AG patches chunk C
Daniel Hellstrom
daniel at gaisler.com
Thu Mar 29 11:38:26 UTC 2012
Hello,
This is the third chunk of patches, it consist mostly of code cleanups which is hopefully easier to review. There are still one open patch, PATCH10 (IO_MANAGER). As nothing in chunk C depends on
PATCH10, I will proceed.
As before, PATCH means I will send them on the rtems-devel list solely, PR means I will file a bugzilla PR.
Thanks,
Daniel
+ SPARC specific enhancements
LIST 9130379 LEON3: IRQ index mask was bad, but always shifted out anyway
LIST c69bf34 SPARC BSPS: added defines for set_vec type argument to bsp.h
LIST 74eda76 LEON3: various cleanups in leon.h
+ SPARC specific bugs
PR 76a7113 LEON3: clock timer indexing should be consequent
+ General bugs
PR f867d27 LEON3: fix GRETH interrupt initialization bug (BUG2044)
+ General enhancements
LIST cd5d29a GRETH: removed the use of rtems_set_clock() in auto-nego timeout
LIST e7e3588 SMC91111: remove old unused LEON2/LEON3 initialization code
LIST 50a1497 SMP: remove unused code in simple SMP scheduler
Patches are listed in reverse apply order:
commit 50a14970d1aa0edab4eec8ef1ed9ca2c8a6704a1
Author: Daniel Hellstrom <daniel at gaisler.com>
Date: Tue Mar 20 13:46:29 2012 +0100
A similar if-statement is just above, I can see no reason why
to have this double code.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
cpukit/score/src/schedulersimplesmpschedule.c | 3 ---
1 files changed, 0 insertions(+), 3 deletions(-)
commit 74eda7652142cfbae9ca01da06e340f54dd7416d
Date: Tue Dec 6 10:56:05 2011 +0100
Removed old LEON2 definitions never used in LEON3 leon.h.
c/src/lib/libbsp/sparc/leon3/include/leon.h | 64 +--------------------------
1 files changed, 1 insertions(+), 63 deletions(-)
commit c69bf349873f84834ecebe59602d3bcfa7271006
Date: Tue Dec 6 10:42:33 2011 +0100
c/src/lib/libbsp/sparc/erc32/include/bsp.h | 4 ++++
c/src/lib/libbsp/sparc/erc32/startup/setvec.c | 2 +-
c/src/lib/libbsp/sparc/leon2/include/bsp.h | 4 ++++
c/src/lib/libbsp/sparc/leon2/startup/setvec.c | 2 +-
c/src/lib/libbsp/sparc/leon3/include/bsp.h | 4 ++++
c/src/lib/libbsp/sparc/leon3/startup/setvec.c | 2 +-
6 files changed, 15 insertions(+), 3 deletions(-)
commit 9130379f20488e6943c9a237fdd2c04f18324a78
Date: Mon Dec 5 17:28:57 2011 +0100
c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 2 +-
1 files changed, 1 insertions(+), 1 deletions(-)
commit 76a711327f944b0a6357e4ef9435c65a1a46b515
Date: Mon Dec 5 17:21:25 2011 +0100
c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 6 +++---
1 files changed, 3 insertions(+), 3 deletions(-)
commit e7e3588ba40c0194f9a186988394c62aae1936ab
Date: Thu Mar 22 13:59:19 2012 +0100
SMC91111: remove old unused LEON2/LEON3 intialization code
c/src/libchip/network/smc91111.c | 36 ------------------------------------
1 files changed, 0 insertions(+), 36 deletions(-)
commit f867d2738c89db90402e2b44366a71f0f2efd338
Date: Thu Mar 22 12:00:40 2012 +0100
Fixed a bug where the vector number is used to clean and unmask
the IRQ at the IRQ controller, the irq number must be used.
.../lib/libbsp/sparc/leon3/leon_greth/leon_greth.c | 8 ++++----
1 files changed, 4 insertions(+), 4 deletions(-)
commit cd5d29a983f1d502238bee5923f38b310a46597d
Date: Fri Dec 2 10:54:44 2011 +0100
c/src/libchip/network/greth.c | 47 +++++++++++++++-------------------------
1 files changed, 18 insertions(+), 29 deletions(-)
