[PATCH 19] GRETH: removed the use of rtems_set_clock() in auto-nego timeout
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Thu Mar 29 14:16:43 UTC 2012
This should be committed.
On 03/29/2012 06:52 AM, Daniel Hellstrom wrote:
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>   c/src/libchip/network/greth.c |   47 +++++++++++++++-------------------------
>   1 files changed, 18 insertions(+), 29 deletions(-)
> diff --git a/c/src/libchip/network/greth.c b/c/src/libchip/network/greth.c
> index df3c143..c8b87ea 100644
> --- a/c/src/libchip/network/greth.c
> +++ b/c/src/libchip/network/greth.c
> @@ -97,6 +97,10 @@ extern void ipalign(struct mbuf *m);
>   #ifndef GRETH_AUTONEGO_TIMEOUT_MS
>   #define GRETH_AUTONEGO_TIMEOUT_MS 4000
>   #endif
> +const struct timespec greth_tan = {
> +   GRETH_AUTONEGO_TIMEOUT_MS/1000,
> +   GRETH_AUTONEGO_TIMEOUT_MS*1000000
>   /* For optimizing the autonegotiation time */
>   #define GRETH_AUTONEGO_PRINT_TIME
> @@ -147,7 +151,7 @@ struct greth_softc
>      int gb;
>      int gbit_mac;
>      int auto_neg;
> -   unsigned int auto_neg_time;
> +   struct timespec auto_neg_time;
>       * Statistics
> @@ -264,8 +268,9 @@ static void print_init_info(struct greth_softc *sc)
>                   printf("Half Duplex\n");
>   #ifdef GRETH_AUTONEGO_PRINT_TIME
> -        if ( sc->auto_neg ){
> -          printf("Autonegotiation Time: %dms\n",sc->auto_neg_time);
> +        if ( sc->auto_neg ) {
> +          printf("Autonegotiation Time: %dms\n", sc->auto_neg_time.tv_sec*1000 +
> +                 sc->auto_neg_time.tv_nsec/1000000);
>   #endif
> @@ -284,8 +289,7 @@ greth_initialize_hardware (struct greth_softc *sc)
>       int phystatus;
>       int tmp1;
>       int tmp2;
> -    unsigned int msecs;
> -    struct timeval tstart, tnow;
> +    struct timespec tstart, tnow;
>       greth_regs *regs;
> @@ -320,33 +324,17 @@ greth_initialize_hardware (struct greth_softc *sc)
>       sc->fd = 0;
>       sc->sp = 0;
>       sc->auto_neg = 0;
> -    sc->auto_neg_time = 0;
> +    _Timespec_Set_to_zero(&sc->auto_neg_time);
>       if ((phyctrl>>  12)&  1) {
>               /*wait for auto negotiation to complete*/
> -            msecs = 0;
>               sc->auto_neg = 1;
> -            if ( rtems_clock_get_tod_timeval(&tstart) == RTEMS_NOT_DEFINED){
> -                /* Not inited, set to epoch */
> -                rtems_time_of_day time;
> -                time.year   = 1988;
> -                time.month  = 1;
> -                time.day    = 1;
> -                time.hour   = 0;
> -                time.minute = 0;
> -                time.second = 0;
> -                time.ticks  = 0;
> -                rtems_clock_set(&time);
> -                tstart.tv_sec = 0;
> -                tstart.tv_usec = 0;
> -                rtems_clock_get_tod_timeval(&tstart);
> +            if (rtems_clock_get_uptime(&tstart) != RTEMS_SUCCESSFUL)
> +                    printk("rtems_clock_get_uptime failed\n");
>               while (!(((phystatus = read_mii(phyaddr, 1))>>  5)&  1)) {
> -                    if ( rtems_clock_get_tod_timeval(&tnow) != RTEMS_SUCCESSFUL )
> -                      printk("rtems_clock_get_tod_timeval failed\n\r");
> -                    msecs = (tnow.tv_sec-tstart.tv_sec)*1000+(tnow.tv_usec-tstart.tv_usec)/1000;
> -                    if ( msecs>  GRETH_AUTONEGO_TIMEOUT_MS ){
> -                            sc->auto_neg_time = msecs;
> +                    if (rtems_clock_get_uptime(&tnow) != RTEMS_SUCCESSFUL)
> +                    _Timespec_Subtract(&tstart,&tnow,&sc->auto_neg_time);
> +                    if (_Timespec_Greater_than(&sc->auto_neg_time,&greth_tan)) {
>                               sc->auto_neg = -1; /* Failed */
>                               tmp1 = read_mii(phyaddr, 0);
>                               sc->gb = ((phyctrl>>  6)&  1)&&  !((phyctrl>>  13)&  1);
> @@ -354,8 +342,9 @@ greth_initialize_hardware (struct greth_softc *sc)
>                               sc->fd = (phyctrl>>  8)&  1;
>                               goto auto_neg_done;
> +                    /* Wait about 30ms, time is PHY dependent */
> +                    rtems_task_wake_after(rtems_clock_get_ticks_per_second()/32);
>               sc->phydev.adv = read_mii(phyaddr, 4);
>               sc->phydev.part = read_mii(phyaddr, 5);
>               if ((phystatus>>  8)&  1) {
Joel Sherrill, Ph.D.             Director of Research&   Development
