[GSOC] How to compile with sparc-rtems4.11-g++ command?
panx at seas.upenn.edu panx at seas.upenn.edu
Thu Jun 21 21:25:18 UTC 2012
Here is another one error message:
sparc-rtems4.11-g++
-B/home/rtems/rtems-4.11-work/b-sis/sparc-rtems4.11/sis/lib/ -specs
bsp_specs -qrtems   -g -Wall  -g    -mcpu=cypress     -c   -o
o-optimize/runner.o runner.cc
Assembler messages:
Fatal error: can't create o-optimize/runner.o: No such file or directory
make: *** [o-optimize/runner.o] Error 1
In the makefile from example-v2, I modified the following part:
CSRCS = test.c
COBJS = $(CSRCS:%.c=${ARCH}/%.o)
to be like this:
CSRCS = runner.cpp
COBJS = $(CSRCS:%.cpp=${ARCH}/%.o)
Which part I was not doing correctly?
Regards,
xiaochen
Quoting Joel Sherrill <joel.sherrill at OARcorp.com>:
> On 06/21/2012 03:54 PM, Xiaochen Pan wrote:
>> Hello all,
>> Here is the command:
>> sparc-rtems4.11-g++ -o runner runner.cpp
> You are still not building with the arguments to have RTEMS and the
> BSP .h files available or included with your application.
> If you use the Makefiles from examples-v2, simply list your C++
> sources as CXXSRCS like this
> CXXSRCS = init.cc
>> Here are the error messages:
>> */opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/../../../../sparc-rtems4.11/bin/ld: warning: cannot find entry symbol _start; defaulting to
>> 00010074
>> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/libstdc++.a(eh_alloc.o): In
>> function `__gthread_mutex_destroy':
>> /builddir/build/BUILD/rtems-4.11-sparc-rtems4.11-gcc-4.6.2/build/sparc-rtems4.11/libstdc++-v3/include/sparc-rtems4.11/bits/gthr-default.h:114: undefined reference to
>> `rtems_gxx_mutex_destroy'
>> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/libstdc++.a(locale.o): In
>> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/libstdc++.a(locale_init.o):
>> In function `__gthread_mutex_destroy':
>> collect2: ld returned 1 exit status*
>> How to fix this problem?
>> regards,
>> xiaochen
> Joel Sherrill, Ph.D.             Director of Research&   Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>     Support Available             (256) 722-9985
