[GSOC] How to fix this error?
Mon Jul 2 18:41:48 UTC 2012
On Mon, Jul 2, 2012 at 1:45 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 07/02/2012 12:42 PM, Xiaochen Pan wrote:
>> Hello,
>> When cmockery compiled under RTEMS, this error occurs: "undefined
>> reference to signal". Which header file should 'signal' be defined under
>> RTEMS library?
> Did you build with --disable-posix?
^ signal comes from posix.
>> regards,
>> xiaochen
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D.             Director of Research&   Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>     Support Available             (256) 722-9985
