libbsd status - uma help desired
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Jul 18 21:13:28 UTC 2012
Hi
After some struggles and temporarily disabling IPV6 so we
can focus on just IPV4, Jennifer and I now have it so anyone
can easily help.
+ Check out rtems-libbsd from git
+ Apply disable_ipv6.diff
+ Use the mips/jmr3904 BSP. It has a simulator included
with gdb and faults on all accesses from 0x0 to 0x87ffffff
which is handy when tracking down issues. :)
+ The test testsuite/link01 will attempt to initialize the stack
and begin to configure the IP address of the lo0 interface.
socket() works, ioctl() works, close() ends like this:
IPsec: Initialized Security Association Processing.
devctl: !system=IFNET subsystem=enc0 type=ATTACH
devctl: !system=IFNET subsystem=lo0 type=ATTACH
Initializing interfaces
mips-core: 4 byte write to unmapped address 0x0 at 0x880713c8
Program received signal SIGBUS, Bus error.
0x880713c8 in zone_free_item (zone=zone at entry=0x88130490,
item=item at entry=0x88191480,
udata=udata at entry=0x0, skip=skip at entry=SKIP_DTOR, flags=flags at entry=2)
at freebsd/vm/uma_core.c:2803
2803 LIST_REMOVE(slab, us_link);
(gdb)
As best Jennifer and I can tell, we never see the item added to
the list it is being removed from.
Any help debugging this or insight into the uma code is
appreciated.
Joel Sherrill, Ph.D. Director of Research& Development
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120718/9374cbce/attachment.bin>
