libbsd - BSP Bus Hook Up Help Please! :)
Tue Jul 3 18:56:30 UTC 2012
Hi,
On 03/07/12 20:10, Joel Sherrill wrote:
> Hi
> Jennifer and I have tracked the current problem down
> to when the fxp driver attempts to alloc a bus resource.
> It (correctly) gets to legacy_pcib_alloc_resource()
> in pci_bus.c around line 541. That calls
> bus_generic_alloc_resource() which (I think) fails because
> there is no BSP Bus code hooked.
this is due to the kobj(9) objects:
http://www.freebsd.org/cgi/man.cgi?query=kobj
The resource management is very generic in FreeBSD.  I don't know if we
really need this in RTEMS.
> In the libbsdport code, the entire bus code was replaced
> with code that only knew PCI. I think this code is sufficient
> for now as our "generic BSP bus" code. But I can't seem
> to figure out how the FreeBSD PC code set this up.
> On top of that, we currently have the bus routines inlined
> as memory access operations. That is wrong for x86.
Yes, we can do this similar to FreeBSD:
http://svnweb.freebsd.org/base/head/sys/x86/include/bus.h?revision=216592&view=markup
The key point is that compile time constant tags are optimized.
> I am sure we need a bus driver hooked in and we are missing
> the link and magic.
> Help appreciated.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
