[GSOC] How to compile with sparc-rtems4.11-g++ command?
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jun 21 21:04:07 UTC 2012
On 06/21/2012 03:54 PM, Xiaochen Pan wrote:
> Hello all,
> Here is the command:
> sparc-rtems4.11-g++ -o runner runner.cpp
You are still not building with the arguments to have RTEMS and the
BSP .h files available or included with your application.
If you use the Makefiles from examples-v2, simply list your C++
sources as CXXSRCS like this
CXXSRCS = init.cc
> Here are the error messages:
> */opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/../../../../sparc-rtems4.11/bin/ld:
> warning: cannot find entry symbol _start; defaulting to 00010074
> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/libstdc++.a(eh_alloc.o):
> In function `__gthread_mutex_destroy':
> /builddir/build/BUILD/rtems-4.11-sparc-rtems4.11-gcc-4.6.2/build/sparc-rtems4.11/libstdc++-v3/include/sparc-rtems4.11/bits/gthr-default.h:114:
> undefined reference to `rtems_gxx_mutex_destroy'
> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/libstdc++.a(locale.o):
> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/libstdc++.a(locale_init.o):
> collect2: ld returned 1 exit status*
> How to fix this problem?
> regards,
> xiaochen
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120621/925b285f/attachment-0001.html>
