_len = *nread - req_len;
-	assert(over_len >= 0);
-	if (cl == -1) {
-		body_len = 0;
-	} else if (cl < (int64_t) over_len) {
-		body_len = (int) cl;
-	} else {
-		body_len = over_len;
-	*nread -= req_len + body_len;
-	(void) memmove(buf, buf + req_len + body_len, *nread);
-static void
-process_new_connection(struct mg_connection *conn)
-	struct mg_request_info *ri = &conn->request_info;
-	char	buf[MAX_REQUEST_SIZE];
-	int	request_len, nread;
-	nread = 0;
-	reset_connection_attributes(conn);
-	/* If next request is not pipelined, read it in */
-	if ((request_len = get_request_len(buf, (size_t) nread)) == 0)
-		request_len = read_request(NULL, conn->client.sock,
-		    conn->ssl, buf, sizeof(buf), &nread);
-	assert(nread >= request_len);
-	if (request_len <= 0)
-		return;	/* Remote end closed the connection */
-	/* 0-terminate the request: parse_request uses sscanf */
-	buf[request_len - 1] = '\0';
-	if (parse_http_request(buf, ri, &conn->client.rsa)) {
-		if (strcmp(ri->http_version, "1.0") != 0 &&
-		    strcmp(ri->http_version, "1.1") != 0) {
-			send_error(conn, 505,
-			    "HTTP version not supported",
-			    "%s", "Weird HTTP version");
-			log_access(conn);
-		} else {
-			ri->post_data = buf + request_len;
-			ri->post_data_len = nread - request_len;
-			conn->birth_time = time(NULL);
-			analyze_request(conn);
-			log_access(conn);
-			shift_to_next(conn, buf, request_len, &nread);
-	} else {
-		/* Do not put garbage in the access log */
-		send_error(conn, 400, "Bad Request",
-		    "Can not parse request: [%.*s]", nread, buf);
- * Worker threads take accepted socket from the queue
-static bool_t
-get_socket(struct mg_context *ctx, struct socket *sp)
-	struct timespec	ts;
-	DEBUG_TRACE((DEBUG_MGS_PREFIX "%s: thread %p: going idle",
-	    __func__, (void *) pthread_self()));
-	/* If the queue is empty, wait. We're idle at this point. */
-	ctx->num_idle++;
-	while (ctx->sq_head == ctx->sq_tail) {
-		ts.tv_nsec = 0;
-		ts.tv_sec = time(NULL) + atoi(ctx->options[OPT_IDLE_TIME]) + 1;
-		if (pthread_cond_timedwait(&ctx->empty_cond,
-		    &ctx->thr_mutex, &ts) != 0) {
-			/* Timeout! release the mutex and return */
-			return (FALSE);
-	assert(ctx->sq_head > ctx->sq_tail);
-	/* We're going busy now: got a socket to process! */
-	ctx->num_idle--;
-	/* Copy socket from the queue and increment tail */
-	*sp = ctx->queue[ctx->sq_tail % ARRAY_SIZE(ctx->queue)];
-	ctx->sq_tail++;
-	    "%s: thread %p grabbed socket %d, going busy",
-	    __func__, (void *) pthread_self(), sp->sock));
-	/* Wrap pointers if needed */
-	while (ctx->sq_tail > (int) ARRAY_SIZE(ctx->queue)) {
-		ctx->sq_tail -= ARRAY_SIZE(ctx->queue);
-		ctx->sq_head -= ARRAY_SIZE(ctx->queue);
-	pthread_cond_signal(&ctx->full_cond);
-	return (TRUE);
-static void
-worker_thread(struct mg_context *ctx)
-	struct mg_connection	conn;
-	DEBUG_TRACE((DEBUG_MGS_PREFIX "%s: thread %p starting",
-	(void) memset(&conn, 0, sizeof(conn));
-	while (get_socket(ctx, &conn.client) == TRUE) {
-		conn.birth_time = time(NULL);
-		conn.ctx = ctx;
-		if (conn.client.is_ssl &&
-		    (conn.ssl = SSL_new(conn.ctx->ssl_ctx)) == NULL) {
-			cry(&conn, "%s: SSL_new: %d", __func__, ERRNO);
-		} else if (conn.client.is_ssl &&
-		    SSL_set_fd(conn.ssl, conn.client.sock) != 1) {
-			cry(&conn, "%s: SSL_set_fd: %d", __func__, ERRNO);
-		} else if (conn.client.is_ssl && SSL_accept(conn.ssl) != 1) {
-			cry(&conn, "%s: SSL handshake error", __func__);
-		} else {
-			process_new_connection(&conn);
-		close_connection(&conn);
-	/* Signal master that we're done with connection and exiting */
-	pthread_mutex_lock(&ctx->thr_mutex);
-	ctx->num_threads--;
-	ctx->num_idle--;
-	pthread_cond_signal(&ctx->thr_cond);
-	assert(ctx->num_threads >= 0);
-	pthread_mutex_unlock(&ctx->thr_mutex);
-	DEBUG_TRACE((DEBUG_MGS_PREFIX "%s: thread %p exiting",
- * Master thread adds accepted socket to a queue
-static void
-put_socket(struct mg_context *ctx, const struct socket *sp)
-	/* If the queue is full, wait */
-	while (ctx->sq_head - ctx->sq_tail >= (int) ARRAY_SIZE(ctx->queue))
-		(void) pthread_cond_wait(&ctx->full_cond, &ctx->thr_mutex);
-	assert(ctx->sq_head - ctx->sq_tail < (int) ARRAY_SIZE(ctx->queue));
-	/* Copy socket to the queue and increment head */
-	ctx->queue[ctx->sq_head % ARRAY_SIZE(ctx->queue)] = *sp;
-	ctx->sq_head++;
-	DEBUG_TRACE((DEBUG_MGS_PREFIX "%s: queued socket %d",
-	    __func__, sp->sock));
-	/* If there are no idle threads, start one */
-	if (ctx->num_idle == 0 && ctx->num_threads < ctx->max_threads) {
-		if (start_thread(ctx,
-		    (mg_thread_func_t) worker_thread, ctx) != 0)
-			cry(fc(ctx), "Cannot start thread: %d", ERRNO);
-		else
-			ctx->num_threads++;
-	pthread_cond_signal(&ctx->empty_cond);
-static void
-accept_new_connection(const struct socket *listener, struct mg_context *ctx)
-	struct socket	accepted;
-	accepted.rsa.len = sizeof(accepted.rsa.u.sin);
-	accepted.lsa = listener->lsa;
-	if ((accepted.sock = accept(listener->sock,
-	    &accepted.rsa.u.sa, &accepted.rsa.len)) == INVALID_SOCKET)
-		return;
-	lock_option(ctx, OPT_ACL);
-	if (ctx->options[OPT_ACL] != NULL &&
-	    !check_acl(ctx, ctx->options[OPT_ACL], &accepted.rsa)) {
-		cry(fc(ctx), "%s: %s is not allowed to connect",
-		    __func__, inet_ntoa(accepted.rsa.u.sin.sin_addr));
-		(void) closesocket(accepted.sock);
-		unlock_option(ctx, OPT_ACL);
-		return;
-	/* Put accepted socket structure into the queue */
-	DEBUG_TRACE((DEBUG_MGS_PREFIX "%s: accepted socket %d",
-	    __func__, accepted.sock));
-	accepted.is_ssl = listener->is_ssl;
-	put_socket(ctx, &accepted);
-static void
-master_thread(struct mg_context *ctx)
-	fd_set		read_set;
-	struct timeval	tv;
-	int		i, max_fd;
-	while (ctx->stop_flag == 0) {
-		FD_ZERO(&read_set);
-		max_fd = -1;
-		/* Add listening sockets to the read set */
-		lock_option(ctx, OPT_PORTS);
-			add_to_set(ctx->listeners[i].sock, &read_set, &max_fd);
-		unlock_option(ctx, OPT_PORTS);
-		tv.tv_sec = 1;
-		tv.tv_usec = 0;
-		if (select(max_fd + 1, &read_set, NULL, NULL, &tv) < 0) {
+    if (select(max_fd + 1, &read_set, NULL, NULL, &tv) < 0) {
 #ifdef _WIN32
-			 * On windows, if read_set and write_set are empty,
-			 * select() returns "Invalid parameter" error
-			 * (at least on my Windows XP Pro). So in this case,
-			 * we sleep here.
-			sleep(1);
-#endif /* _WIN32 */
-		} else {
-				if (FD_ISSET(ctx->listeners[i].sock, &read_set))
-					accept_new_connection(
-					    ctx->listeners + i, ctx);
-	/* Stop signal received: somebody called mg_stop. Quit. */
-	mg_fini(ctx);
-void
-mg_stop(struct mg_context *ctx)
-	ctx->stop_flag = 1;
-	/* Wait until mg_fini() stops */
-	while (ctx->stop_flag != 2)
-		(void) sleep(1);
-	assert(ctx->num_threads == 0);
-	free(ctx);
-#if defined(_WIN32)
-	(void) WSACleanup();
-struct mg_context *
-mg_start(void)
-	struct mg_context	*ctx;
-	int			i;
+      // On windows, if read_set and write_set are empty,
+      // select() returns "Invalid parameter" error
+      // (at least on my Windows XP Pro). So in this case, we sleep here.
+      mg_sleep(1000);
+#endif // _WIN32
+    } else {
+        if (ctx->stop_flag == 0 && FD_ISSET(sp->sock, &read_set)) {
+          accept_new_connection(sp, ctx);
+  DEBUG_TRACE(("stopping workers"));
+  // Stop signal received: somebody called mg_stop. Quit.
+  // Wakeup workers that are waiting for connections to handle.
+  pthread_cond_broadcast(&ctx->sq_full);
+  // Wait until all threads finish
+  while (ctx->num_threads > 0) {
+    (void) pthread_cond_wait(&ctx->cond, &ctx->mutex);
+  // All threads exited, no sync is needed. Destroy mutex and condvars
+  (void) pthread_mutex_destroy(&ctx->mutex);
+  (void) pthread_cond_destroy(&ctx->cond);
+  (void) pthread_cond_destroy(&ctx->sq_empty);
+  (void) pthread_cond_destroy(&ctx->sq_full);
-	WSADATA data;
-	WSAStartup(MAKEWORD(2,2), &data);
-	if ((ctx = (struct mg_context *) calloc(1, sizeof(*ctx))) == NULL) {
-		cry(fc(ctx), "cannot allocate mongoose context");
-		return (NULL);
-	ctx->error_log = stderr;
-	mg_set_log_callback(ctx, builtin_error_log);
-	/* Initialize options. First pass: set default option values */
-		ctx->options[option->index] = option->default_value == NULL ?
-			NULL : mg_strdup(option->default_value);
-	/* Call setter functions */
-		if (option->setter != NULL &&
-		    ctx->options[option->index] != NULL)
-			if (option->setter(ctx,
-			    ctx->options[option->index]) == FALSE) {
-				mg_fini(ctx);
-				return (NULL);
-	DEBUG_TRACE((DEBUG_MGS_PREFIX "%s: root [%s]",
-	    __func__, ctx->options[OPT_ROOT]));
+  uninitialize_ssl(ctx);
+#endif
+  // Signal mg_stop() that we're done
+  ctx->stop_flag = 2;
+static void free_context(struct mg_context *ctx) {
+  int i;
+  // Deallocate config parameters
+  for (i = 0; i < NUM_OPTIONS; i++) {
+    if (ctx->config[i] != NULL)
+      free(ctx->config[i]);
+  // Deallocate SSL context
+    SSL_CTX_free(ctx->ssl_ctx);
+#ifndef NO_SSL
+  if (ssl_mutexes != NULL) {
+    free(ssl_mutexes);
+#endif // !NO_SSL
+  // Deallocate context itself
+  free(ctx);
+void mg_stop(struct mg_context *ctx) {
+  ctx->stop_flag = 1;
+  // Wait until mg_fini() stops
+  while (ctx->stop_flag != 2) {
+    mg_sleep(10);
+  free_context(ctx);
+#if defined(_WIN32) && !defined(__SYMBIAN32__)
+  (void) WSACleanup();
+#endif // _WIN32
+struct mg_context *mg_start(mg_callback_t user_callback, void *user_data,
+                            const char **options) {
+  struct mg_context *ctx;
+  const char *name, *value, *default_value;
+  int i;
+  WSADATA data;
+  WSAStartup(MAKEWORD(2,2), &data);
+  InitializeCriticalSection(&global_log_file_lock);
+#endif // _WIN32
+  // Allocate context and initialize reasonable general case defaults.
+  // TODO(lsm): do proper error handling here.
+  ctx = (struct mg_context *) calloc(1, sizeof(*ctx));
+  ctx->user_callback = user_callback;
+  ctx->user_data = user_data;
+  while (options && (name = *options++) != NULL) {
+    if ((i = get_option_index(name)) == -1) {
+      cry(fc(ctx), "Invalid option: %s", name);
+      return NULL;
+    } else if ((value = *options++) == NULL) {
+      cry(fc(ctx), "%s: option value cannot be NULL", name);
+      return NULL;
+    if (ctx->config[i] != NULL) {
+      cry(fc(ctx), "%s: duplicate option", name);
+    ctx->config[i] = mg_strdup(value);
+    DEBUG_TRACE(("[%s] -> [%s]", name, value));
+  // Set default value if needed
+  for (i = 0; config_options[i * ENTRIES_PER_CONFIG_OPTION] != NULL; i++) {
+    default_value = config_options[i * ENTRIES_PER_CONFIG_OPTION + 2];
+    if (ctx->config[i] == NULL && default_value != NULL) {
+      ctx->config[i] = mg_strdup(default_value);
+      DEBUG_TRACE(("Setting default: [%s] -> [%s]",
+                   config_options[i * ENTRIES_PER_CONFIG_OPTION + 1],
+                   default_value));
+  // NOTE(lsm): order is important here. SSL certificates must
+  // be initialized before listening ports. UID must be set last.
+  if (!set_gpass_option(ctx) ||
+      !set_ssl_option(ctx) ||
+#endif
+      !set_ports_option(ctx) ||
-	 * Ignore SIGPIPE signal, so if browser cancels the request, it
-	 * won't kill the whole process.
-	(void) signal(SIGPIPE, SIG_IGN);
-	/* Initialize options mutexes */
-		(void) pthread_mutex_init(&ctx->opt_mutex[i], NULL);
-	(void) pthread_mutex_init(&ctx->thr_mutex, NULL);
-	(void) pthread_mutex_init(&ctx->bind_mutex, NULL);
-	(void) pthread_cond_init(&ctx->thr_cond, NULL);
-	(void) pthread_cond_init(&ctx->empty_cond, NULL);
-	(void) pthread_cond_init(&ctx->full_cond, NULL);
-	/* Start master (listening) thread */
-	start_thread(ctx, (mg_thread_func_t) master_thread, ctx);
-	return (ctx);
+      !set_uid_option(ctx) ||
+#endif
+      !set_acl_option(ctx)) {
+    return NULL;
+#if !defined(_WIN32) && !defined(__SYMBIAN32__)
+  // Ignore SIGPIPE signal, so if browser cancels the request, it
+  // won't kill the whole process.
+  (void) signal(SIGPIPE, SIG_IGN);
+  // Also ignoring SIGCHLD to let the OS to reap zombies properly.
+  (void) signal(SIGCHLD, SIG_IGN);
+#endif // !_WIN32
+  (void) pthread_mutex_init(&ctx->mutex, NULL);
+  (void) pthread_cond_init(&ctx->cond, NULL);
+  (void) pthread_cond_init(&ctx->sq_empty, NULL);
+  (void) pthread_cond_init(&ctx->sq_full, NULL);
+  // Start master (listening) thread
+  start_thread(ctx, (mg_thread_func_t) master_thread, ctx);
+  // Start worker threads
+  for (i = 0; i < atoi(ctx->config[NUM_THREADS]); i++) {
+    if (start_thread(ctx, (mg_thread_func_t) worker_thread, ctx) != 0) {
+      cry(fc(ctx), "Cannot start worker thread: %d", ERRNO);
+    } else {
+      ctx->num_threads++;
+  return ctx;
diff --git a/cpukit/mghttpd/mongoose.h b/cpukit/mghttpd/mongoose.h
index 5a71e60..61a560a 100644
--- a/cpukit/mghttpd/mongoose.h
+++ b/cpukit/mghttpd/mongoose.h
@@ -1,251 +1,238 @@
- * Copyright (c) 2004-2009 Sergey Lyubka
- * Permission is hereby granted, free of charge, to any person obtaining a copy
- * of this software and associated documentation files (the "Software"), to deal
- * in the Software without restriction, including without limitation the rights
- * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
- * copies of the Software, and to permit persons to whom the Software is
- * furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in
- * all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
- * THE SOFTWARE.
+// Copyright (c) 2004-2011 Sergey Lyubka
+// Permission is hereby granted, free of charge, to any person obtaining a copy
+// of this software and associated documentation files (the "Software"), to deal
+// in the Software without restriction, including without limitation the rights
+// to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
+// copies of the Software, and to permit persons to whom the Software is
+// furnished to do so, subject to the following conditions:
+// The above copyright notice and this permission notice shall be included in
+// all copies or substantial portions of the Software.
+// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+// IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+// FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+// AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+// LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+// OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
+// THE SOFTWARE.
 #ifndef MONGOOSE_HEADER_INCLUDED
-#define	MONGOOSE_HEADER_INCLUDED
+#define  MONGOOSE_HEADER_INCLUDED
+#include <stddef.h>
 #ifdef __cplusplus
 extern "C" {
-#endif /* __cplusplus */
+#endif // __cplusplus
-struct mg_context;	/* Handle for the HTTP service itself	*/
-struct mg_connection;	/* Handle for the individual connection	*/
+struct mg_context;     // Handle for the HTTP service itself
+struct mg_connection;  // Handle for the individual connection
- * This structure contains full information about the HTTP request.
- * It is passed to the user-specified callback function as a parameter.
+// This structure contains information about the HTTP request.
 struct mg_request_info {
-	char	*request_method;	/* "GET", "POST", etc	*/
-	char	*uri;			/* Normalized URI	*/
-	char	*http_version;		/* E.g. "1.0", "1.1"	*/
-	char	*query_string;		/* \0 - terminated	*/
-	char	*post_data;		/* POST data buffer	*/
-	char	*remote_user;		/* Authenticated user	*/
-	long	remote_ip;		/* Client's IP address	*/
-	int	remote_port;		/* Client's port	*/
-	int	post_data_len;		/* POST buffer length	*/
-	int	status_code;		/* HTTP status code	*/
-	int	num_headers;		/* Number of headers	*/
-	struct mg_header {
-		char	*name;		/* HTTP header name	*/
-		char	*value;		/* HTTP header value	*/
-	} http_headers[64];		/* Maximum 64 headers	*/
+  void *user_data;       // User-defined pointer passed to mg_start()
+  char *request_method;  // "GET", "POST", etc
+  char *uri;             // URL-decoded URI
+  char *http_version;    // E.g. "1.0", "1.1"
+  char *query_string;    // URL part after '?' (not including '?') or NULL
+  char *remote_user;     // Authenticated user, or NULL if no auth used
+  char *log_message;     // Mongoose error log message, MG_EVENT_LOG only
+  long remote_ip;        // Client's IP address
+  int remote_port;       // Client's port
+  int status_code;       // HTTP reply status code, e.g. 200
+  int is_ssl;            // 1 if SSL-ed, 0 if not
+  int num_headers;       // Number of headers
+  struct mg_header {
+    char *name;          // HTTP header name
+    char *value;         // HTTP header value
+  } http_headers[64];    // Maximum 64 headers
+// Various events on which user-defined function is called by Mongoose.
+enum mg_event {
+  MG_NEW_REQUEST,   // New HTTP request has arrived from the client
+  MG_HTTP_ERROR,    // HTTP error must be returned to the client
+  MG_EVENT_LOG,     // Mongoose logs an event, request_info.log_message
+  MG_INIT_SSL,      // Mongoose initializes SSL. Instead of mg_connection *,
+                    // SSL context is passed to the callback function.
+  MG_REQUEST_COMPLETE  // Mongoose has finished handling the request
- * User-defined callback function prototype for URI handling, error handling,
- * or logging server messages.
-typedef void (*mg_callback_t)(struct mg_connection *,
-		const struct mg_request_info *info, void *user_data);
- * Start the web server.
- * This must be the first function called by the application.
- * It creates a serving thread, and returns a context structure that
- * can be used to alter the configuration, and stop the server.
-struct mg_context *mg_start(void);
- * Stop the web server.
- * Must be called last, when an application wants to stop the web server and
- * release all associated resources. This function blocks until all Mongoose
- * threads are stopped. Context pointer becomes invalid.
+// Prototype for the user-defined function. Mongoose calls this function
+// on every MG_* event.
+// Parameters:
+//   event: which event has been triggered.
+//   conn: opaque connection handler. Could be used to read, write data to the
+//         client, etc. See functions below that have "mg_connection *" arg.
+//   request_info: Information about HTTP request.
+// Return:
+//   If handler returns non-NULL, that means that handler has processed the
+//   request by sending appropriate HTTP reply to the client. Mongoose treats
+//   the request as served.
+//   If handler returns NULL, that means that handler has not processed
+//   the request. Handler must not send any data to the client in this case.
+//   Mongoose proceeds with request handling as if nothing happened.
+typedef void * (*mg_callback_t)(enum mg_event event,
+                                struct mg_connection *conn,
+                                const struct mg_request_info *request_info);
+// Start web server.
+// Parameters:
+//   callback: user defined event handling function or NULL.
+//   options: NULL terminated list of option_name, option_value pairs that
+//            specify Mongoose configuration parameters.
+// Side-effects: on UNIX, ignores SIGCHLD and SIGPIPE signals. If custom
+//    processing is required for these, signal handlers must be set up
+//    after calling mg_start().
+// Example:
+//   const char *options[] = {
+//     "document_root", "/var/www",
+//     "listening_ports", "80,443s",
+//     NULL
+//   struct mg_context *ctx = mg_start(&my_func, NULL, options);
+// Please refer to http://code.google.com/p/mongoose/wiki/MongooseManual
+// for the list of valid option and their possible values.
+// Return:
+//   web server context, or NULL on error.
+struct mg_context *mg_start(mg_callback_t callback, void *user_data,
+                            const char **options);
+// Stop the web server.
+// Must be called last, when an application wants to stop the web server and
+// release all associated resources. This function blocks until all Mongoose
+// threads are stopped. Context pointer becomes invalid.
 void mg_stop(struct mg_context *);
- * Return current value of a particular option.
-const char *mg_get_option(const struct mg_context *, const char *option_name);
- * Set a value for a particular option.
- * Mongoose makes an internal copy of the option value string, which must be
- * valid nul-terminated ASCII or UTF-8 string. It is safe to change any option
- * at any time. The order of setting various options is also irrelevant with
- * one exception: if "ports" option contains SSL listening ports, a "ssl_cert"
- * option must be set BEFORE the "ports" option.
- * Return value:
- *	-1 if option is unknown
- *	0  if mg_set_option() failed
- *	1  if mg_set_option() succeeded
-int mg_set_option(struct mg_context *, const char *opt_name, const char *value);
- * Add, edit or delete the entry in the passwords file.
- * This function allows an application to manipulate .htpasswd files on the
- * fly by adding, deleting and changing user records. This is one of the two
- * ways of implementing authentication on the server side. For another,
- * cookie-based way please refer to the examples/authentication.c in the
- * source tree.
- * If password is not NULL, entry is added (or modified if already exists).
- * If password is NULL, entry is deleted. Return:
- *	1 on success
- *	0 on error
-int mg_modify_passwords_file(struct mg_context *ctx, const char *file_name,
-		const char *user_name, const char *password);
- * Register URI handler.
- * It is possible to handle many URIs if using * in the uri_regex, which
- * matches zero or more characters. user_data pointer will be passed to the
- * handler as a third parameter. If func is NULL, then the previously installed
- * handler for this uri_regex is removed.
-void mg_set_uri_callback(struct mg_context *ctx, const char *uri_regex,
-		mg_callback_t func, void *user_data);
- * Register HTTP error handler.
- * An application may use that function if it wants to customize the error
- * page that user gets on the browser (for example, 404 File Not Found message).
- * It is possible to specify a error handler for all errors by passing 0 as
- * error_code. That '0' error handler must be set last, if more specific error
- * handlers are also used. The actual error code value can be taken from
- * the request info structure that is passed to the callback.
-void mg_set_error_callback(struct mg_context *ctx, int error_code,
- * Register authorization handler.
- * This function provides a mechanism to implement custom authorization,
- * for example cookie based (look at examples/authorization.c).
- * The callback function must analyze the request, and make its own judgement
- * on wether it should be authorized or not. After the decision is made, a
- * callback must call mg_authorize() if the request is authorized.
-void mg_set_auth_callback(struct mg_context *ctx, const char *uri_regex,
- * Register log handler.
- * By default, Mongoose logs all error messages to stderr. If "error_log"
- * option is specified, the errors are written in the specified file. However,
- * if an application registers its own log handler, Mongoose will not log
- * anything but call the handler function, passing an error message as
- * "user_data" callback argument.
-void mg_set_log_callback(struct mg_context *ctx, mg_callback_t func);
- * Register SSL password handler.
- * This is needed only if SSL certificate asks for a password. Instead of
- * prompting for a password on a console a specified function will be called.
-typedef int (*mg_spcb_t)(char *buf, int num, int w, void *key);
-void mg_set_ssl_password_callback(struct mg_context *ctx, mg_spcb_t func);
- * Send data to the browser.
- * Return number of bytes sent. If the number of bytes sent is less then
- * requested or equals to -1, network error occured, usually meaning the
- * remote side has closed the connection.
-int mg_write(struct mg_connection *, const void *buf, int len);
- * Send data to the browser using printf() semantics.
- * Works exactly like mg_write(), but allows to do message formatting.
- * Note that mg_printf() uses internal buffer of size MAX_REQUEST_SIZE
- * (8 Kb by default) as temporary message storage for formatting. Do not
- * print data that is bigger than that, otherwise it will be truncated.
-int mg_printf(struct mg_connection *, const char *fmt, ...);
- * Read data from the remote or local end.
-int mg_read(struct mg_connection *, int local, void *buf, int len);
- * Get the value of particular HTTP header.
- * This is a helper function. It traverses request_info->http_headers array,
- * and if the header is present in the array, returns its value. If it is
- * not present, NULL is returned.
-const char *mg_get_header(const struct mg_connection *, const char *hdr_name);
- * Authorize the request.
- * See the documentation for mg_set_auth_callback() function.
-void mg_authorize(struct mg_connection *);
- * Get a value of particular form variable.
- * Both query string (whatever comes after '?' in the URL) and a POST buffer
- * are scanned. If a variable is specified in both query string and POST
- * buffer, POST buffer wins. Return value:
- *	NULL      if the variable is not found
- *	non-NULL  if found. NOTE: this returned value is dynamically allocated
- *		  and is subject to mg_free() when no longer needed. It is
- *		  an application's responsibility to mg_free() the variable.
-char *mg_get_var(const struct mg_connection *, const char *var_name);
- * Free up memory returned by mg_get_var().
-void mg_free(char *var);
- * Return Mongoose version.
+// Get the value of particular configuration parameter.
+// The value returned is read-only. Mongoose does not allow changing
+// configuration at run time.
+// If given parameter name is not valid, NULL is returned. For valid
+// names, return value is guaranteed to be non-NULL. If parameter is not
+// set, zero-length string is returned.
+const char *mg_get_option(const struct mg_context *ctx, const char *name);
+// Return array of strings that represent valid configuration options.
+// For each option, a short name, long name, and default value is returned.
+// Array is NULL terminated.
+const char **mg_get_valid_option_names(void);
+// Add, edit or delete the entry in the passwords file.
+// This function allows an application to manipulate .htpasswd files on the
+// fly by adding, deleting and changing user records. This is one of the
+// several ways of implementing authentication on the server side. For another,
+// cookie-based way please refer to the examples/chat.c in the source tree.
+// If password is not NULL, entry is added (or modified if already exists).
+// If password is NULL, entry is deleted.
+// Return:
+//   1 on success, 0 on error.
+int mg_modify_passwords_file(const char *passwords_file_name,
+                             const char *domain,
+                             const char *user,
+                             const char *password);
+// Send data to the client.
+int mg_write(struct mg_connection *, const void *buf, size_t len);
+// Send data to the browser using printf() semantics.
+// Works exactly like mg_write(), but allows to do message formatting.
+// Note that mg_printf() uses internal buffer of size IO_BUF_SIZE
+// (8 Kb by default) as temporary message storage for formatting. Do not
+// print data that is bigger than that, otherwise it will be truncated.
+int mg_printf(struct mg_connection *, const char *fmt, ...)
+#ifdef __GNUC__
+__attribute__((format(printf, 2, 3)))
+#endif
+// Send contents of the entire file together with HTTP headers.
+void mg_send_file(struct mg_connection *conn, const char *path);
+// Read data from the remote end, return number of bytes read.
+int mg_read(struct mg_connection *, void *buf, size_t len);
+// Get the value of particular HTTP header.
+// This is a helper function. It traverses request_info->http_headers array,
+// and if the header is present in the array, returns its value. If it is
+// not present, NULL is returned.
+const char *mg_get_header(const struct mg_connection *, const char *name);
+// Get a value of particular form variable.
+// Parameters:
+//   data: pointer to form-uri-encoded buffer. This could be either POST data,
+//         or request_info.query_string.
+//   data_len: length of the encoded data.
+//   var_name: variable name to decode from the buffer
+//   buf: destination buffer for the decoded variable
+//   buf_len: length of the destination buffer
+// Return:
+//   On success, length of the decoded variable.
+//   On error, -1 (variable not found, or destination buffer is too small).
+// Destination buffer is guaranteed to be '\0' - terminated. In case of
+// failure, dst[0] == '\0'.
+int mg_get_var(const char *data, size_t data_len,
+               const char *var_name, char *buf, size_t buf_len);
+// Fetch value of certain cookie variable into the destination buffer.
+// failure, dst[0] == '\0'. Note that RFC allows many occurrences of the same
+// parameter. This function returns only first occurrence.
+// Return:
+//   On success, value length.
+//   On error, 0 (either "Cookie:" header is not present at all, or the
+//   requested parameter is not found, or destination buffer is too small
+//   to hold the value).
+int mg_get_cookie(const struct mg_connection *,
+                  const char *cookie_name, char *buf, size_t buf_len);
+// Return Mongoose version.
 const char *mg_version(void);
- * Print command line usage string.
-void mg_show_usage_string(FILE *fp);
+// MD5 hash given strings.
+// Buffer 'buf' must be 33 bytes long. Varargs is a NULL terminated list of
+// asciiz strings. When function returns, buf will contain human-readable
+// MD5 hash. Example:
+//   char buf[33];
+//   mg_md5(buf, "aa", "bb", NULL);
+void mg_md5(char *buf, ...);
 #ifdef __cplusplus
-#endif /* MONGOOSE_HEADER_INCLUDED */
+#endif // MONGOOSE_HEADER_INCLUDED
1.6.4.2
