RFC: ARM GCC changes
Fri May 11 15:00:49 UTC 2012
Thanks for testing my patches Sebastian.
The RTEMS results look pretty normal unfortunately. Some
of those tests fail normally and others run too long on some
simulators. The toolset change didn't impact that.
I have filed the patches as
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=53325
and have filed an RTEMS PR to track that.
https://www.rtems.org/bugzilla/show_bug.cgi?id=2064
On 05/04/2012 03:28 AM, Sebastian Huber wrote:
> 	o the target arm-rtemseabi4.11 should be renamed to arm-rtems4.11
> 	  providing the up to date ARM EABI version 5 tool chain,
> 	o the target arm-rtemself4.11 provides the obsolete GNU EABI (also
> 	  known as ARM ELF) variant.
> The patches are attached.
> GCC test suite results for arm-rtems4.11:
> http://gcc.gnu.org/ml/gcc-testresults/2012-05/msg00322.html
> http://gcc.gnu.org/ml/gcc-testresults/2012-05/msg00323.html
> http://gcc.gnu.org/ml/gcc-testresults/2012-05/msg00324.html
Joel Sherrill, Ph.D.             Director of Research&   Development
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120511/265ef992/attachment-0001.html>
