[PATCH] confdefs: Add declaration for unlimited objects.
Thu Mar 29 07:06:32 UTC 2012
On 03/28/2012 03:55 PM, Joel Sherrill wrote:
> But confdefs.h does define things. In many cases, an  ifndef is followed by a define
> to a default value. Those are the cases to document. If I encouraged Gedare to
> Doxygen something else (instead of just a good comment), then that was a mistake.
> Certainly everything in there isn't documented but some is:
> http://www.rtems.org/onlinedocs/doxygen/cpukit/html/confdefs_8h.html#acb6d25ad3c80a72ef6e3b461540b099b
The problem is that this documents only the default configuration.  As a
documentation of the configuration options this is completely useless.  It
doesn't show which options are available and it doesn't cover any constraints
and dependencies among the options.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
