[PATCH] confdefs: Add declaration for unlimited objects.
Joel Sherrill
Joel.Sherrill at OARcorp.com
Wed Mar 28 13:55:17 UTC 2012
But confdefs.h does define things. In many cases, an ifndef is followed by a define
to a default value. Those are the cases to document. If I encouraged Gedare to
Doxygen something else (instead of just a good comment), then that was a mistake.
Certainly everything in there isn't documented but some is:
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/confdefs_8h.html#acb6d25ad3c80a72ef6e3b461540b099b
--joel
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] On Behalf Of Sebastian Huber [sebastian.huber at embedded-brains.de]
Sent: Wednesday, March 28, 2012 2:04 AM
To: rtems-devel at rtems.org
Subject: Re: [PATCH] confdefs: Add declaration for unlimited objects.
On 03/28/2012 01:33 AM, Joel Sherrill wrote:
> I thought confdefs.h was mostly if not all Doxygen comments now. If so, the new element should have Doxygen markup
Doxygen documentation in this file makes no sense, since you can only document
things which are defined. To document the configuration defines we would have
to add a new file which defines every switch and add comments to them.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
rtems-devel mailing list
http://www.rtems.org/mailman/listinfo/rtems-devel
