[GSOC] directive_failed(status, "string") meaning
Sebastian Huber
Mon Jul 2 13:38:14 UTC 2012
On 07/02/2012 03:26 PM, Xiaochen Pan wrote:
> I came across this line when reading the code in testsuites. I would like to know which header file is this function defined and the precise definition of this function.
You can use a "grep" program for this to search in the source code. You can
also use a program like ctags, cscope, or clang to index the sources.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
