fsbenchmark
Thu Jul 12 14:59:24 UTC 2012
Hi,
the idea to use a data structure to drive the test code is good, but why is it
in ASCII text?  The benchmark is only interesting for file systems which use
bdbuf (DOSFS and RFS) so it would be nice if IMFS tests don't pull in the
bdbuf.  Can you please send patches in the git email format with author name
and commit message.   Since you wrote this code probably yourself you should
put your copyright into the file header.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
