ANN: Upgrade rtems-4.11-autoconf to autoconf-2.69
Ralf Corsepius ralf.corsepius at rtems.org
Wed May 23 16:11:06 UTC 2012
On 05/23/2012 05:59 PM, Gedare Bloom wrote:
> how come when i do bootstrap -c I do not have a "clean" checkout?
> ./bootstrap -c
> removing automake generated Makefile.in files
> removing configure files
> removing aclocal.m4 files
> git status
> # On branch master
> # Changed but not updated:
> #   (use "git add/rm<file>..." to update what will be committed)
> #   (use "git checkout --<file>..." to discard changes in working directory)
> #	deleted:    config.guess
> #	deleted:    config.sub
> #	deleted:    install-sh
> #	deleted:    missing
There are two perspectives on this:
1. We always want them to be sync'ed with the versions in automake.
=> ./bootstrap (actually automake) needs to update them.
Afterwards, they must match with the versions in git.
This is what is currently implemented.
2. We want to maintain them manually.
=>  bootstrap -c must not remove them and ./bootstrap must not re-add or
update them.
Ralf
