[rtems commit] Merge branch 'master' of ssh://git.rtems.org/data/git/rtems
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Mar 6 17:09:27 UTC 2012
On 03/06/2012 08:48 AM, Sebastian Huber wrote:
> On 03/06/2012 03:43 PM, Joel Sherrill wrote:
>> I did not do a git merge this time. :(
>> I committed a 1 line patch and pushed it to my personal
>> repo's master. Than I got the non-fast-forward message.
>> So I did a "git fetch upstream" which didn't resolve it.
>> Neither did a simple "git pull"
>> "git pull upstream master" finally pulled a number of changes
>> and when I did the "git push upstream master", it apparently
>> did this. :(
>> Earlier I thought we decided it was a side-effect of git merge.
> Yes, and a git pull is a git fetch + merge!
> Before you use git push, you should make sure that a fast forward is possible,
> e.g. use "git rebase -i".
Thanks Sebastian.
Joel Sherrill, Ph.D. Director of Research& Development
