fsbenchmark
Xiang Cui medivhc at gmail.com
Fri Jul 13 02:18:49 UTC 2012
Hi
On Thu, Jul 12, 2012 at 10:59 PM, Sebastian Huber
> Hi,
> the idea to use a data structure to drive the test code is good, but why is
> it in ASCII text?  The benchmark is only interesting for file systems which
> use bdbuf (DOSFS and RFS) so it would be nice if IMFS tests don't pull in
> the bdbuf.  Can you please send patches in the git email format with author
> name and commit message.   Since you wrote this code probably yourself you
> should put your copyright into the file header.
Thanks for the advice. I will complete the patch in next week.
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> rtems-devel mailing list
> rtems-devel at rtems.org
