[PATCH 19] GRETH: removed the use of rtems_set_clock() in auto-nego timeout
Thu Mar 29 12:10:57 UTC 2012
This is OK to commit.
Thanks Daniel
Daniel Hellstrom <daniel at gaisler.com> wrote:
>Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
> c/src/libchip/network/greth.c |   47 +++++++++++++++-------------------------
> 1 files changed, 18 insertions(+), 29 deletions(-)
>diff --git a/c/src/libchip/network/greth.c b/c/src/libchip/network/greth.c
>index df3c143..c8b87ea 100644
>--- a/c/src/libchip/network/greth.c
>+++ b/c/src/libchip/network/greth.c
>@@ -97,6 +97,10 @@ extern void ipalign(struct mbuf *m);
> #ifndef GRETH_AUTONEGO_TIMEOUT_MS
> #define GRETH_AUTONEGO_TIMEOUT_MS 4000
> #endif
>+const struct timespec greth_tan = {
>+   GRETH_AUTONEGO_TIMEOUT_MS/1000,
>+   GRETH_AUTONEGO_TIMEOUT_MS*1000000
> /* For optimizing the autonegotiation time */
> #define GRETH_AUTONEGO_PRINT_TIME
>@@ -147,7 +151,7 @@ struct greth_softc
>    int gb;
>    int gbit_mac;
>    int auto_neg;
>-   unsigned int auto_neg_time;
>+   struct timespec auto_neg_time;
>     * Statistics
>@@ -264,8 +268,9 @@ static void print_init_info(struct greth_softc *sc)
>                 printf("Half Duplex\n");
> #ifdef GRETH_AUTONEGO_PRINT_TIME
>-        if ( sc->auto_neg ){
>-          printf("Autonegotiation Time: %dms\n",sc->auto_neg_time);
>+        if ( sc->auto_neg ) {
>+          printf("Autonegotiation Time: %dms\n", sc->auto_neg_time.tv_sec*1000 +
>+                 sc->auto_neg_time.tv_nsec/1000000);
> #endif
>@@ -284,8 +289,7 @@ greth_initialize_hardware (struct greth_softc *sc)
>     int phystatus;
>     int tmp1;
>     int tmp2;
>-    unsigned int msecs;
>-    struct timeval tstart, tnow;
>+    struct timespec tstart, tnow;
>     greth_regs *regs;
>@@ -320,33 +324,17 @@ greth_initialize_hardware (struct greth_softc *sc)
>     sc->fd = 0;
>     sc->sp = 0;
>     sc->auto_neg = 0;
>-    sc->auto_neg_time = 0;
>+    _Timespec_Set_to_zero(&sc->auto_neg_time);
>     if ((phyctrl >> 12) & 1) {
>             /*wait for auto negotiation to complete*/
>-            msecs = 0;
>             sc->auto_neg = 1;
>-            if ( rtems_clock_get_tod_timeval(&tstart) == RTEMS_NOT_DEFINED){
>-                /* Not inited, set to epoch */
>-                rtems_time_of_day time;
>-                time.year   = 1988;
>-                time.month  = 1;
>-                time.day    = 1;
>-                time.hour   = 0;
>-                time.minute = 0;
>-                time.second = 0;
>-                time.ticks  = 0;
>-                rtems_clock_set(&time);
>-                tstart.tv_sec = 0;
>-                tstart.tv_usec = 0;
>-                rtems_clock_get_tod_timeval(&tstart);
>+            if (rtems_clock_get_uptime(&tstart) != RTEMS_SUCCESSFUL)
>+                    printk("rtems_clock_get_uptime failed\n");
>             while (!(((phystatus = read_mii(phyaddr, 1)) >> 5) & 1)) {
>-                    if ( rtems_clock_get_tod_timeval(&tnow) != RTEMS_SUCCESSFUL )
>-                      printk("rtems_clock_get_tod_timeval failed\n\r");
>-                    msecs = (tnow.tv_sec-tstart.tv_sec)*1000+(tnow.tv_usec-tstart.tv_usec)/1000;
>-                    if ( msecs > GRETH_AUTONEGO_TIMEOUT_MS ){
>-                            sc->auto_neg_time = msecs;
>+                    if (rtems_clock_get_uptime(&tnow) != RTEMS_SUCCESSFUL)
>+                    _Timespec_Subtract(&tstart, &tnow, &sc->auto_neg_time);
>+                    if (_Timespec_Greater_than(&sc->auto_neg_time, &greth_tan)) {
>                             sc->auto_neg = -1; /* Failed */
>                             tmp1 = read_mii(phyaddr, 0);
>                             sc->gb = ((phyctrl >> 6) & 1) && !((phyctrl >> 13) & 1);
>@@ -354,8 +342,9 @@ greth_initialize_hardware (struct greth_softc *sc)
>                             sc->fd = (phyctrl >> 8) & 1;
>                             goto auto_neg_done;
>+                    /* Wait about 30ms, time is PHY dependent */
>+                    rtems_task_wake_after(rtems_clock_get_ticks_per_second()/32);
>             sc->phydev.adv = read_mii(phyaddr, 4);
>             sc->phydev.part = read_mii(phyaddr, 5);
>             if ((phystatus >> 8) & 1) {
>1.7.0.4
>_______________________________________________
>rtems-devel mailing list
>rtems-devel at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-devel
