[PATCH 1/3] Filesystem: Add shared device IO support
Mon May 14 15:13:36 UTC 2012
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
The device IO file system support in IMFS, devFS, and RFS uses now a
shared implementation.
cpukit/libcsupport/Makefile.am | 3 +
cpukit/libcsupport/include/rtems/deviceio.h | 56 +++++++++++
cpukit/libcsupport/preinstall.am | 4 +
cpukit/libcsupport/src/sup_fs_deviceerrno.c | 70 +++++++++++++
cpukit/libcsupport/src/sup_fs_deviceio.c | 128 ++++++++++++++++++++++++
cpukit/libfs/Makefile.am | 2 +-
cpukit/libfs/src/devfs/devclose.c | 23 +----
cpukit/libfs/src/devfs/devfs.h | 6 -
cpukit/libfs/src/devfs/devioctl.c | 27 +----
cpukit/libfs/src/devfs/devopen.c | 24 ++---
cpukit/libfs/src/devfs/devread.c | 28 +-----
cpukit/libfs/src/devfs/devwrite.c | 28 +-----
cpukit/libfs/src/imfs/deviceerrno.c | 72 --------------
cpukit/libfs/src/imfs/deviceio.c | 140 +++++----------------------
cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c | 67 ++-----------
15 files changed, 322 insertions(+), 356 deletions(-)
create mode 100644 cpukit/libcsupport/include/rtems/deviceio.h
create mode 100644 cpukit/libcsupport/src/sup_fs_deviceerrno.c
create mode 100644 cpukit/libcsupport/src/sup_fs_deviceio.c
delete mode 100644 cpukit/libfs/src/imfs/deviceerrno.c
diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
index 1d6fa3b..46805e9 100644
--- a/cpukit/libcsupport/Makefile.am
+++ b/cpukit/libcsupport/Makefile.am
@@ -24,6 +24,7 @@ include_rtems_motorola_HEADERS += include/motorola/mc68681.h
## rtems
include_rtems_HEADERS += include/rtems/assoc.h
+include_rtems_HEADERS += include/rtems/deviceio.h
include_rtems_HEADERS += include/rtems/error.h
include_rtems_HEADERS += include/rtems/libcsupport.h
include_rtems_HEADERS += include/rtems/libio.h
@@ -127,6 +128,8 @@ libcsupport_a_SOURCES = src/gxx_wrappers.c src/getchark.c src/printk.c \
src/sup_fs_exist_in_same_instance.c \
src/sup_fs_mount_iterate.c \
src/sup_fs_node_type.c \
+ src/sup_fs_deviceio.c \
+ src/sup_fs_deviceerrno.c \
src/clonenode.c \
src/freenode.c \
$(BSD_LIBC_C_FILES) $(BASE_FS_C_FILES) $(MALLOC_C_FILES) \
diff --git a/cpukit/libcsupport/include/rtems/deviceio.h b/cpukit/libcsupport/include/rtems/deviceio.h
new file mode 100644
index 0000000..6ce5d10
--- /dev/null
+++ b/cpukit/libcsupport/include/rtems/deviceio.h
@@ -0,0 +1,56 @@
+ * COPYRIGHT (c) 1989-2012.
+ * On-Line Applications Research Corporation (OAR).
+ * http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_DEVICEIO_H
+#define _RTEMS_DEVICEIO_H
+#include <rtems/libio.h>
+int rtems_deviceio_errno( rtems_status_code status );
+int rtems_deviceio_open(
+ rtems_libio_t *iop,
+ const char *path,
+ int oflag,
+ mode_t mode,
+ rtems_device_major_number major,
+ rtems_device_minor_number minor
+int rtems_deviceio_close(
+ssize_t rtems_deviceio_read(
+ void *buf,
+ size_t nbyte,
+ssize_t rtems_deviceio_write(
+ const void *buf,
+ size_t nbyte,
+int rtems_deviceio_control(
+ ioctl_command_t command,
+ void *buffer,
+#endif /* _RTEMS_DEVICEIO_H */
diff --git a/cpukit/libcsupport/preinstall.am b/cpukit/libcsupport/preinstall.am
index f71362f..eb68f50 100644
--- a/cpukit/libcsupport/preinstall.am
+++ b/cpukit/libcsupport/preinstall.am
@@ -71,6 +71,10 @@ $(PROJECT_INCLUDE)/rtems/assoc.h: include/rtems/assoc.h $(PROJECT_INCLUDE)/rtems
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/assoc.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/assoc.h
+$(PROJECT_INCLUDE)/rtems/deviceio.h: include/rtems/deviceio.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/deviceio.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/deviceio.h
$(PROJECT_INCLUDE)/rtems/error.h: include/rtems/error.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/error.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/error.h
diff --git a/cpukit/libcsupport/src/sup_fs_deviceerrno.c b/cpukit/libcsupport/src/sup_fs_deviceerrno.c
index 0000000..4316496
--- /dev/null
+++ b/cpukit/libcsupport/src/sup_fs_deviceerrno.c
@@ -0,0 +1,70 @@
+ * IMFS Device Node Handlers
+ * This file contains the set of handlers used to map operations on
+ * IMFS device nodes onto calls to the RTEMS Classic API IO Manager.
+ * COPYRIGHT (c) 1989-2008.
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/deviceio.h>
+#include <errno.h>
+static const int status_code_to_errno [RTEMS_STATUS_CODES_LAST + 1] = {
+ [RTEMS_SUCCESSFUL] = 0,
+ [RTEMS_TASK_EXITTED] = EIO,
+ [RTEMS_MP_NOT_CONFIGURED] = EIO,
+ [RTEMS_INVALID_NAME] = EINVAL,
+ [RTEMS_INVALID_ID] = EIO,
+ [RTEMS_TOO_MANY] = EIO,
+ [RTEMS_TIMEOUT] = ETIMEDOUT,
+ [RTEMS_OBJECT_WAS_DELETED] = EIO,
+ [RTEMS_INVALID_SIZE] = EIO,
+ [RTEMS_INVALID_ADDRESS] = EIO,
+ [RTEMS_INVALID_NUMBER] = EBADF,
+ [RTEMS_NOT_DEFINED] = EIO,
+ [RTEMS_RESOURCE_IN_USE] = EBUSY,
+ [RTEMS_UNSATISFIED] = ENODEV,
+ [RTEMS_INCORRECT_STATE] = EIO,
+ [RTEMS_ALREADY_SUSPENDED] = EIO,
+ [RTEMS_ILLEGAL_ON_SELF] = EIO,
+ [RTEMS_ILLEGAL_ON_REMOTE_OBJECT] = EIO,
+ [RTEMS_CALLED_FROM_ISR] = EIO,
+ [RTEMS_INVALID_PRIORITY] = EIO,
+ [RTEMS_INVALID_CLOCK] = EINVAL,
+ [RTEMS_INVALID_NODE] = EINVAL,
+ [RTEMS_NOT_CONFIGURED] = ENOSYS,
+ [RTEMS_NOT_OWNER_OF_RESOURCE] = EPERM,
+ [RTEMS_NOT_IMPLEMENTED] = ENOSYS,
+ [RTEMS_INTERNAL_ERROR] = EIO,
+ [RTEMS_NO_MEMORY] = ENOMEM,
+ [RTEMS_IO_ERROR] = EIO,
+ [RTEMS_PROXY_BLOCKING] = EIO
+int rtems_deviceio_errno(rtems_status_code sc)
+ if (sc == RTEMS_SUCCESSFUL) {
+ return 0;
+ } else {
+ int eno = EINVAL;
+ if ((unsigned) sc <= RTEMS_STATUS_CODES_LAST) {
+ eno = status_code_to_errno [sc];
+ errno = eno;
+ return -1;
diff --git a/cpukit/libcsupport/src/sup_fs_deviceio.c b/cpukit/libcsupport/src/sup_fs_deviceio.c
index 0000000..aeff60e
--- /dev/null
+++ b/cpukit/libcsupport/src/sup_fs_deviceio.c
@@ -0,0 +1,128 @@
+#if HAVE_CONFIG_H
+#endif
+ const char *path,
+ int oflag,
+ mode_t mode,
+ rtems_status_code status;
+ rtems_libio_open_close_args_t args;
+ args.iop = iop;
+ args.flags = iop->flags;
+ args.mode = mode;
+ status = rtems_io_open( major, minor, &args );
+ return rtems_deviceio_errno( status );
+ args.iop = iop;
+ args.flags = 0;
+ args.mode = 0;
+ status = rtems_io_close( major, minor, &args );
+ void *buf,
+ size_t nbyte,
+ rtems_libio_rw_args_t args;
+ args.iop = iop;
+ args.offset = iop->offset;
+ args.buffer = buf;
+ args.count = nbyte;
+ args.bytes_moved = 0;
+ status = rtems_io_read( major, minor, &args );
+ if ( status == RTEMS_SUCCESSFUL ) {
+ return (ssize_t) args.bytes_moved;
+ } else {
+ const void *buf,
+ size_t nbyte,
+ args.iop = iop;
+ status = rtems_io_write( major, minor, &args );
+ } else {
+ void *buffer,
+ rtems_libio_ioctl_args_t args;
+ args.iop = iop;
+ args.command = command;
+ args.buffer = buffer;
+ status = rtems_io_control( major, minor, &args );
+ return args.ioctl_return;
+ } else {
+ return rtems_deviceio_errno(status);
diff --git a/cpukit/libfs/Makefile.am b/cpukit/libfs/Makefile.am
index 9a792d1..c5e483e 100644
--- a/cpukit/libfs/Makefile.am
+++ b/cpukit/libfs/Makefile.am
@@ -37,7 +37,7 @@ libdefaultfs_a_SOURCES = \
noinst_LIBRARIES += libimfs.a
libimfs_a_SOURCES =
-libimfs_a_SOURCES += src/imfs/deviceerrno.c src/imfs/deviceio.c \
+libimfs_a_SOURCES += src/imfs/deviceio.c \
src/imfs/fifoimfs_init.c src/imfs/imfs_chown.c src/imfs/imfs_config.c \
src/imfs/imfs_creat.c src/imfs/imfs_debug.c src/imfs/imfs_directory.c \
src/imfs/imfs_eval.c src/imfs/imfs_fchmod.c \
diff --git a/cpukit/libfs/src/devfs/devclose.c b/cpukit/libfs/src/devfs/devclose.c
index c83fab9..83646c7 100644
--- a/cpukit/libfs/src/devfs/devclose.c
+++ b/cpukit/libfs/src/devfs/devclose.c
@@ -5,33 +5,18 @@
#if HAVE_CONFIG_H
-#include "config.h"
#endif
-#include <rtems.h>
-#include <rtems/io.h>
#include "devfs.h"
int devFS_close(
rtems_libio_t *iop
- rtems_libio_open_close_args_t args;
- rtems_status_code status;
const devFS_node *np = iop->pathinfo.node_access;
- args.iop = iop;
- args.flags = 0;
- args.mode = 0;
- status = rtems_io_close(
- np->major,
- np->minor,
- (void *) &args
- return rtems_deviceio_errno(status);
+ return rtems_deviceio_close( iop, np->major, np->minor );
diff --git a/cpukit/libfs/src/devfs/devfs.h b/cpukit/libfs/src/devfs/devfs.h
index 60ee7ab..4155dd6 100644
--- a/cpukit/libfs/src/devfs/devfs.h
+++ b/cpukit/libfs/src/devfs/devfs.h
@@ -49,12 +49,6 @@ extern const rtems_filesystem_operations_table devFS_ops;
extern const rtems_filesystem_file_handlers_r devFS_file_handlers;
- * This routine associates RTEMS status code with errno
-extern int rtems_deviceio_errno(rtems_status_code code);
static inline const devFS_data *devFS_get_data(
const rtems_filesystem_location_info_t *loc
diff --git a/cpukit/libfs/src/devfs/devioctl.c b/cpukit/libfs/src/devfs/devioctl.c
index bca8250..e1d62c4 100644
--- a/cpukit/libfs/src/devfs/devioctl.c
+++ b/cpukit/libfs/src/devfs/devioctl.c
@@ -1,41 +1,24 @@
-#if HAVE_CONFIG_H
+#if HAVE_CONFIG_H
#endif
-#include <rtems.h>
#include "devfs.h"
int devFS_ioctl(
rtems_libio_t *iop,
void *buffer
- rtems_libio_ioctl_args_t args;
- args.iop = iop;
- args.command = command;
- args.buffer = buffer;
- status = rtems_io_control(
- np->major,
- np->minor,
- (void *) &args
- if ( status )
- return args.ioctl_return;
+ return rtems_deviceio_control( iop, command, buffer, np->major, np->minor );
diff --git a/cpukit/libfs/src/devfs/devopen.c b/cpukit/libfs/src/devfs/devopen.c
index adb8fe4..26450ab 100644
--- a/cpukit/libfs/src/devfs/devopen.c
+++ b/cpukit/libfs/src/devfs/devopen.c
@@ -5,14 +5,13 @@
#if HAVE_CONFIG_H
#endif
-#include <rtems.h>
#include "devfs.h"
int devFS_open(
rtems_libio_t *iop,
const char *pathname,
@@ -20,19 +19,14 @@ int devFS_open(
mode_t mode
- args.iop = iop;
- args.flags = iop->flags;
- args.mode = mode;
- status = rtems_io_open(
+ return rtems_deviceio_open(
+ iop,
+ pathname,
+ oflag,
+ mode,
np->major,
- np->minor,
- (void *) &args
+ np->minor
diff --git a/cpukit/libfs/src/devfs/devread.c b/cpukit/libfs/src/devfs/devread.c
index 6868a9e..25d69b0 100644
--- a/cpukit/libfs/src/devfs/devread.c
+++ b/cpukit/libfs/src/devfs/devread.c
@@ -5,40 +5,20 @@
#if HAVE_CONFIG_H
#endif
-#include <rtems.h>
#include "devfs.h"
ssize_t devFS_read(
rtems_libio_t *iop,
void *buffer,
size_t count
- rtems_libio_rw_args_t args;
- args.iop = iop;
- args.offset = iop->offset;
- args.count = count;
- args.bytes_moved = 0;
- status = rtems_io_read(
- np->major,
- np->minor,
- (void *) &args
- if ( status )
- return (ssize_t) args.bytes_moved;
+ return rtems_deviceio_read( iop, buffer, count, np->major, np->minor );
diff --git a/cpukit/libfs/src/devfs/devwrite.c b/cpukit/libfs/src/devfs/devwrite.c
index fe48745..57e7fdb 100644
--- a/cpukit/libfs/src/devfs/devwrite.c
+++ b/cpukit/libfs/src/devfs/devwrite.c
@@ -5,40 +5,20 @@
#if HAVE_CONFIG_H
#endif
-#include <rtems.h>
#include "devfs.h"
ssize_t devFS_write(
rtems_libio_t *iop,
const void *buffer,
size_t count
- args.iop = iop;
- args.buffer = (void *) buffer;
- status = rtems_io_write(
- np->major,
- np->minor,
- (void *) &args
- if ( status )
+ return rtems_deviceio_write( iop, buffer, count, np->major, np->minor );
diff --git a/cpukit/libfs/src/imfs/deviceerrno.c b/cpukit/libfs/src/imfs/deviceerrno.c
deleted file mode 100644
index eb5e03d..0000000
--- a/cpukit/libfs/src/imfs/deviceerrno.c
+++ /dev/null
@@ -1,72 +0,0 @@
- * IMFS Device Node Handlers
- * This file contains the set of handlers used to map operations on
- * IMFS device nodes onto calls to the RTEMS Classic API IO Manager.
- * COPYRIGHT (c) 1989-2008.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-#if HAVE_CONFIG_H
-#endif
-#include <errno.h>
-#include <rtems.h>
-#include <rtems/libio.h>
-#include <rtems/devfs.h>
-static const int status_code_to_errno [RTEMS_STATUS_CODES_LAST + 1] = {
- [RTEMS_SUCCESSFUL] = 0,
- [RTEMS_TASK_EXITTED] = EIO,
- [RTEMS_MP_NOT_CONFIGURED] = EIO,
- [RTEMS_INVALID_NAME] = EINVAL,
- [RTEMS_INVALID_ID] = EIO,
- [RTEMS_TOO_MANY] = EIO,
- [RTEMS_TIMEOUT] = ETIMEDOUT,
- [RTEMS_OBJECT_WAS_DELETED] = EIO,
- [RTEMS_INVALID_SIZE] = EIO,
- [RTEMS_INVALID_ADDRESS] = EIO,
- [RTEMS_INVALID_NUMBER] = EBADF,
- [RTEMS_NOT_DEFINED] = EIO,
- [RTEMS_RESOURCE_IN_USE] = EBUSY,
- [RTEMS_UNSATISFIED] = ENODEV,
- [RTEMS_INCORRECT_STATE] = EIO,
- [RTEMS_ALREADY_SUSPENDED] = EIO,
- [RTEMS_ILLEGAL_ON_SELF] = EIO,
- [RTEMS_ILLEGAL_ON_REMOTE_OBJECT] = EIO,
- [RTEMS_CALLED_FROM_ISR] = EIO,
- [RTEMS_INVALID_PRIORITY] = EIO,
- [RTEMS_INVALID_CLOCK] = EINVAL,
- [RTEMS_INVALID_NODE] = EINVAL,
- [RTEMS_NOT_CONFIGURED] = ENOSYS,
- [RTEMS_NOT_OWNER_OF_RESOURCE] = EPERM,
- [RTEMS_NOT_IMPLEMENTED] = ENOSYS,
- [RTEMS_INTERNAL_ERROR] = EIO,
- [RTEMS_NO_MEMORY] = ENOMEM,
- [RTEMS_IO_ERROR] = EIO,
- [RTEMS_PROXY_BLOCKING] = EIO
-int rtems_deviceio_errno(rtems_status_code sc)
- if (sc == RTEMS_SUCCESSFUL) {
- return 0;
- } else {
- int eno = EINVAL;
- if ((unsigned) sc <= RTEMS_STATUS_CODES_LAST) {
- eno = status_code_to_errno [sc];
- errno = eno;
- return -1;
diff --git a/cpukit/libfs/src/imfs/deviceio.c b/cpukit/libfs/src/imfs/deviceio.c
index 60a66f3..679f945 100644
--- a/cpukit/libfs/src/imfs/deviceio.c
+++ b/cpukit/libfs/src/imfs/deviceio.c
@@ -4,7 +4,7 @@
@@ -18,13 +18,7 @@
#include "imfs.h"
- * device_open
- * This handler maps an open() operation onto rtems_io_open().
int device_open(
rtems_libio_t *iop,
@@ -33,174 +27,92 @@ int device_open(
mode_t mode
IMFS_jnode_t *the_jnode;
the_jnode = iop->pathinfo.node_access;
- args.iop = iop;
- args.mode = mode;
+ iop,
+ pathname,
+ oflag,
+ mode,
the_jnode->info.device.major,
- the_jnode->info.device.minor,
- (void *) &args
+ the_jnode->info.device.minor
- return rtems_deviceio_errno( status );
- * device_close
- * This handler maps a close() operation onto rtems_io_close().
int device_close(
rtems_libio_t *iop
- args.iop = iop;
- args.flags = 0;
- args.mode = 0;
+ iop,
- (void *) &args
- * device_read
- * This handler maps a read() operation onto rtems_io_read().
ssize_t device_read(
rtems_libio_t *iop,
void *buffer,
size_t count
- args.iop = iop;
+ iop,
+ buffer,
+ count,
- (void *) &args
- if ( status )
- * device_write
- * This handler maps a write() operation onto rtems_io_write().
ssize_t device_write(
rtems_libio_t *iop,
const void *buffer,
size_t count
- args.iop = iop;
+ iop,
+ buffer,
+ count,
- (void *) &args
- if ( status )
- * device_ioctl
- * This handler maps an ioctl() operation onto rtems_io_ioctl().
int device_ioctl(
rtems_libio_t *iop,
void *buffer
- args.iop = iop;
+ iop,
+ command,
+ buffer,
- (void *) &args
- if ( status )
- * device_stat
- * The IMFS_stat() is used.
- * device_rmnod
- * The IMFS_rmnod() is used.
int device_ftruncate(
rtems_libio_t *iop,
off_t length
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
index 729d420..ced234a 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
@@ -18,12 +18,13 @@
#if HAVE_CONFIG_H
#endif
#include "rtems-rfs-rtems.h"
static void
rtems_rfs_rtems_device_get_major_and_minor ( const rtems_libio_t *iop,
rtems_device_major_number *major,
@@ -48,13 +49,11 @@ rtems_rfs_rtems_device_open ( rtems_libio_t *iop,
int oflag,
mode_t mode)
rtems_rfs_file_system* fs = rtems_rfs_rtems_pathloc_dev (&iop->pathinfo);
rtems_rfs_ino ino = rtems_rfs_rtems_get_iop_ino (iop);
rtems_rfs_inode_handle inode;
rtems_device_major_number major;
rtems_device_minor_number minor;
int rc;
rtems_rfs_rtems_lock (fs);
@@ -81,13 +80,7 @@ rtems_rfs_rtems_device_open ( rtems_libio_t *iop,
iop->data0 = major;
iop->data1 = (void *) minor;
- args.iop = iop;
- args.mode = mode;
- status = rtems_io_open (major, minor, (void *) &args);
- return rtems_deviceio_errno (status);
+ return rtems_deviceio_open (iop, pathname, oflag, mode, minor, major);
@@ -100,20 +93,12 @@ rtems_rfs_rtems_device_open ( rtems_libio_t *iop,
static int
rtems_rfs_rtems_device_close (rtems_libio_t* iop)
rtems_rfs_rtems_device_get_major_and_minor (iop, &major, &minor);
- args.iop = iop;
- args.flags = 0;
- args.mode = 0;
- status = rtems_io_close (major, minor, (void *) &args);
+ return rtems_deviceio_close (iop, major, minor);
@@ -128,25 +113,12 @@ rtems_rfs_rtems_device_close (rtems_libio_t* iop)
static ssize_t
rtems_rfs_rtems_device_read (rtems_libio_t* iop, void* buffer, size_t count)
- args.iop = iop;
- status = rtems_io_read (major, minor, (void *) &args);
- if (status)
+ return rtems_deviceio_read (iop, buffer, count, major, minor);
@@ -163,25 +135,12 @@ rtems_rfs_rtems_device_write (rtems_libio_t* iop,
const void* buffer,
size_t count)
- args.iop = iop;
- status = rtems_io_write (major, minor, (void *) &args);
- if (status)
+ return rtems_deviceio_write (iop, buffer, count, major, minor);
@@ -198,22 +157,12 @@ rtems_rfs_rtems_device_ioctl (rtems_libio_t* iop,
void* buffer)
- args.iop = iop;
- status = rtems_io_control (major, minor, (void *) &args);
- if (status)
+ return rtems_deviceio_control (iop, command, buffer, major, minor);
1.6.4.2
