[PATCH 3/4] rbtree: API Changes
Wed May 2 17:02:58 UTC 2012
Copyright should be a plain comment not a Doxygen one.
In _RBTree_Initialize at bottom of patch "next =" appears
to be formatted strangely.
On 05/02/2012 11:35 AM, Gedare Bloom wrote:
> Make default for rtems_rbtree functions be unprotected (preemption enabled)
> unless an unprotected variant e.g. rtems_rbtree_xxx_unprotected is available.
>   cpukit/sapi/inline/rtems/rbtree.inl |   87 ++++++++++++++++++++++++++++++----
>   cpukit/score/src/rbtree.c           |    2 +-
>   2 files changed, 77 insertions(+), 12 deletions(-)
> diff --git a/cpukit/sapi/inline/rtems/rbtree.inl b/cpukit/sapi/inline/rtems/rbtree.inl
> index ab81baf..0d507fb 100644
> --- a/cpukit/sapi/inline/rtems/rbtree.inl
> +++ b/cpukit/sapi/inline/rtems/rbtree.inl
> @@ -5,17 +5,14 @@
>    *  with the RBTree API in RTEMS. The rbtree is a Red Black Tree that
>    *  is part of the Super Core. This is the published interface to that
>    *  code.
> - *  Copyright (c) 2010 Gedare Bloom.
> + *  Copyright (c) 2010-2012 Gedare Bloom.
>    *  The license and distribution terms for this file may be
>    *  found in the file LICENSE in this distribution or at
>    *  http://www.rtems.com/license/LICENSE.
> - *  $Id$
>   #ifndef _RTEMS_RBTREE_H
> @@ -254,6 +251,17 @@ RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_root(
>     return _RBTree_Is_root( the_rbtree, the_node );
> + * @copydoc _RBTree_Find_unprotected()
> +RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_find_unprotected(
> +    rtems_rbtree_control *the_rbtree,
> +    rtems_rbtree_node *the_node
> +  return _RBTree_Find_unprotected( the_rbtree, the_node );
>   /** @brief Find the node with given key in the tree
>    *  This function returns a pointer to the node having key equal to the key
> @@ -316,6 +324,17 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_successor(
> + * @copydoc _RBTree_Extract_unprotected()
> +RTEMS_INLINE_ROUTINE void rtems_rbtree_extract_unprotected(
> +  _RBTree_Extract_unprotected( the_rbtree, the_node );
>    *  @brief Extract the specified node from a rbtree
>    *  This routine extracts @a the_node from @a the_rbtree on which it resides.
> @@ -334,6 +353,20 @@ RTEMS_INLINE_ROUTINE void rtems_rbtree_extract(
>    *  This function removes the min node from @a the_rbtree and returns
>    *  a pointer to that node.  If @a the_rbtree is empty, then NULL is returned.
> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min_unprotected(
> +  return _RBTree_Get_unprotected( the_rbtree, RBT_LEFT );
> + *  @brief Obtain the min node on a rbtree
> + *  This function removes the min node from @a the_rbtree and returns
> + *  a pointer to that node.  If @a the_rbtree is empty, then NULL is returned.
>    *  It disables interrupts to ensure the atomicity of the get operation.
>   RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min(
> @@ -348,6 +381,20 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min(
>    *  This function removes the max node from @a the_rbtree and returns
> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max_unprotected(
> +  return _RBTree_Get_unprotected( the_rbtree, RBT_RIGHT );
> + *  @brief Obtain the max node on a rbtree
> + *  This function removes the max node from @a the_rbtree and returns
>   RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max(
> @@ -363,13 +410,12 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max(
>    *  This function returns a pointer to the min node from @a the_rbtree
>    *  without changing the tree.  If @a the_rbtree is empty,
>    *  then NULL is returned.
> - *  It disables interrupts to ensure the atomicity of the peek operation.
>   RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_min(
>     const rtems_rbtree_control *the_rbtree
> -  return _RBTree_Peek( the_rbtree, RBT_LEFT );
> +  return _RBTree_First( the_rbtree, RBT_LEFT );
> @@ -378,15 +424,23 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_min(
>    *  This function returns a pointer to the max node from @a the_rbtree
>   RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_max(
> -  return _RBTree_Peek( the_rbtree, RBT_RIGHT );
> +  return _RBTree_First( the_rbtree, RBT_RIGHT );
> + * @copydoc _RBTree_Find_header_unprotected()
> +RTEMS_INLINE_ROUTINE rtems_rbtree_control *rtems_rbtree_find_header_unprotected(
> +  return _RBTree_Find_header_unprotected( the_node );
>    *  @brief Find the control header of the tree containing a given node.
> @@ -399,7 +453,18 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_control *rtems_rbtree_find_header(
> -  return(_RBTree_Find_header( the_node ));
> +  return _RBTree_Find_header( the_node );
> + * @copydoc _RBTree_Insert_unprotected()
> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_insert_unprotected(
> +  return _RBTree_Insert_unprotected( the_rbtree, the_node );
> @@ -427,7 +492,7 @@ RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_unique(
> -  return( _RBTree_Is_unique(the_rbtree) );
> +  return _RBTree_Is_unique(the_rbtree);
>   #endif
> diff --git a/cpukit/score/src/rbtree.c b/cpukit/score/src/rbtree.c
> index e0fc560..387e66b 100644
> --- a/cpukit/score/src/rbtree.c
> +++ b/cpukit/score/src/rbtree.c
> @@ -52,7 +52,7 @@ void _RBTree_Initialize(
>     count = number_nodes;
>     next  = starting_address;
>     while ( count-- ) {
> -    _RBTree_Insert(the_rbtree, next);
> +    _RBTree_Insert_unprotected(the_rbtree, next);
>       next           = (RBTree_Node *)
>                           _Addresses_Add_offset( (void *) next, node_size );
Joel Sherrill, Ph.D.             Director of Research&   Development
