HEADSUP: Adding auto*generated files to rtems-4.11's git
Ralf Corsepius ralf.corsepius at rtems.org
Wed Jul 25 13:53:03 UTC 2012
On 07/25/2012 03:48 PM, Sebastian Huber wrote:
> On 07/25/2012 03:34 PM, Ralf Corsepius wrote:
>>>  What happens if you switch to/from branches which
>>> don't have these files?
>> If all files are in git on all branches, you should be able to switch
>> between
>> branches.
> Ok, but what happens if I switch from one revision without these files
> to a revision with these files, e.g. during a bisect of the master
> branch?  During a switch without -> with Git has to overwrite the files?
Just don't do this. Git will only work if everything is commited.
>> [PS.: All non-trunk rtems-branches currently are rotten in git.
>> Switching between rtems-branches will not work.]
> So switching between rtems-4.10 and master will not work?
Correct - the rtems-4.10 has effectly been unattended since git was
introduced and would need to be updated.
In fact, switching between rtems-4.x and trunk already doesn't work.
Ralf
