[PATCH] powerpc: Simplify context switch
Thu May 31 16:18:09 UTC 2012
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
PowerPC cores with the SPE (Signal Processing Extension) have 64-bit
general-purpose registers. The SPE context switch code has been merged
with the standard context switch code. The context switch may use cache
operations to increase the performance. It will be ensured that the
context is 32-byte aligned (PPC_DEFAULT_CACHE_LINE_SIZE). This
increases the overall memory size of the context area in the thread
control block slightly. The general-purpose registers GPR2 and GPR13
are no longer part of the context. The BSP must initialize these
registers during startup (usually initialized by the __eabi() function).
The new BSP option BSP_USE_DATA_CACHE_BLOCK_TOUCH can be used to enable
the dcbt instruction in the context switch.
The new BSP option BSP_USE_SYNC_IN_CONTEXT_SWITCH can be used to enable
sync and isync instructions in the context switch. This should be not
necessary in most cases.
diff --git a/c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup.c b/c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup.c
index 0eba0b7..07b9fd2 100644
--- a/c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup.c
+++ b/c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup.c
@@ -233,7 +233,7 @@ unsigned pvr;
* for use by assembly code.
* Therefore, we compute it here and store it in memory...
- _CPU_altivec_ctxt_off = (uint32_t) &((Context_Control*)0)->altivec;
+ _CPU_altivec_ctxt_off = offsetof(ppc_context, altivec);
* Add space possibly needed for alignment
diff --git a/c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup_asm.S b/c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup_asm.S
index 6b78c0b..1a5c906 100644
--- a/c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup_asm.S
+++ b/c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup_asm.S
@@ -623,17 +623,6 @@ _CPU_load_altivec_volatile:
#endif
blr
- .global _CPU_Context_restore_altivec
-_CPU_Context_restore_altivec:
- /* Restore is like 'switch' but we don't have
- * to save an old context.
- * Move argument to second arg and load NULL pointer
- * to first one, then jump to 'switch' routine.
- mr r4, r3
- li r3, 0
- b _CPU_Context_switch_altivec
.global _CPU_Context_switch_altivec
_CPU_Context_switch_altivec:
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S
index 3165d6b..dd6f694 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S
@@ -78,14 +78,14 @@ ppc_exc_wrap_async_normal:
mr FRAME_REGISTER, r1
/* Load ISR nest level and thread dispatch disable level */
- PPC_EXC_GPR_STORE ISR_NEST_HADDR_REGISTER, ISR_NEST_HADDR_OFFSET(r1)
+ PPC_GPR_STORE ISR_NEST_HADDR_REGISTER, ISR_NEST_HADDR_OFFSET(r1)
lis ISR_NEST_HADDR_REGISTER, ISR_NEST_LEVEL at ha
- PPC_EXC_GPR_STORE ISR_NEST_REGISTER, ISR_NEST_OFFSET(r1)
+ PPC_GPR_STORE ISR_NEST_REGISTER, ISR_NEST_OFFSET(r1)
lwz ISR_NEST_REGISTER, ISR_NEST_LEVEL at l(ISR_NEST_HADDR_REGISTER)
- PPC_EXC_GPR_STORE DISPATCH_LEVEL_REGISTER, DISPATCH_LEVEL_OFFSET(r1)
+ PPC_GPR_STORE DISPATCH_LEVEL_REGISTER, DISPATCH_LEVEL_OFFSET(r1)
lwz DISPATCH_LEVEL_REGISTER, _Thread_Dispatch_disable_level at sdarel(r13)
- PPC_EXC_GPR_STORE SCRATCH_0_REGISTER, SCRATCH_0_OFFSET(r1)
+ PPC_GPR_STORE SCRATCH_0_REGISTER, SCRATCH_0_OFFSET(r1)
#ifdef __SPE__
@@ -96,7 +96,7 @@ ppc_exc_wrap_async_normal:
stw SCRATCH_0_REGISTER, VECTOR_OFFSET(r1)
#endif
- PPC_EXC_GPR_STORE HANDLER_REGISTER, HANDLER_OFFSET(r1)
+ PPC_GPR_STORE HANDLER_REGISTER, HANDLER_OFFSET(r1)
* Load the handler address. Get the handler table index from the
@@ -109,11 +109,11 @@ ppc_exc_wrap_async_normal:
ori HANDLER_REGISTER, HANDLER_REGISTER, ppc_exc_handler_table at l
lwzx HANDLER_REGISTER, HANDLER_REGISTER, SCRATCH_0_REGISTER
- PPC_EXC_GPR_STORE SCRATCH_1_REGISTER, SCRATCH_1_OFFSET(r1)
- PPC_EXC_GPR_STORE SCRATCH_2_REGISTER, SCRATCH_2_OFFSET(r1)
- PPC_EXC_GPR_STORE SCRATCH_3_REGISTER, SCRATCH_3_OFFSET(r1)
- PPC_EXC_GPR_STORE SCRATCH_4_REGISTER, SCRATCH_4_OFFSET(r1)
- PPC_EXC_GPR_STORE SCRATCH_5_REGISTER, SCRATCH_5_OFFSET(r1)
+ PPC_GPR_STORE SCRATCH_1_REGISTER, SCRATCH_1_OFFSET(r1)
+ PPC_GPR_STORE SCRATCH_2_REGISTER, SCRATCH_2_OFFSET(r1)
+ PPC_GPR_STORE SCRATCH_3_REGISTER, SCRATCH_3_OFFSET(r1)
+ PPC_GPR_STORE SCRATCH_4_REGISTER, SCRATCH_4_OFFSET(r1)
+ PPC_GPR_STORE SCRATCH_5_REGISTER, SCRATCH_5_OFFSET(r1)
/* Save SRR0, SRR1, CR, CTR, XER, and LR */
mfsrr0 SCRATCH_0_REGISTER
@@ -197,35 +197,35 @@ thread_dispatching_done:
lwz SCRATCH_4_REGISTER, EXC_XER_OFFSET(r1)
lwz SCRATCH_5_REGISTER, EXC_LR_OFFSET(r1)
- PPC_EXC_GPR_LOAD VECTOR_REGISTER, VECTOR_OFFSET(r1)
- PPC_EXC_GPR_LOAD ISR_NEST_HADDR_REGISTER, ISR_NEST_HADDR_OFFSET(r1)
- PPC_EXC_GPR_LOAD ISR_NEST_REGISTER, ISR_NEST_OFFSET(r1)
+ PPC_GPR_LOAD VECTOR_REGISTER, VECTOR_OFFSET(r1)
+ PPC_GPR_LOAD ISR_NEST_HADDR_REGISTER, ISR_NEST_HADDR_OFFSET(r1)
+ PPC_GPR_LOAD ISR_NEST_REGISTER, ISR_NEST_OFFSET(r1)
#ifdef __SPE__
/* Restore SPEFSCR */
mtspr FSL_EIS_SPEFSCR, DISPATCH_LEVEL_REGISTER
#endif
- PPC_EXC_GPR_LOAD DISPATCH_LEVEL_REGISTER, DISPATCH_LEVEL_OFFSET(r1)
+ PPC_GPR_LOAD DISPATCH_LEVEL_REGISTER, DISPATCH_LEVEL_OFFSET(r1)
#ifdef __SPE__
/* Restore ACC */
evmra HANDLER_REGISTER, HANDLER_REGISTER
#endif
- PPC_EXC_GPR_LOAD HANDLER_REGISTER, HANDLER_OFFSET(r1)
+ PPC_GPR_LOAD HANDLER_REGISTER, HANDLER_OFFSET(r1)
/* Restore SRR0, SRR1, CR, CTR, XER, and LR */
mtsrr0 SCRATCH_0_REGISTER
- PPC_EXC_GPR_LOAD SCRATCH_0_REGISTER, SCRATCH_0_OFFSET(r1)
+ PPC_GPR_LOAD SCRATCH_0_REGISTER, SCRATCH_0_OFFSET(r1)
mtsrr1 SCRATCH_1_REGISTER
- PPC_EXC_GPR_LOAD SCRATCH_1_REGISTER, SCRATCH_1_OFFSET(r1)
+ PPC_GPR_LOAD SCRATCH_1_REGISTER, SCRATCH_1_OFFSET(r1)
mtcr SCRATCH_2_REGISTER
- PPC_EXC_GPR_LOAD SCRATCH_2_REGISTER, SCRATCH_2_OFFSET(r1)
+ PPC_GPR_LOAD SCRATCH_2_REGISTER, SCRATCH_2_OFFSET(r1)
mtctr SCRATCH_3_REGISTER
- PPC_EXC_GPR_LOAD SCRATCH_3_REGISTER, SCRATCH_3_OFFSET(r1)
+ PPC_GPR_LOAD SCRATCH_3_REGISTER, SCRATCH_3_OFFSET(r1)
mtxer SCRATCH_4_REGISTER
- PPC_EXC_GPR_LOAD SCRATCH_4_REGISTER, SCRATCH_4_OFFSET(r1)
+ PPC_GPR_LOAD SCRATCH_4_REGISTER, SCRATCH_4_OFFSET(r1)
mtlr SCRATCH_5_REGISTER
- PPC_EXC_GPR_LOAD SCRATCH_5_REGISTER, SCRATCH_5_OFFSET(r1)
+ PPC_GPR_LOAD SCRATCH_5_REGISTER, SCRATCH_5_OFFSET(r1)
/* Pop stack */
addi r1, r1, PPC_EXC_MINIMAL_FRAME_SIZE
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
index 8eda3a1..1a071c2 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
@@ -142,23 +142,15 @@ extern "C" {
#ifndef __SPE__
- #define PPC_EXC_GPR_TYPE unsigned
- #define PPC_EXC_GPR_SIZE 4
- #define PPC_EXC_GPR_OFFSET(gpr) ((gpr) * PPC_EXC_GPR_SIZE + 36)
+ #define PPC_EXC_GPR_OFFSET(gpr) ((gpr) * PPC_GPR_SIZE + 36)
#define PPC_EXC_VECTOR_PROLOGUE_OFFSET PPC_EXC_GPR_OFFSET(4)
- #define PPC_EXC_GPR_LOAD lwz
- #define PPC_EXC_GPR_STORE stw
#define PPC_EXC_MINIMAL_FRAME_SIZE 96
#define PPC_EXC_FRAME_SIZE 176
#else
- #define PPC_EXC_GPR_TYPE uint64_t
- #define PPC_EXC_GPR_SIZE 8
#define PPC_EXC_SPEFSCR_OFFSET 36
#define PPC_EXC_ACC_OFFSET 40
- #define PPC_EXC_GPR_OFFSET(gpr) ((gpr) * PPC_EXC_GPR_SIZE + 48)
+ #define PPC_EXC_GPR_OFFSET(gpr) ((gpr) * PPC_GPR_SIZE + 48)
#define PPC_EXC_VECTOR_PROLOGUE_OFFSET (PPC_EXC_GPR_OFFSET(4) + 4)
- #define PPC_EXC_GPR_LOAD evldd
- #define PPC_EXC_GPR_STORE evstdd
#define PPC_EXC_MINIMAL_FRAME_SIZE 160
#define PPC_EXC_FRAME_SIZE 320
#endif
@@ -268,38 +260,38 @@ typedef struct {
uint32_t EXC_SPEFSCR;
uint64_t EXC_ACC;
#endif
- PPC_EXC_GPR_TYPE GPR0;
- PPC_EXC_GPR_TYPE GPR1;
- PPC_EXC_GPR_TYPE GPR2;
- PPC_EXC_GPR_TYPE GPR3;
- PPC_EXC_GPR_TYPE GPR4;
- PPC_EXC_GPR_TYPE GPR5;
- PPC_EXC_GPR_TYPE GPR6;
- PPC_EXC_GPR_TYPE GPR7;
- PPC_EXC_GPR_TYPE GPR8;
- PPC_EXC_GPR_TYPE GPR9;
- PPC_EXC_GPR_TYPE GPR10;
- PPC_EXC_GPR_TYPE GPR11;
- PPC_EXC_GPR_TYPE GPR12;
- PPC_EXC_GPR_TYPE GPR13;
- PPC_EXC_GPR_TYPE GPR14;
- PPC_EXC_GPR_TYPE GPR15;
- PPC_EXC_GPR_TYPE GPR16;
- PPC_EXC_GPR_TYPE GPR17;
- PPC_EXC_GPR_TYPE GPR18;
- PPC_EXC_GPR_TYPE GPR19;
- PPC_EXC_GPR_TYPE GPR20;
- PPC_EXC_GPR_TYPE GPR21;
- PPC_EXC_GPR_TYPE GPR22;
- PPC_EXC_GPR_TYPE GPR23;
- PPC_EXC_GPR_TYPE GPR24;
- PPC_EXC_GPR_TYPE GPR25;
- PPC_EXC_GPR_TYPE GPR26;
- PPC_EXC_GPR_TYPE GPR27;
- PPC_EXC_GPR_TYPE GPR28;
- PPC_EXC_GPR_TYPE GPR29;
- PPC_EXC_GPR_TYPE GPR30;
- PPC_EXC_GPR_TYPE GPR31;
+ PPC_GPR_TYPE GPR0;
+ PPC_GPR_TYPE GPR1;
+ PPC_GPR_TYPE GPR2;
+ PPC_GPR_TYPE GPR3;
+ PPC_GPR_TYPE GPR4;
+ PPC_GPR_TYPE GPR5;
+ PPC_GPR_TYPE GPR6;
+ PPC_GPR_TYPE GPR7;
+ PPC_GPR_TYPE GPR8;
+ PPC_GPR_TYPE GPR9;
+ PPC_GPR_TYPE GPR10;
+ PPC_GPR_TYPE GPR11;
+ PPC_GPR_TYPE GPR12;
+ PPC_GPR_TYPE GPR13;
+ PPC_GPR_TYPE GPR14;
+ PPC_GPR_TYPE GPR15;
+ PPC_GPR_TYPE GPR16;
+ PPC_GPR_TYPE GPR17;
+ PPC_GPR_TYPE GPR18;
+ PPC_GPR_TYPE GPR19;
+ PPC_GPR_TYPE GPR20;
+ PPC_GPR_TYPE GPR21;
+ PPC_GPR_TYPE GPR22;
+ PPC_GPR_TYPE GPR23;
+ PPC_GPR_TYPE GPR24;
+ PPC_GPR_TYPE GPR25;
+ PPC_GPR_TYPE GPR26;
+ PPC_GPR_TYPE GPR27;
+ PPC_GPR_TYPE GPR28;
+ PPC_GPR_TYPE GPR29;
+ PPC_GPR_TYPE GPR30;
+ PPC_GPR_TYPE GPR31;
unsigned EXC_MSR;
unsigned EXC_DAR;
} BSP_Exception_frame;
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c b/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c
index 1a34609..5c0f8d1 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c
@@ -65,6 +65,7 @@ void _CPU_Context_Initialize(
bool is_fp
+ ppc_context *the_ppc_context;
uint32_t msr_value;
uint32_t sp;
@@ -122,35 +123,10 @@ void _CPU_Context_Initialize(
memset( the_context, 0, sizeof( *the_context ) );
- PPC_CONTEXT_SET_SP( the_context, sp );
- PPC_CONTEXT_SET_PC( the_context, (uint32_t) entry_point );
- PPC_CONTEXT_SET_MSR( the_context, msr_value );
-#ifndef __SPE__
-#if (PPC_ABI == PPC_ABI_SVR4)
- * SVR4 says R2 is for 'system-reserved' use; it cannot hurt to
- * propagate R2 to all task contexts.
- { uint32_t r2 = 0;
- unsigned r13 = 0;
- __asm__ volatile ("mr %0,2; mr %1,13" : "=r" ((r2)), "=r" ((r13)));
- the_context->gpr2 = r2;
- the_context->gpr13 = r13;
-#elif (PPC_ABI == PPC_ABI_EABI)
- unsigned r13 = 0;
-#else
-#error unsupported PPC_ABI
-#endif
-#endif /* __SPE__ */
+ the_ppc_context = ppc_get_context( the_context );
+ the_ppc_context->gpr1 = sp;
+ the_ppc_context->msr = msr_value;
+ the_ppc_context->lr = (uint32_t) entry_point;
#ifdef __ALTIVEC__
_CPU_Context_initialize_altivec(the_context);
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S b/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
index 3568a0e..04fb8b1 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
@@ -23,7 +23,7 @@
* COPYRIGHT (c) 1989-1997.
* On-Line Applications Research Corporation (OAR).
- * Copyright (c) 2011 embedded brains GmbH.
+ * Copyright (c) 2011-2012 embedded brains GmbH.
* The license and distribution terms for this file may in
* the file LICENSE in this distribution or at
@@ -35,55 +35,33 @@
#include <rtems/score/cpu.h>
#include <bspopts.h>
-#if BSP_DATA_CACHE_ENABLED && PPC_CACHE_ALIGNMENT == 32
- #define DATA_CACHE_ALIGNMENT(reg) \
- li reg, PPC_CACHE_ALIGNMENT
- #define DATA_CACHE_ZERO(rega, regb) \
- dcbz rega, regb
+#if PPC_DEFAULT_CACHE_LINE_SIZE != 32
+ #error "unexpected PPC_DEFAULT_CACHE_LINE_SIZE value"
+#endif
+#ifdef BSP_USE_DATA_CACHE_BLOCK_TOUCH
#define DATA_CACHE_TOUCH(rega, regb) \
- dcbt rega, regb
- #define DATA_CACHE_ZERO_AND_TOUCH(reg, offset) \
- li reg, offset; dcbz reg, r3; dcbt reg, r4
+ dcbt rega, regb
#else
+#endif
+#if BSP_DATA_CACHE_ENABLED && PPC_CACHE_ALIGNMENT == 32
- li reg, offset
+ li reg, offset; dcbz reg, r3; DATA_CACHE_TOUCH(reg, r4)
+#else
+ #define DATA_CACHE_ZERO_AND_TOUCH(reg, offset)
#endif
+#define PPC_CONTEXT_CACHE_LINE_0 32
+#define PPC_CONTEXT_CACHE_LINE_1 64
+#define PPC_CONTEXT_CACHE_LINE_2 96
+#define PPC_CONTEXT_CACHE_LINE_3 128
+#define PPC_CONTEXT_CACHE_LINE_4 160
* Offsets for various Contexts
- .set GP_1, 0
- .set GP_2, (GP_1 + 4)
- .set GP_13, (GP_2 + 4)
- .set GP_14, (GP_13 + 4)
- .set GP_15, (GP_14 + 4)
- .set GP_16, (GP_15 + 4)
- .set GP_17, (GP_16 + 4)
- .set GP_18, (GP_17 + 4)
- .set GP_19, (GP_18 + 4)
- .set GP_20, (GP_19 + 4)
- .set GP_21, (GP_20 + 4)
- .set GP_22, (GP_21 + 4)
- .set GP_23, (GP_22 + 4)
- .set GP_24, (GP_23 + 4)
- .set GP_25, (GP_24 + 4)
- .set GP_26, (GP_25 + 4)
- .set GP_27, (GP_26 + 4)
- .set GP_28, (GP_27 + 4)
- .set GP_29, (GP_28 + 4)
- .set GP_30, (GP_29 + 4)
- .set GP_31, (GP_30 + 4)
- .set GP_CR, (GP_31 + 4)
- .set GP_PC, (GP_CR + 4)
- .set GP_MSR, (GP_PC + 4)
#if (PPC_HAS_DOUBLE==1)
.set FP_SIZE, 8
@@ -129,38 +107,6 @@
.set FP_31, (FP_30 + FP_SIZE)
.set FP_FPSCR, (FP_31 + FP_SIZE)
- .set IP_LINK, 0
- .set IP_0, (IP_LINK + 8)
- .set IP_2, (IP_0 + 4)
- .set IP_3, (IP_2 + 4)
- .set IP_4, (IP_3 + 4)
- .set IP_5, (IP_4 + 4)
- .set IP_6, (IP_5 + 4)
- .set IP_7, (IP_6 + 4)
- .set IP_8, (IP_7 + 4)
- .set IP_9, (IP_8 + 4)
- .set IP_10, (IP_9 + 4)
- .set IP_11, (IP_10 + 4)
- .set IP_12, (IP_11 + 4)
- .set IP_13, (IP_12 + 4)
- .set IP_28, (IP_13 + 4)
- .set IP_29, (IP_28 + 4)
- .set IP_30, (IP_29 + 4)
- .set IP_31, (IP_30 + 4)
- .set IP_CR, (IP_31 + 4)
- .set IP_CTR, (IP_CR + 4)
- .set IP_XER, (IP_CTR + 4)
- .set IP_LR, (IP_XER + 4)
- .set IP_PC, (IP_LR + 4)
- .set IP_MSR, (IP_PC + 4)
- .set IP_END, (IP_MSR + 16)
BEGIN_CODE
* _CPU_Context_save_fp_context
@@ -300,111 +246,15 @@ PROC (_CPU_Context_restore_fp):
#endif
blr
-/* _CPU_Context_switch
- * This routine performs a normal non-FP context switch.
ALIGN (PPC_CACHE_ALIGNMENT, PPC_CACHE_ALIGN_POWER)
PUBLIC_PROC (_CPU_Context_switch)
PROC (_CPU_Context_switch):
-#ifndef __SPE__
+#ifdef BSP_USE_SYNC_IN_CONTEXT_SWITCH
sync
isync
- /* This assumes that all the registers are in the given order */
- DATA_CACHE_ALIGNMENT(r5)
- addi r9,r3,-4
- DATA_CACHE_ZERO(r5, r9)
-#ifdef RTEMS_MULTIPROCESSING
- * We have to clear the reservation of the executing thread. See also
- * Book E section 6.1.6.2 "Atomic Update Primitives".
- li r10, GP_1 + 4
- stwcx. r1, r9, r10
-#endif
- stw r1, GP_1+4(r9)
- stw r2, GP_2+4(r9)
-#if (PPC_USE_MULTIPLE == 1)
- addi r9, r9, GP_18+4
- stmw r13, GP_13-GP_18(r9)
-#else
- stw r13, GP_13+4(r9)
- stw r14, GP_14+4(r9)
- stw r15, GP_15+4(r9)
- stw r16, GP_16+4(r9)
- stw r17, GP_17+4(r9)
- stwu r18, GP_18+4(r9)
- stw r19, GP_19-GP_18(r9)
- stw r20, GP_20-GP_18(r9)
- stw r21, GP_21-GP_18(r9)
- stw r22, GP_22-GP_18(r9)
- stw r23, GP_23-GP_18(r9)
- stw r24, GP_24-GP_18(r9)
- stw r25, GP_25-GP_18(r9)
- stw r26, GP_26-GP_18(r9)
- stw r27, GP_27-GP_18(r9)
- stw r28, GP_28-GP_18(r9)
- stw r29, GP_29-GP_18(r9)
- stw r30, GP_30-GP_18(r9)
- stw r31, GP_31-GP_18(r9)
-#endif
- DATA_CACHE_TOUCH(r0, r4)
- mfcr r6
- stw r6, GP_CR-GP_18(r9)
- mflr r7
- stw r7, GP_PC-GP_18(r9)
- mfmsr r8
- stw r8, GP_MSR-GP_18(r9)
-#ifdef __ALTIVEC__
- mr r14, r4
- EXTERN_PROC(_CPU_Context_switch_altivec)
- bl _CPU_Context_switch_altivec
- mr r4, r14
-#endif
- DATA_CACHE_TOUCH(r5, r4)
- lwz r1, GP_1(r4)
- lwz r2, GP_2(r4)
- addi r4, r4, GP_19
- lmw r13, GP_13-GP_19(r4)
-#else
- lwz r13, GP_13(r4)
- lwz r14, GP_14(r4)
- lwz r15, GP_15(r4)
- lwz r16, GP_16(r4)
- lwz r17, GP_17(r4)
- lwz r18, GP_18(r4)
- lwzu r19, GP_19(r4)
- lwz r20, GP_20-GP_19(r4)
- lwz r21, GP_21-GP_19(r4)
- lwz r22, GP_22-GP_19(r4)
- lwz r23, GP_23-GP_19(r4)
- lwz r24, GP_24-GP_19(r4)
- lwz r25, GP_25-GP_19(r4)
- lwz r26, GP_26-GP_19(r4)
- lwz r27, GP_27-GP_19(r4)
- lwz r28, GP_28-GP_19(r4)
- lwz r29, GP_29-GP_19(r4)
- lwz r30, GP_30-GP_19(r4)
- lwz r31, GP_31-GP_19(r4)
#endif
- lwz r6, GP_CR-GP_19(r4)
- lwz r7, GP_PC-GP_19(r4)
- lwz r8, GP_MSR-GP_19(r4)
- mtcrf 255, r6
- mtlr r7
- mtmsr r8
- isync
- blr
-#else /* __SPE__ */
/* Align to a cache line */
clrrwi r3, r3, 5
clrrwi r4, r4, 5
@@ -421,139 +271,115 @@ PROC (_CPU_Context_switch):
- * Here we assume PPC_CONTEXT_OFFSET_SP == PPC_CONTEXT_CACHE_LINE_0.
+ #if PPC_CONTEXT_OFFSET_GPR1 != PPC_CONTEXT_CACHE_LINE_0 \
+ || !BSP_DATA_CACHE_ENABLED \
+ || PPC_CACHE_ALIGNMENT != 32
+ li r10, PPC_CONTEXT_OFFSET_GPR1
+ #endif
stwcx. r1, r3, r10
#endif
- stw r1, PPC_CONTEXT_OFFSET_SP(r3)
+ stw r1, PPC_CONTEXT_OFFSET_GPR1(r3)
stw r5, PPC_CONTEXT_OFFSET_MSR(r3)
stw r6, PPC_CONTEXT_OFFSET_LR(r3)
stw r7, PPC_CONTEXT_OFFSET_CR(r3)
- evstdd r14, PPC_CONTEXT_OFFSET_GPR14(r3)
- evstdd r15, PPC_CONTEXT_OFFSET_GPR15(r3)
+ PPC_GPR_STORE r14, PPC_CONTEXT_OFFSET_GPR14(r3)
+ PPC_GPR_STORE r15, PPC_CONTEXT_OFFSET_GPR15(r3)
+#if PPC_CONTEXT_OFFSET_GPR20 == PPC_CONTEXT_CACHE_LINE_2
+ DATA_CACHE_ZERO_AND_TOUCH(r10, PPC_CONTEXT_CACHE_LINE_2)
+#endif
+ PPC_GPR_STORE r16, PPC_CONTEXT_OFFSET_GPR16(r3)
+ PPC_GPR_STORE r17, PPC_CONTEXT_OFFSET_GPR17(r3)
+#if PPC_CONTEXT_OFFSET_GPR26 == PPC_CONTEXT_CACHE_LINE_2
+#endif
- evstdd r16, PPC_CONTEXT_OFFSET_GPR16(r3)
- evstdd r17, PPC_CONTEXT_OFFSET_GPR17(r3)
- evstdd r18, PPC_CONTEXT_OFFSET_GPR18(r3)
- evstdd r19, PPC_CONTEXT_OFFSET_GPR19(r3)
+ PPC_GPR_STORE r18, PPC_CONTEXT_OFFSET_GPR18(r3)
+ PPC_GPR_STORE r19, PPC_CONTEXT_OFFSET_GPR19(r3)
+#if PPC_CONTEXT_OFFSET_GPR24 == PPC_CONTEXT_CACHE_LINE_3
DATA_CACHE_ZERO_AND_TOUCH(r10, PPC_CONTEXT_CACHE_LINE_3)
+#endif
- evstdd r20, PPC_CONTEXT_OFFSET_GPR20(r3)
- evstdd r21, PPC_CONTEXT_OFFSET_GPR21(r3)
- evstdd r22, PPC_CONTEXT_OFFSET_GPR22(r3)
- evstdd r23, PPC_CONTEXT_OFFSET_GPR23(r3)
+ PPC_GPR_STORE r20, PPC_CONTEXT_OFFSET_GPR20(r3)
+ PPC_GPR_STORE r21, PPC_CONTEXT_OFFSET_GPR21(r3)
+ PPC_GPR_STORE r22, PPC_CONTEXT_OFFSET_GPR22(r3)
+ PPC_GPR_STORE r23, PPC_CONTEXT_OFFSET_GPR23(r3)
+#if PPC_CONTEXT_OFFSET_GPR28 == PPC_CONTEXT_CACHE_LINE_4
DATA_CACHE_ZERO_AND_TOUCH(r10, PPC_CONTEXT_CACHE_LINE_4)
+#endif
- evstdd r24, PPC_CONTEXT_OFFSET_GPR24(r3)
- evstdd r25, PPC_CONTEXT_OFFSET_GPR25(r3)
- evstdd r26, PPC_CONTEXT_OFFSET_GPR26(r3)
- evstdd r27, PPC_CONTEXT_OFFSET_GPR27(r3)
+ PPC_GPR_STORE r24, PPC_CONTEXT_OFFSET_GPR24(r3)
+ PPC_GPR_STORE r25, PPC_CONTEXT_OFFSET_GPR25(r3)
+ PPC_GPR_STORE r26, PPC_CONTEXT_OFFSET_GPR26(r3)
+ PPC_GPR_STORE r27, PPC_CONTEXT_OFFSET_GPR27(r3)
- evstdd r28, PPC_CONTEXT_OFFSET_GPR28(r3)
- evstdd r29, PPC_CONTEXT_OFFSET_GPR29(r3)
- evstdd r30, PPC_CONTEXT_OFFSET_GPR30(r3)
- evstdd r31, PPC_CONTEXT_OFFSET_GPR31(r3)
+ PPC_GPR_STORE r28, PPC_CONTEXT_OFFSET_GPR28(r3)
+ PPC_GPR_STORE r29, PPC_CONTEXT_OFFSET_GPR29(r3)
+ PPC_GPR_STORE r30, PPC_CONTEXT_OFFSET_GPR30(r3)
+ PPC_GPR_STORE r31, PPC_CONTEXT_OFFSET_GPR31(r3)
/* Restore context from r4 */
restore_context:
- lwz r1, PPC_CONTEXT_OFFSET_SP(r4)
+#ifdef __ALTIVEC__
+ mr r14, r4
+ .extern _CPU_Context_switch_altivec
+ bl _CPU_Context_switch_altivec
+ mr r4, r14
+#endif
+ lwz r1, PPC_CONTEXT_OFFSET_GPR1(r4)
lwz r5, PPC_CONTEXT_OFFSET_MSR(r4)
lwz r6, PPC_CONTEXT_OFFSET_LR(r4)
lwz r7, PPC_CONTEXT_OFFSET_CR(r4)
- evldd r14, PPC_CONTEXT_OFFSET_GPR14(r4)
- evldd r15, PPC_CONTEXT_OFFSET_GPR15(r4)
+ PPC_GPR_LOAD r14, PPC_CONTEXT_OFFSET_GPR14(r4)
+ PPC_GPR_LOAD r15, PPC_CONTEXT_OFFSET_GPR15(r4)
DATA_CACHE_TOUCH(r0, r1)
- evldd r16, PPC_CONTEXT_OFFSET_GPR16(r4)
- evldd r17, PPC_CONTEXT_OFFSET_GPR17(r4)
- evldd r18, PPC_CONTEXT_OFFSET_GPR18(r4)
- evldd r19, PPC_CONTEXT_OFFSET_GPR19(r4)
+ PPC_GPR_LOAD r16, PPC_CONTEXT_OFFSET_GPR16(r4)
+ PPC_GPR_LOAD r17, PPC_CONTEXT_OFFSET_GPR17(r4)
+ PPC_GPR_LOAD r18, PPC_CONTEXT_OFFSET_GPR18(r4)
+ PPC_GPR_LOAD r19, PPC_CONTEXT_OFFSET_GPR19(r4)
- evldd r20, PPC_CONTEXT_OFFSET_GPR20(r4)
- evldd r21, PPC_CONTEXT_OFFSET_GPR21(r4)
- evldd r22, PPC_CONTEXT_OFFSET_GPR22(r4)
- evldd r23, PPC_CONTEXT_OFFSET_GPR23(r4)
+ PPC_GPR_LOAD r20, PPC_CONTEXT_OFFSET_GPR20(r4)
+ PPC_GPR_LOAD r21, PPC_CONTEXT_OFFSET_GPR21(r4)
+ PPC_GPR_LOAD r22, PPC_CONTEXT_OFFSET_GPR22(r4)
+ PPC_GPR_LOAD r23, PPC_CONTEXT_OFFSET_GPR23(r4)
- evldd r24, PPC_CONTEXT_OFFSET_GPR24(r4)
- evldd r25, PPC_CONTEXT_OFFSET_GPR25(r4)
- evldd r26, PPC_CONTEXT_OFFSET_GPR26(r4)
- evldd r27, PPC_CONTEXT_OFFSET_GPR27(r4)
+ PPC_GPR_LOAD r24, PPC_CONTEXT_OFFSET_GPR24(r4)
+ PPC_GPR_LOAD r25, PPC_CONTEXT_OFFSET_GPR25(r4)
+ PPC_GPR_LOAD r26, PPC_CONTEXT_OFFSET_GPR26(r4)
+ PPC_GPR_LOAD r27, PPC_CONTEXT_OFFSET_GPR27(r4)
- evldd r28, PPC_CONTEXT_OFFSET_GPR28(r4)
- evldd r29, PPC_CONTEXT_OFFSET_GPR29(r4)
- evldd r30, PPC_CONTEXT_OFFSET_GPR30(r4)
- evldd r31, PPC_CONTEXT_OFFSET_GPR31(r4)
+ PPC_GPR_LOAD r28, PPC_CONTEXT_OFFSET_GPR28(r4)
+ PPC_GPR_LOAD r29, PPC_CONTEXT_OFFSET_GPR29(r4)
+ PPC_GPR_LOAD r30, PPC_CONTEXT_OFFSET_GPR30(r4)
+ PPC_GPR_LOAD r31, PPC_CONTEXT_OFFSET_GPR31(r4)
mtcr r7
mtlr r6
mtmsr r5
+ isync
+#endif
blr
- * _CPU_Context_restore
- * This routine is generallu used only to restart self in an
- * efficient manner. It may simply be a label in _CPU_Context_switch.
- * NOTE: May be unnecessary to reload some registers.
- * ACB: Don't worry about cache optimisation here - this is not THAT critical.
- ALIGN (PPC_CACHE_ALIGNMENT, PPC_CACHE_ALIGN_POWER)
PUBLIC_PROC (_CPU_Context_restore)
PROC (_CPU_Context_restore):
-#ifndef __SPE__
- lwz r5, GP_CR(r3)
- lwz r6, GP_PC(r3)
- lwz r7, GP_MSR(r3)
- mtcrf 255, r5
- mtlr r6
- mtmsr r7
- isync
- lwz r1, GP_1(r3)
- lwz r2, GP_2(r3)
- lmw r13, GP_13(r3)
-#else
- lwz r13, GP_13(r3)
- lwz r14, GP_14(r3)
- lwz r15, GP_15(r3)
- lwz r16, GP_16(r3)
- lwz r17, GP_17(r3)
- lwz r18, GP_18(r3)
- lwz r19, GP_19(r3)
- lwz r20, GP_20(r3)
- lwz r21, GP_21(r3)
- lwz r22, GP_22(r3)
- lwz r23, GP_23(r3)
- lwz r24, GP_24(r3)
- lwz r25, GP_25(r3)
- lwz r26, GP_26(r3)
- lwz r27, GP_27(r3)
- lwz r28, GP_28(r3)
- lwz r29, GP_29(r3)
- lwz r30, GP_30(r3)
- lwz r31, GP_31(r3)
-#endif
-#ifdef __ALTIVEC__
- EXTERN_PROC(_CPU_Context_restore_altivec)
- b _CPU_Context_restore_altivec
-#endif
- blr
clrrwi r4, r3, 5
+#ifdef __ALTIVEC__
+ li r3, 0
+#endif
b restore_context
diff --git a/cpukit/score/cpu/powerpc/cpu.c b/cpukit/score/cpu/powerpc/cpu.c
index b12deae..a1ede94 100644
--- a/cpukit/score/cpu/powerpc/cpu.c
+++ b/cpukit/score/cpu/powerpc/cpu.c
@@ -10,6 +10,43 @@
#ifdef HAVE_CONFIG_H
-#include "config.h"
+ #include "config.h"
#endif
+#include <rtems/system.h>
+#include <rtems/score/cpu.h>
+#define PPC_ASSERT_OFFSET(field, off) \
+ RTEMS_STATIC_ASSERT( \
+ offsetof(ppc_context, field) + PPC_DEFAULT_CACHE_LINE_SIZE \
+ == PPC_CONTEXT_OFFSET_ ## off, \
+ ppc_context_offset_ ## field \
+PPC_ASSERT_OFFSET(gpr1, GPR1);
+PPC_ASSERT_OFFSET(msr, MSR);
+PPC_ASSERT_OFFSET(lr, LR);
+PPC_ASSERT_OFFSET(cr, CR);
+PPC_ASSERT_OFFSET(gpr14, GPR14);
+PPC_ASSERT_OFFSET(gpr15, GPR15);
+PPC_ASSERT_OFFSET(gpr16, GPR16);
+PPC_ASSERT_OFFSET(gpr17, GPR17);
+PPC_ASSERT_OFFSET(gpr18, GPR18);
+PPC_ASSERT_OFFSET(gpr19, GPR19);
+PPC_ASSERT_OFFSET(gpr20, GPR20);
+PPC_ASSERT_OFFSET(gpr21, GPR21);
+PPC_ASSERT_OFFSET(gpr22, GPR22);
+PPC_ASSERT_OFFSET(gpr23, GPR23);
+PPC_ASSERT_OFFSET(gpr24, GPR24);
+PPC_ASSERT_OFFSET(gpr25, GPR25);
+PPC_ASSERT_OFFSET(gpr26, GPR26);
+PPC_ASSERT_OFFSET(gpr27, GPR27);
+PPC_ASSERT_OFFSET(gpr28, GPR28);
+PPC_ASSERT_OFFSET(gpr29, GPR29);
+PPC_ASSERT_OFFSET(gpr30, GPR30);
+PPC_ASSERT_OFFSET(gpr31, GPR31);
+RTEMS_STATIC_ASSERT(
+ sizeof(Context_Control) % PPC_DEFAULT_CACHE_LINE_SIZE == 0,
+ ppc_context_size
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 3ed76df..e845362 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -23,7 +23,7 @@
* Copyright (c) 2001 Surrey Satellite Technology Limited (SSTL).
- * Copyright (c) 2010-2011 embedded brains GmbH.
+ * Copyright (c) 2010-2012 embedded brains GmbH.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
@@ -249,159 +249,110 @@ extern "C" {
* a debugger such as gdb. But that is another problem.
-#ifndef ASM
-typedef struct {
- #ifndef __SPE__
- uint32_t gpr1; /* Stack pointer for all */
- uint32_t gpr2; /* Reserved SVR4, section ptr EABI + */
- uint32_t gpr13; /* Section ptr SVR4/EABI */
- uint32_t gpr14; /* Non volatile for all */
- uint32_t gpr15; /* Non volatile for all */
- uint32_t gpr16; /* Non volatile for all */
- uint32_t gpr17; /* Non volatile for all */
- uint32_t gpr18; /* Non volatile for all */
- uint32_t gpr19; /* Non volatile for all */
- uint32_t gpr20; /* Non volatile for all */
- uint32_t gpr21; /* Non volatile for all */
- uint32_t gpr22; /* Non volatile for all */
- uint32_t gpr23; /* Non volatile for all */
- uint32_t gpr24; /* Non volatile for all */
- uint32_t gpr25; /* Non volatile for all */
- uint32_t gpr26; /* Non volatile for all */
- uint32_t gpr27; /* Non volatile for all */
- uint32_t gpr28; /* Non volatile for all */
- uint32_t gpr29; /* Non volatile for all */
- uint32_t gpr30; /* Non volatile for all */
- uint32_t gpr31; /* Non volatile for all */
- uint32_t cr; /* PART of the CR is non volatile for all */
- uint32_t pc; /* Program counter/Link register */
- uint32_t msr; /* Initial interrupt level */
- #ifdef __ALTIVEC__
- * 12 non-volatile vector registers, cache-aligned area for vscr/vrsave
- * and padding to ensure cache-alignment. Unfortunately, we can't verify
- * the cache line size here in the cpukit but altivec support code will
- * produce an error if this is ever different from 32 bytes.
- * Note: it is the BSP/CPU-support's responsibility to save/restore
- * volatile vregs across interrupts and exceptions.
- uint8_t altivec[16*12 + 32 + 32];
- #endif
- #else
- /* Non-volatile context according to E500ABIUG and EABI */
- uint32_t context [
- 8 /* Cache line padding */
- + 1 /* Stack pointer */
- + 1 /* MSR */
- + 1 /* LR */
- + 1 /* CR */
- + 18 * 2 /* GPR 14 to GPR 31 */
- #endif
-} Context_Control;
-#endif /* ASM */
#ifndef __SPE__
- #define PPC_CONTEXT_SET_SP( _context, _sp ) \
- do { \
- (_context)->gpr1 = _sp; \
- } while (0)
+ #define PPC_GPR_TYPE uint32_t
+ #define PPC_GPR_SIZE 4
+ #define PPC_GPR_LOAD lwz
+ #define PPC_GPR_STORE stw
+#else
+ #define PPC_GPR_TYPE uint64_t
+ #define PPC_GPR_SIZE 8
+ #define PPC_GPR_LOAD evldd
+ #define PPC_GPR_STORE evstdd
+#endif
- #define PPC_CONTEXT_GET_CR( _context ) \
- (_context)->cr
+#define PPC_DEFAULT_CACHE_LINE_SIZE 32
- #define PPC_CONTEXT_GET_MSR( _context ) \
- (_context)->msr
+#ifndef ASM
- #define PPC_CONTEXT_SET_MSR( _context, _msr ) \
- do { \
- (_context)->msr = _msr; \
- } while (0)
+/* Non-volatile context according to E500ABIUG and EABI */
+typedef struct {
+ uint32_t gpr1;
+ uint32_t msr;
+ uint32_t lr;
+ uint32_t cr;
+ PPC_GPR_TYPE gpr14;
+ PPC_GPR_TYPE gpr15;
+ PPC_GPR_TYPE gpr16;
+ PPC_GPR_TYPE gpr17;
+ PPC_GPR_TYPE gpr18;
+ PPC_GPR_TYPE gpr19;
+ PPC_GPR_TYPE gpr20;
+ PPC_GPR_TYPE gpr21;
+ PPC_GPR_TYPE gpr22;
+ PPC_GPR_TYPE gpr23;
+ PPC_GPR_TYPE gpr24;
+ PPC_GPR_TYPE gpr25;
+ PPC_GPR_TYPE gpr26;
+ PPC_GPR_TYPE gpr27;
+ PPC_GPR_TYPE gpr28;
+ PPC_GPR_TYPE gpr29;
+ PPC_GPR_TYPE gpr30;
+ PPC_GPR_TYPE gpr31;
+ #ifdef __ALTIVEC__
+ * 12 non-volatile vector registers, cache-aligned area for vscr/vrsave
+ * and padding to ensure cache-alignment. Unfortunately, we can't verify
+ * the cache line size here in the cpukit but altivec support code will
+ * produce an error if this is ever different from 32 bytes.
+ * Note: it is the BSP/CPU-support's responsibility to save/restore
+ * volatile vregs across interrupts and exceptions.
+ uint8_t altivec[16*12 + 32 + PPC_DEFAULT_CACHE_LINE_SIZE];
+ #endif
+} ppc_context;
- #define PPC_CONTEXT_FIRST_SAVED_GPR 13
+typedef struct {
+ uint8_t context [
+ + sizeof(ppc_context)
+ + (sizeof(ppc_context) % PPC_DEFAULT_CACHE_LINE_SIZE == 0
+ ? 0
+ : PPC_DEFAULT_CACHE_LINE_SIZE
+ - sizeof(ppc_context) % PPC_DEFAULT_CACHE_LINE_SIZE)
+} Context_Control;
- #define PPC_CONTEXT_GET_FIRST_SAVED( _context ) \
- (_context)->gpr13
+static inline ppc_context *ppc_get_context( Context_Control *context )
+ uintptr_t clsz = PPC_DEFAULT_CACHE_LINE_SIZE;
+ uintptr_t mask = clsz - 1;
+ uintptr_t addr = (uintptr_t) context;
- #define PPC_CONTEXT_GET_PC( _context ) \
- (_context)->pc
+ return (ppc_context *) ((addr & ~mask) + clsz);
- #define PPC_CONTEXT_SET_PC( _context, _pc ) \
- do { \
- (_context)->pc = _pc; \
- } while (0)
+#define _CPU_Context_Get_SP( _context ) \
+ ppc_get_context(_context)->gpr1
+#endif /* ASM */
- #define _CPU_Context_Get_SP( _context ) \
- (_context)->gpr1
-#else
- #define PPC_CONTEXT_CACHE_LINE_0 32
- #define PPC_CONTEXT_OFFSET_SP 32
- #define PPC_CONTEXT_OFFSET_MSR 36
- #define PPC_CONTEXT_OFFSET_LR 40
- #define PPC_CONTEXT_OFFSET_CR 44
- #define PPC_CONTEXT_OFFSET_GPR14 48
- #define PPC_CONTEXT_OFFSET_GPR15 56
- #define PPC_CONTEXT_CACHE_LINE_1 64
- #define PPC_CONTEXT_OFFSET_GPR16 64
- #define PPC_CONTEXT_OFFSET_GPR17 72
- #define PPC_CONTEXT_OFFSET_GPR18 80
- #define PPC_CONTEXT_OFFSET_GPR19 88
- #define PPC_CONTEXT_CACHE_LINE_2 96
- #define PPC_CONTEXT_OFFSET_GPR20 96
- #define PPC_CONTEXT_OFFSET_GPR21 104
- #define PPC_CONTEXT_OFFSET_GPR22 112
- #define PPC_CONTEXT_OFFSET_GPR23 120
- #define PPC_CONTEXT_CACHE_LINE_3 128
- #define PPC_CONTEXT_OFFSET_GPR24 128
- #define PPC_CONTEXT_OFFSET_GPR25 136
- #define PPC_CONTEXT_OFFSET_GPR26 144
- #define PPC_CONTEXT_OFFSET_GPR27 152
- #define PPC_CONTEXT_CACHE_LINE_4 160
- #define PPC_CONTEXT_OFFSET_GPR28 160
- #define PPC_CONTEXT_OFFSET_GPR29 168
- #define PPC_CONTEXT_OFFSET_GPR30 176
- #define PPC_CONTEXT_OFFSET_GPR31 184
- #define PPC_CONTEXT_AREA( _context ) \
- ((uint32_t *) (((uintptr_t) (_context)) & ~0x1fU))
- #define PPC_CONTEXT_FIELD( _context, _offset ) \
- PPC_CONTEXT_AREA( _context ) [(_offset) / 4]
- do { \
- PPC_CONTEXT_FIELD( _context, PPC_CONTEXT_OFFSET_SP ) = _sp; \
- } while (0)
- PPC_CONTEXT_FIELD( _context, PPC_CONTEXT_OFFSET_CR )
- PPC_CONTEXT_FIELD( _context, PPC_CONTEXT_OFFSET_MSR )
- do { \
- PPC_CONTEXT_FIELD( _context, PPC_CONTEXT_OFFSET_MSR ) = _msr; \
- } while (0)
- #define PPC_CONTEXT_FIRST_SAVED_GPR 14
- PPC_CONTEXT_FIELD( _context, PPC_CONTEXT_OFFSET_GPR14 )
- PPC_CONTEXT_FIELD( _context, PPC_CONTEXT_OFFSET_LR )
- do { \
- PPC_CONTEXT_FIELD( _context, PPC_CONTEXT_OFFSET_LR ) = _pc; \
- } while (0)
-#endif
+#define PPC_CONTEXT_OFFSET_GPR1 32
+#define PPC_CONTEXT_OFFSET_MSR 36
+#define PPC_CONTEXT_OFFSET_LR 40
+#define PPC_CONTEXT_OFFSET_CR 44
+#define PPC_CONTEXT_GPR_OFFSET( gpr ) \
+ (((gpr) - 14) * PPC_GPR_SIZE + 48)
+#define PPC_CONTEXT_OFFSET_GPR14 PPC_CONTEXT_GPR_OFFSET( 14 )
+#define PPC_CONTEXT_OFFSET_GPR15 PPC_CONTEXT_GPR_OFFSET( 15 )
+#define PPC_CONTEXT_OFFSET_GPR16 PPC_CONTEXT_GPR_OFFSET( 16 )
+#define PPC_CONTEXT_OFFSET_GPR17 PPC_CONTEXT_GPR_OFFSET( 17 )
+#define PPC_CONTEXT_OFFSET_GPR18 PPC_CONTEXT_GPR_OFFSET( 18 )
+#define PPC_CONTEXT_OFFSET_GPR19 PPC_CONTEXT_GPR_OFFSET( 19 )
+#define PPC_CONTEXT_OFFSET_GPR20 PPC_CONTEXT_GPR_OFFSET( 20 )
+#define PPC_CONTEXT_OFFSET_GPR21 PPC_CONTEXT_GPR_OFFSET( 21 )
+#define PPC_CONTEXT_OFFSET_GPR22 PPC_CONTEXT_GPR_OFFSET( 22 )
+#define PPC_CONTEXT_OFFSET_GPR23 PPC_CONTEXT_GPR_OFFSET( 23 )
+#define PPC_CONTEXT_OFFSET_GPR24 PPC_CONTEXT_GPR_OFFSET( 24 )
+#define PPC_CONTEXT_OFFSET_GPR25 PPC_CONTEXT_GPR_OFFSET( 25 )
+#define PPC_CONTEXT_OFFSET_GPR26 PPC_CONTEXT_GPR_OFFSET( 26 )
+#define PPC_CONTEXT_OFFSET_GPR27 PPC_CONTEXT_GPR_OFFSET( 27 )
+#define PPC_CONTEXT_OFFSET_GPR28 PPC_CONTEXT_GPR_OFFSET( 28 )
+#define PPC_CONTEXT_OFFSET_GPR29 PPC_CONTEXT_GPR_OFFSET( 29 )
+#define PPC_CONTEXT_OFFSET_GPR30 PPC_CONTEXT_GPR_OFFSET( 30 )
+#define PPC_CONTEXT_OFFSET_GPR31 PPC_CONTEXT_GPR_OFFSET( 31 )
#ifndef ASM
typedef struct {
