Continuous Integration - rtbf64c
    Julien Delange
    julien.delange at gmail.com
    Fri May  4 07:35:38 UTC 2012
On Fri, May 4, 2012 at 8:26 AM, Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
> Fedora supplies the tools I am using to build the toolchains. All other OSes
> are either too outdated, or do not supply the tools.
No matter the distribution : you can always build the tools by
yourself, no ? It would also ensure that your toolchain works
perfectly from scratch and with vanilla-version of the tools (not the
packaged ones).
We have a similar process here with a nightly build that rebuilds
RTEMS toolchain on a nightly basis and automatically compiles
different projects. If this is tough to set up, it is very useful at
the end !
