GSoC RTEMS compilation issues
Julien Delange julien.delange at gmail.com
Mon Jun 18 11:57:34 UTC 2012
Hi,
I think you should read [1] even if your description of the
--enable-maintainer-mode seems correct. About the problem you have, it
would be great to be able to make a test. so far, I do not see the
problem just by inspecting the sources and so, it would require more
investigation.
So, if you can provide few instructions to get the sources tree with
your changes, we might also give a try :-)
Best,
[1] http://rtemsramblings.blogspot.nl/2012/05/rtems-build-system-ruminations.html
