[rtems commit] Merge branch 'master' of ssh://git.rtems.org/data/git/rtems
Sebastian Huber
Tue Mar 6 14:48:56 UTC 2012
On 03/06/2012 03:43 PM, Joel Sherrill wrote:
> I did not do a git merge this time. :(
> I committed a 1 line patch and pushed it to my personal
> repo's master. Than I got the non-fast-forward message.
> So I did a "git fetch upstream" which didn't resolve it.
> Neither did a simple "git pull"
> "git pull upstream master" finally pulled a number of changes
> and when I did the "git push upstream master", it apparently
> did this. :(
> Earlier I thought we decided it was a side-effect of git merge.
Yes, and a git pull is a git fetch + merge!
Before you use git push, you should make sure that a fast forward is possible,
e.g. use "git rebase -i".
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
