pull request for atomic
Tue Jul 24 18:42:14 UTC 2012
On Tue, Jul 24, 2012 at 12:29 PM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
> 2012/7/23 Gedare Bloom <gedare at rtems.org>:
>> On Mon, Jul 23, 2012 at 4:45 AM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>>> 2012/7/23 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>>>> Hi,
>>>> is it possible to squash the commits together?  This makes it easier to
>>>> review.
>>> Hi Sebastian, firstly thank you for your comments. The commits are a
>>> little trivial because all commits are submitted step by step. And i
>>> do not know how to make a pull request on github with a single patch
>>> from first commit to last commit. Or i can generate a patch manually
>>> and send it to mail list.
>> git rebase -i
>> should let you specify revision range and squash commits together.
>> then you can push a new branch and make new request.
> Hi Gedare, Could you tell me more details about this command.
> I use git rebase master atomic but all commits do not squash together.
http://git-scm.com/book/en/Git-Tools-Rewriting-History#Squashing-Commits
>>>> Since you wrote the files probably on your own they should have your
>>>> copyright.
>>> OK, i will add the copyright to the appropriate files.
>>>> The file "cpukit/score/cpu/i386/rtems/score/atomic_cpu.h" should include a
>>>> generic file e.g. "cpukit/score/include/rtems/score/genericcpuatomic.h" with
>>>> the type definitions.  I think we can use this generic file on every CPU
>>>> port.
>>> Yeah, agree. And RTEMS support so many architectures so i will think
>>> about what types should be generic to all cpu architecture.
>>>> I suggest to use the following type names:
>>>> Atomic_Int
>>>> Atomic_Long
>>>> Atomic_Int32
>>>> Atomic_Int64
>>>> Atomic_Pointer
>>> OK. and which file follow this rule that i can study the name rule on RTEMS?
>>>> I suggest to rename "atomic_cpu.h" into "cpuatomic.h".  Currently there is
>>>> no header file in the score with a "_".
>>> OK.
>>>> On 07/22/2012 06:08 PM, yangwei weiyang wrote:
>>>>> Hi all,
>>>>> I have made a pull request for review the source code of atomic, and
>>>>> could you give me any comments? thank you!
>>>>> pull request link is blow:
>>>>> https://github.com/RTEMS/rtems/pull/1
>>>> Sebastian Huber, embedded brains GmbH
>>>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>>>> Phone   : +49 89 18 90 80 79-6
>>>> Fax     : +49 89 18 90 80 79-9
>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>> PGP     : Public key available on request.
>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> rtems-devel at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>> Wei Yang
>>> Best Regards
> Wei Yang
> Best Regards
