v850 tool patches
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Jun 11 21:37:15 UTC 2012
Hi,
I just committed a port of RTEMS to the Renesas v850. These are
the tool patches for the v850. There technically isn't much needed.
+ binutils - nothing
+ gdb - nothing
+ newlib - add v850 to _types.h
+ gcc - add v850-*-rtems* to config.gcc
add config/v850/rtems.h as new file
v850 has regressed some on gcc but is sufficient to build a functional
RTEMS on all variants but the "e1". The newest test results are from
the 4.5 time frame:
http://gcc.gnu.org/ml/gcc-testresults/2011-10/msg01663.html
Results for 4.8.0 are here with many more failures:
http://www.rtems.org/pipermail/rtems-tooltestresults/2012-May/000598.html
We will need to run a git bisect to figure out where things broke
and get that reported.
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120611/470e43a8/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120611/470e43a8/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120611/470e43a8/attachment-0001.bin>
