[PATCH 3/4] rbtree: API Changes
Wed May 2 17:08:53 UTC 2012
On Wed, May 2, 2012 at 1:02 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Copyright should be a plain comment not a Doxygen one.
OK
> In _RBTree_Initialize at bottom of patch "next =" appears
> to be formatted strangely.
I'd prefer to deal with style issues separately. This formatting was
copied from Chain_Initialize and probably occurs there.
> On 05/02/2012 11:35 AM, Gedare Bloom wrote:
>> Make default for rtems_rbtree functions be unprotected (preemption
>> enabled)
>> unless an unprotected variant e.g. rtems_rbtree_xxx_unprotected is
>> available.
>>  cpukit/sapi/inline/rtems/rbtree.inl |   87
>>  cpukit/score/src/rbtree.c           |    2 +-
>>  2 files changed, 77 insertions(+), 12 deletions(-)
>> diff --git a/cpukit/sapi/inline/rtems/rbtree.inl
>> b/cpukit/sapi/inline/rtems/rbtree.inl
>> index ab81baf..0d507fb 100644
>> --- a/cpukit/sapi/inline/rtems/rbtree.inl
>> +++ b/cpukit/sapi/inline/rtems/rbtree.inl
>> @@ -5,17 +5,14 @@
>>   *  with the RBTree API in RTEMS. The rbtree is a Red Black Tree that
>>   *  is part of the Super Core. This is the published interface to that
>>   *  code.
>> - *  Copyright (c) 2010 Gedare Bloom.
>> + *  Copyright (c) 2010-2012 Gedare Bloom.
>>   *  The license and distribution terms for this file may be
>>   *  found in the file LICENSE in this distribution or at
>>   *  http://www.rtems.com/license/LICENSE.
>> - *  $Id$
>>  #ifndef _RTEMS_RBTREE_H
>> @@ -254,6 +251,17 @@ RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_root(
>>    return _RBTree_Is_root( the_rbtree, the_node );
>> + * @copydoc _RBTree_Find_unprotected()
>> +RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_find_unprotected(
>> +    rtems_rbtree_control *the_rbtree,
>> +    rtems_rbtree_node *the_node
>> +  return _RBTree_Find_unprotected( the_rbtree, the_node );
>>  /** @brief Find the node with given key in the tree
>>   *  This function returns a pointer to the node having key equal to the
>> key
>> @@ -316,6 +324,17 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node*
>> rtems_rbtree_successor(
>> + * @copydoc _RBTree_Extract_unprotected()
>> +RTEMS_INLINE_ROUTINE void rtems_rbtree_extract_unprotected(
>> +  _RBTree_Extract_unprotected( the_rbtree, the_node );
>>   *  @brief Extract the specified node from a rbtree
>>   *  This routine extracts @a the_node from @a the_rbtree on which it
>> resides.
>> @@ -334,6 +353,20 @@ RTEMS_INLINE_ROUTINE void rtems_rbtree_extract(
>>   *  This function removes the min node from @a the_rbtree and returns
>>   *  a pointer to that node.  If @a the_rbtree is empty, then NULL is
>> returned.
>> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min_unprotected(
>> +  return _RBTree_Get_unprotected( the_rbtree, RBT_LEFT );
>> + *  @brief Obtain the min node on a rbtree
>> + *  This function removes the min node from @a the_rbtree and returns
>> + *  a pointer to that node.  If @a the_rbtree is empty, then NULL is
>> returned.
>>   *  It disables interrupts to ensure the atomicity of the get operation.
>>  RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min(
>> @@ -348,6 +381,20 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node
>>   *  This function removes the max node from @a the_rbtree and returns
>> returned.
>> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max_unprotected(
>> +  return _RBTree_Get_unprotected( the_rbtree, RBT_RIGHT );
>> + *  @brief Obtain the max node on a rbtree
>> + *  This function removes the max node from @a the_rbtree and returns
>> returned.
>>  RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max(
>> @@ -363,13 +410,12 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node
>>   *  This function returns a pointer to the min node from @a the_rbtree
>>   *  without changing the tree.  If @a the_rbtree is empty,
>>   *  then NULL is returned.
>> - *  It disables interrupts to ensure the atomicity of the peek operation.
>>  RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_min(
>>    const rtems_rbtree_control *the_rbtree
>> -  return _RBTree_Peek( the_rbtree, RBT_LEFT );
>> +  return _RBTree_First( the_rbtree, RBT_LEFT );
>> @@ -378,15 +424,23 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node
>>   *  This function returns a pointer to the max node from @a the_rbtree
>>  RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_max(
>> -  return _RBTree_Peek( the_rbtree, RBT_RIGHT );
>> +  return _RBTree_First( the_rbtree, RBT_RIGHT );
>> + * @copydoc _RBTree_Find_header_unprotected()
>> +RTEMS_INLINE_ROUTINE rtems_rbtree_control
>> *rtems_rbtree_find_header_unprotected(
>> +  return _RBTree_Find_header_unprotected( the_node );
>>   *  @brief Find the control header of the tree containing a given node.
>> @@ -399,7 +453,18 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_control
>> *rtems_rbtree_find_header(
>> -  return(_RBTree_Find_header( the_node ));
>> +  return _RBTree_Find_header( the_node );
>> + * @copydoc _RBTree_Insert_unprotected()
>> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_insert_unprotected(
>> +  return _RBTree_Insert_unprotected( the_rbtree, the_node );
>> @@ -427,7 +492,7 @@ RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_unique(
>> -  return( _RBTree_Is_unique(the_rbtree) );
>> +  return _RBTree_Is_unique(the_rbtree);
>>  #endif
>> diff --git a/cpukit/score/src/rbtree.c b/cpukit/score/src/rbtree.c
>> index e0fc560..387e66b 100644
>> --- a/cpukit/score/src/rbtree.c
>> +++ b/cpukit/score/src/rbtree.c
>> @@ -52,7 +52,7 @@ void _RBTree_Initialize(
>>    count = number_nodes;
>>    next  = starting_address;
>>    while ( count-- ) {
>> -    _RBTree_Insert(the_rbtree, next);
>> +    _RBTree_Insert_unprotected(the_rbtree, next);
>>      next           = (RBTree_Node *)
>>                          _Addresses_Add_offset( (void *) next, node_size
> Joel Sherrill, Ph.D.             Director of Research&   Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>    Support Available             (256) 722-9985
