[PATCH 22] LEON3: clock timer indexing should be consequent
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Mar 29 12:44:34 UTC 2012
Ok to apply
Daniel Hellstrom <daniel at gaisler.com> wrote:
>Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
> c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 6 +++---
> 1 files changed, 3 insertions(+), 3 deletions(-)
>diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>index 86a968f..932b8fd 100644
>--- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>+++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>@@ -54,7 +54,7 @@ static int clkirq;
> } while(0)
> #else
>- #define Adjust_clkirq_for_node()
>+ #define Adjust_clkirq_for_node() do { clkirq += LEON3_CLOCK_INDEX; } while(0)
> #endif
> #define Clock_driver_support_find_timer() \
>@@ -102,10 +102,10 @@ uint32_t bsp_clock_nanoseconds_since_last_tick(void)
> if ( !LEON3_Timer_Regs )
> return 0;
>- clicks = LEON3_Timer_Regs->timer[0].value;
>+ clicks = LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].value;
> if ( LEON_Is_interrupt_pending( clkirq ) ) {
> usecs = (2*rtems_configuration_get_microseconds_per_tick() - clicks);
> } else {
> usecs = (rtems_configuration_get_microseconds_per_tick() - clicks);
>1.7.0.4
>_______________________________________________
>rtems-devel mailing list
>rtems-devel at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-devel
