[rtems commit] libblock: Block device transfer request API change
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Nov 5 14:58:52 UTC 2012
Hi
Jennifer has a compile error now in rtems-bsd-cam.c. I suspect
this is related to this patch or one of the set. How does that
code need to change?
--joel
On 11/02/2012 03:38 AM, Sebastian Huber wrote:
> Module: rtems
> Branch: master
> Commit: 9f0a68ce5afca9d21d34bab83d42fbe4bb0cf8ef
> Changeset: http://git.rtems.org/rtems/commit/?id=9f0a68ce5afca9d21d34bab83d42fbe4bb0cf8ef
> Author: Sebastian Huber<sebastian.huber at embedded-brains.de>
> Date: Wed Oct 31 11:54:39 2012 +0100
> Add and use rtems_blkdev_request_done(). Block device transfer requests
> must signal the completion status now with rtems_blkdev_request_done().
> The return value of the block device IO control will be ignored for
> transfer requests.
> The first parameter of rtems_blkdev_request_cb is now the transfer
> request structure.
> Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to
> break third party drivers at compile time, otherwise this API change
> would result in runtime errors.
> c/src/lib/libbsp/arm/gp32/smc/smc.c | 4 +-
> .../libbsp/lm32/shared/milkymist_memcard/memcard.c | 6 +-
> c/src/libchip/i2c/spi-sd-card.c | 12 ++--
> c/src/libchip/ide/ata.c | 3 +-
> c/src/libchip/ide/ata_internal.h | 4 +-
> cpukit/libblock/include/rtems/blkdev.h | 66 ++++++++++++-----
> cpukit/libblock/src/bdbuf.c | 25 ++----
> cpukit/libblock/src/flashdisk.c | 6 +-
> cpukit/libblock/src/nvdisk.c | 8 +-
> cpukit/libblock/src/ramdisk-driver.c | 6 +-
> testsuites/libtests/block05/init.c | 2 +-
> testsuites/libtests/block06/init.c | 9 +-
> testsuites/libtests/block08/test_disk.c | 27 ++++---
> testsuites/libtests/block09/init.c | 79 ++++++++++----------
> testsuites/libtests/block10/init.c | 2 +-
> testsuites/libtests/block12/init.c | 2 +-
> testsuites/libtests/block13/init.c | 2 +-
> testsuites/libtests/block14/init.c | 2 +-
> testsuites/libtests/block15/init.c | 2 +-
> 19 files changed, 146 insertions(+), 121 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/gp32/smc/smc.c b/c/src/lib/libbsp/arm/gp32/smc/smc.c
> index b9419de..9cf460b 100644
> --- a/c/src/lib/libbsp/arm/gp32/smc/smc.c
> +++ b/c/src/lib/libbsp/arm/gp32/smc/smc.c
> @@ -544,7 +544,7 @@ int sm_ECCEncode(const uint8_t * p_buf, uint8_t * p_ecc)
> static int smc_write(rtems_blkdev_request *req)
> - req->req_done(req->done_arg, RTEMS_SUCCESSFUL);
> + rtems_blkdev_request_done(req, RTEMS_SUCCESSFUL);
> return 0;
> @@ -573,7 +573,7 @@ smc_read(rtems_blkdev_request *req)
> smc_read_page(sg->block,sg->buffer);
> remains -= count;
> return 0;
> diff --git a/c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c b/c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c
> index 747903d..93c7a1d 100644
> --- a/c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c
> +++ b/c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c
> @@ -197,14 +197,16 @@ static int memcard_disk_block_read(rtems_blkdev_request *r)
> return -RTEMS_IO_ERROR;
> - r->req_done(r->done_arg, RTEMS_SUCCESSFUL);
> + rtems_blkdev_request_done(r, RTEMS_SUCCESSFUL);
> return 0;
> static int memcard_disk_block_write(rtems_blkdev_request *r)
> - return -RTEMS_IO_ERROR;
> + rtems_blkdev_request_done(r, RTEMS_IO_ERROR);
> + return 0;
> static rtems_status_code memcard_init(void)
> diff --git a/c/src/libchip/i2c/spi-sd-card.c b/c/src/libchip/i2c/spi-sd-card.c
> index bdd6fe0..d85c177 100644
> --- a/c/src/libchip/i2c/spi-sd-card.c
> +++ b/c/src/libchip/i2c/spi-sd-card.c
> @@ -1117,7 +1117,7 @@ static int sd_card_disk_block_read( sd_card_driver_entry *e, rtems_blkdev_reques
> RTEMS_CHECK_SC_RV( sc, "Stop");
> /* Done */
> - r->req_done( r->done_arg, RTEMS_SUCCESSFUL);
> + rtems_blkdev_request_done( r, RTEMS_SUCCESSFUL);
> return 0;
> @@ -1132,9 +1132,9 @@ sd_card_disk_block_read_cleanup:
> sd_card_stop( e);
> /* Done */
> - r->req_done( r->done_arg, RTEMS_IO_ERROR);
> + rtems_blkdev_request_done( r, RTEMS_IO_ERROR);
> - return rv;
> + return 0;
> static int sd_card_disk_block_write( sd_card_driver_entry *e, rtems_blkdev_request *r)
> @@ -1206,7 +1206,7 @@ static int sd_card_disk_block_write( sd_card_driver_entry *e, rtems_blkdev_reque
> /* Done */
> return 0;
> @@ -1225,9 +1225,9 @@ sd_card_disk_block_write_cleanup:
> sd_card_stop( e);
> /* Done */
> - return rv;
> + return 0;
> static int sd_card_disk_ioctl( rtems_disk_device *dd, uint32_t req, void *arg)
> diff --git a/c/src/libchip/ide/ata.c b/c/src/libchip/ide/ata.c
> index 18d8d14..1e25003 100644
> --- a/c/src/libchip/ide/ata.c
> +++ b/c/src/libchip/ide/ata.c
> @@ -185,7 +185,8 @@ ata_io_data_request(dev_t device, rtems_blkdev_request *req)
> areq = malloc(sizeof(ata_req_t));
> if (areq == NULL)
> - return RTEMS_NO_MEMORY;
> + rtems_blkdev_request_done(req, RTEMS_NO_MEMORY);
> + return RTEMS_SUCCESSFUL;
> areq->breq = req;
> diff --git a/c/src/libchip/ide/ata_internal.h b/c/src/libchip/ide/ata_internal.h
> index 3eea2d1..32c9422 100644
> --- a/c/src/libchip/ide/ata_internal.h
> +++ b/c/src/libchip/ide/ata_internal.h
> @@ -218,8 +218,8 @@ typedef struct ata_req_s {
> /* call callback provided by block device request if it is defined */
> #define ATA_EXEC_CALLBACK(areq, status) \
> do {\
> - if (((areq)->breq != NULL)&& ((areq)->breq->req_done != NULL)) \
> - (areq)->breq->req_done((areq)->breq->done_arg, status); \
> + if ((areq)->breq != NULL) \
> + rtems_blkdev_request_done((areq)->breq, status); \
> } while (0)
> /* ATA RTEMS driver events types */
> diff --git a/cpukit/libblock/include/rtems/blkdev.h b/cpukit/libblock/include/rtems/blkdev.h
> index ccc8981..7f83a26 100644
> --- a/cpukit/libblock/include/rtems/blkdev.h
> +++ b/cpukit/libblock/include/rtems/blkdev.h
> @@ -53,18 +53,15 @@ typedef enum rtems_blkdev_request_op {
> RTEMS_BLKDEV_REQ_SYNC /**< Sync any data with the media. */
> } rtems_blkdev_request_op;
> +struct rtems_blkdev_request;
> * @brief Block device request done callback function type.
> - * The first parameter @a arg must be the argument provided by the block device
> - * request structure @ref rtems_blkdev_request.
> - * The second parameter @a status should contain the status of the operation:
> - * - @c RTEMS_SUCCESSFUL Operation was successful.
> - * - @c RTEMS_IO_ERROR Some sort of input or output error.
> - * - @c RTEMS_UNSATISFIED Media no more present.
> -typedef void (*rtems_blkdev_request_cb)(void *arg, rtems_status_code status);
> +typedef void (*rtems_blkdev_request_cb)(
> + struct rtems_blkdev_request *req,
> + rtems_status_code status
> * Block device scatter or gather buffer structure.
> @@ -92,15 +89,16 @@ typedef struct rtems_blkdev_sg_buffer {
> } rtems_blkdev_sg_buffer;
> - * The block device request structure is used to read or write a number of
> - * blocks from or to the device.
> + * @brief The block device transfer request is used to read or write a number
> + * of blocks from or to the device.
> + * Transfer requests are issued to the disk device driver with the
> + * @ref RTEMS_BLKIO_REQUEST IO control. The transfer request completion status
> + * must be signalled with rtems_blkdev_request_done(). This function must be
> + * called exactly once per request. The return value of the IO control will be
> + * ignored for transfer requests.
> - * TODO: The use of these req blocks is not a great design. The req is a
> - * struct with a single 'bufs' declared in the req struct and the
> - * others are added in the outer level struct. This relies on the
> - * structs joining as a single array and that assumes the compiler
> - * packs the structs. Why not just place on a list ? The BD has a
> - * node that can be used.
> + * @see rtems_blkdev_create().
> typedef struct rtems_blkdev_request {
> @@ -111,7 +109,7 @@ typedef struct rtems_blkdev_request {
> * Request done callback function.
> - rtems_blkdev_request_cb req_done;
> + rtems_blkdev_request_cb done;
> * Argument to be passed to callback function.
> @@ -133,6 +131,15 @@ typedef struct rtems_blkdev_request {
> rtems_id io_task;
> + * TODO: The use of these req blocks is not a great design. The req is a
> + * struct with a single 'bufs' declared in the req struct and the
> + * others are added in the outer level struct. This relies on the
> + * structs joining as a single array and that assumes the compiler
> + * packs the structs. Why not just place on a list ? The BD has a
> + * node that can be used.
> * List of scatter or gather buffers.
> @@ -140,6 +147,25 @@ typedef struct rtems_blkdev_request {
> } rtems_blkdev_request;
> + * @brief Signals transfer request completion status.
> + * This function must be called exactly once per request.
> + * @param[in,out] req The transfer request.
> + * @param[in] status The status of the operation should be
> + * - @c RTEMS_SUCCESSFUL, if the operation was successful,
> + * - @c RTEMS_IO_ERROR, if some sort of input or output error occured, or
> + * - @c RTEMS_UNSATISFIED, if media is no more present.
> +static inline void rtems_blkdev_request_done(
> + rtems_blkdev_request *req,
> + (*req->done)(req, status);
> * The start block in a request.
> * Only valid if the driver has returned the @ref RTEMS_BLKIO_CAPABILITIES of
> @@ -341,6 +367,8 @@ extern const rtems_driver_address_table rtems_blkdev_generic_ops;
> * @retval RTEMS_INVALID_NUMBER Block size or block count is not positive.
> * @retval RTEMS_NO_MEMORY Not enough memory.
> * @retval RTEMS_UNSATISFIED Cannot create generic device node.
> + * @see rtems_blkdev_create_partition() and rtems_blkdev_request.
> rtems_status_code rtems_blkdev_create(
> const char *device,
> @@ -370,6 +398,8 @@ rtems_status_code rtems_blkdev_create(
> * @retval RTEMS_INVALID_NUMBER Block begin or block count is invalid.
> rtems_status_code rtems_blkdev_create_partition(
> const char *partition,
> diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
> index 81f641e..8fb3848 100644
> --- a/cpukit/libblock/src/bdbuf.c
> +++ b/cpukit/libblock/src/bdbuf.c
> @@ -1871,10 +1871,8 @@ rtems_bdbuf_get (rtems_disk_device *dd,
> * @param status I/O completion status
> static void
> -rtems_bdbuf_transfer_done (void* arg, rtems_status_code status)
> +rtems_bdbuf_transfer_done (rtems_blkdev_request* req, rtems_status_code status)
> - rtems_blkdev_request* req = (rtems_blkdev_request*) arg;
> req->status = status;
> rtems_event_transient_send (req->io_task);
> @@ -1886,7 +1884,6 @@ rtems_bdbuf_execute_transfer_request (rtems_disk_device *dd,
> bool cache_locked)
> rtems_status_code sc = RTEMS_SUCCESSFUL;
> - int result = 0;
> uint32_t transfer_index = 0;
> bool wake_transfer_waiters = false;
> bool wake_buffer_waiters = false;
> @@ -1894,15 +1891,12 @@ rtems_bdbuf_execute_transfer_request (rtems_disk_device *dd,
> if (cache_locked)
> rtems_bdbuf_unlock_cache ();
> - result = dd->ioctl (dd->phys_dev, RTEMS_BLKIO_REQUEST, req);
> + /* The return value will be ignored for transfer requests */
> + dd->ioctl (dd->phys_dev, RTEMS_BLKIO_REQUEST, req);
> - if (result == 0)
> - rtems_bdbuf_wait_for_transient_event ();
> - sc = req->status;
> - else
> - sc = RTEMS_IO_ERROR;
> + /* Wait for transfer request completion */
> + rtems_bdbuf_wait_for_transient_event ();
> + sc = req->status;
> rtems_bdbuf_lock_cache ();
> @@ -1977,10 +1971,8 @@ rtems_bdbuf_execute_read_request (rtems_disk_device *dd,
> sizeof (rtems_blkdev_sg_buffer) * transfer_count);
> req->req = RTEMS_BLKDEV_REQ_READ;
> - req->req_done = rtems_bdbuf_transfer_done;
> - req->done_arg = req;
> + req->done = rtems_bdbuf_transfer_done;
> req->io_task = rtems_task_self ();
> - req->status = RTEMS_RESOURCE_IN_USE;
> req->bufnum = 0;
> rtems_bdbuf_set_state (bd, RTEMS_BDBUF_STATE_TRANSFER);
> @@ -2655,8 +2647,7 @@ rtems_bdbuf_swapout_writereq_alloc (void)
> rtems_fatal_error_occurred (RTEMS_BLKDEV_FATAL_BDBUF_SO_NOMEM);
> write_req->req = RTEMS_BLKDEV_REQ_WRITE;
> - write_req->req_done = rtems_bdbuf_transfer_done;
> - write_req->done_arg = write_req;
> + write_req->done = rtems_bdbuf_transfer_done;
> write_req->io_task = rtems_task_self ();
> return write_req;
> diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
> index ec1ace2..a9e56c9 100644
> --- a/cpukit/libblock/src/flashdisk.c
> +++ b/cpukit/libblock/src/flashdisk.c
> @@ -2086,8 +2086,7 @@ rtems_fdisk_read (rtems_flashdisk* fd, rtems_blkdev_request* req)
> - req->status = ret ? RTEMS_IO_ERROR : RTEMS_SUCCESSFUL;
> - req->req_done (req->done_arg, req->status);
> + rtems_blkdev_request_done (req, ret ? RTEMS_IO_ERROR : RTEMS_SUCCESSFUL);
> return 0;
> @@ -2122,8 +2121,7 @@ rtems_fdisk_write (rtems_flashdisk* fd, rtems_blkdev_request* req)
> return 0;
> diff --git a/cpukit/libblock/src/nvdisk.c b/cpukit/libblock/src/nvdisk.c
> index c90f319..127291d 100644
> --- a/cpukit/libblock/src/nvdisk.c
> +++ b/cpukit/libblock/src/nvdisk.c
> @@ -597,10 +597,9 @@ rtems_nvdisk_read (rtems_nvdisk* nvd, rtems_blkdev_request* req)
> - return ret;
> + return 0;
> @@ -637,8 +636,7 @@ rtems_nvdisk_write (rtems_nvdisk* nvd, rtems_blkdev_request* req)
> return 0;
> diff --git a/cpukit/libblock/src/ramdisk-driver.c b/cpukit/libblock/src/ramdisk-driver.c
> index fb4a80f..881b7df 100644
> --- a/cpukit/libblock/src/ramdisk-driver.c
> +++ b/cpukit/libblock/src/ramdisk-driver.c
> @@ -67,8 +67,7 @@ ramdisk_read(struct ramdisk *rd, rtems_blkdev_request *req)
> #endif
> memcpy(sg->buffer, from + (sg->block * rd->block_size), sg->length);
> - req->status = RTEMS_SUCCESSFUL;
> + rtems_blkdev_request_done (req, RTEMS_SUCCESSFUL);
> return 0;
> @@ -92,8 +91,7 @@ ramdisk_write(struct ramdisk *rd, rtems_blkdev_request *req)
> #endif
> memcpy(to + (sg->block * rd->block_size), sg->buffer, sg->length);
> return 0;
> diff --git a/testsuites/libtests/block05/init.c b/testsuites/libtests/block05/init.c
> index dd5d646..0a56ec6 100644
> --- a/testsuites/libtests/block05/init.c
> +++ b/testsuites/libtests/block05/init.c
> @@ -379,7 +379,7 @@ static int disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
> switch (r->req) {
> case RTEMS_BLKDEV_REQ_READ:
> case RTEMS_BLKDEV_REQ_WRITE:
> return 0;
> default:
> errno = EINVAL;
> diff --git a/testsuites/libtests/block06/init.c b/testsuites/libtests/block06/init.c
> index e007a5e..ff309b1 100644
> --- a/testsuites/libtests/block06/init.c
> +++ b/testsuites/libtests/block06/init.c
> @@ -488,7 +488,7 @@ bdbuf_disk_ioctl (rtems_disk_device *dd, uint32_t req, void* argp)
> if (!bdbuf_disk_ioctl_process (bdd, r))
> - errno = EIO;
> else
> rtems_blkdev_sg_buffer* sg = r->bufs;
> @@ -511,15 +511,16 @@ bdbuf_disk_ioctl (rtems_disk_device *dd, uint32_t req, void* argp)
> remains -= length;
> - r->req_done (r->done_arg, RTEMS_SUCCESSFUL);
> + rtems_blkdev_request_done (r, RTEMS_SUCCESSFUL);
> bdbuf_disk_ioctl_leave (bdd, r->bufnum);
> break;
> - errno = EIO;
> + else
> break;
> diff --git a/testsuites/libtests/block08/test_disk.c b/testsuites/libtests/block08/test_disk.c
> index 3040ab3..f743c00 100644
> --- a/testsuites/libtests/block08/test_disk.c
> +++ b/testsuites/libtests/block08/test_disk.c
> @@ -32,18 +32,20 @@ static Objects_Id testq_id = OBJECTS_ID_NONE;
> static int
> test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
> - rtems_status_code rc;
> - bdbuf_test_msg msg;
> - size_t msg_size;
> + rtems_status_code rc;
> + bdbuf_test_msg msg;
> + size_t msg_size;
> + rtems_blkdev_request *r;
> switch (req)
> case RTEMS_BLKIO_REQUEST:
> - rtems_blkdev_request *r = argp;
> rtems_blkdev_sg_buffer *sg;
> unsigned int i;
> + r = argp;
> printk("DISK_DRV: %s ",
> r->req == RTEMS_BLKDEV_REQ_READ ? "R" :
> r->req == RTEMS_BLKDEV_REQ_WRITE ? "W" : "?");
> @@ -71,7 +73,8 @@ test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
> if (rc != RTEMS_SUCCESSFUL)
> printf("Error while sending a message to Test task: %u\n", rc);
> - return -1;
> + return 0;
> /* Wait for a reply from the test task */
> @@ -81,27 +84,27 @@ test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
> printf("Error while reading a message from Test task: %u\n", rc);
> - return rc;
> + return 0;
> if (msg.type != BDBUF_TEST_MSG_TYPE_DRIVER_REPLY)
> printf("Unexpected message comes to test disk driver: %d\n",
> msg.type);
> - return -1;
> + return 0;
> if (msg.val.driver_reply.ret_val != 0)
> - errno = msg.val.driver_reply.ret_errno;
> else
> - rtems_blkdev_request *r = (rtems_blkdev_request *)argp;
> - r->req_done(r->done_arg, msg.val.driver_reply.res_status);
> + rtems_blkdev_request_done(r, msg.val.driver_reply.res_status);
> - return msg.val.driver_reply.ret_val;
> + return 0;
> rtems_device_driver
> diff --git a/testsuites/libtests/block09/init.c b/testsuites/libtests/block09/init.c
> index d29d6ac..e17819f 100644
> --- a/testsuites/libtests/block09/init.c
> +++ b/testsuites/libtests/block09/init.c
> @@ -64,47 +64,50 @@ static int disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
> rtems_blkdev_sg_buffer *sg =&r->bufs [i];
> char *buf = sg->buffer;
> - if (sg->length != 1) {
> - return -1;
> - switch (r->req) {
> - case RTEMS_BLKDEV_REQ_READ:
> - switch (sg->block) {
> - case BLOCK_READ_IO_ERROR:
> - break;
> - case BLOCK_READ_UNSATISFIED:
> - sc = RTEMS_UNSATISFIED;
> - break;
> - case BLOCK_READ_SUCCESSFUL:
> - case BLOCK_WRITE_IO_ERROR:
> - *buf = disk_data [sg->block];
> - break;
> - default:
> - return -1;
> - break;
> - case RTEMS_BLKDEV_REQ_WRITE:
> - disk_data [sg->block] = *buf;
> - break;
> - break;
> - default:
> - return -1;
> - break;
> - default:
> - return -1;
> + if (sg->length == 1) {
> + switch (r->req) {
> + case RTEMS_BLKDEV_REQ_READ:
> + switch (sg->block) {
> + case BLOCK_READ_IO_ERROR:
> + sc = RTEMS_IO_ERROR;
> + break;
> + case BLOCK_READ_UNSATISFIED:
> + sc = RTEMS_UNSATISFIED;
> + break;
> + case BLOCK_READ_SUCCESSFUL:
> + case BLOCK_WRITE_IO_ERROR:
> + *buf = disk_data [sg->block];
> + break;
> + default:
> + break;
> + break;
> + case RTEMS_BLKDEV_REQ_WRITE:
> + disk_data [sg->block] = *buf;
> + break;
> + break;
> + default:
> + break;
> + break;
> + default:
> + break;
> + } else {
> - r->req_done(r->done_arg, sc);
> + rtems_blkdev_request_done(r, sc);
> return 0;
> } else {
> diff --git a/testsuites/libtests/block10/init.c b/testsuites/libtests/block10/init.c
> index 37b757a..fe8c21b 100644
> --- a/testsuites/libtests/block10/init.c
> +++ b/testsuites/libtests/block10/init.c
> @@ -105,7 +105,7 @@ static int disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
> set_task_prio(RTEMS_SELF, PRIORITY_SWAPOUT);
> return 0;
> } else {
> diff --git a/testsuites/libtests/block12/init.c b/testsuites/libtests/block12/init.c
> index 8182cd6..9931c0b 100644
> --- a/testsuites/libtests/block12/init.c
> +++ b/testsuites/libtests/block12/init.c
> @@ -55,7 +55,7 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
> ++block_access_counts [block];
> - breq->req_done(breq->done_arg, RTEMS_SUCCESSFUL);
> + rtems_blkdev_request_done(breq, RTEMS_SUCCESSFUL);
> } else {
> errno = EINVAL;
> rv = -1;
> diff --git a/testsuites/libtests/block13/init.c b/testsuites/libtests/block13/init.c
> index 267e4ec..d5d2593 100644
> --- a/testsuites/libtests/block13/init.c
> +++ b/testsuites/libtests/block13/init.c
> @@ -126,7 +126,7 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
> - (*breq->req_done)(breq->done_arg, RTEMS_SUCCESSFUL);
> } else {
> errno = EINVAL;
> rv = -1;
> diff --git a/testsuites/libtests/block14/init.c b/testsuites/libtests/block14/init.c
> index b95b86d..1c4f1c7 100644
> --- a/testsuites/libtests/block14/init.c
> +++ b/testsuites/libtests/block14/init.c
> @@ -105,7 +105,7 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
> - (*breq->req_done)(breq->done_arg, sc);
> + rtems_blkdev_request_done(breq, sc);
> } else {
> errno = EINVAL;
> rv = -1;
> diff --git a/testsuites/libtests/block15/init.c b/testsuites/libtests/block15/init.c
> index e6de9c3..a6e4937 100644
> --- a/testsuites/libtests/block15/init.c
> +++ b/testsuites/libtests/block15/init.c
> @@ -84,7 +84,7 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
> } else if (req == RTEMS_BLKIO_CAPABILITIES) {
> *(uint32_t *) arg = RTEMS_BLKDEV_CAP_MULTISECTOR_CONT;
> } else {
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
Joel Sherrill, Ph.D. Director of Research& Development
Ask me about RTEMS: a free RTOS Huntsville AL 35806
