RFC: ARM GCC changes
Fri May 4 08:28:03 UTC 2012
Hi,
I propose a change of the RTEMS configuration for ARM GCC:
	o the target arm-rtemseabi4.11 should be renamed to arm-rtems4.11
	  providing the up to date ARM EABI version 5 tool chain,
	o the target arm-rtemself4.11 provides the obsolete GNU EABI (also
	  known as ARM ELF) variant.
The patches are attached.
GCC test suite results for arm-rtems4.11:
http://gcc.gnu.org/ml/gcc-testresults/2012-05/msg00322.html
http://gcc.gnu.org/ml/gcc-testresults/2012-05/msg00323.html
http://gcc.gnu.org/ml/gcc-testresults/2012-05/msg00324.html
RTEMS test suite results for arm-rtems4.11 follow.
GCC 4.6.4 20120420 (edb7312):
WARNING - log/fsnofs01 did not appear to complete execution
WARNING - log/imfs_fsrdwr did not appear to complete execution
WARNING - log/mdosfs_fsrdwr did not appear to complete execution
WARNING - log/mdosfs_fstime did not appear to complete execution
WARNING - log/mimfs_fsrdwr did not appear to complete execution
WARNING - log/mrfs_fsrdwr did not appear to complete execution
WARNING - log/mrfs_fstime did not appear to complete execution
WARNING - log/sp2038 did not appear to complete execution
WARNING - log/spfatal13 did not appear to complete execution
WARNING - log/spintrcritical09 did not appear to complete execution
WARNING - log/spprintk did not appear to complete execution
GCC 4.6.4 20120420 (lm3s6965):
WARNING - log/sp37 did not appear to complete execution
WARNING - log/spintrcritical08 did not appear to complete execution
WARNING - log/spintrcritical17 did not appear to complete execution
GCC 4.7.1 20120428 difference to GCC 4.6.4 20120420 (edb7312):
+WARNING - log/psxpipe01 did not appear to complete execution
+WARNING - log/termios01 did not appear to complete execution
GCC 4.7.1 20120428 difference to GCC 4.6.4 20120420 (lm3s6965):
+WARNING - log/devfs03 did not appear to complete execution
-WARNING - log/spintrcritical08 did not appear to complete execution
GCC 4.8.0 20120429 difference to GCC 4.6.4 20120420 (edb7312):
GCC 4.8.0 20120429 difference to GCC 4.6.4 20120420 (lm3s6965):
The changes in the RTEMS test suite need further examination.
This is the proposed ARM GCC tool chain for RTEMS 4.11.  The arm-rtemself
should be removed as soon as possible.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120504/53c0de2f/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120504/53c0de2f/attachment-0001.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120504/53c0de2f/attachment-0002.bin>
