[PATCH 2/3] score: New structure TOD_Control
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Jun 13 12:32:54 UTC 2012
That's the method. Is it used? Is it correct to return an address?
Also you removed the "at tick" method. Did you restrict the math to using timestamp methods? You cannot assume 64 bit integers on all platforms. We are pretty sure they are always better on 32 bit CPUs but haven't analyzed 16 bit ones.
Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>On 06/13/2012 01:52 PM, Joel Sherrill wrote:
>> _Timestamp_Get_seconds_since_epoch() returns an address. Is this correct based on its usage? Is it used?
>There is no such function. Do you mean:
>#define _TOD_Seconds_since_epoch() \
> _Timestamp_Get_seconds(&_TOD.now)
>> Coretodtickle.c has a comment above each of the lines you changed that says it is in timespec format. I am not sure that is right.
>These comments are fixed in patch 3.
>Sebastian Huber, embedded brains GmbH
>Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>Phone : +49 89 18 90 80 79-6
>Fax : +49 89 18 90 80 79-9
>E-Mail : sebastian.huber at embedded-brains.de
>PGP : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
