Add statistic to rtems_disk_device and bdbuf
Xiang Cui
medivhc at gmail.com
Wed May 23 10:50:56 UTC 2012
Hi
I want to add new struct to the rtems_disk_device and bdbuf. All of
them are counters for read/write and cache hit number. This is a very
basic ideal now. These change will help to measure the IO performance
and uncover the bdbuf state.
All these statistics will be updated in bdbuf, I think.
The changes in bdbuf.h and diskdevs.h may like this.
diff --git a/cpukit/libblock/include/rtems/bdbuf.h
b/cpukit/libblock/include/rtems/bdbuf.h
index 134a0ce..25ad374 100644
--- a/cpukit/libblock/include/rtems/bdbuf.h
+++ b/cpukit/libblock/include/rtems/bdbuf.h
@@ -292,6 +292,18 @@ typedef enum
} rtems_bdbuf_buf_state;
+* @brief Statistic for bdbuf.
+typedef struct {
+ unsigned swapout_execute_count; /**< counter for swapout execute */
+ unsigned recycle_count; /**< counter for the recycle */
+ unsigned total_write_count; /**< counter for the total write action */
+ unsigned total_read_count; /**< counter for the total read action */
+ unsigned total_write_hit; /**< counter for the total write hit */
+ unsigned total_read_hit; /**< counter for the total read hit */
+} rtems_bdbuf_statistic;
* Forward reference to the block.
struct rtems_bdbuf_group;
@@ -644,6 +656,14 @@ rtems_bdbuf_purge_dev (const rtems_disk_device *dd);
rtems_status_code
rtems_bdbuf_set_block_size (rtems_disk_device *dd, uint32_t block_size);
+* @brief Return the statistic for bdbuf.
+* @return pointer to rtems_bdbuf_statistic.
+const rtems_bdbuf_statistic *rtems_bdbuf_get_statistic(void);
#ifdef __cplusplus
diff --git a/cpukit/libblock/include/rtems/diskdevs.h
b/cpukit/libblock/include/rtems/diskdevs.h
index 2e3f753..e969894 100644
--- a/cpukit/libblock/include/rtems/diskdevs.h
+++ b/cpukit/libblock/include/rtems/diskdevs.h
@@ -55,6 +55,30 @@ typedef int (*rtems_block_device_ioctl)(
+ * @brief Statistic to count the write and read number for bdbuf.
+ * These statistics counted by block size.
+typedef struct {
+ * @brief counter for write number since the disk device was created
+ unsigned write_count;
+ * @brief counter for read number since the disk device was created
+ unsigned read_count;
+ * @brief counter for write hit in bdbuf
+ unsigned write_hit;
+ * @brief counter for read hit in bdbuf
+ unsigned read_hit;
+} rtems_disk_device_statistic;
* @brief Description of a disk device (logical and physical disks).
* An array of pointer tables to rtems_disk_device structures is maintained.
@@ -153,6 +177,13 @@ struct rtems_disk_device {
* releases this disk.
bool deleted;
+ * @brief statistic for disk device. The logical disks have the same
+ * pointer to these physical disk.
+ rtems_disk_device_statistic *statistic;
@@ -217,6 +248,12 @@ static inline rtems_blkdev_bnum rtems_disk_get_block_count(
return dd->size;
+static inline rtems_disk_device_statistic *
+rtems_disk_get_statistic( const rtems_disk_device *dd)
+ return dd->statistic;
