[GSOC] directive_failed(status, "string") meaning
Gedare Bloom
gedare at rtems.org
Mon Jul 2 15:05:15 UTC 2012
for example:
cd rtems
grep "directive_failed" -R *
I prefer to use ack (or ack-grep), which is tuned to ignore certain
kinds of files leading to faster searches, though I have to configure
it to find the .inl files
-Gedare
On Mon, Jul 2, 2012 at 9:38 AM, Sebastian Huber
> On 07/02/2012 03:26 PM, Xiaochen Pan wrote:
>> I came across this line when reading the code in testsuites. I would like
>> to know which header file is this function defined and the precise
>> definition of this function.
> You can use a "grep" program for this to search in the source code. You can
> also use a program like ctags, cscope, or clang to index the sources.
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> rtems-devel mailing list
> rtems-devel at rtems.org
