[GSoC] lm3s6965 on QEMU issue
Hesham Moustafa
heshamelmatary at gmail.com
Fri Jul 27 15:06:34 UTC 2012
> Message: 8
> Date: Fri, 27 Jul 2012 05:44:29 +0200
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> To: rtems-devel at rtems.org
> Subject: Re: [GSoC] lm3s6965 on QEMU issue
> Message-ID: <50120E9D.6060809 at embedded-brains.de>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> On 07/27/2012 11:40 AM, Hesham Moustafa wrote:
> > Hey,
> > I have applied patches for lm3s69xx BSP and run qemu with this command
> but i
> > get that error
> > $./qemu-system-arm -nographic -M lm3s6965evb -kernel
> /home/hesham/lm/arm-rtems4.11/c/lm3s6965/testsuites/samples/hello/hello.exe
> > *** HELLO WORLD TEST ***
> > Hello World
> > *** END OF HELLO WORLD TEST ***
> > qemu: hardware error: gic_dist_writeb: Bad offset 4f0
> > CPU #0:
> > R00=00000000 R01=00000004 R02=00000000 R03=e000e100
> > R04=00000000 R05=00000000 R06=00000000 R07=00000000
> > R08=00000000 R09=00000000 R10=00000000 R11=00000000
> > R12=00000001 R13=20001130 R14=0000014b R15=00000466
> > PSR=600001b3 -ZC- T svc32
> > Aborted (core dumped)
> > Do i have to worry about that? and if yes how could i solve that error ?
> Everything works fine. This error shows that the application terminated
> successfully. I figured out no explicit way to reset the Qemu system on
> target
> request so I have chosen an invalid memory access for that.
> and how could i debug with QEMU, If i can with gdb, how can i connect QEMU
with GDB to run a test case ?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120727/73086517/attachment.html>
