Status of SMP Work
Sebastian Huber
Sun Jul 29 15:53:21 UTC 2012
Hello,
I would like to summarize the current status of the SMP work that is
already done in RTEMS. Please correct me if something is wrong or
missing. An interesting document about real-time systems on SMP is the
dissertation from Björn B. Brandenburg
(http://www.cs.unc.edu/~bbb/diss/). He mentions also RTEMS as a
classical uni-processor real-time system.
1. We have now per-CPU information so that some state can be maintained
on a per-CPU basis:
http://git.rtems.org/rtems/tree/cpukit/score/include/rtems/score/percpu.h
Access to several global variables has been encapsulated with a function.
2. We have now a configurable scheduler (examples are FP, EDF, CBS)
which makes it possible to develop SMP capable scheduler more easily.
3. We have a first support for spin locks. The current implementation is
not suitable for real-time applications:
http://git.rtems.org/rtems/tree/cpukit/score/src/smplock.c
Here interrupts are disabled before the loop and thus the disable
interrupt time on this core is unbounded. We need also a lock with FIFO
properties like a MCS lock.
4. Support for atomic operations is a current GSoC project and now also
part of the C and C++ standard.
5. There are a couple of PRs with an unknown status, like
https://www.rtems.org/bugzilla/show_bug.cgi?id=1946
https://www.rtems.org/bugzilla/buglist.cgi?quicksearch=smp
6. It seems that in the current SMP work the sections covered by
_Thread_Disable_dispatch() and _Thread_Enable_dispatch() produce a
critical section that is protected by a giant lock:
http://git.rtems.org/rtems/tree/cpukit/score/src/threaddispatchdisablelevel.c
These critical sections are pretty huge and I don't think this scales
well with an increasing processor count. Why was it not possible to move
the thread dispatch disable level into the per-CPU information and use
_ISR_Disable()/_ISR_Enable() as the giant lock? This has the benefit
that we can probably use existing interrupt and exception code. It
makes it also possible to gradually replace the
_ISR_Disable()/_ISR_Enable() sections with more specific locks, e.g. one
for a basic semaphore operation and one for the general blocking path.
I think only thread restart and delete operations are problematic here.
Did I miss something important? What lead to the decision of a global
thread dispatch disable level?
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
