[rtems-libbsd commit] Add MIPS cpu specific .h files
Fri Jul 13 15:31:10 UTC 2012
On Fri, Jul 13, 2012 at 9:53 AM, Joel Sherrill <joel at rtems.org> wrote:
> Module:    rtems-libbsd
> Branch:    master
> Commit:    8db44c67764416cca304aea443b4266397c0e896
> Changeset: http://git.rtems.org/rtems-libbsd/commit/?id=8db44c67764416cca304aea443b4266397c0e896
> Author:    Kevin Polulak <kpolulak at gmail.com>
> Date:      Fri Jul 13 08:57:28 2012 -0500
>  freebsd/mips/include/freebsd/machine/cpufunc.h |  410 ++++++++++
>  freebsd/mips/include/freebsd/machine/cpuregs.h |  987 ++++++++++++++++++++++++
>  2 files changed, 1397 insertions(+), 0 deletions(-)
> diff --git a/freebsd/mips/include/freebsd/machine/cpufunc.h b/freebsd/mips/include/freebsd/machine/cpufunc.h
> new file mode 100644
> index 0000000..f693dcb
> --- /dev/null
> +++ b/freebsd/mips/include/freebsd/machine/cpufunc.h
> @@ -0,0 +1,410 @@
> +/*     $OpenBSD: pio.h,v 1.2 1998/09/15 10:50:12 pefo Exp $    */
> + * Copyright (c) 2002-2004 Juli Mallett.  All rights reserved.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> + * Copyright (c) 1995-1999 Per Fogelstrom.  All rights reserved.
> + * are met:
> + * 3. All advertising materials mentioning features or use of this software
> + *    must display the following acknowledgement:
> + *      This product includes software developed by Per Fogelstrom.
This restriction is unacceptable for RTEMS code.
> + * 4. The name of the author may not be used to endorse or promote products
> + *    derived from this software without specific prior written permission
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
> + * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
> + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
> + * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
> + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
> + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
> + * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
> + * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
> + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
> + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> + *     JNPR: cpufunc.h,v 1.5 2007/08/09 11:23:32 katta
> + * $FreeBSD$
> +#ifndef _MACHINE_CPUFUNC_HH_
> +#define        _MACHINE_CPUFUNC_HH_
> +#include <freebsd/sys/types.h>
> +#include <freebsd/machine/cpuregs.h>
> + * These functions are required by user-land atomi ops
> +static __inline void
> +mips_barrier(void)
> +       __asm __volatile (".set noreorder\n\t"
> +                         "nop\n\t"
> +                         "nop\n\t"
> +                         "nop\n\t"
> +                         "nop\n\t"
> +                         "nop\n\t"
> +                         "nop\n\t"
> +                         "nop\n\t"
> +                         "nop\n\t"
> +                         ".set reorder\n\t"
> +                         : : : "memory");
> +mips_cp0_sync(void)
> +       __asm __volatile (__XSTRING(COP0_SYNC));
> +mips_wbflush(void)
> +       __asm __volatile ("sync" : : : "memory");
> +       mips_barrier();
> +mips_read_membar(void)
> +       /* Nil */
> +mips_write_membar(void)
> +       mips_wbflush();
> +#ifdef _KERNEL
> +#if defined(__mips_n32) || defined(__mips_n64)
> +#define        MIPS_RDRW64_COP0(n,r)                                   \
> +static __inline uint64_t                                       \
> +mips_rd_ ## n (void)                                           \
> +       int v0;                                                 \
> +       __asm __volatile ("dmfc0 %[v0], $"__XSTRING(r)";"       \
> +                         : [v0] "=&r"(v0));                    \
> +       mips_barrier();                                         \
> +       return (v0);                                            \
> +static __inline void                                           \
> +mips_wr_ ## n (uint64_t a0)                                    \
> +       __asm __volatile ("dmtc0 %[a0], $"__XSTRING(r)";"       \
> +                        __XSTRING(COP0_SYNC)";"                \
> +                        "nop;"                                 \
> +                        "nop;"                                 \
> +                        : [a0] "r"(a0));                       \
> +       mips_barrier();                                         \
> +} struct __hack
> +#if defined(__mips_n64)
> +MIPS_RDRW64_COP0(entrylo0, MIPS_COP_0_TLB_LO0);
> +MIPS_RDRW64_COP0(entrylo1, MIPS_COP_0_TLB_LO1);
> +MIPS_RDRW64_COP0(entryhi, MIPS_COP_0_TLB_HI);
> +MIPS_RDRW64_COP0(pagemask, MIPS_COP_0_TLB_PG_MASK);
> +#endif
> +MIPS_RDRW64_COP0(xcontext, MIPS_COP_0_TLB_XCONTEXT);
> +#undef MIPS_RDRW64_COP0
> +#endif
> +#define        MIPS_RDRW32_COP0(n,r)                                   \
> +static __inline uint32_t                                       \
> +       int v0;                                                 \
> +       __asm __volatile ("mfc0 %[v0], $"__XSTRING(r)";"        \
> +       mips_barrier();                                         \
> +       return (v0);                                            \
> +mips_wr_ ## n (uint32_t a0)                                    \
> +       __asm __volatile ("mtc0 %[a0], $"__XSTRING(r)";"        \
> +                        "nop;"                                 \
> +                        "nop;"                                 \
> +       mips_barrier();                                         \
> +} struct __hack
> +#define        MIPS_RDRW32_COP0_SEL(n,r,s)                                     \
> +mips_rd_ ## n(void)                                            \
> +       int v0;                                                 \
> +       __asm __volatile ("mfc0 %[v0], $"__XSTRING(r)", "__XSTRING(s)";"        \
> +       mips_barrier();                                         \
> +       return (v0);                                            \
> +mips_wr_ ## n(uint32_t a0)                                     \
> +       __asm __volatile ("mtc0 %[a0], $"__XSTRING(r)", "__XSTRING(s)";"        \
> +                        "nop;"                                 \
> +                        "nop;"                                 \
> +       mips_barrier();                                         \
> +} struct __hack
> +#ifdef CPU_CNMIPS
> +static __inline void mips_sync_icache (void)
> +               ".set push\n"
> +               ".set mips64\n"
> +               ".word 0x041f0000\n"            /* xxx ICACHE */
> +               "nop\n"
> +               ".set pop\n"
> +#endif
> +MIPS_RDRW32_COP0(compare, MIPS_COP_0_COMPARE);
> +MIPS_RDRW32_COP0(config, MIPS_COP_0_CONFIG);
> +MIPS_RDRW32_COP0_SEL(config1, MIPS_COP_0_CONFIG, 1);
> +MIPS_RDRW32_COP0_SEL(config2, MIPS_COP_0_CONFIG, 2);
> +MIPS_RDRW32_COP0_SEL(config3, MIPS_COP_0_CONFIG, 3);
> +MIPS_RDRW32_COP0(count, MIPS_COP_0_COUNT);
> +MIPS_RDRW32_COP0(index, MIPS_COP_0_TLB_INDEX);
> +MIPS_RDRW32_COP0(wired, MIPS_COP_0_TLB_WIRED);
> +MIPS_RDRW32_COP0(cause, MIPS_COP_0_CAUSE);
> +MIPS_RDRW32_COP0(status, MIPS_COP_0_STATUS);
> +/* XXX: Some of these registers are specific to MIPS32. */
> +#if !defined(__mips_n64)
> +MIPS_RDRW32_COP0(entrylo0, MIPS_COP_0_TLB_LO0);
> +MIPS_RDRW32_COP0(entrylo1, MIPS_COP_0_TLB_LO1);
> +MIPS_RDRW32_COP0(entryhi, MIPS_COP_0_TLB_HI);
> +MIPS_RDRW32_COP0(pagemask, MIPS_COP_0_TLB_PG_MASK);
> +#endif
> +MIPS_RDRW32_COP0(prid, MIPS_COP_0_PRID);
> +/* XXX 64-bit?  */
> +MIPS_RDRW32_COP0_SEL(ebase, MIPS_COP_0_PRID, 1);
> +MIPS_RDRW32_COP0(watchlo, MIPS_COP_0_WATCH_LO);
> +MIPS_RDRW32_COP0_SEL(watchlo1, MIPS_COP_0_WATCH_LO, 1);
> +MIPS_RDRW32_COP0_SEL(watchlo2, MIPS_COP_0_WATCH_LO, 2);
> +MIPS_RDRW32_COP0_SEL(watchlo3, MIPS_COP_0_WATCH_LO, 3);
> +MIPS_RDRW32_COP0(watchhi, MIPS_COP_0_WATCH_HI);
> +MIPS_RDRW32_COP0_SEL(watchhi1, MIPS_COP_0_WATCH_HI, 1);
> +MIPS_RDRW32_COP0_SEL(watchhi2, MIPS_COP_0_WATCH_HI, 2);
> +MIPS_RDRW32_COP0_SEL(watchhi3, MIPS_COP_0_WATCH_HI, 3);
> +MIPS_RDRW32_COP0_SEL(perfcnt0, MIPS_COP_0_PERFCNT, 0);
> +MIPS_RDRW32_COP0_SEL(perfcnt1, MIPS_COP_0_PERFCNT, 1);
> +MIPS_RDRW32_COP0_SEL(perfcnt2, MIPS_COP_0_PERFCNT, 2);
> +MIPS_RDRW32_COP0_SEL(perfcnt3, MIPS_COP_0_PERFCNT, 3);
> +#undef MIPS_RDRW32_COP0
> +static __inline register_t
> +intr_disable(void)
> +       register_t s;
> +       s = mips_rd_status();
> +       mips_wr_status(s & ~MIPS_SR_INT_IE);
> +       return (s & MIPS_SR_INT_IE);
> +intr_enable(void)
> +       register_t s;
> +       mips_wr_status(s | MIPS_SR_INT_IE);
> +       return (s);
> +intr_restore(register_t ie)
> +       if (ie == MIPS_SR_INT_IE) {
> +               intr_enable();
> +set_intr_mask(uint32_t mask)
> +       uint32_t ostatus;
> +       ostatus = mips_rd_status();
> +       mask = (ostatus & ~MIPS_SR_INT_MASK) | (mask & MIPS_SR_INT_MASK);
> +       mips_wr_status(mask);
> +       return (ostatus);
> +get_intr_mask(void)
> +       return (mips_rd_status() & MIPS_SR_INT_MASK);
> +breakpoint(void)
> +       __asm __volatile ("break");
> +#if defined(__GNUC__) && !defined(__mips_o32)
> +static inline uint64_t
> +mips3_ld(const volatile uint64_t *va)
> +       uint64_t rv;
> +#if defined(_LP64)
> +       rv = *va;
> +#else
> +       __asm volatile("ld      %0,0(%1)" : "=d"(rv) : "r"(va));
> +#endif
> +       return (rv);
> +static inline void
> +mips3_sd(volatile uint64_t *va, uint64_t v)
> +#if defined(_LP64)
> +       *va = v;
> +#else
> +       __asm volatile("sd      %0,0(%1)" :: "r"(v), "r"(va));
> +#endif
> +#else
> +uint64_t mips3_ld(volatile uint64_t *va);
> +void mips3_sd(volatile uint64_t *, uint64_t);
> +#endif /* __GNUC__ */
> +#endif /* _KERNEL */
> +#define        readb(va)       (*(volatile uint8_t *) (va))
> +#define        readw(va)       (*(volatile uint16_t *) (va))
> +#define        readl(va)       (*(volatile uint32_t *) (va))
> +#define        writeb(va, d)   (*(volatile uint8_t *) (va) = (d))
> +#define        writew(va, d)   (*(volatile uint16_t *) (va) = (d))
> +#define        writel(va, d)   (*(volatile uint32_t *) (va) = (d))
> + * I/O macros.
> +#define        outb(a,v)       (*(volatile unsigned char*)(a) = (v))
> +#define        out8(a,v)       (*(volatile unsigned char*)(a) = (v))
> +#define        outw(a,v)       (*(volatile unsigned short*)(a) = (v))
> +#define        out16(a,v)      outw(a,v)
> +#define        outl(a,v)       (*(volatile unsigned int*)(a) = (v))
> +#define        out32(a,v)      outl(a,v)
> +#define        inb(a)          (*(volatile unsigned char*)(a))
> +#define        in8(a)          (*(volatile unsigned char*)(a))
> +#define        inw(a)          (*(volatile unsigned short*)(a))
> +#define        in16(a)         inw(a)
> +#define        inl(a)          (*(volatile unsigned int*)(a))
> +#define        in32(a)         inl(a)
> +#define        out8rb(a,v)     (*(volatile unsigned char*)(a) = (v))
> +#define        out16rb(a,v)    (__out16rb((volatile uint16_t *)(a), v))
> +#define        out32rb(a,v)    (__out32rb((volatile uint32_t *)(a), v))
> +#define        in8rb(a)        (*(volatile unsigned char*)(a))
> +#define        in16rb(a)       (__in16rb((volatile uint16_t *)(a)))
> +#define        in32rb(a)       (__in32rb((volatile uint32_t *)(a)))
> +#define        _swap_(x)       (((x) >> 24) | ((x) << 24) | \
> +           (((x) >> 8) & 0xff00) | (((x) & 0xff00) << 8))
> +static __inline void __out32rb(volatile uint32_t *, uint32_t);
> +static __inline void __out16rb(volatile uint16_t *, uint16_t);
> +static __inline uint32_t __in32rb(volatile uint32_t *);
> +static __inline uint16_t __in16rb(volatile uint16_t *);
> +__out32rb(volatile uint32_t *a, uint32_t v)
> +       uint32_t _v_ = v;
> +       _v_ = _swap_(_v_);
> +       out32(a, _v_);
> +__out16rb(volatile uint16_t *a, uint16_t v)
> +       uint16_t _v_;
> +       _v_ = ((v >> 8) & 0xff) | (v << 8);
> +       out16(a, _v_);
> +__in32rb(volatile uint32_t *a)
> +       uint32_t _v_;
> +       _v_ = in32(a);
> +       return _v_;
> +__in16rb(volatile uint16_t *a)
> +       uint16_t _v_;
> +       _v_ = in16(a);
> +       _v_ = ((_v_ >> 8) & 0xff) | (_v_ << 8);
> +       return _v_;
> +void insb(uint8_t *, uint8_t *,int);
> +void insw(uint16_t *, uint16_t *,int);
> +void insl(uint32_t *, uint32_t *,int);
> +void outsb(uint8_t *, const uint8_t *,int);
> +void outsw(uint16_t *, const uint16_t *,int);
> +void outsl(uint32_t *, const uint32_t *,int);
> +u_int loadandclear(volatile u_int *addr);
> +#endif /* !_MACHINE_CPUFUNC_HH_ */
> diff --git a/freebsd/mips/include/freebsd/machine/cpuregs.h b/freebsd/mips/include/freebsd/machine/cpuregs.h
> index 0000000..db6450f
> --- /dev/null
> +++ b/freebsd/mips/include/freebsd/machine/cpuregs.h
> @@ -0,0 +1,987 @@
> +/*     $NetBSD: cpuregs.h,v 1.70 2006/05/15 02:26:54 simonb Exp $      */
> + * Copyright (c) 1992, 1993
> + *     The Regents of the University of California.  All rights reserved.
> + * This code is derived from software contributed to Berkeley by
> + * Ralph Campbell and Rick Macklem.
> + * are met:
> + * 3. Neither the name of the University nor the names of its contributors
> + *    may be used to endorse or promote products derived from this software
> + *    without specific prior written permission.
> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
> + * SUCH DAMAGE.
> + *     @(#)machConst.h 8.1 (Berkeley) 6/10/93
> + * machConst.h --
> + *     Machine dependent constants.
> + *     Copyright (C) 1989 Digital Equipment Corporation.
> + *     Permission to use, copy, modify, and distribute this software and
> + *     its documentation for any purpose and without fee is hereby granted,
> + *     provided that the above copyright notice appears in all copies.
> + *     Digital Equipment Corporation makes no representations about the
> + *     suitability of this software for any purpose.  It is provided "as is"
> + *     without express or implied warranty.
> + * from: Header: /sprite/src/kernel/mach/ds3100.md/RCS/machConst.h,
> + *     v 9.2 89/10/21 15:55:22 jhh Exp  SPRITE (DECWRL)
> + * from: Header: /sprite/src/kernel/mach/ds3100.md/RCS/machAddrs.h,
> + *     v 1.2 89/08/15 18:28:21 rab Exp  SPRITE (DECWRL)
> + * from: Header: /sprite/src/kernel/vm/ds3100.md/RCS/vmPmaxConst.h,
> + *     v 9.1 89/09/18 17:33:00 shirriff Exp  SPRITE (DECWRL)
> + * $FreeBSD$
> +#ifndef _MIPS_CPUREGS_HH_
> +#define        _MIPS_CPUREGS_HH_
> + * Address space.
> + * 32-bit mips CPUS partition their 32-bit address space into four segments:
> + * kuseg   0x00000000 - 0x7fffffff  User virtual mem,  mapped
> + * kseg0   0x80000000 - 0x9fffffff  Physical memory, cached, unmapped
> + * kseg1   0xa0000000 - 0xbfffffff  Physical memory, uncached, unmapped
> + * kseg2   0xc0000000 - 0xffffffff  kernel-virtual,  mapped
> + * Caching of mapped addresses is controlled by bits in the TLB entry.
> +#define        MIPS_KSEG0_LARGEST_PHYS         (0x20000000)
> +#define        MIPS_KSEG0_PHYS_MASK            (0x1fffffff)
> +#define        MIPS_XKPHYS_LARGEST_PHYS        (0x10000000000)  /* 40 bit PA */
> +#define        MIPS_XKPHYS_PHYS_MASK           (0x0ffffffffff)
> +#ifndef LOCORE
> +#define        MIPS_KUSEG_START                0x00000000
> +#define        MIPS_KSEG0_START                ((intptr_t)(int32_t)0x80000000)
> +#define        MIPS_KSEG0_END                  ((intptr_t)(int32_t)0x9fffffff)
> +#define        MIPS_KSEG1_START                ((intptr_t)(int32_t)0xa0000000)
> +#define        MIPS_KSEG1_END                  ((intptr_t)(int32_t)0xbfffffff)
> +#define        MIPS_KSSEG_START                ((intptr_t)(int32_t)0xc0000000)
> +#define        MIPS_KSSEG_END                  ((intptr_t)(int32_t)0xdfffffff)
> +#define        MIPS_KSEG3_START                ((intptr_t)(int32_t)0xe0000000)
> +#define        MIPS_KSEG3_END                  ((intptr_t)(int32_t)0xffffffff)
> +#define MIPS_KSEG2_START               MIPS_KSSEG_START
> +#define MIPS_KSEG2_END                 MIPS_KSSEG_END
> +#endif
> +#define        MIPS_PHYS_TO_KSEG0(x)           ((uintptr_t)(x) | MIPS_KSEG0_START)
> +#define        MIPS_PHYS_TO_KSEG1(x)           ((uintptr_t)(x) | MIPS_KSEG1_START)
> +#define        MIPS_KSEG0_TO_PHYS(x)           ((uintptr_t)(x) & MIPS_KSEG0_PHYS_MASK)
> +#define        MIPS_KSEG1_TO_PHYS(x)           ((uintptr_t)(x) & MIPS_KSEG0_PHYS_MASK)
> +#define        MIPS_IS_KSEG0_ADDR(x)                                   \
> +       (((vm_offset_t)(x) >= MIPS_KSEG0_START) &&              \
> +           ((vm_offset_t)(x) <= MIPS_KSEG0_END))
> +#define        MIPS_IS_KSEG1_ADDR(x)                                   \
> +       (((vm_offset_t)(x) >= MIPS_KSEG1_START) &&              \
> +           ((vm_offset_t)(x) <= MIPS_KSEG1_END))
> +#define        MIPS_IS_VALID_PTR(x)            (MIPS_IS_KSEG0_ADDR(x) || \
> +                                           MIPS_IS_KSEG1_ADDR(x))
> + * Cache Coherency Attributes:
> + *     UC:     Uncached.
> + *     UA:     Uncached accelerated.
> + *     C:      Cacheable, coherency unspecified.
> + *     CNC:    Cacheable non-coherent.
> + *     CC:     Cacheable coherent.
> + *     CCE:    Cacheable coherent, exclusive read.
> + *     CCEW:   Cacheable coherent, exclusive write.
> + *     CCUOW:  Cacheable coherent, update on write.
> + * Note that some bits vary in meaning across implementations (and that the
> + * listing here is no doubt incomplete) and that the optimal cached mode varies
> + * between implementations.  0x02 is required to be UC and 0x03 is required to
> + * be a least C.
> + * We define the following logical bits:
> + *     UNCACHED:
> + *             The optimal uncached mode for the target CPU type.  This must
> + *             be suitable for use in accessing memory-mapped devices.
> + *     CACHED: The optional cached mode for the target CPU type.
> +#define        MIPS_CCA_UC             0x02    /* Uncached. */
> +#define        MIPS_CCA_C              0x03    /* Cacheable, coherency unspecified. */
> +#if defined(CPU_R4000) || defined(CPU_R10000)
> +#define        MIPS_CCA_CNC    0x03
> +#define        MIPS_CCA_CCE    0x04
> +#define        MIPS_CCA_CCEW   0x05
> +#ifdef CPU_R4000
> +#define        MIPS_CCA_CCUOW  0x06
> +#endif
> +#ifdef CPU_R10000
> +#define        MIPS_CCA_UA     0x07
> +#endif
> +#define        MIPS_CCA_CACHED MIPS_CCA_CCEW
> +#endif /* defined(CPU_R4000) || defined(CPU_R10000) */
> +#if defined(CPU_SB1)
> +#define        MIPS_CCA_CC     0x05    /* Cacheable Coherent. */
> +#endif
> +#ifndef        MIPS_CCA_UNCACHED
> +#define        MIPS_CCA_UNCACHED       MIPS_CCA_UC
> +#endif
> + * If we don't know which cached mode to use and there is a cache coherent
> + * mode, use it.  If there is not a cache coherent mode, use the required
> + * cacheable mode.
> +#ifndef MIPS_CCA_CACHED
> +#ifdef MIPS_CCA_CC
> +#else
> +#endif
> +#endif
> +#define        MIPS_PHYS_TO_XKPHYS(cca,x) \
> +       ((0x2ULL << 62) | ((unsigned long long)(cca) << 59) | (x))
> +#define        MIPS_PHYS_TO_XKPHYS_CACHED(x) \
> +       ((0x2ULL << 62) | ((unsigned long long)(MIPS_CCA_CACHED) << 59) | (x))
> +#define        MIPS_PHYS_TO_XKPHYS_UNCACHED(x) \
> +       ((0x2ULL << 62) | ((unsigned long long)(MIPS_CCA_UNCACHED) << 59) | (x))
> +#define        MIPS_XKPHYS_TO_PHYS(x)          ((uintptr_t)(x) & MIPS_XKPHYS_PHYS_MASK)
> +#define        MIPS_XKPHYS_START               0x8000000000000000
> +#define        MIPS_XKPHYS_END                 0xbfffffffffffffff
> +#define        MIPS_XUSEG_START                0x0000000000000000
> +#define        MIPS_XUSEG_END                  0x0000010000000000
> +#define        MIPS_XKSEG_START                0xc000000000000000
> +#define        MIPS_XKSEG_END                  0xc00000ff80000000
> +#define        MIPS_XKSEG_COMPAT32_START       0xffffffff80000000
> +#define        MIPS_XKSEG_COMPAT32_END         0xffffffffffffffff
> +#define        MIPS_XKSEG_TO_COMPAT32(va)      ((va) & 0xffffffff)
> +#ifdef __mips_n64
> +#define        MIPS_DIRECT_MAPPABLE(pa)        1
> +#define        MIPS_PHYS_TO_DIRECT(pa)         MIPS_PHYS_TO_XKPHYS_CACHED(pa)
> +#define        MIPS_PHYS_TO_DIRECT_UNCACHED(pa)        MIPS_PHYS_TO_XKPHYS_UNCACHED(pa)
> +#define        MIPS_DIRECT_TO_PHYS(va)         MIPS_XKPHYS_TO_PHYS(va)
> +#else
> +#define        MIPS_DIRECT_MAPPABLE(pa)        ((pa) < MIPS_KSEG0_LARGEST_PHYS)
> +#define        MIPS_PHYS_TO_DIRECT(pa)         MIPS_PHYS_TO_KSEG0(pa)
> +#define        MIPS_PHYS_TO_DIRECT_UNCACHED(pa)        MIPS_PHYS_TO_KSEG1(pa)
> +#define        MIPS_DIRECT_TO_PHYS(va)         MIPS_KSEG0_TO_PHYS(va)
> +#endif
> +/* CPU dependent mtc0 hazard hook */
> +#ifdef CPU_CNMIPS
> +#define        COP0_SYNC  nop; nop; nop; nop; nop;
> +#elif defined(CPU_SB1)
> +#define COP0_SYNC  ssnop; ssnop; ssnop; ssnop; ssnop; ssnop; ssnop; ssnop; ssnop
> +#elif defined(CPU_RMI)
> +#define COP0_SYNC
> +#else
> + * Pick a reasonable default based on the "typical" spacing described in the
> + * "CP0 Hazards" chapter of MIPS Architecture Book Vol III.
> +#endif
> +#define        COP0_HAZARD_FPUENABLE   nop; nop; nop; nop;
> + * The bits in the cause register.
> + * Bits common to r3000 and r4000:
> + *     MIPS_CR_BR_DELAY        Exception happened in branch delay slot.
> + *     MIPS_CR_COP_ERR         Coprocessor error.
> + *     MIPS_CR_IP              Interrupt pending bits defined below.
> + *                             (same meaning as in CAUSE register).
> + *     MIPS_CR_EXC_CODE        The exception type (see exception codes below).
> + * Differences:
> + *  r3k has 4 bits of execption type, r4k has 5 bits.
> +#define        MIPS_CR_BR_DELAY        0x80000000
> +#define        MIPS_CR_COP_ERR         0x30000000
> +#define        MIPS1_CR_EXC_CODE       0x0000003C      /* four bits */
> +#define        MIPS3_CR_EXC_CODE       0x0000007C      /* five bits */
> +#define        MIPS_CR_IP              0x0000FF00
> +#define        MIPS_CR_EXC_CODE_SHIFT  2
> + * The bits in the status register.  All bits are active when set to 1.
> + *     R3000 status register fields:
> + *     MIPS_SR_COP_USABILITY   Control the usability of the four coprocessors.
> + *     MIPS_SR_TS              TLB shutdown.
> + *     MIPS_SR_INT_IE          Master (current) interrupt enable bit.
> + * Differences:
> + *     r3k has cache control is via frobbing SR register bits, whereas the
> + *     r4k cache control is via explicit instructions.
> + *     r3k has a 3-entry stack of kernel/user bits, whereas the
> + *     r4k has kernel/supervisor/user.
> +#define        MIPS_SR_COP_USABILITY   0xf0000000
> +#define        MIPS_SR_COP_0_BIT       0x10000000
> +#define        MIPS_SR_COP_1_BIT       0x20000000
> +#define MIPS_SR_COP_2_BIT       0x40000000
> +       /* r4k and r3k differences, see below */
> +#define        MIPS_SR_MX              0x01000000      /* MIPS64 */
> +#define        MIPS_SR_PX              0x00800000      /* MIPS64 */
> +#define        MIPS_SR_BEV             0x00400000      /* Use boot exception vector */
> +#define        MIPS_SR_TS              0x00200000
> +#define MIPS_SR_DE             0x00010000
> +#define        MIPS_SR_INT_IE          0x00000001
> +/*#define MIPS_SR_MBZ          0x0f8000c0*/    /* Never used, true for r3k */
> +#define MIPS_SR_INT_MASK       0x0000ff00
> + * The R2000/R3000-specific status register bit definitions.
> + * all bits are active when set to 1.
> + *     MIPS_SR_PARITY_ERR      Parity error.
> + *     MIPS_SR_CACHE_MISS      Most recent D-cache load resulted in a miss.
> + *     MIPS_SR_PARITY_ZERO     Zero replaces outgoing parity bits.
> + *     MIPS_SR_SWAP_CACHES     Swap I-cache and D-cache.
> + *     MIPS_SR_ISOL_CACHES     Isolate D-cache from main memory.
> + *                             Interrupt enable bits defined below.
> + *     MIPS_SR_KU_OLD          Old kernel/user mode bit. 1 => user mode.
> + *     MIPS_SR_INT_ENA_OLD     Old interrupt enable bit.
> + *     MIPS_SR_KU_PREV         Previous kernel/user mode bit. 1 => user mode.
> + *     MIPS_SR_INT_ENA_PREV    Previous interrupt enable bit.
> + *     MIPS_SR_KU_CUR          Current kernel/user mode bit. 1 => user mode.
> +#define        MIPS1_PARITY_ERR        0x00100000
> +#define        MIPS1_CACHE_MISS        0x00080000
> +#define        MIPS1_PARITY_ZERO       0x00040000
> +#define        MIPS1_SWAP_CACHES       0x00020000
> +#define        MIPS1_ISOL_CACHES       0x00010000
> +#define        MIPS1_SR_KU_OLD         0x00000020      /* 2nd stacked KU/IE*/
> +#define        MIPS1_SR_INT_ENA_OLD    0x00000010      /* 2nd stacked KU/IE*/
> +#define        MIPS1_SR_KU_PREV        0x00000008      /* 1st stacked KU/IE*/
> +#define        MIPS1_SR_INT_ENA_PREV   0x00000004      /* 1st stacked KU/IE*/
> +#define        MIPS1_SR_KU_CUR         0x00000002      /* current KU */
> +/* backwards compatibility */
> +#define        MIPS_SR_PARITY_ERR      MIPS1_PARITY_ERR
> +#define        MIPS_SR_CACHE_MISS      MIPS1_CACHE_MISS
> +#define        MIPS_SR_PARITY_ZERO     MIPS1_PARITY_ZERO
> +#define        MIPS_SR_SWAP_CACHES     MIPS1_SWAP_CACHES
> +#define        MIPS_SR_ISOL_CACHES     MIPS1_ISOL_CACHES
> +#define        MIPS_SR_KU_OLD          MIPS1_SR_KU_OLD
> +#define        MIPS_SR_INT_ENA_OLD     MIPS1_SR_INT_ENA_OLD
> +#define        MIPS_SR_KU_PREV         MIPS1_SR_KU_PREV
> +#define        MIPS_SR_KU_CUR          MIPS1_SR_KU_CUR
> +#define        MIPS_SR_INT_ENA_PREV    MIPS1_SR_INT_ENA_PREV
> + * R4000 status register bit definitons,
> + * where different from r2000/r3000.
> +#define        MIPS3_SR_XX             0x80000000
> +#define        MIPS3_SR_RP             0x08000000
> +#define        MIPS3_SR_FR             0x04000000
> +#define        MIPS3_SR_RE             0x02000000
> +#define        MIPS3_SR_DIAG_DL        0x01000000              /* QED 52xx */
> +#define        MIPS3_SR_DIAG_IL        0x00800000              /* QED 52xx */
> +#define        MIPS3_SR_SR             0x00100000
> +#define        MIPS3_SR_NMI            0x00080000              /* MIPS32/64 */
> +#define        MIPS3_SR_DIAG_CH        0x00040000
> +#define        MIPS3_SR_DIAG_CE        0x00020000
> +#define        MIPS3_SR_DIAG_PE        0x00010000
> +#define        MIPS3_SR_EIE            0x00010000              /* TX79/R5900 */
> +#define        MIPS3_SR_KX             0x00000080
> +#define        MIPS3_SR_SX             0x00000040
> +#define        MIPS3_SR_UX             0x00000020
> +#define        MIPS3_SR_KSU_MASK       0x00000018
> +#define        MIPS3_SR_KSU_USER       0x00000010
> +#define        MIPS3_SR_KSU_SUPER      0x00000008
> +#define        MIPS3_SR_KSU_KERNEL     0x00000000
> +#define        MIPS3_SR_ERL            0x00000004
> +#define        MIPS3_SR_EXL            0x00000002
> +#ifdef MIPS3_5900
> +#undef MIPS_SR_INT_IE
> +#define        MIPS_SR_INT_IE          0x00010001              /* XXX */
> +#endif
> +#define        MIPS_SR_SOFT_RESET      MIPS3_SR_SR
> +#define        MIPS_SR_DIAG_CH         MIPS3_SR_DIAG_CH
> +#define        MIPS_SR_DIAG_CE         MIPS3_SR_DIAG_CE
> +#define        MIPS_SR_DIAG_PE         MIPS3_SR_DIAG_PE
> +#define        MIPS_SR_KX              MIPS3_SR_KX
> +#define        MIPS_SR_SX              MIPS3_SR_SX
> +#define        MIPS_SR_UX              MIPS3_SR_UX
> +#define        MIPS_SR_KSU_MASK        MIPS3_SR_KSU_MASK
> +#define        MIPS_SR_KSU_USER        MIPS3_SR_KSU_USER
> +#define        MIPS_SR_KSU_SUPER       MIPS3_SR_KSU_SUPER
> +#define        MIPS_SR_KSU_KERNEL      MIPS3_SR_KSU_KERNEL
> +#define        MIPS_SR_ERL             MIPS3_SR_ERL
> +#define        MIPS_SR_EXL             MIPS3_SR_EXL
> + * The interrupt masks.
> + * If a bit in the mask is 1 then the interrupt is enabled (or pending).
> +#define        MIPS_INT_MASK           0xff00
> +#define        MIPS_INT_MASK_5         0x8000
> +#define        MIPS_INT_MASK_4         0x4000
> +#define        MIPS_INT_MASK_3         0x2000
> +#define        MIPS_INT_MASK_2         0x1000
> +#define        MIPS_INT_MASK_1         0x0800
> +#define        MIPS_INT_MASK_0         0x0400
> +#define        MIPS_HARD_INT_MASK      0xfc00
> +#define        MIPS_SOFT_INT_MASK_1    0x0200
> +#define        MIPS_SOFT_INT_MASK_0    0x0100
> + * mips3 CPUs have on-chip timer at INT_MASK_5.  Each platform can
> + * choose to enable this interrupt.
> +#if defined(MIPS3_ENABLE_CLOCK_INTR)
> +#define        MIPS3_INT_MASK                  MIPS_INT_MASK
> +#define        MIPS3_HARD_INT_MASK             MIPS_HARD_INT_MASK
> +#else
> +#define        MIPS3_INT_MASK                  (MIPS_INT_MASK &  ~MIPS_INT_MASK_5)
> +#define        MIPS3_HARD_INT_MASK             (MIPS_HARD_INT_MASK & ~MIPS_INT_MASK_5)
> +#endif
> + * The bits in the context register.
> +#define        MIPS1_CNTXT_PTE_BASE    0xFFE00000
> +#define        MIPS1_CNTXT_BAD_VPN     0x001FFFFC
> +#define        MIPS3_CNTXT_PTE_BASE    0xFF800000
> +#define        MIPS3_CNTXT_BAD_VPN2    0x007FFFF0
> + * Location of MIPS32 exception vectors. Most are multiplexed in
> + * the sense that further decoding is necessary (e.g. reading the
> + * CAUSE register or NMI bits in STATUS).
> + * Most interrupts go via the
> + * The INT vector is dedicated for hardware interrupts; it is
> + * only referenced if the IV bit in CAUSE is set to 1.
> +#define        MIPS_VEC_RESET          0xBFC00000      /* Hard, soft, or NMI */
> +#define        MIPS_VEC_EJTAG          0xBFC00480
> +#define        MIPS_VEC_TLB            0x80000000
> +#define        MIPS_VEC_XTLB           0x80000080
> +#define        MIPS_VEC_CACHE          0x80000100
> +#define        MIPS_VEC_GENERIC        0x80000180      /* Most exceptions */
> +#define        MIPS_VEC_INTERRUPT      0x80000200
> + * The bits in the MIPS3 config register.
> + *     bit 0..5: R/W, Bit 6..31: R/O
> +/* kseg0 coherency algorithm - see MIPS3_TLB_ATTR values */
> +#define        MIPS3_CONFIG_K0_MASK    0x00000007
> + * R/W Update on Store Conditional
> + *     0: Store Conditional uses coherency algorithm specified by TLB
> + *     1: Store Conditional uses cacheable coherent update on write
> +#define        MIPS3_CONFIG_CU         0x00000008
> +#define        MIPS3_CONFIG_DB         0x00000010      /* Primary D-cache line size */
> +#define        MIPS3_CONFIG_IB         0x00000020      /* Primary I-cache line size */
> +#define        MIPS3_CONFIG_CACHE_L1_LSIZE(config, bit) \
> +       (((config) & (bit)) ? 32 : 16)
> +#define        MIPS3_CONFIG_DC_MASK    0x000001c0      /* Primary D-cache size */
> +#define        MIPS3_CONFIG_DC_SHIFT   6
> +#define        MIPS3_CONFIG_IC_MASK    0x00000e00      /* Primary I-cache size */
> +#define        MIPS3_CONFIG_IC_SHIFT   9
> +#define        MIPS3_CONFIG_C_DEFBASE  0x1000          /* default base 2^12 */
> +/* Cache size mode indication: available only on Vr41xx CPUs */
> +#define        MIPS3_CONFIG_CS         0x00001000
> +#define        MIPS3_CONFIG_C_4100BASE 0x0400          /* base is 2^10 if CS=1 */
> +#define        MIPS3_CONFIG_CACHE_SIZE(config, mask, base, shift) \
> +       ((base) << (((config) & (mask)) >> (shift)))
> +/* External cache enable: Controls L2 for R5000/Rm527x and L3 for Rm7000 */
> +#define        MIPS3_CONFIG_SE         0x00001000
> +/* Block ordering: 0: sequential, 1: sub-block */
> +#define        MIPS3_CONFIG_EB         0x00002000
> +/* ECC mode - 0: ECC mode, 1: parity mode */
> +#define        MIPS3_CONFIG_EM         0x00004000
> +/* BigEndianMem - 0: kernel and memory are little endian, 1: big endian */
> +#define        MIPS3_CONFIG_BE         0x00008000
> +/* Dirty Shared coherency state - 0: enabled, 1: disabled */
> +#define        MIPS3_CONFIG_SM         0x00010000
> +/* Secondary Cache - 0: present, 1: not present */
> +#define        MIPS3_CONFIG_SC         0x00020000
> +/* System Port width - 0: 64-bit, 1: 32-bit (QED RM523x), 2,3: reserved */
> +#define        MIPS3_CONFIG_EW_MASK    0x000c0000
> +#define        MIPS3_CONFIG_EW_SHIFT   18
> +/* Secondary Cache port width - 0: 128-bit data path to S-cache, 1: reserved */
> +#define        MIPS3_CONFIG_SW         0x00100000
> +/* Split Secondary Cache Mode - 0: I/D mixed, 1: I/D separated by SCAddr(17) */
> +#define        MIPS3_CONFIG_SS         0x00200000
> +/* Secondary Cache line size */
> +#define        MIPS3_CONFIG_SB_MASK    0x00c00000
> +#define        MIPS3_CONFIG_SB_SHIFT   22
> +#define        MIPS3_CONFIG_CACHE_L2_LSIZE(config) \
> +       (0x10 << (((config) & MIPS3_CONFIG_SB_MASK) >> MIPS3_CONFIG_SB_SHIFT))
> +/* Write back data rate */
> +#define        MIPS3_CONFIG_EP_MASK    0x0f000000
> +#define        MIPS3_CONFIG_EP_SHIFT   24
> +/* System clock ratio - this value is CPU dependent */
> +#define        MIPS3_CONFIG_EC_MASK    0x70000000
> +#define        MIPS3_CONFIG_EC_SHIFT   28
> +/* Master-Checker Mode - 1: enabled */
> +#define        MIPS3_CONFIG_CM         0x80000000
> + * The bits in the MIPS4 config register.
> +#define        MIPS4_CONFIG_K0_MASK    MIPS3_CONFIG_K0_MASK
> +#define        MIPS4_CONFIG_DN_MASK    0x00000018      /* Device number */
> +#define        MIPS4_CONFIG_CT         0x00000020      /* CohPrcReqTar */
> +#define        MIPS4_CONFIG_PE         0x00000040      /* PreElmReq */
> +#define        MIPS4_CONFIG_PM_MASK    0x00000180      /* PreReqMax */
> +#define        MIPS4_CONFIG_EC_MASK    0x00001e00      /* SysClkDiv */
> +#define        MIPS4_CONFIG_SB         0x00002000      /* SCBlkSize */
> +#define        MIPS4_CONFIG_SK         0x00004000      /* SCColEn */
> +#define        MIPS4_CONFIG_BE         0x00008000      /* MemEnd */
> +#define        MIPS4_CONFIG_SS_MASK    0x00070000      /* SCSize */
> +#define        MIPS4_CONFIG_SC_MASK    0x00380000      /* SCClkDiv */
> +#define        MIPS4_CONFIG_RESERVED   0x03c00000      /* Reserved wired 0 */
> +#define        MIPS4_CONFIG_DC_MASK    0x1c000000      /* Primary D-Cache size */
> +#define        MIPS4_CONFIG_IC_MASK    0xe0000000      /* Primary I-Cache size */
> +#define        MIPS4_CONFIG_DC_SHIFT   26
> +#define        MIPS4_CONFIG_IC_SHIFT   29
> +#define        MIPS4_CONFIG_CACHE_SIZE(config, mask, base, shift)              \
> +#define        MIPS4_CONFIG_CACHE_L2_LSIZE(config)                             \
> +       (((config) & MIPS4_CONFIG_SB) ? 128 : 64)
> + * Location of exception vectors.
> + * Common vectors:  reset and UTLB miss.
> +#define        MIPS_RESET_EXC_VEC      ((intptr_t)(int32_t)0xBFC00000)
> +#define        MIPS_UTLB_MISS_EXC_VEC  ((intptr_t)(int32_t)0x80000000)
> + * MIPS-1 general exception vector (everything else)
> +#define        MIPS1_GEN_EXC_VEC       ((intptr_t)(int32_t)0x80000080)
> + * MIPS-III exception vectors
> +#define        MIPS3_XTLB_MISS_EXC_VEC ((intptr_t)(int32_t)0x80000080)
> +#define        MIPS3_CACHE_ERR_EXC_VEC ((intptr_t)(int32_t)0x80000100)
> +#define        MIPS3_GEN_EXC_VEC       ((intptr_t)(int32_t)0x80000180)
> + * TX79 (R5900) exception vectors
> +#define MIPS_R5900_COUNTER_EXC_VEC             0x80000080
> +#define MIPS_R5900_DEBUG_EXC_VEC               0x80000100
> + * MIPS32/MIPS64 (and some MIPS3) dedicated interrupt vector.
> +#define        MIPS3_INTR_EXC_VEC      0x80000200
> + * Coprocessor 0 registers:
> + *                             v--- width for mips I,III,32,64
> + *                                  (3=32bit, 6=64bit, i=impl dep)
> + *  0  MIPS_COP_0_TLB_INDEX    3333 TLB Index.
> + *  1  MIPS_COP_0_TLB_RANDOM   3333 TLB Random.
> + *  2  MIPS_COP_0_TLB_LO0      .636 r4k TLB entry low.
> + *  3  MIPS_COP_0_TLB_LO1      .636 r4k TLB entry low, extended.
> + *  4  MIPS_COP_0_TLB_CONTEXT  3636 TLB Context.
> + *  5  MIPS_COP_0_TLB_PG_MASK  .333 TLB Page Mask register.
> + *  6  MIPS_COP_0_TLB_WIRED    .333 Wired TLB number.
> + *  7  MIPS_COP_0_INFO         ..33 Info registers
> + *  8  MIPS_COP_0_BAD_VADDR    3636 Bad virtual address.
> + *  9  MIPS_COP_0_COUNT        .333 Count register.
> + * 10  MIPS_COP_0_TLB_HI       3636 TLB entry high.
> + * 11  MIPS_COP_0_COMPARE      .333 Compare (against Count).
> + * 12  MIPS_COP_0_STATUS       3333 Status register.
> + * 13  MIPS_COP_0_CAUSE        3333 Exception cause register.
> + * 14  MIPS_COP_0_EXC_PC       3636 Exception PC.
> + * 15  MIPS_COP_0_PRID         3333 Processor revision identifier.
> + * 16  MIPS_COP_0_CONFIG       3333 Configuration register.
> + * 16/1        MIPS_COP_0_CONFIG1      ..33 Configuration register 1.
> + * 16/2        MIPS_COP_0_CONFIG2      ..33 Configuration register 2.
> + * 16/3        MIPS_COP_0_CONFIG3      ..33 Configuration register 3.
> + * 17  MIPS_COP_0_LLADDR       .336 Load Linked Address.
> + * 18  MIPS_COP_0_WATCH_LO     .336 WatchLo register.
> + * 19  MIPS_COP_0_WATCH_HI     .333 WatchHi register.
> + * 20  MIPS_COP_0_TLB_XCONTEXT .6.6 TLB XContext register.
> + * 23  MIPS_COP_0_DEBUG        .... Debug JTAG register.
> + * 24  MIPS_COP_0_DEPC         .... DEPC JTAG register.
> + * 25  MIPS_COP_0_PERFCNT      ..36 Performance Counter register.
> + * 26  MIPS_COP_0_ECC          .3ii ECC / Error Control register.
> + * 27  MIPS_COP_0_CACHE_ERR    .3ii Cache Error register.
> + * 28/0        MIPS_COP_0_TAG_LO       .3ii Cache TagLo register (instr).
> + * 28/1        MIPS_COP_0_DATA_LO      ..ii Cache DataLo register (instr).
> + * 28/2        MIPS_COP_0_TAG_LO       ..ii Cache TagLo register (data).
> + * 28/3        MIPS_COP_0_DATA_LO      ..ii Cache DataLo register (data).
> + * 29/0        MIPS_COP_0_TAG_HI       .3ii Cache TagHi register (instr).
> + * 29/1        MIPS_COP_0_DATA_HI      ..ii Cache DataHi register (instr).
> + * 29/2        MIPS_COP_0_TAG_HI       ..ii Cache TagHi register (data).
> + * 29/3        MIPS_COP_0_DATA_HI      ..ii Cache DataHi register (data).
> + * 30  MIPS_COP_0_ERROR_PC     .636 Error EPC register.
> + * 31  MIPS_COP_0_DESAVE       .... DESAVE JTAG register.
> +/* Deal with inclusion from an assembly file. */
> +#if defined(_LOCORE) || defined(LOCORE)
> +#define        _(n)    $n
> +#else
> +#define        _(n)    n
> +#endif
> +#define        MIPS_COP_0_TLB_INDEX    _(0)
> +#define        MIPS_COP_0_TLB_RANDOM   _(1)
> +       /* Name and meaning of  TLB bits for $2 differ on r3k and r4k. */
> +#define        MIPS_COP_0_TLB_CONTEXT  _(4)
> +                                       /* $5 and $6 new with MIPS-III */
> +#define        MIPS_COP_0_BAD_VADDR    _(8)
> +#define        MIPS_COP_0_TLB_HI       _(10)
> +#define        MIPS_COP_0_STATUS       _(12)
> +#define        MIPS_COP_0_CAUSE        _(13)
> +#define        MIPS_COP_0_EXC_PC       _(14)
> +#define        MIPS_COP_0_PRID         _(15)
> +/* MIPS-III */
> +#define        MIPS_COP_0_TLB_LO0      _(2)
> +#define        MIPS_COP_0_TLB_LO1      _(3)
> +#define        MIPS_COP_0_TLB_PG_MASK  _(5)
> +#define        MIPS_COP_0_TLB_WIRED    _(6)
> +#define        MIPS_COP_0_COUNT        _(9)
> +#define        MIPS_COP_0_COMPARE      _(11)
> +#define        MIPS_COP_0_CONFIG       _(16)
> +#define        MIPS_COP_0_LLADDR       _(17)
> +#define        MIPS_COP_0_WATCH_LO     _(18)
> +#define        MIPS_COP_0_WATCH_HI     _(19)
> +#define        MIPS_COP_0_TLB_XCONTEXT _(20)
> +#define        MIPS_COP_0_ECC          _(26)
> +#define        MIPS_COP_0_CACHE_ERR    _(27)
> +#define        MIPS_COP_0_TAG_LO       _(28)
> +#define        MIPS_COP_0_TAG_HI       _(29)
> +#define        MIPS_COP_0_ERROR_PC     _(30)
> +/* MIPS32/64 */
> +#define        MIPS_COP_0_INFO         _(7)
> +#define        MIPS_COP_0_DEBUG        _(23)
> +#define        MIPS_COP_0_DEPC         _(24)
> +#define        MIPS_COP_0_PERFCNT      _(25)
> +#define        MIPS_COP_0_DATA_LO      _(28)
> +#define        MIPS_COP_0_DATA_HI      _(29)
> +#define        MIPS_COP_0_DESAVE       _(31)
> +/* MIPS32 Config register definitions */
> +#define MIPS_MMU_NONE                  0x00            /* No MMU present */
> +#define MIPS_MMU_TLB                   0x01            /* Standard TLB */
> +#define MIPS_MMU_BAT                   0x02            /* Standard BAT */
> +#define MIPS_MMU_FIXED                 0x03            /* Standard fixed mapping */
> +#define MIPS_CONFIG0_MT_MASK           0x00000380      /* bits 9..7 MMU Type */
> +#define MIPS_CONFIG0_MT_SHIFT          7
> +#define MIPS_CONFIG0_BE                        0x00008000      /* data is big-endian */
> +#define MIPS_CONFIG0_VI                        0x00000004      /* instruction cache is virtual */
> +#define MIPS_CONFIG1_TLBSZ_MASK                0x7E000000      /* bits 30..25 # tlb entries minus one */
> +#define MIPS_CONFIG1_TLBSZ_SHIFT       25
> +#define        MIPS_MAX_TLB_ENTRIES            64
> +#define MIPS_CONFIG1_IS_MASK           0x01C00000      /* bits 24..22 icache sets per way */
> +#define MIPS_CONFIG1_IS_SHIFT          22
> +#define MIPS_CONFIG1_IL_MASK           0x00380000      /* bits 21..19 icache line size */
> +#define MIPS_CONFIG1_IL_SHIFT          19
> +#define MIPS_CONFIG1_IA_MASK           0x00070000      /* bits 18..16 icache associativity */
> +#define MIPS_CONFIG1_IA_SHIFT          16
> +#define MIPS_CONFIG1_DS_MASK           0x0000E000      /* bits 15..13 dcache sets per way */
> +#define MIPS_CONFIG1_DS_SHIFT          13
> +#define MIPS_CONFIG1_DL_MASK           0x00001C00      /* bits 12..10 dcache line size */
> +#define MIPS_CONFIG1_DL_SHIFT          10
> +#define MIPS_CONFIG1_DA_MASK           0x00000380      /* bits  9.. 7 dcache associativity */
> +#define MIPS_CONFIG1_DA_SHIFT          7
> +#define MIPS_CONFIG1_LOWBITS           0x0000007F
> +#define MIPS_CONFIG1_C2                        0x00000040      /* Coprocessor 2 implemented */
> +#define MIPS_CONFIG1_MD                        0x00000020      /* MDMX ASE implemented (MIPS64) */
> +#define MIPS_CONFIG1_PC                        0x00000010      /* Performance counters implemented */
> +#define MIPS_CONFIG1_WR                        0x00000008      /* Watch registers implemented */
> +#define MIPS_CONFIG1_CA                        0x00000004      /* MIPS16e ISA implemented */
> +#define MIPS_CONFIG1_EP                        0x00000002      /* EJTAG implemented */
> +#define MIPS_CONFIG1_FP                        0x00000001      /* FPU implemented */
> + * Values for the code field in a break instruction.
> +#define        MIPS_BREAK_INSTR        0x0000000d
> +#define        MIPS_BREAK_VAL_MASK     0x03ff0000
> +#define        MIPS_BREAK_VAL_SHIFT    16
> +#define        MIPS_BREAK_KDB_VAL      512
> +#define        MIPS_BREAK_SSTEP_VAL    513
> +#define        MIPS_BREAK_BRKPT_VAL    514
> +#define        MIPS_BREAK_SOVER_VAL    515
> +#define        MIPS_BREAK_DDB_VAL      516
> +#define        MIPS_BREAK_KDB          (MIPS_BREAK_INSTR | \
> +                               (MIPS_BREAK_KDB_VAL << MIPS_BREAK_VAL_SHIFT))
> +#define        MIPS_BREAK_SSTEP        (MIPS_BREAK_INSTR | \
> +                               (MIPS_BREAK_SSTEP_VAL << MIPS_BREAK_VAL_SHIFT))
> +#define        MIPS_BREAK_BRKPT        (MIPS_BREAK_INSTR | \
> +                               (MIPS_BREAK_BRKPT_VAL << MIPS_BREAK_VAL_SHIFT))
> +#define        MIPS_BREAK_SOVER        (MIPS_BREAK_INSTR | \
> +                               (MIPS_BREAK_SOVER_VAL << MIPS_BREAK_VAL_SHIFT))
> +#define        MIPS_BREAK_DDB          (MIPS_BREAK_INSTR | \
> +                               (MIPS_BREAK_DDB_VAL << MIPS_BREAK_VAL_SHIFT))
> + * Mininum and maximum cache sizes.
> +#define        MIPS_MIN_CACHE_SIZE     (16 * 1024)
> +#define        MIPS_MAX_CACHE_SIZE     (256 * 1024)
> +#define        MIPS3_MAX_PCACHE_SIZE   (32 * 1024)     /* max. primary cache size */
> + * The floating point version and status registers.
> +#define        MIPS_FPU_ID     $0
> +#define        MIPS_FPU_CSR    $31
> + * The floating point coprocessor status register bits.
> +#define        MIPS_FPU_ROUNDING_BITS          0x00000003
> +#define        MIPS_FPU_ROUND_RN               0x00000000
> +#define        MIPS_FPU_ROUND_RZ               0x00000001
> +#define        MIPS_FPU_ROUND_RP               0x00000002
> +#define        MIPS_FPU_ROUND_RM               0x00000003
> +#define        MIPS_FPU_STICKY_BITS            0x0000007c
> +#define        MIPS_FPU_STICKY_INEXACT         0x00000004
> +#define        MIPS_FPU_STICKY_UNDERFLOW       0x00000008
> +#define        MIPS_FPU_STICKY_OVERFLOW        0x00000010
> +#define        MIPS_FPU_STICKY_DIV0            0x00000020
> +#define        MIPS_FPU_STICKY_INVALID         0x00000040
> +#define        MIPS_FPU_ENABLE_BITS            0x00000f80
> +#define        MIPS_FPU_ENABLE_INEXACT         0x00000080
> +#define        MIPS_FPU_ENABLE_UNDERFLOW       0x00000100
> +#define        MIPS_FPU_ENABLE_OVERFLOW        0x00000200
> +#define        MIPS_FPU_ENABLE_DIV0            0x00000400
> +#define        MIPS_FPU_ENABLE_INVALID         0x00000800
> +#define        MIPS_FPU_EXCEPTION_BITS         0x0003f000
> +#define        MIPS_FPU_EXCEPTION_INEXACT      0x00001000
> +#define        MIPS_FPU_EXCEPTION_UNDERFLOW    0x00002000
> +#define        MIPS_FPU_EXCEPTION_OVERFLOW     0x00004000
> +#define        MIPS_FPU_EXCEPTION_DIV0         0x00008000
> +#define        MIPS_FPU_EXCEPTION_INVALID      0x00010000
> +#define        MIPS_FPU_EXCEPTION_UNIMPL       0x00020000
> +#define        MIPS_FPU_COND_BIT               0x00800000
> +#define        MIPS_FPU_FLUSH_BIT              0x01000000      /* r4k,  MBZ on r3k */
> +#define        MIPS1_FPC_MBZ_BITS              0xff7c0000
> +#define        MIPS3_FPC_MBZ_BITS              0xfe7c0000
> + * Constants to determine if have a floating point instruction.
> +#define        MIPS_OPCODE_SHIFT       26
> +#define        MIPS_OPCODE_C1          0x11
> + * The low part of the TLB entry.
> +#define        MIPS1_TLB_PFN                   0xfffff000
> +#define        MIPS1_TLB_NON_CACHEABLE_BIT     0x00000800
> +#define        MIPS1_TLB_DIRTY_BIT             0x00000400
> +#define        MIPS1_TLB_VALID_BIT             0x00000200
> +#define        MIPS1_TLB_GLOBAL_BIT            0x00000100
> +#define        MIPS3_TLB_PFN                   0x3fffffc0
> +#define        MIPS3_TLB_ATTR_MASK             0x00000038
> +#define        MIPS3_TLB_ATTR_SHIFT            3
> +#define        MIPS3_TLB_DIRTY_BIT             0x00000004
> +#define        MIPS3_TLB_VALID_BIT             0x00000002
> +#define        MIPS3_TLB_GLOBAL_BIT            0x00000001
> +#define        MIPS1_TLB_PHYS_PAGE_SHIFT       12
> +#define        MIPS3_TLB_PHYS_PAGE_SHIFT       6
> +#define        MIPS1_TLB_PF_NUM                MIPS1_TLB_PFN
> +#define        MIPS3_TLB_PF_NUM                MIPS3_TLB_PFN
> +#define        MIPS1_TLB_MOD_BIT               MIPS1_TLB_DIRTY_BIT
> +#define        MIPS3_TLB_MOD_BIT               MIPS3_TLB_DIRTY_BIT
> + * MIPS3_TLB_ATTR values - coherency algorithm:
> + * 0: cacheable, noncoherent, write-through, no write allocate
> + * 1: cacheable, noncoherent, write-through, write allocate
> + * 2: uncached
> + * 3: cacheable, noncoherent, write-back (noncoherent)
> + * 4: cacheable, coherent, write-back, exclusive (exclusive)
> + * 5: cacheable, coherent, write-back, exclusive on write (sharable)
> + * 6: cacheable, coherent, write-back, update on write (update)
> + * 7: uncached, accelerated (gather STORE operations)
> +#define        MIPS3_TLB_ATTR_WT               0 /* IDT */
> +#define        MIPS3_TLB_ATTR_WT_WRITEALLOCATE 1 /* IDT */
> +#define        MIPS3_TLB_ATTR_UNCACHED         2 /* R4000/R4400, IDT */
> +#define        MIPS3_TLB_ATTR_WB_NONCOHERENT   3 /* R4000/R4400, IDT */
> +#define        MIPS3_TLB_ATTR_WB_EXCLUSIVE     4 /* R4000/R4400 */
> +#define        MIPS3_TLB_ATTR_WB_SHARABLE      5 /* R4000/R4400 */
> +#define        MIPS3_TLB_ATTR_WB_UPDATE        6 /* R4000/R4400 */
> +#define        MIPS4_TLB_ATTR_UNCACHED_ACCELERATED 7 /* R10000 */
> + * The high part of the TLB entry.
> +#define        MIPS1_TLB_VPN                   0xfffff000
> +#define        MIPS1_TLB_PID                   0x00000fc0
> +#define        MIPS1_TLB_PID_SHIFT             6
> +#define        MIPS3_TLB_VPN2                  0xffffe000
> +#define        MIPS3_TLB_ASID                  0x000000ff
> +#define        MIPS1_TLB_VIRT_PAGE_NUM         MIPS1_TLB_VPN
> +#define        MIPS3_TLB_VIRT_PAGE_NUM         MIPS3_TLB_VPN2
> +#define        MIPS3_TLB_PID                   MIPS3_TLB_ASID
> +#define        MIPS_TLB_VIRT_PAGE_SHIFT        12
> + * r3000: shift count to put the index in the right spot.
> +#define        MIPS1_TLB_INDEX_SHIFT           8
> + * The first TLB that write random hits.
> +#define        MIPS1_TLB_FIRST_RAND_ENTRY      8
> +#define        MIPS3_TLB_WIRED_UPAGES          1
> + * The number of process id entries.
> +#define        MIPS1_TLB_NUM_PIDS              64
> +#define        MIPS3_TLB_NUM_ASIDS             256
> + * Patch codes to hide CPU design differences between MIPS1 and MIPS3.
> +/* XXX simonb: this is before MIPS3_PLUS is defined (and is ugly!) */
> +#if !(defined(MIPS3) || defined(MIPS4) || defined(MIPS32) || defined(MIPS64)) \
> +    && defined(MIPS1)                          /* XXX simonb must be neater! */
> +#define        MIPS_TLB_PID_SHIFT              MIPS1_TLB_PID_SHIFT
> +#define        MIPS_TLB_NUM_PIDS               MIPS1_TLB_NUM_PIDS
> +#endif
> +#if (defined(MIPS3) || defined(MIPS4) || defined(MIPS32) || defined(MIPS64)) \
> +    && !defined(MIPS1)                         /* XXX simonb must be neater! */
> +#define        MIPS_TLB_PID_SHIFT              0
> +#define        MIPS_TLB_NUM_PIDS               MIPS3_TLB_NUM_ASIDS
> +#endif
> +#if !defined(MIPS_TLB_PID_SHIFT)
> +#define        MIPS_TLB_PID_SHIFT \
> +    ((MIPS_HAS_R4K_MMU) ? 0 : MIPS1_TLB_PID_SHIFT)
> +#define        MIPS_TLB_NUM_PIDS \
> +    ((MIPS_HAS_R4K_MMU) ? MIPS3_TLB_NUM_ASIDS : MIPS1_TLB_NUM_PIDS)
> +#endif
> + * CPU processor revision IDs for company ID == 0 (non mips32/64 chips)
> +#define        MIPS_R2000      0x01    /* MIPS R2000                   ISA I   */
> +#define        MIPS_R3000      0x02    /* MIPS R3000                   ISA I   */
> +#define        MIPS_R6000      0x03    /* MIPS R6000                   ISA II  */
> +#define        MIPS_R4000      0x04    /* MIPS R4000/R4400             ISA III */
> +#define        MIPS_R3LSI      0x05    /* LSI Logic R3000 derivative   ISA I   */
> +#define        MIPS_R6000A     0x06    /* MIPS R6000A                  ISA II  */
> +#define        MIPS_R3IDT      0x07    /* IDT R3041 or RC36100         ISA I   */
> +#define        MIPS_R10000     0x09    /* MIPS R10000                  ISA IV  */
> +#define        MIPS_R4200      0x0a    /* NEC VR4200                   ISA III */
> +#define        MIPS_R4300      0x0b    /* NEC VR4300                   ISA III */
> +#define        MIPS_R4100      0x0c    /* NEC VR4100                   ISA III */
> +#define        MIPS_R12000     0x0e    /* MIPS R12000                  ISA IV  */
> +#define        MIPS_R14000     0x0f    /* MIPS R14000                  ISA IV  */
> +#define        MIPS_R8000      0x10    /* MIPS R8000 Blackbird/TFP     ISA IV  */
> +#define        MIPS_RC32300    0x18    /* IDT RC32334,332,355          ISA 32  */
> +#define        MIPS_R4600      0x20    /* QED R4600 Orion              ISA III */
> +#define        MIPS_R4700      0x21    /* QED R4700 Orion              ISA III */
> +#define        MIPS_R3SONY     0x21    /* Sony R3000 based             ISA I   */
> +#define        MIPS_R4650      0x22    /* QED R4650                    ISA III */
> +#define        MIPS_TX3900     0x22    /* Toshiba TX39 family          ISA I   */
> +#define        MIPS_R5000      0x23    /* MIPS R5000                   ISA IV  */
> +#define        MIPS_R3NKK      0x23    /* NKK R3000 based              ISA I   */
> +#define        MIPS_RC32364    0x26    /* IDT RC32364                  ISA 32  */
> +#define        MIPS_RM7000     0x27    /* QED RM7000                   ISA IV  */
> +#define        MIPS_RM5200     0x28    /* QED RM5200s                  ISA IV  */
> +#define        MIPS_TX4900     0x2d    /* Toshiba TX49 family          ISA III */
> +#define        MIPS_R5900      0x2e    /* Toshiba R5900 (EECore)       ISA --- */
> +#define        MIPS_RC64470    0x30    /* IDT RC64474/RC64475          ISA III */
> +#define        MIPS_TX7900     0x38    /* Toshiba TX79                 ISA III+*/
> +#define        MIPS_R5400      0x54    /* NEC VR5400                   ISA IV  */
> +#define        MIPS_R5500      0x55    /* NEC VR5500                   ISA IV  */
> + * CPU revision IDs for some prehistoric processors.
> +/* For MIPS_R3000 */
> +#define        MIPS_REV_R3000          0x20
> +#define        MIPS_REV_R3000A         0x30
> +/* For MIPS_TX3900 */
> +#define        MIPS_REV_TX3912         0x10
> +#define        MIPS_REV_TX3922         0x30
> +#define        MIPS_REV_TX3927         0x40
> +/* For MIPS_R4000 */
> +#define        MIPS_REV_R4000_A        0x00
> +#define        MIPS_REV_R4000_B        0x22
> +#define        MIPS_REV_R4000_C        0x30
> +#define        MIPS_REV_R4400_A        0x40
> +#define        MIPS_REV_R4400_B        0x50
> +#define        MIPS_REV_R4400_C        0x60
> +/* For MIPS_TX4900 */
> +#define        MIPS_REV_TX4927         0x22
> + * CPU processor revision IDs for company ID == 1 (MIPS)
> +#define        MIPS_4Kc        0x80    /* MIPS 4Kc                     ISA 32  */
> +#define        MIPS_5Kc        0x81    /* MIPS 5Kc                     ISA 64  */
> +#define        MIPS_20Kc       0x82    /* MIPS 20Kc                    ISA 64  */
> +#define        MIPS_4Kmp       0x83    /* MIPS 4Km/4Kp                 ISA 32  */
> +#define        MIPS_4KEc       0x84    /* MIPS 4KEc                    ISA 32  */
> +#define        MIPS_4KEmp      0x85    /* MIPS 4KEm/4KEp               ISA 32  */
> +#define        MIPS_4KSc       0x86    /* MIPS 4KSc                    ISA 32  */
> +#define        MIPS_M4K        0x87    /* MIPS M4K                     ISA 32  Rel 2 */
> +#define        MIPS_25Kf       0x88    /* MIPS 25Kf                    ISA 64  */
> +#define        MIPS_5KE        0x89    /* MIPS 5KE                     ISA 64  Rel 2 */
> +#define        MIPS_4KEc_R2    0x90    /* MIPS 4KEc_R2                 ISA 32  Rel 2 */
> +#define        MIPS_4KEmp_R2   0x91    /* MIPS 4KEm/4KEp_R2            ISA 32  Rel 2 */
> +#define        MIPS_4KSd       0x92    /* MIPS 4KSd                    ISA 32  Rel 2 */
> +#define        MIPS_24K        0x93    /* MIPS 24Kc/24Kf               ISA 32  Rel 2 */
> +#define        MIPS_34K        0x95    /* MIPS 34K                     ISA 32  R2 MT */
> +#define        MIPS_24KE       0x96    /* MIPS 24KEc                   ISA 32  Rel 2 */
> +#define        MIPS_74K        0x97    /* MIPS 74Kc/74Kf               ISA 32  Rel 2 */
> + * AMD (company ID 3) use the processor ID field to donote the CPU core
> + * revision and the company options field do donate the SOC chip type.
> +/* CPU processor revision IDs */
> +#define        MIPS_AU_REV1    0x01    /* Alchemy Au1000 (Rev 1)       ISA 32  */
> +#define        MIPS_AU_REV2    0x02    /* Alchemy Au1000 (Rev 2)       ISA 32  */
> +/* CPU company options IDs */
> +#define        MIPS_AU1000     0x00
> +#define        MIPS_AU1500     0x01
> +#define        MIPS_AU1100     0x02
> +#define        MIPS_AU1550     0x03
> + * CPU processor revision IDs for company ID == 4 (Broadcom)
> +#define        MIPS_SB1        0x01    /* SiByte SB1                   ISA 64  */
> + * CPU processor revision IDs for company ID == 5 (SandCraft)
> +#define        MIPS_SR7100     0x04    /* SandCraft SR7100             ISA 64  */
> + * FPU processor revision ID
> +#define        MIPS_SOFT       0x00    /* Software emulation           ISA I   */
> +#define        MIPS_R2360      0x01    /* MIPS R2360 FPC               ISA I   */
> +#define        MIPS_R2010      0x02    /* MIPS R2010 FPC               ISA I   */
> +#define        MIPS_R3010      0x03    /* MIPS R3010 FPC               ISA I   */
> +#define        MIPS_R6010      0x04    /* MIPS R6010 FPC               ISA II  */
> +#define        MIPS_R4010      0x05    /* MIPS R4010 FPC               ISA II  */
> +#define        MIPS_R31LSI     0x06    /* LSI Logic derivate           ISA I   */
> +#define        MIPS_R3TOSH     0x22    /* Toshiba R3000 based FPU      ISA I   */
> +#ifdef ENABLE_MIPS_TX3900
> +#include <freebsd/mips/r3900regs.h>
> +#endif
> +#ifdef MIPS3_5900
> +#include <freebsd/mips/r5900regs.h>
> +#endif
> +#ifdef MIPS64_SB1
> +#include <freebsd/mips/sb1regs.h>
> +#endif
> +#endif /* _MIPS_CPUREGS_HH_ */
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
