the hash approach of POSIX key
Ashi
ashi08104 at gmail.com
Mon May 21 13:30:04 UTC 2012
Hi, all.
I'm working on the POSIX key project(here is a introduction of it:[1]).
Since using hash is a good candidate of the solution, I'm trying to do the
design using hash. I'm not clear about how to deal with UThash[2] in RTEMS.
Shall we directly include this lib or reimplemented in RTEMS? If assumed
directly use, I think we can manage all keys in one hash table as like in
the rbtree approach. Since UThash is able to use structure as it's hash
key, then the POSIX_Keys_Control can be defined as:
typedef struct {
Objects_Control Object;
void (*destructor) (void *);
hash_key_t hash_key; /* use struct hash_key_t as a hash key */
void *value;
UT_hash_handle hh;
} POSIX_Keys_Control;
the hash_key_t type is a structure include Object id and pthread_key_t:
typedef struct {
Objects_Id thread_id;
pthread_key_t key;
} hash_key_t;
Then all the keys' data is managed in one hash table. I've a question about
this design: is it a waste of memory that every key data holds a
POSIX_Keys_Control structure? If it is, I think we could manage it in a two
level structure: first level manages all keys by one hash table, and each
key manages its values in second level by one bash table:
typedef struct {
Objects_Id Object.id; /* use Object.id as hash key, I don't know
whether we could directly use Object as a hash key? I know it's no problem
in UThash */
key_node_t * key_node;
UT_hash_handle hh;
typedef struct {
Objects_Id thread_id; /* use thread_id as hash key */
void *value;
UT_hash_handle hh;
} key_node_t;
And as Gedare suggested in my last discuss, the implementation should
consider do actually work in in the supercore layer and shared between
Posix Keys and Classic Task vars, however, I haven't think about it yet,
I'm a little behind my work.
links:
[1]: http://www.rtems.com/ml/rtems-users/2012/april/msg00110.html
[2]:http://uthash.sourceforge.net/
Best wishes!
zw_yao
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120521/2cc6d867/attachment.html>
