Add statistic to rtems_disk_device and bdbuf
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Wed May 23 11:35:04 UTC 2012
Hi,
this is nice idea. Getting more insight into the BDBuf performance is
always a good idea ;-)
Nevertheless I would appreciate if the size of the struct fields would
be explicitly defined, so you should use "uint32_t" instead of "unsigned".
wkr,
Thomas.
Am 23.05.2012 12:50, schrieb Xiang Cui:
> Hi
> I want to add new struct to the rtems_disk_device and bdbuf. All of
> them are counters for read/write and cache hit number. This is a very
> basic ideal now. These change will help to measure the IO performance
> and uncover the bdbuf state.
> All these statistics will be updated in bdbuf, I think.
> The changes in bdbuf.h and diskdevs.h may like this.
> diff --git a/cpukit/libblock/include/rtems/bdbuf.h
> b/cpukit/libblock/include/rtems/bdbuf.h
> index 134a0ce..25ad374 100644
> --- a/cpukit/libblock/include/rtems/bdbuf.h
> +++ b/cpukit/libblock/include/rtems/bdbuf.h
> @@ -292,6 +292,18 @@ typedef enum
>  } rtems_bdbuf_buf_state;
> +* @brief Statistic for bdbuf.
> +typedef struct {
> +  unsigned swapout_execute_count;   /**< counter for swapout execute */
> +  unsigned recycle_count;           /**< counter for the recycle */
> +  unsigned total_write_count;       /**< counter for the total write action */
> +  unsigned total_read_count;        /**< counter for the total read action */
> +  unsigned total_write_hit;         /**< counter for the total write hit  */
> +  unsigned total_read_hit;          /**< counter for the total read hit */
> +} rtems_bdbuf_statistic;
>   * Forward reference to the block.
>  struct rtems_bdbuf_group;
> @@ -644,6 +656,14 @@ rtems_bdbuf_purge_dev (const rtems_disk_device *dd);
>  rtems_status_code
>  rtems_bdbuf_set_block_size (rtems_disk_device *dd, uint32_t block_size);
> +* @brief Return the statistic for bdbuf.
> +* @return pointer to rtems_bdbuf_statistic.
> +const rtems_bdbuf_statistic *rtems_bdbuf_get_statistic(void);
>  #ifdef __cplusplus
> diff --git a/cpukit/libblock/include/rtems/diskdevs.h
> b/cpukit/libblock/include/rtems/diskdevs.h
> index 2e3f753..e969894 100644
> --- a/cpukit/libblock/include/rtems/diskdevs.h
> +++ b/cpukit/libblock/include/rtems/diskdevs.h
> @@ -55,6 +55,30 @@ typedef int (*rtems_block_device_ioctl)(
> + * @brief Statistic to count the write and read number for bdbuf.
> + * These statistics counted by block size.
> +typedef struct {
> +  * @brief counter for write number since the disk device was created
> +  unsigned write_count;
> +  * @brief counter for read number since the disk device was created
> +  unsigned read_count;
> +  * @brief counter for write hit in bdbuf
> +  unsigned write_hit;
> +  * @brief counter for read hit in bdbuf
> +  unsigned read_hit;
> +} rtems_disk_device_statistic;
>   * @brief Description of a disk device (logical and physical disks).
>   * An array of pointer tables to rtems_disk_device structures is maintained.
> @@ -153,6 +177,13 @@ struct rtems_disk_device {
>     * releases this disk.
>    bool deleted;
> +  * @brief statistic for disk device. The logical disks have the same
> +  * pointer to these physical disk.
> +  rtems_disk_device_statistic *statistic;
> @@ -217,6 +248,12 @@ static inline rtems_blkdev_bnum rtems_disk_get_block_count(
>    return dd->size;
> +static inline rtems_disk_device_statistic *
> +rtems_disk_get_statistic( const rtems_disk_device *dd)
> +  return dd->statistic;
> rtems-devel mailing list
> rtems-devel at rtems.org
embedded brains GmbH
Thomas Doerfler
Obere Lagerstrasse 30
D-82178 Puchheim
Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax: +49-89-18908079-9
PGP: Public key available on request.
