ANN: Upgrade rtems-4.11-autoconf to autoconf-2.69
Gedare Bloom
gedare at rtems.org
Wed May 23 15:59:44 UTC 2012
how come when i do bootstrap -c I do not have a "clean" checkout?
./bootstrap -c
removing automake generated Makefile.in files
removing configure files
removing aclocal.m4 files
git status
# On branch master
# Changed but not updated:
# (use "git add/rm <file>..." to update what will be committed)
# (use "git checkout -- <file>..." to discard changes in working directory)
# deleted: config.guess
# deleted: config.sub
# deleted: install-sh
# deleted: missing
-Gedare
On Wed, May 23, 2012 at 11:21 AM, Ralf Corsepius
<ralf.corsepius at rtems.org> wrote:
> Hi,
> I am going to upgrade the rtems-4.11-autoconf rpms to autoconf-2.69.
> The corresponding rpms are supposed to land in the rtems-4.11 repos within
> the next couple of hours.
> Note:
> This upgrade requires everybody who is using a checked and autoconf-2.68
> bootstrap'ed rtems-4.11 source tree to once manually run
> ./bootstrap -c
> ./bootstrap
> from the toplevel directory of the source tree.
> Ralf
> rtems-devel mailing list
> rtems-devel at rtems.org
