[PATCH 2/4] score/rbtree: replace _RBTree_Peek_unprotected with _RBTree_First.
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Wed May  2 17:01:04 UTC 2012
Looks good
On 05/02/2012 11:34 AM, Gedare Bloom wrote:
>   cpukit/score/inline/rtems/score/rbtree.inl |   20 +-------------------
>   cpukit/score/src/rbtreepeek.c              |    6 ++----
>   2 files changed, 3 insertions(+), 23 deletions(-)
> diff --git a/cpukit/score/inline/rtems/score/rbtree.inl b/cpukit/score/inline/rtems/score/rbtree.inl
> index d646b06..a079745 100644
> --- a/cpukit/score/inline/rtems/score/rbtree.inl
> +++ b/cpukit/score/inline/rtems/score/rbtree.inl
> @@ -10,13 +10,11 @@
> - *  Copyright (c) 2010 Gedare Bloom.
> + *  Copyright (c) 2010-2012 Gedare Bloom.
>    *  The license and distribution terms for this file may be
>    *  found in the file LICENSE in this distribution or at
>    *  http://www.rtems.com/license/LICENSE.
> - *  $Id$
>   #ifndef _RTEMS_SCORE_RBTREE_H
> @@ -459,22 +457,6 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Get_unprotected(
>     return the_node;
> -/** @brief Peek at the First Node (unprotected)
> - *  This function returns a pointer to the first node, minimum if @a dir is 0
> - *  or maximum if @a dir is 1, from @a the_rbtree without extracting it.
> - *  It does NOT disable interrupts to ensure the atomicity of the peek.
> - *  @retval NULL if @a the_rbtree is empty.
> -RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Peek_unprotected(
> -  const RBTree_Control *the_rbtree,
> -  RBTree_Direction dir
> -  return(the_rbtree->first[dir]);
>   /** @brief Rotate the_node in the direction passed as second argument
>    *  This routine rotates @a the_node to the direction @a dir, swapping
> diff --git a/cpukit/score/src/rbtreepeek.c b/cpukit/score/src/rbtreepeek.c
> index 13ea333..81ff0fd 100644
> --- a/cpukit/score/src/rbtreepeek.c
> +++ b/cpukit/score/src/rbtreepeek.c
> @@ -1,11 +1,9 @@
> - *  $Id$
>   #if HAVE_CONFIG_H
> @@ -45,7 +43,7 @@ RBTree_Node *_RBTree_Peek(
>     return_node = NULL;
>     _ISR_Disable( level );
> -      return_node = _RBTree_Peek_unprotected( the_rbtree, dir );
> +      return_node = _RBTree_First( the_rbtree, dir );
>     _ISR_Enable( level );
>     return return_node;
Joel Sherrill, Ph.D.             Director of Research&   Development
