POSIX key structure in rbtree approach
Ashi
ashi08104 at gmail.com
Wed May 9 04:02:47 UTC 2012
2012/5/8 Gedare Bloom <gedare at rtems.org>
> On Tue, May 8, 2012 at 3:17 AM, Ashi <ashi08104 at gmail.com> wrote:
> > 2012/5/7 Gedare Bloom <gedare at rtems.org>
> >> On Mon, May 7, 2012 at 11:16 AM, Ashi <ashi08104 at gmail.com> wrote:
> >> > I'm terribly sorry for my late reply. I'm off for my weekend.
> >> Most of us are. :)
> >> > 2012/5/4 Gedare Bloom <gedare at rtems.org>
> >> >> On Fri, May 4, 2012 at 3:28 AM, Ashi <ashi08104 at gmail.com> wrote:
> >> >> > Hi, all. I'm working on the "Use hash or map in POSIX keys"
> project.
> >> >> > As Joel said, the first thing to be determined is the problem of
> what
> >> >> > data goes with each thread and what goes with each key. I find it's
> >> >> > difficult to design the interface without some specific approach.
> And
> >> >> > since the rbtree api is available in RTEMS, I have tried to do the
> >> >> > design in the rbtree approach.
> >> >> Good. The rbtree should support an efficient map operation.
> >> > Gedare, thanks for your reply!
> >> >> > I find 2 data structures need revised(added): POSIX_Keys_Control
> and
> >> >> > key_node.
> >> >> > typedef struct {
> >> >> > Objects_Control Object;
> >> >> > void (*destructor)( void * );
> >> >> > key_node * key_node_ptr;
> >> >> > }POSIX_Keys_Control;
> >> >> > typedef struct{
> >> >> > rtems_rbtree_node Node;
> >> >> > Objects_Id thread_id;
> >> >> > void **value;
> >> >> > }key_node;
> >> >> > POSIX_Keys_Control is used to manage all keys. And key_node is the
> >> >> > structure contains key data and rbtree node.
> >> >> I think you might want an rtems_rbtree_control key_tree field in
> >> >> POSIX_Keys_Control instead of this key_node* dynamic array. Then
> your
> >> >> code can add structs containing an rtems_rbtree_node dynamically to
> >> >> the key_tree.
> >> > After read the rbtree.h in score, I find I confused the
> >> > rtems_rbtree_node
> >> > and rtems_rbtree_control. It should be the rtems_rbtree_control here.
> >> >> Also the key_node structure should follow a naming convention of
> >> >> POSIX_Keys_Key_node or something similar.
> >> >> API_Package_name_Struct_type_name is the general format for
> >> >> structures. API_Package_name_Method_name is the general format for
> >> >> functions. Note the mixture of lower and upper case letters.
> >> > I see.
> >> >> > I'm not quite sure about the Objects_Control member's function in
> >> >> > current implementation. I find key = Object.id, in which key is
> >> >> > pthread_key_t type, and _POSIX_Keys_Get(key, &location) is used to
> >> >> > find key's corresponding the_key, which is POSIX_Keys_Control
> type.So
> >> >> > is it the only function of Object member ?
> >> >> Object_Control means the structure embeds an RTEMS Object so that the
> >> >> structure can be managed by the Object Manager whose responsibilities
> >> >> include pre-allocating enough objects of a certain type to satisfy
> >> >> requests to Create those objects.
> >> >> It seems to me that the Key (key_node) should be the Object since the
> >> >> number of keys is the resource being managed. The present solution
> >> >> uses an array of values (one for each thread) because each thread can
> >> >> have its own version of a given key. The key is "looked up" by the
> >> >> Object Id of the Key and then the requesting thread. What we should
> >> >> prefer is a more scalable solution that does not require
> >> >> pre-allocating an array of values for all possible threads.
> Something
> >> >> like...
> >> >> typedef struct {
> >> >> void **value;
> >> >> } POSIX_Keys_Control;
> >> >> And maybe a global:
> >> >> rtems_rbtree_control POSIX_Keys_Tree;
> >> > I think this is a new and great idea that I haven't thought
> before,Does
> >> > it
> >> > mean a single POSIX_Keys_Tree contains all node in the system?
> >> yes
> >> > I know a rbtree contains only key data belongs to one specific key in
> my
> >> > design above, and I was thinking the idea of manage all keys by a
> >> > rbtree,
> >> > then there would be a hiearchy: all keys are in one rbtree, and each
> >> > key's
> >> > data are in their own rbtrees. But I think this design is a little
> >> > complex,
> >> > and your idea is more uniform. However, will these two differ much in
> >> > runtime?
> >> not sure because i do not quite understand your design. but I get the
> >> feeling that your design will have a big problem of managing multiple
> >> rbtrees simultaneously. I have not tried to do that before. Both
> >> approaches seem like they would have similar (log-time) asymptotic
> >> behavior.
> > I mean all keys are managed in one globle rbtree, in which each node has
> a
> > member of rtems_rbtree_control, like:
> > typedef struct {
> > void (*destructor)(void*);
> > rtems_rbtree_control key_tree;
> > and for each key, all the key data is managed in each key's rbtree, like:
> > typedef struct{
> > rtems_rbtree_node node;
> > void *value;
> > }POSIX_Keys_Key_node;
> > However, this design seems more complex. And I don't know what could
> lead to
> > the problem of managing multiple
> > rbtrees simultaneously, can you give some example?
> What do you mean "give some example"?
I mean the example of the problem of managing multiple rbtrees
simultaneously.
> I agree that the design of multiple rbtree's in a hierarchy is more
> complex. It would work, but it seems unnecessary here. A single rbtree
> of all the keys should be OK. Lookup/insert/delete times would all be
> O(lg n) where n is the total number of keys. In a hierarchical design
> the cost is lg k + lg t where k is the number of distinct keys and t
> is the number of tasks. The worst-case for the single rbtree is when
> every key is used by every thread and n = k*t. Then
> lg(n)=lg(k*t)=lg(k)+lg(t) which is the worst-case for the hierarchical
> approach. Granted there are cases where the hierarchical approach can
> do better, but in worst-case thinking the single rbtree approach is
> the best.
> Let's take an example. Consider a case where you have 4 distinct keys
> and 4 threads. If each key is only used by 1 thread then the
> worst-case lookup time for either approach is about lg(4) or 2
> branches traversed. Now suppose that 1 of the keys is used by all 4
> threads, 1 key is used by 2 threads, and the other 2 are used by 1
> thread each. Then the worst-case lookup time for the hierarchical
> approach is approx lg(4)+lg(4) = 4 for the key shared by all threads,
> and for the single rbtree it is lg(8) = 3. The expected cost for
> accessing an unshared key is about lg(4) =2 for hierarchical and
> lg(8)=3 for the single rbtree, so as I said sometimes the hierarchical
> can do better, but it does so by sacrificing the worst-case
> performance.
Very helpful, Thanks!
> Also, you should consider how the implementation can be done in the
> supercore layer and shared between Posix Keys and Classic Task vars.
> Examples of sharing implementations between Posix and Classic APIs are
> plentiful. See for example the corebarrier in score and corresponding
> barrier interfaces in posix/classic.
> OK, I think I'm not familiar with Task variable enough, I'll also read the
cpukit/rtems/src/taskvariable*.c carefully.
>It occurred to me that you might also be able to put the
>_RBTree_Control in the thread control block (tcb) of each thread. then
>you can store the keys per thread and lookup time will be log in the
>number of keys a particular thread uses.
Will it be added to the tcb's API_Extensions member or others? I'll take a
look at some examples about tcb to get familiar with it.
-zw_yao
-Gedare
> > -zw_yao
> >> >> Then you would implement an rbtree_compare function that will combine
> >> >> the POSIX_Keys_control.Object.id with POSIX_Keys_control.thread_id
> as
> >> >> a "key" for the rbtree to use for storing each POSIX_Keys_Control.
> >> > I see, I can compare POSIX_Keys_control.Object.id first and if they
> are
> >> > equal, then compare the POSIX_Keys_control.thread_id.
> >> >> all key related operations are described as follow:
> >> >> - key create:
> >> >> create POSIX_Keys_Control instance and intialize an empty rbtree, in
> >> >> which rtems_rbtree_control instance will be created and an rbtree
> >> >> node's key compare function is also needed. Thread_id is compared in
> >> >> the compare function. So this approach doesdn't consider allocate
> same
> >> >> data for the same thread in the same key, because only different
> >> >> Thread_id are comparable. But I find something about duplicate node
> in
> >> >> the Gedare's rbtree patch, maybe the duplicate feature also can be
> >> >> added into POSIX key.
> >> >> You still want unique rbtree comparisons so that a thread can
> >> >> distinguish its own keys, unless it is valid for a thread to allocate
> >> >> multiple values with the same key?
> >> >> Key create should not create the red-black tree; the rbtree should be
> >> >> created during initialization of the POSIX_Keys manager---which by
> the
> >> >> way is improperly named right now as POSIX_Key_Manager_initialization
> >> >> and should be renamed POSIX_Keys_Manager_initialization with an s on
> >> >> Keys (or just POSIX_Keys_Initialization).
> >> > I didn't notice the POSIX_Key_Manager_initialization before, thanks.
> >> > BTW
> >> > I've a question about the _Objects_Initialize_information(), which
> >> > _POSIX_Key_Manager_initialization calls. I read the code of
> >> > _Objects_Initialize_information(), but still don't know what the
> maximum
> >> > parameter is used for? I think it's not for determining the memory
> size
> >> > of
> >> > all objects in one manager and then allocating such size of memory, is
> >> > it?
> >> maximum determines the total number of that kind of object. it is
> >> controlled by some CONFIGURE_MAXIMUM_XXX, e.g.
> >> CONIFIGURE_MAXIMUM_POSIX_KEYS.
> >> -Gedare
> >> >> > - key delete
> >> >> > delete all the nodes in rbtree by rtems_rbtree_get_min() or
> >> >> > rtems_rbtree_get_max(), and delete the RBTree_Control,
> >> >> > POSIX_Keys_Control instance. The key data's deallocation is done by
> >> >> > user.
> >> >> > - key get specific
> >> >> > we can use _RBTree_Find() to do the actually work behind
> >> >> > get_specific(), the runtime is O(log(n))
> >> >> > - key set specific
> >> >> > after a proper key_node is create, we can use _RBTree_Insert() to
> do
> >> >> > the set specific. the runtime is rbtree insert runtime, which is
> >> >> > O(log(n)).
> >> >> > I'm not sure whether this design is appropriate and this design is
> >> >> > very simple, need many more work to do. Hope further discussion to
> >> >> > make it more clear!
> >> >> Simple is good. I think you're on the right track other than my few
> >> >> comments about organizing the structures. You have the right ideas
> for
> >> >> how to implement the Keys functions I believe.
> >> >> -Gedare
> >> > Yeah, it remind me the K.I.S.S. principle!
> >> > -best regards!
> >> > -zw_yao
> >> >> > --best regards!
> >> >> > --zw_yao
> >> >> > _______________________________________________
> >> >> > rtems-devel mailing list
> >> >> > rtems-devel at rtems.org
> >> >> > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120509/5d6f86f3/attachment-0001.html>
