[PATCH] rbtree: API change for Insert routines.
Gedare Bloom
gedare at rtems.org
Sun May 13 17:40:28 UTC 2012
Make the Insert routines return either valid nodes or NULL.
cpukit/score/include/rtems/score/rbtree.h | 4 ++--
cpukit/score/src/rbtreeinsert.c | 4 ++--
testsuites/sptests/sprbtree01/init.c | 2 +-
3 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/cpukit/score/include/rtems/score/rbtree.h b/cpukit/score/include/rtems/score/rbtree.h
index 271e2fa..ed0b752 100644
--- a/cpukit/score/include/rtems/score/rbtree.h
+++ b/cpukit/score/include/rtems/score/rbtree.h
@@ -262,10 +262,10 @@ RBTree_Control *_RBTree_Find_header(
* @param[in] the_rbtree The red-black tree.
* @param[in] the_node The node to insert.
- * @retval 0 if successfully inserted.
+ * @retval @a the_node if successfully inserted.
* @retval a node that compares equal to @a the_node if it exists and
* the_rbtree->is_unique is true
- * @retval -1 otherwise.
+ * @retval NULL otherwise.
RBTree_Node *_RBTree_Insert_unprotected(
RBTree_Control *the_rbtree,
diff --git a/cpukit/score/src/rbtreeinsert.c b/cpukit/score/src/rbtreeinsert.c
index 9c889bd..75359a5 100644
--- a/cpukit/score/src/rbtreeinsert.c
+++ b/cpukit/score/src/rbtreeinsert.c
@@ -75,7 +75,7 @@ RBTree_Node *_RBTree_Insert_unprotected(
if ( !the_node ) {
- return (RBTree_Node*)-1;
+ return NULL;
RBTree_Node *iter_node = the_rbtree->root;
@@ -120,7 +120,7 @@ RBTree_Node *_RBTree_Insert_unprotected(
/* verify red-black properties */
_RBTree_Insert_validate( the_node );
- return (RBTree_Node*)0;
+ return the_node;
RBTree_Node *_RBTree_Insert(
diff --git a/testsuites/sptests/sprbtree01/init.c b/testsuites/sptests/sprbtree01/init.c
index f94a010..00f922c 100644
--- a/testsuites/sptests/sprbtree01/init.c
+++ b/testsuites/sptests/sprbtree01/init.c
@@ -117,7 +117,7 @@ rtems_task Init(
rtems_rbtree_insert( &rbtree1, &node2.Node );
p = rtems_rbtree_insert( &rbtree1, NULL );
- if (p != (void *)(-1))
+ if ( p )
puts( "INIT - FAILED NULL NODE INSERT" );
_RBTree_Rotate(NULL, RBT_LEFT);
1.7.1
