Does anyone know the possible reason for such error?
Sun Jun 17 02:56:05 UTC 2012
If these are the RTEMS project provided tools then you did not provide a path to the install point of the desired BSP.
--joel
"panx at seas.upenn.edu" <panx at seas.upenn.edu> wrote:
>Hello,
>I come across this error message when trying to compile some tests:
>sparc-rtems4.11-gcc -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I. -I..
>-I../../support/include   -g -O2 -MT init.o -MD -MP -MF .deps/init.Tpo
>-c -o init.o init.c
>sparc-rtems4.11-gcc: error: bsp_specs: No such file or directory
>What is the possible reason for such errors? How to fix this?
>Regards,
>Xiaochen Pan
>_______________________________________________
>rtems-devel mailing list
>rtems-devel at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-devel
