pull request for atomic
yangwei weiyang
wei.a.yang at gmail.com
Tue Jul 24 16:29:19 UTC 2012
2012/7/23 Gedare Bloom <gedare at rtems.org>:
> On Mon, Jul 23, 2012 at 4:45 AM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>> 2012/7/23 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>>> Hi,
>>> is it possible to squash the commits together? This makes it easier to
>>> review.
>> Hi Sebastian, firstly thank you for your comments. The commits are a
>> little trivial because all commits are submitted step by step. And i
>> do not know how to make a pull request on github with a single patch
>> from first commit to last commit. Or i can generate a patch manually
>> and send it to mail list.
> git rebase -i
> should let you specify revision range and squash commits together.
> then you can push a new branch and make new request.
Hi Gedare, Could you tell me more details about this command.
I use git rebase master atomic but all commits do not squash together.
>>> Since you wrote the files probably on your own they should have your
>>> copyright.
>> OK, i will add the copyright to the appropriate files.
>>> The file "cpukit/score/cpu/i386/rtems/score/atomic_cpu.h" should include a
>>> generic file e.g. "cpukit/score/include/rtems/score/genericcpuatomic.h" with
>>> the type definitions. I think we can use this generic file on every CPU
>>> port.
>> Yeah, agree. And RTEMS support so many architectures so i will think
>> about what types should be generic to all cpu architecture.
>>> I suggest to use the following type names:
>>> Atomic_Int
>>> Atomic_Long
>>> Atomic_Int32
>>> Atomic_Int64
>>> Atomic_Pointer
>> OK. and which file follow this rule that i can study the name rule on RTEMS?
>>> I suggest to rename "atomic_cpu.h" into "cpuatomic.h". Currently there is
>>> no header file in the score with a "_".
>> OK.
>>> On 07/22/2012 06:08 PM, yangwei weiyang wrote:
>>>> Hi all,
>>>> I have made a pull request for review the source code of atomic, and
>>>> could you give me any comments? thank you!
>>>> pull request link is blow:
>>>> https://github.com/RTEMS/rtems/pull/1
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>>> Phone : +49 89 18 90 80 79-6
>>> Fax : +49 89 18 90 80 79-9
>>> E-Mail : sebastian.huber at embedded-brains.de
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>> Wei Yang
>> Best Regards
Wei Yang
Best Regards
