[PATCH 3/4] rbtree: API Changes
    Gedare Bloom
    gedare at rtems.org
    Wed May  2 16:35:00 UTC 2012
Make default for rtems_rbtree functions be unprotected (preemption enabled)
unless an unprotected variant e.g. rtems_rbtree_xxx_unprotected is available.
 cpukit/sapi/inline/rtems/rbtree.inl |   87 ++++++++++++++++++++++++++++++----
 cpukit/score/src/rbtree.c           |    2 +-
 2 files changed, 77 insertions(+), 12 deletions(-)
diff --git a/cpukit/sapi/inline/rtems/rbtree.inl b/cpukit/sapi/inline/rtems/rbtree.inl
index ab81baf..0d507fb 100644
--- a/cpukit/sapi/inline/rtems/rbtree.inl
+++ b/cpukit/sapi/inline/rtems/rbtree.inl
@@ -5,17 +5,14 @@
  *  with the RBTree API in RTEMS. The rbtree is a Red Black Tree that
  *  is part of the Super Core. This is the published interface to that
  *  code.
- *  Copyright (c) 2010 Gedare Bloom.
+ *  Copyright (c) 2010-2012 Gedare Bloom.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
  *  http://www.rtems.com/license/LICENSE.
- *  $Id$
 #ifndef _RTEMS_RBTREE_H
@@ -254,6 +251,17 @@ RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_root(
   return _RBTree_Is_root( the_rbtree, the_node );
+ * @copydoc _RBTree_Find_unprotected()
+RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_find_unprotected(
+    rtems_rbtree_control *the_rbtree,
+    rtems_rbtree_node *the_node
+  return _RBTree_Find_unprotected( the_rbtree, the_node );
 /** @brief Find the node with given key in the tree
  *  This function returns a pointer to the node having key equal to the key
@@ -316,6 +324,17 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_successor(
+ * @copydoc _RBTree_Extract_unprotected()
+RTEMS_INLINE_ROUTINE void rtems_rbtree_extract_unprotected(
+  _RBTree_Extract_unprotected( the_rbtree, the_node );
  *  @brief Extract the specified node from a rbtree
  *  This routine extracts @a the_node from @a the_rbtree on which it resides.
@@ -334,6 +353,20 @@ RTEMS_INLINE_ROUTINE void rtems_rbtree_extract(
  *  This function removes the min node from @a the_rbtree and returns
  *  a pointer to that node.  If @a the_rbtree is empty, then NULL is returned.
+RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min_unprotected(
+  return _RBTree_Get_unprotected( the_rbtree, RBT_LEFT );
+ *  @brief Obtain the min node on a rbtree
+ *  This function removes the min node from @a the_rbtree and returns
+ *  a pointer to that node.  If @a the_rbtree is empty, then NULL is returned.
  *  It disables interrupts to ensure the atomicity of the get operation.
 RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min(
@@ -348,6 +381,20 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min(
  *  This function removes the max node from @a the_rbtree and returns
+RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max_unprotected(
+  return _RBTree_Get_unprotected( the_rbtree, RBT_RIGHT );
+ *  @brief Obtain the max node on a rbtree
+ *  This function removes the max node from @a the_rbtree and returns
 RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max(
@@ -363,13 +410,12 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max(
  *  This function returns a pointer to the min node from @a the_rbtree
  *  without changing the tree.  If @a the_rbtree is empty,
  *  then NULL is returned.
- *  It disables interrupts to ensure the atomicity of the peek operation.
 RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_min(
   const rtems_rbtree_control *the_rbtree
-  return _RBTree_Peek( the_rbtree, RBT_LEFT );
+  return _RBTree_First( the_rbtree, RBT_LEFT );
@@ -378,15 +424,23 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_min(
  *  This function returns a pointer to the max node from @a the_rbtree
 RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_max(
-  return _RBTree_Peek( the_rbtree, RBT_RIGHT );
+  return _RBTree_First( the_rbtree, RBT_RIGHT );
+ * @copydoc _RBTree_Find_header_unprotected()
+RTEMS_INLINE_ROUTINE rtems_rbtree_control *rtems_rbtree_find_header_unprotected(
+  return _RBTree_Find_header_unprotected( the_node );
  *  @brief Find the control header of the tree containing a given node.
@@ -399,7 +453,18 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_control *rtems_rbtree_find_header(
-  return(_RBTree_Find_header( the_node ));
+  return _RBTree_Find_header( the_node );
+ * @copydoc _RBTree_Insert_unprotected()
+RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_insert_unprotected(
+  return _RBTree_Insert_unprotected( the_rbtree, the_node );
@@ -427,7 +492,7 @@ RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_unique(
-  return( _RBTree_Is_unique(the_rbtree) );
+  return _RBTree_Is_unique(the_rbtree);
 #endif
diff --git a/cpukit/score/src/rbtree.c b/cpukit/score/src/rbtree.c
index e0fc560..387e66b 100644
--- a/cpukit/score/src/rbtree.c
+++ b/cpukit/score/src/rbtree.c
@@ -52,7 +52,7 @@ void _RBTree_Initialize(
   count = number_nodes;
   next  = starting_address;
   while ( count-- ) {
-    _RBTree_Insert(the_rbtree, next);
+    _RBTree_Insert_unprotected(the_rbtree, next);
     next           = (RBTree_Node *)
                         _Addresses_Add_offset( (void *) next, node_size );
1.7.1
