[PATCH 22] LEON3: clock timer indexing should be consequent
Daniel Hellstrom
daniel at gaisler.com
Thu Mar 29 11:52:13 UTC 2012
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 6 +++---
1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
index 86a968f..932b8fd 100644
--- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
@@ -54,7 +54,7 @@ static int clkirq;
} while(0)
#else
- #define Adjust_clkirq_for_node()
+ #define Adjust_clkirq_for_node() do { clkirq += LEON3_CLOCK_INDEX; } while(0)
#endif
#define Clock_driver_support_find_timer() \
@@ -102,10 +102,10 @@ uint32_t bsp_clock_nanoseconds_since_last_tick(void)
if ( !LEON3_Timer_Regs )
return 0;
- clicks = LEON3_Timer_Regs->timer[0].value;
+ clicks = LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].value;
if ( LEON_Is_interrupt_pending( clkirq ) ) {
usecs = (2*rtems_configuration_get_microseconds_per_tick() - clicks);
} else {
usecs = (rtems_configuration_get_microseconds_per_tick() - clicks);
1.7.0.4
